180KW一体式充电桩 ADSM4000 控制板PCB 原理图 整套资料 STM32F42
NamePart TypePCB DecalValueB1INDUCTOR_20603R1.5A,600@100MHzB2INDUCTOR_20603R1.5A,600@100MHzB3INDUCTOR_20603R1.5A,600@100MHzB4INDUCTOR_20603R1.5A,600@100MHzB5INDUCTOR_20603R1.5A,600@100MHzBAT15V1FBATT-2N-CR2450CR2450D3DIODIODE-SMA1N4007D8DIODIODE-SMAES1DD10DIOSOD-123US1MD11DIODIODE-SMAES1DD12DIODIODE-SMAES1DD1340CPQ045/TO_0SOT23BAV70LT1D1840CPQ045/TO_1SOT23BZX84C 16VLT1D19DIODIODE-SOD123MMSD4148T1GD20DIODIODE-SOD123MMSD4148T1GD21DIODIODE-SOD123MMSD4148T1GD22DIODIODE-SOD123MMSD4148T1GD23DIODIODE-SOD123MMSD4148T1GD24DIODIODE-SOD123MMSD4148T1GD25DIODIODE-SOD123MMSD4148T1GD26DIOSOD-123M7D27DIODIODE-SMAES1DD37DIODIODE-SOD123MMSD4148T1GD38DIOSOD-123M7D47DIOSOD-123MMSD4148T1GD48ZHCS1000/SOT_1DIODE-SOD323-100HTVSBV-05CD49ZHCS1000/SOT_1DIODE-SOD323-100HTVSBV-05CDN1DIODE_DUAL_S_KJA_0SOT23BAV99LT1DS3LAMPLED-2N254P400MM-VD4MMLEDDS5LAMPLED-2N254P400MM-VD4MMLEDE4CAP1206C1206-106K-25VE5CAP1206C1206-106K-25VE6CAPCAPMP32164.7uF 2012E7CAPC06032.2uFE8CAPC06032.2uFE9CAP1206C1206-106K-25VESD130CPQ100/TO_0SOT23-3NUP2105ESD230CPQ100/TO_0SOT23-3NUP2105H1TPMH-3D0M-PTHHOLEH2TPMH-3D0M-PTHHOLEH3TPMH-3D0M-PTHHOLEH4TPMH-3D0M-PTHHOLEJ1CON4_2HEAD-4N0508P2230L0850WCON4J23CON3HEAD-3N03810P1280L0730W-VDCON3J24RJ45NTL_1RJ45-1N1590W2134L1340HRJ45NTLJ25CON6HEAD-6N254P2X3VDCON6J26LCDPGPFC-40N0050P1950L0300W0210HLCDPGJ27CON4FPC-4N100P260H-5943CON4J28MINUSBUSB-MICROMINUSBJ29MICROSD_0SD-MICMICROSDJP1JPR3JUMP-3N254P1X3VDUT-JPRL1INDUCTORL-2N0580P0850C200uHL2R_3L120633R100M1206L3CHOKE_CM14L-4N1300L1100W20mhL4FILUU98H-H020157uHL5R_3L120633R100M1206LED1LEDLED080517-21SURC/S530-A2/TR8LS1SPEAKERBEEPDC5VMOV1RVDR-2N750P2100H-471KD1414D471Q3MPF6659_0TO220-3N254P1880H-LIRFBE30Q4NPN1SOT23-3BC846ALT1GQ162N4403/TO_0SOT23-32N4403Q182N4403/TO_0SOT23-32N4403Q19NPN1SOT23-3BC846ALT1GQ20NPN1SOT23-3BC846ALT1GQ21NPN1SOT23-3BC846ALT1GQ22NPN1SOT23-3BC846ALT1GQ23NPN1SOT23-3BC846ALT1GQ24NPN1SOT23-3BC846ALT1GQ25NPN1SOT23-3BC846ALT1GQ26NPN1SOT23-3BC846ALT1GQ27NPN1SOT23-3BC846ALT1GRLY2G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY3G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY4G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY5G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY6G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY7G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY8G2R2RLY-10N0254P1400L0900W0500HTQ2-5