高通 QCA9531 无线路由器 PCB文件和原理图 datas
NamePCB DecalValuePart TypeDS1LED-0603LEDLED-0603-LTST-C190GKTJ1CON-HRS-UFL-APPLECON RF 3PINCON_RF_3PINJ2CON-HRS-UFL-APPLECON RF 3PINCON_RF_3PINJ5HDR7X2CON-TH-M-V-2X7-100X100CON-TH-M-V-2X7-100X100J6USB-A-RT-90KS-001V-ANW-LCON-USB-A-4SHDJ7CON-RJ45X4-2CON-RJ45-1X4CON-RJ45-1X4J8CON-RJ45-3-2CON JACK SINGLE PORTCON_ETHER_1PORTJ10CON-PWRJACK-ACTPJ-102AHCON_POWERJACKJ31CON-PCI-XPR-MINI-FCON PCI EXPRESS MINICON_PCI_EXPRESS_MINIJP1HDR6X2CON-TH-M-V-2X6-100X100CON-TH-M-V-2X6-100X100L1IND-SM-3X32.2uHIND-FERRITEL15IND-02013.9nHIND_2L16IND-RAD-200-590X31510uHIND_3L17IND-04023.0nHIND_4L18IND-04023.0nHIND_4L20IND-SM-5X5-VLC6.8uHINDL27IND-02012.2nHIND_2L28IND-02012.2nHIND_2L30IND-SM-7.3X6.84.7uHIND_6L31RES-02010RRES_2L32RES-02010RRES_2L57IND-02012.4nHIND_7L58IND-02012.4nHIND_7L63IND-02013.3nHIND_6L64IND-02013.3nHIND_6L65IND-02019.1nHIND_8L66IND-020115nHIND_8L67IND-02019.1nHIND_8L68IND-020115nHIND_8PT1HOLE-150R102T POINT RT_POINT_RPT2HOLE-150R102T POINT RT_POINT_RPT3HOLE-150R102T POINT RT_POINT_RPT4HOLE-150R102T POINT RT_POINT_RPT5HOLE-150R102T POINT RT_POINT_RQ1TRA-SOT23MMBT2907ATRA-SOT23-MMBT2907AQ2TRA-SOT23MMBT2907ATRA-SOT23-MMBT2907AQ3TRA-SOT23MMBT2907ATRA-SOT23-MMBT2907AQ4TRA-SOT23MMBT2907ATRA-SOT23-MMBT2907AQ6SOT-343RBFU768FTRANSISTOR_NPN_4-PIN_CQ7SOT-343RBFU768FTRANSISTOR_NPN_4-PIN_CS1SWI-6P-TSONSKY13370-374LFSWI-SKY13370-374LFS2SWI-6P-TSONSKY13370-374LFSWI-SKY13370-374LFS3SWI-RT-PUSH-TU-DBLPS-22F02L-CAPSW-PS-6PSLOT1SLOT-47X20TP SMDTP_SMD_2SLOT2SLOT-47X20TP SMDTP_SMD_2SW1SW-PUSH-RT-OPT2TS02D-BNSW-TACT-4PSW2SW-PUSH-RT-OPT2TS02D-BNSW-TACT-4PT1YCL20PMT04AHN1664CTRANSFORMER_HN1664CT2HN2064CHN2064CTRANSFORMER_HN2064CT3HN2064CHN2064CTRANSFORMER_HN2064CU4QFN-16-3X3-GND-2SE2623LPA-SE2623LU5SOP8-OPT2RT7247ART7247AU6QFN-DR-156-EPQCA9531-DL1AQCA9531U7BGA-84-9X15-3SDRAM-DDR2-512MBSDRAM-DDR2-512MB_2U8QFN-16-3X3-GND-2SE2623LPA-SE2623LU9SO8-200N25Q064A13ESE40FN25Q128A-SO8WVR2SO8NB-1GND-2RT8293BRT8293BVR3SO8NB-1GND-2RT8293BRT8293BY1XTAL-HC49US25MHzXTAL-TH-HC49-25MHZZH1HOLE-200D225NP-CUSTESTPAD35TESTPAD35ZH2HOLE-200D225NP-CUSTESTPAD35TESTPAD35ZH3HOLE-200D225NP-CUSTESTPAD35TESTPAD35ZH4HOLE-200D225NP-CUSTESTPAD35TESTPAD35
这个芯片的 PCB 资料。网上完全找不到
**** Hidden Message *****
之前论坛上有人求这个资料。http://bbs.ntpcb.com/read.php?tid-63877.html
后来我找到了。忘记发上来了。今天发上来。 太好的资料了,谢谢分享!! 好好,,, 老大V5,谢谢 逆天作品 回复顶一下。
