NVIDIA GK208 GPU显卡PCB文件 4层 挂GDDR5 142-12131-10
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBKT1BRACKET_LOW_1X_TOP-LP_DVI3185_B BRKT_LP_1TAB_1_DVI_DSUB_2_HDMI_DPCN1CON_PCI_EXPRESS_NONPHY-X16-124B CON_FINGER_PEX_124D1D_3PIN_AC_SOT23-BAV99,100V,N/AB SOT23D2D_3PIN_CC_SOT23-BAT54C,30V,600B SOT23D3D_3PIN_AC_SOT23-BAV99,100V,N/AB SOT23D4D_SOT23-1N4148,75V,600MA,1V@10B SOT23D5D_SOT23-1N4148,75V,600MA,1V@10B SOT23D6D_3PIN_AA_SOT23-BAT54A,30V,600B SOT23D7D_SOT23-1N4148,75V,600MA,1V@10B SOT23D8D_3PIN_AC_SOT23-BAV99,100V,N/AB SOT23D9D_3PIN_AC_SOT23-BAV99,100V,N/AB SOT23FR1R_1206_F-1.8,5%,1/4W,EC07,RDPA1.81206G1U_GPU_GB2_64_BGA595-GK208-400-B BGA_0595_P080_P084_P085_P090_P100_230X230J1CON_DSUB15HD_VGA_SLIM-CON_DSUBB CON_DSUB_015_TH_RA_F_HD_L068_BJ2CON_DISPLAYPORT_NORM-DISPLAYPOB CON_DP_020_SMT_RA_F_BJ3CON_HDMI_HDMI_A_SMD-HDMI_A_SPRB CON_HDMI_019_SMD_RA_FJ4CON_DVI_I_DVI_I_SHLD-DVI-I_BEIB CON_DVII_030_RA_F_SHDJ5HDR_2X6_NORM-HDR_2M6,MALE,2.54B CON_HDR_002X006_TH_ST_M_PI100J6HDR_1X4_NORM-HDR_1M4,MALE,2.0MB CON_WAFER232_004_TH_ST_P020J7HDR_1X2_NORM-HDR_1M2_FAN,MALE,B CON_HDR_001X002_TH_ST_M_P025_SHRL1L_SMD_4_5X4-100UH,FERRITE,10%,B100uHIND_NONRKO_SMD_045X040_BL2L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402L3L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402L4L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402L5L_TH-0.470UH,IRON,20%,38A,50A,B0.470uHIND_NONRKO_TH_117X117_BL6L_TH-1.8UH,IRONPOWDER,20%,12AB1.8uHIND_NONRKO_TH_150X080L7L_SMD_420X400-0.470UH,METALDUB0.470uHIND_NONRKO_SMD_I420X400L8L_SMD_078X072-1.0UH,FERRITE,30B1.0uHIND_NONRKO_SMD_078X072L9L_SMD_5X5-2.2UH,WIREWOUND,20%B2.2uHIND_NONRKO_SMD_058X052_CL501L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402L502L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402L503L_0402-0.068UH,MTLR,5%,N/A,0.1B0.068uHIND_SMD_0402LB501L_BEAD_0603-30R@100MHZ,FERRITEB30R@100MHzIND_SMD_0603LB502L_BEAD_0603-300R@100MHZ,FERRITB300R@100MHzIND_SMD_0603LB503L_BEAD_0603-180R@100MHZ,FERRITB180R@100MHzIND_SMD_0603LB504L_BEAD_0603-300R@100MHZ,FERRITB300R@100MHzIND_SMD_0603LB505L_BEAD_0603-30R@100MHZ,FERRITED30R@100MHzIND_SMD_0603LB506L_BEAD_0603-220R@100MHZ,FERRITB220R@100MHzIND_SMD_0603LB507L_BEAD_0603-300R@100MHZ,FERRITB300R@100MHzIND_SMD_0603LB508L_BEAD_0603-220R@100MHZ,FERRITB220R@100MHzIND_SMD_0603M1U_MEM_SD_DDR5_X32_BGA170-H5GQ2B BGA_0170_P080_140X120M2U_MEM_SD_DDR5_X32_BGA170_MIRR-B BGA_0170_P080_140X120M501U_MEM_SD_DDR5_X32_BGA170_MIRR-B BGA_0170_P080_140X120M502U_MEM_SD_DDR5_X32_BGA170-H5GQ2B