车载电脑主板-车载娱乐系统MT3360+TNJ3321PF+TEF6624+MT6611+MT3328 P
再上一个安卓车载电脑主板 PCB文件和原理图,结构图整套完整的资料。4层设计
板子有以下主要元件。
NamePart TypePCB DecalValue1V5TESTPOINT-1TESTP-1.01V15TESTPOINT-1TESTP-1.03V3TESTPOINT-1TESTP-1.05VTESTPOINT-1TESTP-1.08V5TESTPOINT-1TESTP-1.0ARXDTEST_POINT_SMD0.6_2TESTP-1.0-ATEST POINT SMD0.6ATXDTEST_POINT_SMD0.6_2TESTP-1.0-ATEST POINT SMD0.6BUZBUZZERBZ2-1200BUZZER2¨·?o?CE5CAP_EC100UF/10V/D5H11_2SC0805220uF/10vCN7TV_ANTCON2-2050-ANT(TUNER)ANT 2¨·?o?CON1TF-SOCKET-8PINTF-SOCKET-8PINCON2CON-SMT-40PINSFPC-40PIN-0.5MMCON3CON-SMT-40PINSFPC-40PIN-0.5MMCON4CON-SMT-4PINSCON-4PIN-1.25MM-V4PIN CON 1.25mm liCON5RD_AV_OUTCON12-AV-RCA9CON6CON-SMT-4PINSCON-4PIN-1.25MM-V4PIN CON 1.25mm liCON7JLHISOCON20-0250-PWRFUSE-R2¨·?o?CON8CON-SMT-10PINSCON-10PIN-1.25MM-VCON9FPC-12PIN-0.5MMSFPC-12PIN-0.5MM12P CON 0.5mm FFCCON10CON-SMT-2PINSCON-2PIN-1.25MM-V2PIN CON 1.25mmCON13FPC-12PIN-0.5MMSFPC-12PIN-0.5MM12P CON 0.5mm FFCCON14CON-SMT-40PINSFPC-40PIN-0.5MMCON16CON_4PINSIP-4PIN-2.0UART_debug 2¨·?o?D1DIODESD-SOD3234148D2DIODESD-SOD3234148D3DIODESD-SOD3234148D3V3TEST_POINT_SMD0.6_2TESTP-1.0-ATEST POINT SMD0.6D4DIODESD-SOD3234148D5DIODESD-SOD3234148D6DIODE-DSD-SOD3231N4148D71N5404SD-SOD2145404 PINOUTSD8DIODESD-SOD214SK34D9DIODESD-SOD1064148D10DIODESD-SOD1064148D111N5404SD-SOD2145404 PINOUTSD42DIODE_SMD_0603_ESD_PROTECTIONSESD0402LXES15AAA1-017D43DIODESD-SOD3234148D44DIODESD-SOD3234148D50DIODESD-SOD1064148D52DIODESD-SOD3234148D55BAV99-ASOT23-ABAV99WTD56DIODESD-SOD1064148D57DIODESD-SOD1064148EC1CAP-ESEC5.047UF/16VEC2CAP-ESEC4.01UF/50VEC4CAP-ECP2-16006800uF/20V2¨·?o?EC8CAP-ESEC5.0220UF/16VEC10CAP-ESEC5.022UF/16VEC11CAP-ESEC5.047UF/16VEC12CAP-ESEC5.047UF/16VEC13CAP-ESEC5.0220UF/16VESD50ESD0603SD-ESD0603PJSD05TS (NC)ESD51ESD0603SD-ESD0603PJSD05TSFAN-12V1TESTPOINT-1TESTP-1.0FB2L0402SFB0402BLM15HD102SN1FB4L0402SFB0402BLM15HD102SN1FB6L0402SFB0603BLM18AG601SN1FB7INDUCTOR_0JUMP-3.0BLM18AG601SN1/NCFB8INDUCTOR_0SFB0603BLM18AG601SN1FB9INDUCTOR_0SFB0402BLM15AG601SN1FB10INDUCTOR_0SFB0603BLM18AG601SN1FB34FBSFB0603600RFB35FBSFB0603600RFB36FBSFB0603600RFB37FBSFB0603600RFU1FUSESF12101.1AFU2FUSESF12100.2AFU3FUSESF12101.1AFU5FUSESF12100.2AGNDTEST_POINT_SMD0.6_2TESTP-1.0-ATEST POINT SMD0.6GND_TVTPTP-2.5VTG_J1ANT-HANT-H-AG_J3ANT-HANT-HIC1LDO_7808SOT263-3L2940IC2STM8-80QFP80-065-1414LSTM207IC5SOP8SOP8-50-150IC48IPOD_ADSQFN20-050-0404LIC51EEPROMSOP8-50-15024C02IC63LP2950SOP8-50-150LP2950J27WIFI_20WIFI_20J29R-JUMPJUMP-PAD2.0JP1JUMPJUMP-2.0JP2JUMPJUMP-2.0JP3JUMPJUMP-2.0JP4JUMPJUMP-2.0L1LSL06031.8nHL2FERRITE_BEAD_SMD_1206SFB0603FB/BLM18PG121SN1L3LSL06031.8nHL4FERRITE_BEAD_SMD_1206SR0805FB/BLM18PG121SN1L11CDH-125SPL12120922uH/5A(CDH129)L16L3SL1210560uH 2¨·?o?L17L3SL1210560uH 