Allegro转PADS问题求助
有一个Allegro文件想转PADS,在Allegro运行skill load "dfl_main.il" 然后main out最后显示0 error,如下
Al2Exp - 0 error(s), 48 warning(s)
Export log file saved at "D:/master/162_MGC\LogFiles\interfacelog.txt" file
Run "show log" command to view log file
------------------------------ Done -------------------------------
Grids are drawn 20.00, 20.00 apart for enhanced viewability.
Grids are drawn 80.00, 80.00 apart for enhanced viewability.
但在导入到PADS是,提示不成功(cannot prepare data for Allegro-to-Pads translation Stopping)。其他的文件可以成功转换,请问文件有可能是怎么回事?谢谢 同问 可以的 想问下最后这个问题解决了吗? 没有吧 解决了吗?
