CC1352+TM4C1294NCPDTT3R+ADS127L01IPBS+USB3300-EZK 做的一个物联网板PCB
本帖最后由 sisi9000 于 2024-6-24 23:06 编辑PCB文件。回复可见下载
**** Hidden Message *****
A1ANTENNA_PCB_ANTENNA_DN024N_DISC868MHz/2440MHzANTENNA_DN024N
CR1LED_LEDC1707X65L_LPL296-J2L2-25LPL296-J2L2-25LEDC1707X65L
CR2LED_LEDC1708X67L_LSL296-P2Q2-1LSL296-P2Q2-1LEDC1708X67L
CR4LED_LEDC1708X67N_IC_LSL296-P2QLSL296-P2Q2-1LEDC1708X67L
CR5LED_LEDC1707X65N_IC_LPL296-J2L2LPL296-J2L2-25LEDC1707X65L
CR6DIODE_TPD4E004_SON6_SON50P100X1TPD4E004DRYSON50P100X145X60-6N
CR7DIODE_TVS_TPD6E004_QFN8_V1_QFN5TPD6E004RSERQFN50P150X150X60-8N
CR8DIODE_TVS_TPD6E004_QFN8_V1_QFN5TPD6E004RSERQFN50P150X150X60-8N
CR14DIODE_ZENER_DIO_BZX84JN_IC_3.9V3.9VDIO_BZX84JN
CR15DIODE_SCHOTTKY_SOD3716X135N_IC_MBR130T1SOD3716X135L
FIDU1FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FIDU2FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FIDU3FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FIDU4FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FIDU5FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FIDU6FIDMARK_FID127X142_IO_FIDU_1.27FIDU_1.27mmFID127X142
FL1FILTER_2PIN_FIL_BLM18HE152SN1DLBLM18HE152SN1FIL_BLM18HE152SN1DL
FL2FILTER_2PIN_FIL_BLM18HE152SN1DNBLM18HE152SN1FIL_BLM18HE152SN1DN
FL3FILTER_LFD21829_0_FIL_LFD21829MLFD21829MDKED859FIL_LFD21829MDKED859_A2N
FL4FILTER_2PIN_FIL_BLM18HE152SN1DNBLM18HE152SN1FIL_BLM18HE152SN1DL
FL5FILTER_2PIN_FIL_BLM18HE152SN1DNBLM18HE152SN1FIL_BLM18HE152SN1DN
J1CONN_HEADER_2X10_J_S_V1_SAMTEC_SSQ-110-23-L-DSAMTEC_SSQ11023LD_A2B
J2CONN_HEADER_2X10_J_S_V1_SAMTEC_SSQ-110-23-L-DSAMTEC_SSQ11023LD_A2B
J6CONN_USB_MICRO_B_2MH_MOLEX_1051105164-0001MOLEX_1051640001_B2N
J7CONN_COAX_1_4_HUSTSAN_SMA10V21TSMA-10V21-TGGHUSTSAN_SMA10V21TGGAN
L11INDUCTOR_HOR_1_2_INDC1005X60D2N15nHINDC1005X60D2N
L12INDUCTOR_HOR_1_2_INDC1005X60D_12.4nHINDC1005X60D2N
L13INDUCTOR_HOR_1_2_INDC1005X60D_22nHINDC1005X60D2N
L14INDUCTOR_HOR_1_2_INDC1005X60D_22nHINDC1005X60D2N
L21INDUCTOR_HOR_1_2_INDC1005X60D_12.4nHINDC1005X60D2N
L31INDUCTOR_HOR_1_2_INDC1005X60C2N3.9nHINDC1005X60C2N
L32INDUCTOR_HOR_1_2_INDC1005X60D_322nHINDC1005X60D2N
L33INDUCTOR_HOR_1_2_INDC1005X60C_110nHINDC1005X60C2N
L34INDUCTOR_HOR_1_2_INDC1005X60D_47.5nHINDC1005X60D2N
L41INDUCTOR_HOR_1_2_INDC1005X60C2N3.9nHINDC1005X60C2N
L42INDUCTOR_HOR_1_2_INDC1005X60C_110nHINDC1005X60C2N
L331INDUCTOR_INDC2012X150A2N_DISCRE6.8uHINDC2012X150A2N
L332INDUCTOR_FILC2012X110A2N_DISCREBLM21PG221SN1FILC2012X110A2N
L333INDUCTOR_FILC2012X110A2N_DISCREBLM21PG221SN1FILC2012X110A2N
