TMS320C6657+XC3S200AN 挂三个 MT41J128M16HA DDR PCB文件
NamePCB DecalPart Type560V2_PWR1HD_4X2P_100_DCONNECTOR_-_4_X_2_HD_4X2P_100_DAMC1GF-AMC-B00_GF-AMC-B_0_GF-AMC-B_GF-AMC-BCLK2QFN_48P_20_276X276_TP220V25CDCE62005RGZT_0_QFN_48P_20_276XCOM1MOL22-23-2031CONNECTOR_-_3_X_1_MOL22-23-2031COM_SEL1SAMTSM-103-01-S-DV1653_JH3X2V_0_SAMTSM-103-01-S-DCT6CT7343CAP_POL_CT7343__100UFD1LED_LTST-S270K_RA130_LED_LED-0603_R_0_LED_LTST-SD2LED_LTST-S270K_RA130_LED_2P_B_0_LED_LTST-S270K_RD3DIODE_2P_158_197X110SCHOTTKY_DIODE_DIODE_2P_158_197D4ESD_2P_65_63X31130_ESD_D0603_0_ESD_2P_65_63X31D5ESD_2P_65_63X31130_ESD_D0603_0_ESD_2P_65_63X31D7DIODE_2P_158_197X110130_SCHOTTKY_SMA-1_0_DIODE_2P_1D9SOD-323130_SCHOTTKY_SOD-323_SOD-323_DID10SOD-323130_SCHOTTKY_SOD-323_SOD-323_DID11LED_0603130_LED_LED-0603_G_0_LED_0603_GD17LED_LTST-C171LED_LED_LTST-C171__LEDD18DIO_DO214AA_SMBZENER_DIODE_DIO_DO214AA_SMB__SMDC_IN1CON_RAPC712_PWRJACKCONN_JACK_PWR_CON_RAPC712_PWRJADSP1BGA80P_38X38_625_SKT_EINFTMS320C6657_BGA80P_38X38_625_SKEEPROM1SOIC_8P_50_193X236AT24C1024_0_SOIC_8P_50_193X236_EMU1BB_30X2P_50_770X250_2HOLD1654_BB_30X2P_SOLC-115-02_0_BB_ESD1AMC-ESD-B00_AMC-ESD-B_0_AMC-ESD-B_AMC-ESF6PTC_RUEF300FUSE_PTC_RUEF300__RUEF300F7FUSE_C0603FUSE_FUSE_C0603__F0603E3R00FSTRF8FUSE_C0603FUSE_FUSE_C0603__MFU0603FF04000F9FUSE_C0603FUSE_FUSE_C0603__F0603E1R00FSTRFAN1WHL3V-2M1655_WHL3V-2M_0_WHL3V-2M_IO_NU_FM1FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIALFM2FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIALFM3FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIALFM4FIDUCIAL00_FIDUCIAL_0_FIDUCIAL_FIDUCIALFPGA1BGA_256P_39_669X669_H61XC3S200AN-4FTG256C_BGA_256P_39_FPGA_D1LED_0603130_LED_2P_B_0_LED_0603_GRNFPGA_D2LED_0603130_LED_2P_B_0_LED_0603_GRNFPGA_D3LED_0603130_LED_2P_B_0_LED_0603_GRNFPGA_D4LED_0603130_LED_2P_B_0_LED_0603_GRNH1H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-H2H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-H3H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-H4H35-NPTH00_SCREWHOLE_CIRCLE_NPTH_1_H35-H5H27P35-MTH00_H27P35-MTH_0_H27P35-MTH_H27PHYPERLINK1IPASSHD_36P_76867-00111654_IPASS_36P_76867-0011_0_IPAJ4SAMTSW-102-07-S-SCONNECTOR_-_2_X_1_SAMTSW-102-07J5SAMTSW-102-07-S-SCONNECTOR_-_2_X_1_SAMTSW-102-07L2IND_NR80401211_L_0_IND_NR8040_DISCRETE_22L3IND_NRG40261211_CHOKE_0_IND_NRG4026_DISC_1L15IND_NRG40261211_CHOKE_0_IND_NRG4026_DISCREL16CHK_ELL-5PRR47N1211_CHOKE_0_CHK_ELL-5PRR47N_DIL118IND_NR60281211_CHOKE_0_IND_NR6028_DISCRETLAN1RJ45_17P_101112FHBMAM404ZA1652_RJ45_17P_101112FHBMAM_0_RJMMC1QFP_80P_20_551X551MSP430F5435IPN_0_QFP_80P_20_551NAND1VFBGA80P_10P5X15_63_EINFNAND512R3A2DZA6E_2_VFBGA80P_10PPHY1QFN50P900X900_64_PWP_A_EINF88E1112_QFN50P900X900_64_PWP_A_PMBUS1HD_5X1P_100_D1653_JH5X1V_0_HD_5X1P_100_D_IO_Q1SOT-23131_N_MOS_SOT-23_1_SOT-23_2N700Q2QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_Q3QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_Q4QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_Q5QFN_8P_26_118X118TPS73701DRBT_QFN_8P_26_118X118_Q6SOT-23131_N_MOS_SOT-23_1_SOT-23_2N700Q13SC-70_5P141_MICROCHIP_MCP9700AT-E-LT_0_RST_COLD1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQRST_FULL1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQRST_WARM1SW_EVQ-PF003M160_SW-HDK632_SW_EVQ-PF003M_EVQSBW_MMC1PWR-S4PV1655_PWR-S4PV_0_PWR-S4PV_IO_W_4SW3SW_SDA08H0SBDIP_SWITCH_-_8_SW_SDA08H0SB__SDSW5SW_SDA08H0SBDIP_SWITCH_-_8_SW_SDA08H0SB__SDSW9SW_SDA02H0SB160_SW_4P_ESD102EZ_0_SW_SDA02H0SYSPG_D1LED_LTST-C171130_LED_2P_B_0_LED_LTST-C171_YETAP_FPGA1HD_8X1P_100_D1653_JH8X1V_0_HD_8X1P_100_D_IO_TEST_PH1HD_40X2P_50_2HOLD_F1653_HD_40X2P_F_L1_0_HD_40X2P_5U1SOIC_16P_26_197X252ICS557GI-08LFT_0_SOIC_16P_26_19U5BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31_52U6BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31__1U9QFP_64P_20_472X472FT2232H_QFP_64P_20_472X472__FT2U10SOIC_20P_26_256X252TXS0108EPWR_SOIC_20P_26_256X252U11TSSOP65P640_14SN74AHC00PWR_TSSOP65P640_14_SN7U12SOIC_8P_50_193X236141_ATMEL_AT93C46DN-SH-T_0_SOICU13SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197U16BGA_96P_31_524X295_C14MT41J128M16HA-125_BGA_96P_31_52U19SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197U24SOIC_16P_26_197X252SN74AVC4T245PWR_SOIC_16P_26_197U26SOIC_8P_50_193X236141_ATMEL_AT25128B-SSHL-B_SOIC_U27QFN10P_20_118X118_TP94X65V5TPS51200DRCT_QFN10P_20_118X118_U29SOIC_8P_50_193X236141_TI_TPS54231D_0_SOIC_8P_50_1U30QFN_14P_20_138X138_TP79TPS54620RGY_QFN_14P_20_138X138_U32QFN_48P_20_276X276_TP202V25UCD9222RGZR_QFN_48P_20_276X276_U34QFN_32P_20_236X236_UDC7242141_TI_UCD7242RSJT_0_QFN_32P_20U36QFN_14P_20_138X138_TP79TPS54620RGY_QFN_14P_20_138X138_U244SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9U245SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9U248SOIC_8P_20_79X122PCA9306_SOIC_8P_20_79X122__PCA9U249SOIC_16P_26_197X252MAX3221_SOIC_16P_26_197X252_MAXU251SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOTU252SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOTU253SOT-23_5P14S_TI_SN74LVC1G07_SOT-23-5_SOTU254SOIC_48P_20_492X319TS3L301_SOIC_48P_20_492X319__TSU255SOIC_14P_26_197X252141_TI_SN74ALVC125PWR_0_SOIC_14U259SOIC_48P_20_492X319TS3L301_SOIC_48P_20_492X319__TSU260SOP127P790_8141_NUMONYX_N25Q128A21BSF40F_SOU264TSSOP65P640_8AT24C02A_TSSOP65P640_8_24LC02B-U266SC70_5PSN74LVC1G08DCKR_SC70_5P_SN74LVCU267SC70_5PSN74LVC1G32DCKR_SC70_5P_SN74LVCU268SC70_5PSN74AUC1G32DCKR_SC70_5P_SN74AUCU269SC70_5PSN74AUC1G32DCKR_SC70_5P_SN74AUCU1131SOT23_6TPS3808G_SOT23_6__TPS3808G18DBVUSB1MOL54819-0519MINI_USB_CONNECTOR_MOL54819-051Y1XTAL_ABS10CRYSTAL-2PIN_XTAL_ABS10__ABS10-Y2XTAL_ABM3BCRYSTAL-4_PIN_XTAL_ABM3B__ABM3BY3XTAL_ABM3BCRYSTAL-4_PIN_XTAL_ABM3B__ABM_1Y5XTAL_ABM31231_XTAL_2P_0_XTAL_ABM3_7A-25.Y7OSC_535_9259_11233_OSC_4P_0_OSC_535_9259_1_AS
**** Hidden Message ***** 这个厉害,谢谢 谢谢分享!!!!! 这么复杂 这个pcb工艺要求很高 比较密哦, 眼花缭乱 谢谢分享 谢谢分享! very Good!
