Lattice LFE5UM-85F-8BG381I +DP83867IRPAPT+FT4232HL 做的PCB和原理图共享
PCB 原理图一起打包。回复可见
**** Hidden Message *****
D1DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D2DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D3DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D4DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D5DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D6DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D7DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D8DIODE_SCHOTTKY_DIO_POWERDI-323_PD3S230HQ-7DIO_POWERDI-323_0-7
D9TPD2EUSB30D_SOT-3_SOT-3_TPD2EUSTPD2EUSB30DRTRSOT-3
D10DIODE_SOD323_DIO_SOD323_SD05C-0SD05C-01FTGDIO_SOD323
D11TPD2EUSB30D_SOT-3_SOT-3_TPD2EUSTPD2EUSB30DRTRSOT-3
D12DIODE_SOD323_DIO_SOD323_SD05C-0SD05C-01FTGDIO_SOD323
D13DIODE_SOD323_DIO_SOD323_SD05C-0SD05C-01FTGDIO_SOD323
D14DIODE_SOD323_DIO_SOD323_SD05C-0SD05C-01FTGDIO_SOD323
D15DIODE_PESD_DIO_DFN0402_TPD1E10BTPD1E10B06DPYDIO_DFN0402
D16DIODE_TVS_DUAL_DIO_SMC_SMCJ64CASMCJ64CADIO_SMC
F1FUSE_FUSE_1206_5A5AFUSE_1206
FB1INDUCTOR_FERRITE_IND0402_60E60EIND0402
FB2INDUCTOR_FERRITE_IND0402_60E60EIND0402
FB3INDUCTOR_FERRITE_IND0402_60E60EIND0402
FB4INDUCTOR_FERRITE_IND0402_60E60EIND0402
FL1EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL2EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL3EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL4EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL5EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL6EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL7EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL8EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL9EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
FL10EMIFILTER_IND_EMIFIL_BLM21P_08030EEMIFIL_BLM21P_0805_1-1
J1CON_USB-B_5_4SH_CON_USBB5_10501CON_USB-B_5_FCON_USBB5_105017-01_S_R_S_2-6
J2CON_PWRJACK3_RAPC722_CON_PWRJACRAPC722CON_PWRJACK3_RAPC722_P_R_T
J3CON_PMC_30X2_M_CON_PMC2X30_QTH-CON_PMC_2X30_MCON_PMC2X30_QTH-30_P_S_S_4-3
J4CON_USB-B_5_4SH_CON_USBB5_10501CON_USB-B_5_FCON_USBB5_105017-01_S_R_S_2-6
J5CON_SDCARD_8_DM3AT-SF-PEJM_CON_DM3AT-SF-PEJM5CON_SD8_DM3AT-SF_S_R_S_1-7
J6CON_RJ45-14_LPJG16414A4NL_CON_RCON_RJ45-14_LPJG16414A4NLCON_RJ45-14_LPJG16414A4NL_S_R_T_13-5
L1INDUCTOR_IND_NRS5020_200X200_SM4.7uHIND_NRS5020_200X200_SMD_3-1
L2INDUCTOR_IND_NRS5020_200X200_SM4.7uHIND_NRS5020_200X200_SMD_3-1
L3INDUCTOR_IND_IHLP2020CZ_230X21510uHIND_IHLP2020CZ_230X215_SMD
L4INDUCTOR_IND_IHLP2020CZ_230X21510uHIND_IHLP2020CZ_230X215_SMD
LD1DIODE_LED_LED_0603_0-8_LTST-C19LTST-C190KGKTLED_0603_0-8
LD2DIODE_LED_LED_0603_0-8_LTST-C19LTST-C190KGKTLED_0603_0-8
LD3DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD4DIODE_LED_LED_0603_0-8_LTST-C19LTST-C190KGKTLED_0603_0-8
LD5DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD6DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD7DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD8DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD9DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD10DIODE_LED_LED_0603_0-8_LTST-C19LTST-C190KGKTLED_0603_0-8
LD11DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD12DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD13DIODE_LED_LED_0603_LTST-C190KRKLTST-C190KRKTLED_0603