L334INDUCTOR_FILC2012X110A2N_DISCREBLM21PG221SN1FILC2012X110A2N
LBL2TI_LOGO_V1_TI_LOGO_1_MECHANICALTI_LOGOTI_LOGO_1
LBL3CE_LABEL_V1_CE_MARKING_MECHANICCE_labelCE_MARKING
LBL4LABEL_FOR_EVALUATOIN_ONLY_LABELLABEL_FOR_EVALUATION_ONLYLABEL_FOR_EVALUATION_ONLY
LBL5TRASH_V2_TRASH_7MM_MECHANICAL_TTRASH_7mmTRASH_7MM
LBL6ESD_LABEL_ESD_LABEL_5X5_MECHANIESD_LABEL_5x5mmESD_LABEL_5X5
M1MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M2MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M3MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M4MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M5MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M6MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M7MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M8MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M9MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M10MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M11MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M12MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M13MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M14MECH_SHUNT_JUMPER_V1_SAMTEC_SNTSNT-100-BK-GSAMTEC_SNT100BKG
M15MECH_SPACERS_SUPPORT_V1_MECH_DCDCB-10MECH_DCB10_A2B
M16MECH_SPACERS_SUPPORT_V1_MECH_DCDCB-10MECH_DCB10_A2B
M17MECH_SPACERS_SUPPORT_V1_MECH_DCDCB-10MECH_DCB10_A2B
M18MECH_SPACERS_SUPPORT_V1_MECH_DCDCB-10MECH_DCB10_A2B
MH1HOLE_PTH_MTG320_380_IO_HOLE_3.2HOLE_3.2mm_PTHMTG320_380
MH2HOLE_PTH_MTG320_380_IO_HOLE_3.2HOLE_3.2mm_PTHMTG320_380
MH3HOLE_PTH_MTG320_380_IO_HOLE_3.2HOLE_3.2mm_PTHMTG320_380
MH4HOLE_PTH_MTG320_380_IO_HOLE_3.2HOLE_3.2mm_PTHMTG320_380
MH5HOLE_PTH_MTG110_170_IO_HOLE_1.1HOLE_1.1mm_PTHMTG110_170
P1CONN_HEADER_3_P_S_GRADCONN_BB02BB02-HC031-KB1-603000GRADCONN_BB02HC031KB1603000_A2B
P2CONN_HEADER_3_P_S_GRADCONN_BB02BB02-HC031-KB1-603000GRADCONN_BB02HC031KB1603000_A2B
P4CONN_HEADER_2X11_P_S_GRADCONN_BBB02-HJ221-KB1-603000GRADCONN_BB02HJ221KB160300_A2B
P5CONN_HEADER_2X5_SAMTEC_FTSH-105FTSH-105-01-F-DV-KSAMTEC_FTSH-105-01-F-DV-K-10L
P6CONN_HEADER_2X2_P_GRADCONN_BB02BB02-HJ041-KB1-603000GRADCONN_BB02HJ041KB1603000_A2B
P7CONN_HEADER_2X5_SAMTEC_FTSH-105FTSH-105-01-F-DV-KSAMTEC_FTSH-105-01-F-DV-K-10L
P8CONN_IDC_TC2050-IDC-NL_TAGCONNETC2050-IDC-NLTAGCONNECT_TC2050IDCNL_A2N
P10CONN_HEADER_3_P_S_GRADCONN_BB02BB02-HC031-KB1-603000GRADCONN_BB02HC031KB1603000_A2B
P11CONN_COAX_1_1_P_2MH_V1_MURATA_MMM5829-2700MURATA_MM58292700RJ4_A2N
P12CONN_COAX_1_1_P_2MH_V1_MURATA_MMM5829-2700MURATA_MM58292700RJ4_A2N