2¨·?o?L18LSL0805270nHL19FERRITE_BEAD_SMD_1206SFB0603FB/BLM18PG121SN1L20FERRITE_BEAD_SMD_1206SFB0603FB/BLM18PG121SN1L21L2SL1206270nHL23LSL08051uHL24FERRITE_BEAD_SMD_1206SFB0603FB/BLM18PG121SN1L25L1SL08051.8uHL26LSL1206220nHL27JLW_LLC2-1300-V2¨·?o?L30INDUCTOR_0SFB0402NCL31INDUCTOR_0SFB0402NCL32INDUCTOR_0SFB040227nH/LQW15AN27NL33INDUCTOR_0SFB04020RL34INDUCTOR_0SFB04024.7nH/LQW15AN4N7L35INDUCTOR_0SFB0402BLM15AG601SN1L36INDUCTOR_0SFB04020R/NCL37INDUCTOR_0SFB04020R/NCL38FBSFB0603100UHL40LLSPL0302100UHL41FBSL12061A/1206L42LLSL1206100UHL44LSPL030215uH/CD32(NC)M1PCHANNELSOT23-AIRLML6402M2PCHANNELSOT23-AIRLML6402M3IRF7205SOP8-50-150IRF7205M6PCHANNELSOT23-AIRLML6402MCU_3V3TESTPOINT-1TESTP-1.0P14VTPTP-1.0VTP14V_TVTPTP-2.5VTPL1LSPL0505023.3uHPL2LSPL0505023.3uHQ1TRANS-NPNSOT23-A3904Q2TRANS-NPNSOT23-A3904Q3TRANS-PNPSOT23-A2N3906Q4TRANS-PNPSOT893CG1663Q5TRANS-NPNSOT23-A3904Q6TRANS-NPNSOT23-A3904Q7TRANS-PNPSOT891132Q8NPNSOT23-A2SC8050Q9TRANS-NPNSOT23-A3904Q102N3904SOT23-A2N3904SQ112N3904SOT23-A2N3904SQ16DTC314-NPNSOT23-ADTC643Q20TRANS-NPNSOT23-A3904Q23DTC314-NPNSOT23-ADTC643Q24DTC314-NPNSOT23-ADTC643Q80DTC314-NPNSOT23-ADTC643Q71012N3904SOT23-A3904RN15RN0402_8P4R_2SRN040222RX4TC1ECAPSC1206TC2CAP-ESEC5.047UF/16VTC3ECAPSC120610UF/16VTC4ECAPCP2-10001000UF/25V2¨·?o?TC6CAP-ESEC6.3100UF/16VTC7ECAPCP2-0800220UF/25V 2¨·?o?TC9CAP-ESEC5.047UF/16VTC10CAP-ESEC6.3100UF/6.3VTC11CAP-ESEC6.3100UF/6.3VTC16ECAPCP2-08001000UF/6.3V 2¨·?o?TC20ECAPSEC5.0100UF/6.3V ESRTC31ECAPSEC6.3100uF/16VTV1TVTUNTCPN9081TNJ3321PFU1XC6401_0SOT23-6AS-1711B2828-M6T1GU2G9091-330T11USOT23-5AS-1311B40-M5T1SU3RT9179SOT23-5ART9013-12PB 500mAU6TEF6606TSOP32-50-300TEF6624U7OCP2152-ADJDFN10-20-118AU8RT9164SOT252LD1117-3.3(S0T-252)U9OCP2152-ADJDFN10-20-118AU10TC58128FT_3SOP48-20-720MT29F32G08CBACAU11TDA7386FLEXWATT25-0200-RTDA7388U12MT3360_73MT3360/PBGA500MT3360U13IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/MICRONH5TQ1G63DFR-H9CU14IC_DDR3_X16_FBGA-96FBGA96/SMD/P0.8/MICRONH5TQ1G63DFR-H9CU15SST25V040_SERIAL_FLASHSOP8-50-208M25P16/EON F16U16FMS6141SOT23-5BFMS6141S5XU17BA3121FSOP8-50-150BA3121FU19IMP811SEUS-TSOT143U21AMPLIFIERSOP8-50-150UTC4558U22IC_OPA_NJM4558_SOP-8_7SOP8-50-150LM4558U23IC_OPA_NJM4558_SOP-8_7SOP8-50-150LM4558U27TSSOP20/CS4361SOP20-26-173CS4361-CZZ /NCU30BALUN_5BPF_6611RFBPB2012060AMST61U31MT6611_SMD_WLCSP-61_25QFN40-040-0505L-AMT6612_QFN40U32MAX2659_0DFN6/SMD/DALLAS/MAX2659MAX2659U33SAFEB1G57KA0F00_0SFLT5-2511SAFEB1G57KE0F00 / 856561U34MT3328QFN48-040-0606L-AMT3328Y1XTALSX2-12504MY2CRYSTAL-32K768SX4-671432K768Y3OSCDUAL_7SX4-3225IT3205CE/26MHZ+/-0.5ppm(TX5070)Y4XTAL_SHIELDSX4-503227MY5XTALSX2-12508MZD1ZDIODE-ASD-SOD32318VZD2ZDIODE-ASD-SOD32318VZD3ZDIODE-ASD-SOD3235V6ZD61N6263SD-SOD3235V6ZD9ZDIODESD-SOD32310vZD151N6263SD-SOD32318VZD16DIODESD-SOD3234148
配套的3个板子在这里。
http://bbs.ntpcb.com/read.php?tid-81588.html
http://bbs.ntpcb.com/read.php?tid-81586.html
http://bbs.ntpcb.com/read.php?tid-81587.html 整套完整的设计资料。
原理图PCB文件都有。都是PADS9.5格式的。
支持 谢谢楼主分享