BGA_0170_P080_140X120MEC1MECH_SPECIAL_NOPIN-VGA_HDR_CABB CON_HDR_002X006_TH_ST_M_PI100_CBLMEC2MEC_SPRNG_SMD-MEC_SPRING_P394,B EMIPAD_059X035MEC3HEATSINK_4PIN-LP40W,N/A-LP40W,A HSA_GPU_LP40W_T_AL_1MEC5MEC_SPRNG_SMD-MEC_SPRING_P394,B EMIPAD_059X035Q1Q_NPN_SOT23_1B1C1E-MMBT2222A,4B SOT23Q2Q_NPN_SOT23_1B1C1E-MMBT2222A,4B SOT23Q3Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q4Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q5Q_NPN_SOT363-MMBT3904D,60.0V,0B SC70_6Q6Q_FET_N_ENH_SO8_DUAL_1G2D1S-EMB SO08_I190X150Q7Q_FET_N_ENH_DFN3X3-EMB20N03V,3B MULTI_SMD_DFN08_SON08Q8Q_FET_N_ENH_DFN3X3-EMB12N03V,3B MULTI_SMD_DFN08_SON08Q9Q_FET_N_ENH_LFPAK-EMB06N03H,30B MULTI_SMD_SOT669_LFPAK_BQ10Q_FET_N_ENH_LFPAK-EMB12N03H,30B MULTI_SMD_SOT669_LFPAK_BQ11Q_FET_N_ENH_LFPAK-EMB06N03H,30B MULTI_SMD_SOT669_LFPAK_BQ12Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q13Q_FET_N_ENH_SOT363-2N7002DW,60B SC70_6Q14Q_NPN_SOT363-MMBT3904D,60.0V,0B SC70_6Q15Q_FET_N_ENH_SOT363-2N7002DW,60B SC70_6Q16Q_NPN_SOT23_1B1C1E-MMBT2222A,4B SOT23Q501Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q502Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q503Q_NPN_SOT363-MMBT3904D,60.0V,0B SC70_6Q504Q_FET_N_ENH_SOT363-2N7002DW,60B SC70_6Q505Q_FET_N_ENH_SOT363-2N7002DW,60B SC70_6Q506Q_NPN_SOT363-MMBT3904D,60.0V,0B SC70_6Q507Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23TP501LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP502LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP503LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP504LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP505LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP506LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP507LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PTP508LABTESTPOINT_PIN-LABTESTPOINT-A LTPT35C49PU1U_VREG_3PIN_TO92-APL78L05ECTRGBADJ_VR=N/ATO92_3_THU2U_VREG_3PIN_COMBINED_IGO-UA78MBVR=5VSOT223U3U_SWREG_UP6101_PSOP8-EM5303A,ABADJ_VR=0.6VSO08_I190X150_TI90X90U4U_OPENVREG_TYPE0_DFN10-UP1728PBVR_SW=0.6VDFN10_P050_030X030_TI106X070U5U_SWREG_UP6101_PSOP8-EM5303A,ABADJ_VR=0.6VSO08_I190X150_TI90X90U6U_AND_2IN_SC70-5-74AHCT1G08GW,B SC70_5U7U_AND_2IN_SC70-5-74AHCT1G08GW,B SC70_5U8U_VREG_APL5910_SOP8-GS7103NV,ABADJ_VR=0.8SO08_I190X150_TI118X102U501U_MEM_FL_SER_256KX8_SO8-GD25Q2B SO08_I190X150U502U_AND_2IN_SC70-5-M74VHC1GT08DFB SC70_5U503U_SW_PWR_TPS2031_SO8-APL3510AKB SO08_I190X150Y1XTAL_HC49SA-ESA27.0000F18M33FNB27MHZXTAL_TH_2_110X046 PCB文件。回复可见下载。
**** Hidden Message ***** 牛逼4层板!!!!!
