SVP7500 高清摄像头 PCB文件 allegro拼版生产
PCB文件。回复可见
**** Hidden Message *****
D1SP3401-02UTG_UDFN-6L_SP3401-02UTGSP3401-02UTGUDFN-6L
FB1FB_0402_120OHM_LB00635120ohm402
J1QSH/QTH-30_QTH_030_03_AP_QTH-030-03-F-D-A-KQTH-030-03-F-D-A-KQTH_030_03_AP
J2QSH/QTH-30_QTH_030_03_AP_QTH-030-03-F-D-A-KQTH-030-03-F-D-A-KQTH_030_03_AP
J3CONN_RCPT_3X2_SOCKET_3X2_100_6_CONTACT6_ContactSOCKET_3X2_100
J4HEADER_4_HEADER_4PIN_100_SINGLEROW_04SingleRow_04HEADER_4PIN_100
J5CONN_RCPT_3X2_SOCKET_3X2_100_6_CONTACT6_ContactSOCKET_3X2_100
J9QSH/QTH-30_0_QTH-030-08-L-D-A_QTH-030-01-F-D-A-KQTH-030-01-F-D-A-KQTH-030-08-L-D-A
J10USB2.0C_629722000214_USB2.0 CUSB2.0C6.29722E+11
JP1JUMPER_3_HEADER_3PIN_100_SINGLEROW_03SingleRow_03HEADER_3PIN_100
JP2JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP3JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP4JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP5JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP6JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP7JUMPER_3_HEADER_3PIN_100_SINGLEROW_03SingleRow_03HEADER_3PIN_100
JP9JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP10JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
JP11JUMPER_2_HEADER_2PIN_100_SINGLEROW_02SingleRow_02HEADER_2PIN_100
L1INDUCTOR_0806_2.2UH2.2uH806
SW1SW_DIP2_SMT_DIP2_50MIL_DIP2Dip2SMT_DIP2_50MIL
SW3SW_PUSHBUTTON_SPST_2_SMD_6MM_B3S-1000_SW00152B3S-1000SMD_6MM
TP1TP_TP_TP-WHITETP-WhiteTP
TP2TP_TP_TP-WHITETP-WhiteTP
TP3TP_TP_TP-WHITETP-WhiteTP
TP5TP_TP_TP-WHITETP-WhiteTP
U1SVP7500_1_FCCSP122L_SVP7500SVP7500FCCSP122L
U2LP2980X_SO_SOT23_5PIN_LP2981A-33LP2981A-33SOT23_5PIN
U3SIT1533AI-H4-DCC-32.768D_XO4PIN_DISCRETE_32.768KHZ_TMP-1232.768kHzXO4PIN
Y1RFX_6035_CRY_3225_070_24MHZ24MHzCRY_3225_070
学习学习
好东东,谢谢分享!!!
