老吴 发表于 2016-12-25 23:17:10
RK3288平板电脑挂一个LPDDR2+STK3310+GSL3680+GL852G+ES8316 PCB文件和
NamePart TypePCB DecalValueCPM3CAPNP_DUP1_1C040243pFCPM4CAPNP_DUP1_1C040243pFCSM3CAPNP_DUP1_1C040282pFCSM4CAPNP_DUP1_1C040282pFD1LEDLED0603LEDD5DIODESOD1231N5819D14DIODE_ZENER13_0D120622VD15DIODE_ZENER13_0D12066.8VD18DIODE_2SOD1231N5819D19DIODE_1SOT23BAT54SD24DIODE_1SOT23BAT54SD38DIODE_0SOD3231N4148D2500DIODE_3SOD123SS32D2501DIODE_3SOD123SS32D2502DIODE_3SOD123SS32D5200DIODE_2SOD1231N5819ED8113DIODE_BI-DIR_TRIGE0402NESD9B5VED8114DIODE_BI-DIR_TRIGE0402NESD5431NFB26INDUCTOR_4L0402600R100MFB27INDUCTOR_4L0402600R100MFB7100INDUCTOR_4L0603BLM18PG181SN1J3TP12PIN_2FPC0515-08-HYSTP_8PINJ57''WSVGAFPC0515-40PIN-RFH12A-40S-0.5SH-DOWNJ9CON4_5COTEX-FPC0515-6RL-TAOW-5PJ11PJ-3536_3PJ-3139-XT-CJPJ-3139J15CON4_2USB-HXQK-AF90USB3J19TP12PIN_8IC-SENSOR-APDS-9901STK3310J2000USB_MIN_4USB-MCD-HXQK5F-LJ10HUM011D-5-SJ4600LCM0200CE1A0_4FPC0515-30PIN-RZT300B1J6000ANT_0WIFIANTRFANT5220J6201ANT3R1210RFANT5220J7101CON2R1210CON2J7102CON2R1210CON2J7103CON2R1210CON2J8100SD_SOCKET_0TF-9PINTF_SD_SOCKETJ8101SD_SOCKET_0TF-9PINTF_SD_SOCKETJ8200HDMI_CHDMI-19PINMHDMI_CJ8201CAMERA-MIPI-30P_1FPC0310-31B2-GXX-LCAMERA-MIPI-30PL3INDUCTOR_3IND-3X33.3uHL4INDUCTOR_5IND-4X41.5uHL5INDUCTOR_2L0603LQW18CNR33J00L6INDUCTOR_2L0603LQW18CNR33J00L7INDUCTOR_5IND-4X41.5uHL13INDUCTOR_1IND-4X42.2uH/2AL14INDUCTOR_0_2IND-4X422uHL21INDUCTORS_OF_FERRITE_2IND-4X410uH/1.5AL27INDUCTOR_5IND-4X41.5uHL29INDUCTOR_5IND-4X41.5uHL30INDUCTOR_5IND-4X41.5uHL50900T_0CMF-1210TF1210A2X900MTL2208INDUCTORS_OF_FERRITEIND-5X5SWPA5020SR47NT/5AL5200INDUCTORS_OF_FERRITE_2IND-4X410uH/1AL6201INDUCTOR_2L04026.8nHMIC7100MICMIC13MIC-0402NC/U4000NANDFLASH_0TSOP1-48NAND_FLASHNC/U4101DS8008_4SOT25NC/PT5108E23E-33P2208TESTPOINT1PAD2X2_5VBA+P2209TESTPOINT1PAD2X2_5NTCP2210TESTPOINT1PAD2X2_5GNDQ2WPM4005_11DFN8-0.65-2X2-WPM1481WPM1481Q340852_1SOT23S8050Q440852_1SOT23NC/S8050Q1340852_1SOT23S8050Q15MOSFET_N_0SOT23WPM2026Q288050SOT238050Q2205FET_P_MOSSOT23NC/WPM2015Q2206FET_P_MOSSOT23WPM2026Q2207FET_P_MOSSOT23NC/WPM2026Q2208NPN4SOT238050Q2209NPN4SOT23NC/S8050Q2501MOSFET_PSOT_23WPM2341-3/TRQ2503MOSFET_PSOT_23WPM2341-3/TRQ2504NPN_2SOT_23S8050Q3400FET_N_MOSSOT23WNM2016Q3401NPN4SOT238050Q3603NPNSOT23S8050Q8200FET_N_MOSSOT23WNM2021/2SK3018Q8