全志allwinner A83T 平板电脑PCB和原理图AXP813+WD2053+GSL1680+RTL8723
NamePCB DecalValuePart TypeANT1WIFIANTPCBWIFIANTCN1CON24PIN-0.5MMCON24PINCON24PIN-0.5MMCN2FPC_60_0D5_BHSD070IDW2FPC_60_0D5_BCN3SPEAK_SMD2.2AABACKLIGHTSPEAK_SMD2.2AACN4FFC30PIN30PIN-0.5MM-???óFFC30PINCN5SPEAK_SMD2.2AASPEAKERSPEAK_SMD2.2AACON1CON6-MURATASW_CONNCON6-MURATAD4SOD-123XBS104S14SOD-123D39SOD-123SS14/IN5819SOD-123D40SOT-23BAT54SSOT-23D41SOD-1237VSOD-123D42SOD-123IN5819SOD-123D43SOT-23BAT54SSOT-23D44SOD-12315VSOD-123DU1FBGA96C80P9X13DDR3-FBGA96FBGA96C80P9X13DU2FBGA96C80P9X13DDR3-FBGA96FBGA96C80P9X13ESD8ESD0402SESD5Z6VESD0402ESD9ESD0402SESDFBP05CESD0402ESD10ESD0402SESDFBP05CESD0402FB1L0402600R-100ML0402FB2L0402600R-100ML0402FB3L0603600R-100ML0603FB4L0603600R/100ML0603HR1R040210K/NCR0402J1BAT-PMPCON3BAT-PMPJ6CK3.5-381B-23B-AHP_JACKCK3.5-381B-23B-AJ7PJR-0226-S001HP_JACKPJR-0226-S001J8TF-CKT01-009DMICROSD/TF_SLOTTF-CKT01-009DJ9DC-058DCINDC-058L1CD21/21.0UHCD21/2L2CDRH3B141.0UHCDRH3B14L3CDRH3B141.0UHCDRH3B14L5CDRH3B141.0UHCDRH3B14L6CD21/21.0UHCD21/2L7CD21/21.0UHCD21/2L11CDRH3B141.0UHCDRH3B14L12CDRH3B1410UHCDRH3B14L13CDRH3B1422UHCDRH3B14L14L04020RL0402L15L0402NOTE_3L0402L16L04020RL0402L17L04020RL0402MIC1MIC4MMMICPHONEMIC4MMOD1SOD-123SS24SOD-123OL1CDRH3B142.2UH-DCR<0.1R-2ACDRH3B14OU1SOT-26MT3608SOT-26Q4DFN8P0_65B2_00X2_00H0_75WPM1481DFN8P0_65B2_00X2_00H0_75Q6SOT-23AO3401SOT-23Q7SOT-23MMBT3904SOT-23Q9SOT-23MMBT3904SOT-23Q10SOT-23MMBT3904SOT-23SW1IT_1207SMDPWRONIT_1207SMDSW3IT_1207SMDVOL+IT_1207SMDSW4IT_1207SMDVOL-IT_1207SMDSW5SW3UBOOTSW3T1PAD-60D37TPPAD-60D37TP4PAD-60D37UART0-TXPAD-60D37TP5PAD-60D37UART0-RXPAD-60D37TP6PAD-60D37CPUS-UTXPAD-60D37TP7PAD-60D37CPUS-URXPAD-60D37TP16PAD-60D37VREFPAD-60D37TP17PAD-60D37PMU-SDAPAD-60D37TP18PAD-60D37PMU-SCKPAD-60D37TP19PAD-60D37VDDFB-CPUBPAD-60D37TP20PAD-60D37VDDFB-CPUAPAD-60D37U1BGA345P0_65B14X14A83TA83T_BGA345P0_65B14X14_A83TU4TSOP-48NANDTSOP-48U5TSOP-48NANDTSOP-48U28AXP813-BGA218AXP813-BGA218AXP813-BGA218U29SOT-26WD2053SOT-26U30QFN-40GSL1680QFN-40U31SOT-23-5G5125SOT-23-5U32DFN10NC/MMA7660FCDFN10U34MSOP8LM4890MSOP8U35QFN-68RTL8723BSQFN-68U205DS_DA213DS_DA213DS_DA213USB1JS-MR1-4036MIRCO-USB-5PJS-MR1-4036VLED+1PAD-60D37CTPPAD-60D37VLED-1PAD-60D37CTPPAD-60D37X1OSC_322524M-20PF-10PPMOSC_3225X2Y-RTC32768Y-RTCX3OSC_322540MHZOSC_3225
板子没画完。如有需要练习的可以下载。PCB原理图都有。
不错,学习一下,谢谢 还没画完的A83T,听说解码能力比较强 支持 A83的,看起来不错 好东西哦 楼主自己画的板子?
