spi从机
/*********************************************************************** ****************** name:SPI_Slaver_Driver ************** ********** author:made by zzuxzt ********** ****************** time:2014.4.29 *********************************************************************************************///use SPI 3 mode,CHOL = 1,CHAL = 1module spi(input clk, input rst_n, input CS_N, input SCK, input MOSI, input txd_data, output reg MISO, output reg rxd_data, output rxd_flag);//-------------------------capture the sck-----------------------------reg sck_r0,sck_r1;wire sck_n,sck_p;always@(posedge clk or negedge rst_n)begin if(!rst_n) begin sck_r0 <= 1'b1; //sck of the idle state is high sck_r1 <= 1'b1; end else begin sck_r0 <= SCK; sck_r1 <= sck_r0; endendassign sck_n = (~sck_r0 & sck_r1)? 1'b1:1'b0; //capture the sck negedgeassign sck_p = (~sck_r1 & sck_r0)? 1'b1:1'b0; //capture the sck posedge//-----------------------spi_slaver read data-------------------------------reg rxd_flag_r;reg rxd_state;always@(posedge clk or negedge rst_n)begin if(!rst_n) begin rxd_data <= 1'b0; rxd_flag_r <= 1'b0; rxd_state <= 1'b0; end else if(sck_p && !CS_N) begin case(rxd_state) 3'd0:begin rxd_data <= MOSI; rxd_flag_r <= 1'b0; //reset rxd_flag rxd_state <= 3'd1; end 3'd1:begin rxd_data <= MOSI; rxd_state <= 3'd2; end 3'd2:begin rxd_data <= MOSI; rxd_state <= 3'd3; end 3'd3:begin rxd_data <= MOSI; rxd_state <= 3'd4; end 3'd4:begin rxd_data <= MOSI; rxd_state <= 3'd5; end 3'd5:begin rxd_data <= MOSI; rxd_state <= 3'd6; end 3'd6:begin rxd_data <= MOSI; rxd_state <= 3'd7; end 3'd7:begin rxd_data <= MOSI; rxd_flag_r <= 1'b1;//set rxd_flag rxd_state <= 3'd0; end default: ; endcase endend//--------------------capture spi_flag posedge--------------------------------reg rxd_flag_r0,rxd_flag_r1;always@(posedge clk or negedge rst_n)begin if(!rst_n) begin rxd_flag_r0 <= 1'b0; rxd_flag_r1 <= 1'b0; end else begin rxd_flag_r0 <= rxd_flag_r; rxd_flag_r1 <= rxd_flag_r0; endendassign rxd_flag = (~rxd_flag_r1 & rxd_flag_r0)? 1'b1:1'b0;//---------------------spi_slaver send data---------------------------reg txd_state;always@(posedge clk or negedge rst_n)begin if(!rst_n) begin txd_state <= 1'b0; end else if(sck_n && !CS_N) begin case(txd_state) 3'd0:begin MISO <= txd_data; txd_state <= 3'd1; end 3'd1:begin MISO <= txd_data; txd_state <= 3'd2; end 3'd2:begin MISO <= txd_data; txd_state <= 3'd3; end 3'd3:begin MISO <= txd_data; txd_state <= 3'd4; end 3'd4:begin MISO <= txd_data; txd_state <= 3'd5; end 3'd5:begin MISO <= txd_data; txd_state <= 3'd6; end 3'd6:begin MISO <= txd_data; txd_state <= 3'd7; end 3'd7:begin MISO <= txd_data; txd_state <= 3'd0; end default: ; endcase endendendmodule