PCB1PCB_V2_TI_MCUXX_MECHANICAL_WCS0WCS038TI_MCUXX
SW1SWITCH_TACT_V2_SW_1188E1K2V_A2N1188E-1K2-VSW_1188E1K2V_A2N
SW2SWITCH_TACT_V2_SW_1188E1K2V_A2N1188E-1K2-VSW_1188E1K2V_A2N
SW3SWITCH_TACT_V2_SW_1188E1K2V_A_11188E-1K2SW_1188E1K2V_A2N
U1IC_RF_CC1352_QFN48_QFNFC50P700XCC1352R1F3RGZQFNFC50P700X700X100-49A2N
U4IC_FLASH_MX25R8035F_USON8_SON50MX25R8035FZUIL0SON50P300X200X60-9B2L
U5IC_PROC_TM4C1294NCPDT_TQFP128_QTM4C1294NCPDTT3RQFP40P1600X1600X120-128N
U6IC_REF_LM4040_SC70-5_SOT65P210XLM4040B25IDCKSOT65P210X110-5N
U7IC_PM_TPS79601_SON8_SON65P300X3TPS79601DRSON65P300X300X100-9AL
U8IC_XCVR_SN74AVC4T245_UQFN16_2_QSN74AVC4T245RSVQFNFC40P180X260X55-16A2L
U9IC_XCVR_SN74AVC4T245_UQFN16_2_QSN74AVC4T245RSVQFNFC40P180X260X55-16A2L
U10IC_XCVR_SN74AVC4T245_UQFN16_2_QSN74AVC4T245RSVQFNFC40P180X260X55-16A2L
U15IC_PROC_USB3300_QFN32_QFNWB50P5USB3300-EZKQFNWB50P500X500X100-33N
U33IC_SWITCH_TS3A24159_SON10_SON50TS3A24159DRCSON50P300X300X100-11A2N
U34IC_LOGIC_SN74LVC2G74_VSSOP8_SOPSN74LVC2G74DCUSOP50P310X90-8N
U35IC_ADC_ADS127L01_QFP32_0_QFP50PADS127L01IPBSQFP50P700X700X120-32A2N
U36IC_OPAMP_INA118U_SO8_SOIC127P60INA118UBSOIC127P600X175-8N
U37IC_OPAMP_THS4551_QFN10_QFNFCP50THS4551IRUNQFNFCP50P200X200X80-10A2N
U38IC_SWITCH_TS3A24159_SON10_SON50TS3A24159DRCSON50P300X300X100-11A2N
U39IC_SWITCH_TS3A4751_QFN14_QFNFC4TS3A4751RUCRQFNFC40P200X200X40-14A2N
U40IC_REF_REF6025_VSSOP8_SOP65P490REF6025IDGKSOP65P490X110-8A2N
U41IC_OPAMP_OPA320_SOT23-5_SOT95P2OPA320AIDBVSOT95P280X145-5A2N
U42IC_PM_TPS79601_SON8_SON65P300X3TPS79601DRSON65P300X300X100-9AL
U43IC_PM_LP5907-1_8_SOT23-5_SOT95PLP5907MFX-1.8SOT95P280X145-5A2N
U44IC_PM_TPS73101_SOT23-5_SOT95P28TPS73101DBVSOT95P280X145-5A2N
U45IC_OPAMP_OPA314_SC70-5_SOT65P21OPA314AIDCKSOT65P210X110-5A2N
U46IC_PM_TPS79601_SON8_SON65P300X3TPS79601DRSON65P300X300X100-9AN
U47IC_PM_TPS259530_WSON8_SON50P200TPS259530DSGSON50P200X200X80-9A2N
Y1CRYSTAL_XTAL_FC-135N_32.768KHZ_32.768kHzXTAL_FC-135N
Y2XTAL_4PINS_1_3_OSCCC200X160X45-48MHzOSCCC200X160X45-4A2N
Y3XTAL_4_OSCCC250X320X100-4BN_IC_16MHzOSCCC250X320X100-4BN
Y4XTAL_4_OSCCC250X320X70-4AN_IC_224MHzOSCCC250X320X70-4AN
Y5XTAL_GEN_EN_V1_OSCSC254P320X50016.384MHzOSCSC254P320X500X130-4A2N
Z60INDUCTOR_INDC1005X60B2N_DISCRET3.3nHINDC1005X60B2N
Z61CAPACITOR_CAPC1005X60B2N_DIS_125.6pFCAPC1005X60B2N
Z62INDUCTOR_INDC1005X60B2N_DISCRET3.3nHINDC1005X60B2N
Z63CAPACITOR_CAPC1005X60B2N_DIS_125.6pFCAPC1005X60B2N
:):):handshake 感谢分享,要回复才能看 :):):):):):):):):):) :):):) :) :lol:lol:lol :) :):) 7777777777777777777777
