来一个威盛的VIA8505平板电脑上用的邮票孔设计的核心板PCB
板子有以下元件,如有需要可以下载提取封装使用。都是验证OK 的板子
NameValuePCB DecalPart Type#0001FIDFID#0002FIDFID1P5STestPoint_1mmSMD_TP_1MMSMD_TP_1MM3P3STestPoint_1mmSMD_TP_1MMSMD_TP_1MM3P3VTestPoint_1mmSMD_TP_1MMSMD_TP_1MM15ENTestPoint_1mmSMD_TP_1MMSMD_TP_1MM18ENTestPoint_1mmSMD_TP_1MMSMD_TP_1MM33ENTestPoint_1mmSMD_TP_1MMSMD_TP_1MMC14.7uFCAP0603CAP0603C40.1uFCAP0603CAP0603C50.1uFCAP0603CAP0603C61uFCAP0603CAP0603C70.1uFCAP0603CAP0603C94.7uFCAP0603CAP0603C115600pFCAP0603CAP0603C141uFCAP0603CAP0603C151uFCAP0603CAP0603C161uFCAP0603CAP0603C171uFCAP0603CAP0603C180.1uFCAP0603CAP0603C191uFCAP0603CAP0603C210.1uFCAP0603CAP0603C220.1uFCAP0603CAP0603C231uFCAP0603CAP0603C240.1uFCAP0603CAP0603C274.7uFCAP0603CAP0603C2927pFCAP0603CAP0603C3027pFCAP0603CAP0603C3110pFCAP0603CAP0603C3210pFCAP0603CAP0603C331uFCAP0603CAP0603C351uFCAP0603CAP0603C361uFCAP0603CAP0603C381uFCAP0603CAP0603C401uFCAP0603CAP0603C410.1uFCAP0603CAP0603C420.1uFCAP0603CAP0603C431uFCAP0603CAP0603C471uFCAP0603CAP0603C481uFCAP0603CAP0603C501uFCAP0603CAP0603C511uFCAP0603CAP0603C521uFCAP0603CAP0603C531uFCAP0603CAP0603C541uFCAP0603CAP0603GND1TestPoint_1mmSMD_TP_1MMSMD_TP_1MMGND2TestPoint_1mmSMD_TP_1MMSMD_TP_1MMPBTNTestPoint_1mmSMD_TP_1MMSMD_TP_1MMPWGDTestPoint_1mmSMD_TP_1MMSMD_TP_1MMR147KRES0603RES0603R5120_1%RES0603RES0603R9301_1%RES0603RES0603R1310K_1%RES0603RES0603R1410K_1%RES0603RES0603R1510KRES0603RES0603R1610KRES0603RES0603R1710KRES0603RES0603R1810KRES0603RES0603R1910KRES0603RES0603R2010KRES0603RES0603R2110KRES0603RES0603R2310KRES0603RES0603R2410KRES0603RES0603R2533RES0603RES0603R3233RES0603RES0603R3333RES0603RES0603R344.7KRES0603RES0603R354.7KRES0603RES0603R375.62K_1%RES0603RES0603R3822RES0603RES0603R391KRES0603RES0603R401KRES0603RES0603R434.7KRES0603RES0603R444.7KRES0603RES0603R4610KRES0603RES0603R4810KRES0603RES0603R531.5KRES0603RES0603R544.7KRES0603RES0603R601MRES0603RES0603RXDTestPoint_1mmSMD_TP_1MMSMD_TP_1MMTXDTestPoint_1mmSMD_TP_1MMSMD_TP_1MMU1WM8505PFBGA479-31P5PFBGA479-31P5U3K9G4G08U0A-PCB0TSOP48-19P7X768TSOP48-19P7X768U4EN25F40-75HCP/XSOIC8-50X288SOIC8-50X288U5EN25F40-75GCPSMD_AT25FS040N-SH27_W600-PLSMD_AT25FS040N-SH27_W600-PLU6VT8505_CBWM8505_CB_32X90_111PIN-PLWM8505_CB_32X90_111PIN-PLU11K4T1G084QE-HCE6FBGA60-31P5FBGA60-31P5U12K4T1G084QE-HCE6FBGA60-31P5FBGA60-31P5VBATTestPoint_1mmSMD_TP_1MMSMD_TP_1MMVDDTestPoint_1mmSMD_TP_1MMSMD_TP_1MMVMEMTestPoint_1mmSMD_TP_1MMSMD_TP_1MMX127MHZSMD_2PIN_32P768-PL_X1SMD_2PIN_32P768-PL_X1X232.768KHzSMD_2PIN_32P768-PL_X2SMD_2PIN_32P768-PL_X2X327MHZ/XOSC4-146X087OSC4-146X087 **** Hidden Message ***** 下来看看 用的什么片子 谢谢楼主分享! 正好学习一下 看看,怎么样,谢谢分享。 看看先,之前是否看过 看看吧,这个邮票···· 正想做邮票板,刚好拿来参考下。谢谢楼主。 邮票孔学习!!!!!!