LD14DIODE_LED_LED_0603_0-8_LTST-C19LTST-C190KGKTLED_0603_0-8
LD15DIODE_LED_LED_0603_LTST-C191KGKLTST-C191KGKTLED_0603
Q1NPN_BEC_TO_SOT23-123_MMBT3904-7MMBT3904-7-FTO_SOT23-123
RA1RESARR_ISO4_RESA_EXB28V_0402-4_22ERESA_EXB28V_0402-4_0-5
RA2RESARR_ISO4_RESA_EXB28V_0402-4_22ERESA_EXB28V_0402-4_0-5
RA3RESARR_ISO4_RESA_EXB28V_0402-4_22ERESA_EXB28V_0402-4_0-5
RA4RESARR_ISO4_RESA_EXB28V_0402-4_22ERESA_EXB28V_0402-4_0-5
RA5RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
RA6RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
RA7RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
RA8RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
RA9RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
RA10RESARR_ISO4_RESA_741C_0402-4_0-51ERESA_741C_0402-4_0-5
S1SW8_TDA04H0SB1R_SW8_50X300_245XTDA04H0SB1RSW8_50X300_245X245_SMD
SW1SW6_219-3MST_SW6_4161311608_2104.16131E+11SW6_4161311608_210X230_SMD_2-7
SW2SW8_218-8LPSTR_SW8_218-8LPST_45218-8LPSTRSW8_218-8LPST_450X230_SMD_2-7
SW3SW3_1103_SW3_500SSP1S2M2_510X26500SSP1S2M2QEASW3_500SSP1S2M2_510X260_TH_15-1
SW4SW4_1571634_SW4_84X163_170X130_PTS810SJG 250 SMTR LFSSW4_84X163_170X130_SMD
SW5SW4_1571634_SW4_84X163_170X130_PTS810SJG 250 SMTR LFSSW4_84X163_170X130_SMD
SW6SW4_1571634_SW4_84X163_170X130_PTS810SJG 250 SMTR LFSSW4_84X163_170X130_SMD
SW7SW4_1571634_SW4_84X163_170X130_PTS810SJG 250 SMTR LFSSW4_84X163_170X130_SMD
TP32TESTPOINT_TP_40X80_THRUHOLETHRUHOLETP_40X80
TP33TESTPOINT_TP_40X80_THRUHOLETHRUHOLETP_40X80
U1LM26400YMHX_HTSSOP16_ETSSOP16_2LM26400YMHXETSSOP16_25-59_200X180
U2LM26400YMHX_HTSSOP16_ETSSOP16_2LM26400YMHXETSSOP16_25-59_200X180
U3FT4232H_LQFP64_LQFP64_19-68_39FT4232HLLQFP64_19-68_390X390
U493LC56B-I/SN_SOIC8_SOIC8_1-8_9393LC56C-I/SNSOIC8_1-8
U5TPS7A8101DRB_SON8_SON8_25-59_12TPS7A8101DRBTSON8_25-59_120X120
U6DP83867IRPAPT_HTQFP64_EQFP64_19DP83867IRPAPTEQFP64_19-68_400X400
U7AT24CM02-SSHD_SOIC8_SOIC8_AT24CAT24CM02SOIC8
U8OSC6_ASEMPXX_OSC6_ASEMP_130X100100.000MHzOSC6_ASEMP_130X100_SMD_0-9
U9OSC6_ASEMPXX_OSC6_ASEMP_130X100100.000MHzOSC6_ASEMP_130X100_SMD_0-9
U10MT41J128M8JP-125_FBGA78_FBGA78_MT41K1G8SN-125IT:AFBGA78_31-49_360X520_1-2
U11MT41J128M8JP-125_FBGA78_FBGA78_MT41K1G8SN-125IT:AFBGA78_31-49_360X520_1-2
U12LFE5UM-85F-7BG381I_CSBGA381_CABLFE5UM-85F-8BG381ICABGA381_31-49_670X670_1-8
U13SN74LVC1G08DRLR_SOT553-5_SOT553SN74LVC1G08DRLRSOT553-5_0-6
U14MT25QL128ABA8ESF_SOIC16_SOIC16_MT25QL128ABA8ESF-0SITSOIC16_W_2-7
U15FT2232H_LQFP64_LQFP64_19-68_400FT2232HLLQFP64_19-68_400X400
U16TPD6E001RSE_UQFN10_UQFN10_19-68TPD6E001RSERUQFN10_19-68_80X60_0-6
U17TPD4E05U06DQAR_USON10_USON10_TPTPD4E05U06QDQARQ1USON10_TPD4E05U_40X100_0-6
U18TPD4E05U06DQAR_USON10_USON10_TPTPD4E05U06QDQARQ1USON10_TPD4E05U_40X100_0-6
U19TPS51200DRCT_SON10_SON10_19-68_TPS51200DRCTSON10_19-68_125X125_1
U2093LC56B-I/SN_SOIC8_SOIC8_1-8_9393LC56C-I/SNSOIC8_1-8
Y1CRY4_13_XTAL4_86-61X62-99_130X112.000MHzXTAL4_86-61X62-99_130X105_SMD_0-6
Y2CRY_XTAL_ABM3_205X130_SMD_1-4_225.000MHzXTAL_ABM3_205X130_SMD_1-4
Y3CRY4_13_XTAL4_86-61X62-99_130X112.000MHzXTAL4_86-61X62-99_130X105_SMD_0-6
:):):handshake 感谢分享,要回复才能看 这个不错,感谢感谢 感谢分享 学习下,谢谢分享!!! :handshake 谢谢分享:lol 👍👍👍👍👍👍👍 1
