GF106挂12个DDR5 +SN0808087+MP38876DB 做的图像处理板卡PCB共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECN1CON_MXM3_NPHY-CON_MXM3_EDGE,EDB CON_FINGER_MXM_270CN501CON_POGO_MXMB_ISEN-CON_TP_2PINB CON_MXMB_002_TPB_ST_PI100CN502CON_POGO_MXMB_TP-CON_TP_MXMB,FC CON_MXMB_024_TPB_ST_PI100D1D_SCHOTTKY_SOD323-NSR0320MW2T1B DIODE_SMD_SOD323D2D_SCHOTTKY_SMA-SBR3A40SA,40V,4B DIODE_SMD_SMAD3D_SCHOTTKY_SMA-SBR3A40SA,40V,4B DIODE_SMD_SMAG1U_GPU_GB1_192_BGA1328-GF106-66B BGA_1328_P080_P085_P100_350X350J1CON_B2B_40_MXM30_SLI_GC-MXM3_MB CON_MISC_040_SMD_ST_M_P005_BTB_BL1L_SMD_420X400-0.39UH,METALDUSB0.39UHIND_NONRKO_SMD_I420X400L2L_SMD_420X400-0.39UH,METALDUSB0.39UHIND_NONRKO_SMD_I420X400L3L_SMD_420X400-1.0UH,METALDUSTB1.0UHIND_NONRKO_SMD_I420X400L501L_SMD_045_041-0.47UH,FERRITE,+B0.47uHIND_NONRKO_SMD_I175X160L502L_0603-120R@100MHZ,FERRITE,25%B120R@100MHzIND_SMD_0603L503L_0603-120R@100MHZ,FERRITE,25%B120R@100MHzIND_SMD_0603LB501L_BEAD_0603-30R@100MHZ,FERRITEB30R@100MHzIND_SMD_0603LB502L_BEAD_0603-300R@100MHZ,FERRITB300R@100MHZIND_SMD_0603LB503L_BEAD_0603-180R@100MHZ,FERRITB180R@100MHzIND_SMD_0603LB504L_BEAD_0603-180R@100MHZ,FERRITB180R@100MHzIND_SMD_0603LB505L_BEAD_0603-300R@100MHZ,FERRITB300R@100MHZIND_SMD_0603LB506L_BEAD_0603-220R@100MHZ,FERRITB220R@100MHzIND_SMD_0603LB507L_BEAD_0603-220R@100MHZ,FERRITB220R@100MHzIND_SMD_0603LB508L_0603-22NH,MTLR,+/-5%,N/A,50B22nHIND_SMD_0603M1U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M2U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120M3U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M4U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120M5U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M6U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120M501U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M502U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120M503U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M504U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120M505U_MEM_SD_DDR5_X32_BGA170-BGA17D BGA_0170_P080_140X120M506U_MEM_SD_DDR5_X32_BGA170_MIRR-D BGA_0170_P080_140X120MEC1MOUNTING_HOLE_X6-MXM_V3_TYPE_BC MECH_MXMB_00820X01050_HOLESQ1Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q2Q_FET_N_ENH_LFPAK-CSD17305Q5A,B MULTI_SMD_SOT669_LFPAK_BQ3Q_FET_N_ENH_LFPAK-CSD17305Q5A,B MULTI_SMD_SOT669_LFPAK_BQ4Q_FET_N_ENH_LFPAK-CSD17307Q5A,B MULTI_SMD_SOT669_LFPAK_BQ5Q_FET_N_ENH_LFPAK-CSD17307Q5A,B MULTI_SMD_SOT669_LFPAK_BQ6Q_FET_N_ENH_LFPAK-CSD17305Q5A,B MULTI_SMD_SOT669_LFPAK_BQ7Q_FET_N_ENH_LFPAK-CSD17305Q5A,B MULTI_SMD_SOT669_LFPAK_BQ8Q_FET_N_ENH_LFPAK-CSD17305Q5A,B MULTI_SMD_SOT669_LFPAK_BQ9Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q501Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q502Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q503Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q504Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q505Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q506Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q507Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q508Q_FET_P_ENH_SOT23_1G1D1S-NTR21B SOT23Q509Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q510Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q511Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q512Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q513Q_FET_N_ENH_SOT23_1G1D1S-2N700B SOT23Q514Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6Q515Q_FET_P_ENH_SOT23_1G1D1S-NTR21B SOT23Q900Q_FET_N_ENH_SOT363-2N7002DW-7-B SC70_6RS1R_SENSE_4PIN_MXM_ONLY-0.001,1%B0.001RES_04_SMD_I394X260_ILLEGALRS2R_SENSE_4PIN_MXM_ONLY-0.001,1%B0.001RES_04_SMD_I394X260_ILLEGALRS3R_SENSE_4PIN_MXM_ONLY-0.001,1%B0.001RES_04_SMD_I394X260_ILLEGALRS501R_SENSE_4PIN_MXM_ALT-0.01OHM,B0.01 OHMRES_04_SMD_I250X125_ILLEGALU1U_CLK_SS_PL671_SOT23-PL671-02-B SOT23_6U2U_MEM_FL_SER_128KX8_SO8-MX25L1B SO08_I190X150U3U_VREG_RT9018_DFN10-RT9018B-25B0.8V_VREFDFN10_P050_030X030U4U_SWREG_MP38876_QFN20-MP38876DBVR=0.8VQFN020R_P050_0350X0450_T009X026U501U_SWREG_MP28275_DFN14-MP28275,BVR=0.808VDFN14_P050_030X040_TI136X071U502U_SWREG_SN0808087_QFN40-SN0808BDYNAMICVID(0.4-1.25V)QFN040Q_P050_0065_TI165X165U503U_VREG_5PIN_SOT23-5-UP7703NMT5BADJ_VR=0.8VSOT23_5U504U_MEM_EE_I2C_TSSOP8-24AA64,2V5C XSOP08_P065_030X044U505U_TEMP_AD1032_SO8_122MIL-MAX66B XSOP08_P065_030X030Y1XTAL_4PIN_SMD-E3SB27.0000F18S3B27MHZXTAL_SMD_4_032X025 **** Hidden Message ***** 谢谢分享! 把原理图分享出来 谢谢分享! 强!!! 这个牛逼。想下载看看。级别不够。 牛 的一逼,DDR5都出来了 瞧瞧,嘿嘿