201FET_N_MOSSOT23WNM2021/2SK3018RA1RESISTOR_0_3R0402NC/0RRA2RESISTOR_0_3R0402NC/0RRA3RESISTOR_0_3R0402NC/0RRA4RESISTOR_0_3R0402NC/0RRA5RESISTOR_0_3R0402NC/0RRA6RESISTOR_0_3R0402NC/0RRP4100RESISTOR_4PACKR0402S410KRP4101RESISTOR_4PACKR0402S410KRP4102RESISTOR_4PACKR0402S410KRSM3R_0R06030R(0603)RSM4R_0R06030R(0603)SW1SW4P_1GF-A31-2X4PWRONSW3SW4P_3GF-A31-2X4VOL-SW4SW4P_1GF-A31-2X4RESETSW6SW4P_2GF-A31-2X4VOL+U1AP6493_8AP6XXXAP6xxxU3K3PE0E000E_6FBGA216-12MX12MLPDDR2U8G5121_1SOT26SY7208/DT6104/TCS9208//LP6218U11AXP22X_0QFN68-0.4-8X8AXP229U12DS8008_6_2SOT25TCS4201-FU23GL850G/GL852GSSOP28P_GL852GNC/GL850G/GL852GU25RT9271_0SOT26TSC3356U38DS8008_0SOT25SY6280AAC/WS4603U40MMA7660FC_2MMA7660FCMMA7660FCU49TP12PIN_1FPC0310-13B2-G3RTP15PINU80GSL3680_0GSL3680GSL3680BU81MMA8653FCMMA865XFCMMA8653FCU82MMA8653FC_1MMC3416PJMMC3416xPJU98NPN_0SOT23HAL48U1000MCU_RK3288_8BGA636_1MCU_RK3288U2206BB27_0WLCSP-20SYR828U2209RTCMSOP8HYM8563U2210DS8008_3SOT25SY6280/TT9107/UP7534GMA5-10U4100INANDINAND_169INANDU4500DS8008_4SOT25AP7335-15W/RT9013-15BU4501DS8008_4SOT25LN6210_EU5200LED_DRIVE-BLSOT26ETA1617U6202LNA_MAX2659_1BGU7005MAX2659/BGU7005U7201DS8008_4SOT25PT5108E23E-18U7202ALC3224_1QFN-34BCM20795P1U7300CODEC_ES8316QFN32-4X4-0.4MMES8316U7302AMPLIFIER_PT1505MSOP8PT1505EMSHU7304AMPLIFIER_PT1505MSOP8PT1505EMSHU7601D97-L3312A_0FPC0515-54PIN-RFPC-0310-61B2-G3RU8005LSM330_5GL823-QFN-24PINGL823U8200DS8008_10SLP2510P8TPD4E05U06/AZ1045-04FU8201DS8008_12SLP2510P8TPD4E05U06/AZ1045-04FU8202DS8008_13SLP2510P8TPD4E05U06/AZ1045-04FU8506LDO-PT5127SOT26PT5128E23F-EX2FB2H2G45_CELL_2CRY-D3225TCXO 26MHz (2520)Y1CRYSTAL_2CRY-MC14632.768KY3CRYSTAL_0252026MHz (3225)Y4CRYSTAL_0252026MHz (3225)Y1100CRYSTAL-4_1CRY-D322524M-30ppmY1101CRYSTAL-4_1CRY-D322512MHz
老吴 发表于 2016-12-25 23:18:20
PCB是PADS9.5格式。原理图是ORCAD16.3格式。
**** Hidden Message *****
dahai_851129 发表于 2016-12-26 00:18:40
谢谢分享
yangtao0559 发表于 2016-12-26 00:36:18
好作品观摩一下
草帽焦 发表于 2016-12-26 08:07:23
上班开电脑后第一件事就是先把论坛浏览个遍
yfchen1003 发表于 2016-12-26 08:08:45
下载玩玩!!
神话2013 发表于 2016-12-26 08:09:43
谢谢分享!
madong12 发表于 2016-12-26 08:13:28
下載下來學習學習
tom6508 发表于 2016-12-26 08:14:49
谢谢分享
hlim89 发表于 2016-12-26 08:19:49
谢谢分享
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: RK3288平板电脑挂一个LPDDR2+STK3310+GSL3680+GL852G+ES8316 PCB文件和
