Tigerboard_AM335X_V1.1 8层核心板和底板PCB原理图整套资料
Tigerboard_AM335X_V1.1 8层核心板和底板PCB原理图整套资料(NC)R06031R1873004 MX3.0-4P1J11206L075THFUSE-12063FB1, FB2, FB312K(1%)R06031R94150KR06031R1715pF/50V/X7R/0603C06032C27, C281812L300/3AFUSE-18121F11K(V1.2)R06031R1141KR06033R12, R15, R881MR06031R981N4148DIS-12-082D5, D111uFC06033C43, C46, C56220uF/10V/Tanipc_7343_311C322R(V1.1)R06032R101, R10224LC32ASOT-231U824MHzAX80451Y325MHzAA50321Y227pFC06033C52, C53, C1192PIN/2.0MMCON2 _2.0MM1J232.768kHz/AH3215SM_XTAL_CM3151Y1330pFC06032C14, C9533K(1%)R06032R22, R12133R(NC)R06033R115, R116, R11733RR06032R193, R19636.5K(1%)R06031R93V 80mAh/MS621FBATT_MINI2BT1, BT24.7KR06033R13, R14, R634.7uF(NC)C06031C724.7uFC06034C41, C68, C70, C754.7uFC08051C764.7uHSM-7351-IND-06031L46.8uHLLS-28-202L1, L116pFC06032C63, C6474LCX74MTC/TSSOP14SOP127P620X265-14N1U491pFC06032C13, C87am335xam335x_B1AM1AR1021WIFI_SMT-M1U27AR8035(QFN40)AR8035_QFN-401U15BLM18KG221SN1D(NC)SM-7351-IND-06031L10BLM18KG221SN1D(V1.2)SM-7351-IND-06031L8BLM18KG221SN1DSM-7351-IND-060310L2, BS3-1000PSW-DIP-W1S1CAT6219-180TD-GT3SOT-235-041U33CAT6219-330TD-GT3SOT-235-045U5, U12, U17, U21, U30CON2 _2.0MMCON2 _2.0MM1J4CON20CONS20_1.271J15CON-3con3-2.541J3FDC6330LSM-SOT-6-p95-1p51U1FUSE_2A_1206(V1.2)FUSE-12062F3, F4FUSE_2A_1206FUSE-12065F2, F5, F6, F7, F8IRF9328SO-08-051U3KAN0631SW-DIP-W2S2, S3LED_GREEND12065D3, D4, D6, D7, D8LED_REDD12061D2MAX6816/SOT143SOT-1431U7MICRO_SD-cardTF-card1J5Micro_USBMICRO_USB1J8MINI_HDMIMINI_HDMI_SMT1J14MiniPCI-EMINI-PCI-E1J9NEO-6MNEO-6G1U29PCF8563T/SOP8SO-08-051U9PGB0010603MRF603-41X392D9, D10RB751V40SOD-3231D12RJ45-1000M(48F-01GY2DPL2NL)48F-01GY2DPL2NL1U16SIM_CARDmicro_SIM1J10SMBJ6CADV2-22-121D1SMF05CT1G/SC88SC-881U24SN74AUC1G74DCTDCT (R-PDSO-G8)1U32SN75C3232EDRso16-25x751U10SP706SEN-LSO-08-051U11SS9014(NPN)SM-SOT-231Q1TDA19988-HVQFN-64TDA19988_HVQFN-641U31TPD3E001DRYR(NC)U_6_DRY1U22TPD3E001DRYR(V1.2)U_6_DRY1U20TPD3E001DRYRU_6_DRY2U19, U25TPD6E001RSERsm-qfn-10-p5-rse2U13, U14TPS3803G15tbd1U6TPS54320RHLQFN142U2, U23TPS73733DCQ/SOT223SOT2231U26UMCC_VERTSMT_UMCCVERT-T1J13USB_2032USBA_X21J6USB2534(QFN36)USB2534_SQFN-361U18
CommentPatternQuantityComponents24MHC49US1Y132.768KHz MC-306SM_XTAL_CM3151Y2AM3359BZCZA100_15mmx15mmAM33XX_15X151U5am335xAM335X1AM3359BLM18KG221SN1DL06031FB9MT41J128M16JT-125BGA14X10-961U6REDD06031D2SDIN5D2-8G-LBGA169_EMMC_0.51U7SN74AUP2G08U_8_DCU1U4TPS65910A3U_48_RSL1U1TPS71718SMDSC70-51U2 资料一起打包。回复可见下载
**** Hidden Message ***** 很好的学习资料
