老吴 发表于 2017-2-12 20:17:38
SKYPINE(天派) 车载主板 ZR36970+TEF6621+FMS6502+TDA7719 PCB和原理图
NamePCB DecalValuePart Type5VTP-R2.0T(L)TP8V5TP-R1.5TESTPOINT-1ACCTP-1.0RL-TPACCOM1ACCOM-CHOKESACCOMAGNDTP-1.5TPTEST_POINT_1B+TP-R2.0RL-TPB3V3TP-1.2TPTEST_POINT_1BREAKTP-1.0RL-TPB_3V3TP-1.0T(L)TPCN2NAVI-ANAVI-ACN5CON-16-PWR-776ACON16(power)POWER_INTERFACECN7ANT-ESTT-10ANTTV_ANTCON1FPC-12PIN-0.5MMNCFPC-12PIN-0.5MMCON2SFPC-50PIN-0.5MM-BCON-SMT-50PINCON3DEBUD4NCCON-4PCON4NAVI_BUILT_IN_CON20P CONAV_CONCON5AV_CON_EXTRA18P CONAV_CON_EXTRACON6CON7-1.25/SOJ7PIN/1.25/SMDCON-7PINCON7CON-4PIN-SOJ-1.254PIN CON 1.25mm liCON-SMT-4PINCON8CON-10PIN-SOJ-1.25CON-SMT-10PINCON9FPC-12PIN-0.5MMNCFPC-12PIN-0.5MMCON10CON-10PIN-SOJ-1.25CON-SMT-10PINCON15CON-2PIN-SOJ-1.25CON-SMT-2PIND1SOD-323-7761N4148DIODED2SOD-323-7761N4148DIODED3SOD-323-7761N4148DIODED5DIODE_TVS_DIP_V_UTVSDIODED6SOD-106IN40041SR154-400D7SOD-1061N4004DIODE-1D8SOD-1061N4004DIODE-2D9SOD-106SS16DIODE-3D10SOD-323-7761N4148DIODED21SM-C-DO-SS33SK34DIODEDGNDTP-1.0T(L)TPESD1IMSA_6801ESD_PROGNDTP-1.0RL-TPIC1TEF6606V2TEF6621TEF6606TIC2LQFP64-P-1010-0.5ASTM8-80STM8-64IC4SOP-8LSP3132LSP3132IC6SOP-8LP2950(3.3V)LP2950IC48IPOD_2_0_BIPOD_ADSILLTP-1.0RL-TPJ8FPC-52PIN-0.5MMCON-SMT-52PINJP101DEBUG3BOOTSELHEADER_3_0AL1IND-SMT-CD54100uH//CD54LL2IND-SMT-CD320RLL3CDH-12522uH/5A(CDH129)CDH-125L5FB080510uH/0805INDL6IND-SMT-CD54100uH//CD54LL8IND-SMT-CD32100uH//CD32LL9IND-SMT-CD3222uH/CD32LL10IND-SMT-06032.2UHLLL11SL1206215NH/1206IND-215NH-1206L12L12101A60RLL13IND-SMT-CD3210uH/CD32LL14SL12060290NH/1206IND-290NH-1206L15IND-SMT-08051UH/1.1UH?LLL16IND-SMT-08051.8UHLLL21IND-SMT-06032.2UHLLL22L1210A560uHLL23L1210A560uHLL25IND-SMT-CD3215uH/CD32LM-IN_SWTP-1.2TPTEST_POINT_1M-OUT_SWTP-1.2TPTEST_POINT_1M1SOT-23-MOSFETIRLML6402PCHANNELM2SOP84459IRF7205M5SOT-23-MOSFETIRLML6402PCHANNELQ2SOT-23-39063906PNPQ9SOT-23MMBBT2907APNPQ10SOT-23-39063906PNPQ11SOT-23MMBBT2907APNPQ12SOT-23-39063906PNPQ14USMKRC402KRC402Q15SOT-233904TRANS-NPNQ16SOT-893CG1663TRANS-PNPQ22SOT-23-7762N3904KTC3265YQ24SOT-89-776KTD1624TRANS-NPNQ25SOT-23-776SC3265TRANS-NPNQ37SOT-632020TRANS-NPNQ70USMKRC402KRC402RESETTP-1.0T(L)TPREVERSETP-1.0RL-TPTV1TCPN9081TNJ3321PFTVTUNU1SIP-10PLB1641U2FLEXWATT25TDA7388TDA7386U3SOP-84558BA3121FU5TDA7719_TSSOP28_H1M2TDA7719TDA7719U7TO-252LD1117-3.3(S0T-252)RT9164U10SOT-223LD1117-1.8(S0T-223)RT9164U12QFP-128-XEZR36970V9_9_1.0U14TSSOP10CS4344U20HSOP28BA5954BA5954FPU24SO8NB24C16-SNAT24C01A-10SCU26TSSOP-24FMS6502FMS6502U28SOP845584558U100ATMELSOP_8SPI FLASH-SOP824C01A_0U301TSOP-54K4S161622C-TC/L70
W9864G6GH-6
IC42S16400F-7TLHY57V641620HG_7U501SIP-10PLB1641VR1CAP-0603200PF/5V5VRVR3CAP-0603200PF/5V5VRVR9CAP-06035PF/18VVRX1HC49US-SMT27MHz/ê¥ìì/27PFXTALX5HC-49US-SMTTCXO-C-16M-HC-49S/SMD-AAY1HC49US-SMT4MHzXTALZD1SOD-323-7765.1V1N6263ZD5TVSFTZ5.6EZD6TVSFTZ5.6EZD9TVSFTZ5.6EZD10SOD-323-7765V11N6263ZD11SOD-323-7766V21N6263ZD21SOD-323-77610VZDIODEZD25SOT-23-776TLC431ZDIODE-REF
老吴 发表于 2017-2-12 20:18:46
PCB和原理图都是PADS 9.5 格式。
**** Hidden Message *****
单枪舞九州 发表于 2017-2-12 20:43:02
第一时间支持吴老大
topdenzengzhi 发表于 2017-2-12 20:53:13
板子画的还是挺漂亮的,支持吴老师
qrfbntel 发表于 2017-2-12 22:17:45
qrfbntel 发表于 2017-2-12 22:21:11
金币不够用啊,下两个就打回原型了
o桃花岛主o 发表于 2017-2-13 00:49:59
回 老吴 的帖子
老吴:PCB和原理图都是PADS 9.5 格式。
[内容隐藏]
 (2017-02-12 20:18) images/back.gif
不错
学海无涯 发表于 2017-2-13 07:02:45
学海无涯 发表于 2017-2-13 07:03:48
天派,吴老师在福永。
marco117 发表于 2017-2-13 07:54:26
页: [1] 2 3 4 5 6 7 8
查看完整版本: SKYPINE(天派) 车载主板 ZR36970+TEF6621+FMS6502+TDA7719 PCB和原理图