RLY9G2R2RLY-10N0254P1400L0900W0500HTQ2-5SINK1TPSINK-1500L1100W散热器SW1SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMSW2SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMSW3SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMSW4SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMSW5SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMSW6SW_PUSHBUTTON-SPST-2SW-4N350H6X66X6MMT1TAN_1PWR-EE24LEE25T4FLTL-4N1100L540W1270HFLTU378L05TO220-3N254P1880H-L7805U775LBC184_1SOIC-8N0127P0500L0620W0175HMAX485U13UC2843SOIC-8N127P490L390W155HUC2843U16MOC70K3OC-4N254P360L440W260HPC817U18TL431_1TO92-3N127PTL431U21PS2501-1OC-4N127P260L440W210HTLP281U22PS2501-1OC-4N127P260L440W210HTLP281U24PS2501-1OC-4N127P260L440W210HTLP281U25PS2501-1OC-4N127P260L440W210HTLP281U26PS2501-1OC-4N127P260L440W210HTLP281U27PS2501-1OC-4N127P260L440W210HTLP281U28PS2501-1OC-4N127P260L440W210HTLP281U116MAX3232SOIC-16N127P990L390W175HMAX3232U144MAX13487SOIC-8N0127P0500L0620W0175HMAX13487U145HCPL-M453MO-155ACPL-M50LU146HCPL-M453MO-155ACPL-M50LU147MAX13487SOIC-8N0127P0500L0620W0175HMAX13487U148HCPL-M453MO-155ACPL-M50LU149HCPL-M453MO-155ACPL-M50LU150MAX13487SOIC-8N0127P0500L0620W0175HMAX13487U151HCPL-M453MO-155ACPL-M50LU152HCPL-M453MO-155ACPL-M50LU153MAX13487SOIC-8N0127P0500L0620W0175HMAX13487U154HCPL-M453MO-155ACPL-M50LU155HCPL-M453MO-155ACPL-M50LU156MAX13487SOIC-8N0127P0500L0620W0175HMAX13487U157HCPL-M453MO-155ACPL-M50LU158HCPL-M453MO-155ACPL-M50LU161M74HVC1G08SOT23-5M74HVC1G08U164HCPL-M453MO-155ACPL-M50LU173ISO1050DUBSO-8N0254P0950L1070W0485HISO1050DUBU174ISO1050DUBSO-8N0254P0950L1070W0485HISO1050DUBU175STM32F429ILQFP-176N050P240L240W0160HSTM32F429IGT6U17674HC595/SOSOIC-16N127P990L390W175H74HC595/SOU17774HC165/SO_0SOIC-16N127P990L390W175H74HC165/SOU178PS2501-1OC-4N127P260L440W210HTLP281U179PS2501-1OC-4N127P260L440W210HTLP281U180PS2501-1OC-4N127P260L440W210HTLP281U18174HC165/SO_0SOIC-16N127P990L390W175H74HC165/SOU182PS2501-1OC-4N127P260L440W210HTLP281U183PS2501-1OC-4N127P260L440W210HTLP281U184PS2501-1OC-4N127P260L440W210HTLP281U185PS2501-1OC-4N127P260L440W210HTLP281U186PS2501-1OC-4N127P260L440W210HTLP281U187PS2501-1OC-4N127P260L440W210HTLP281U188XPT2046_0SSOP-16N0635P490L390W173HXPT2046U189W5500_0QFP48W5500U190LMS1585ACS-3_0.3SOT223LM1117-3.3VU191IMP706R-8SO_0SOIC-8N127P490L390W175HIMP706RESAU192IS42SI6400JTSOP-54P080P2230L1020W120HIS42SI6400JU19324LC256_0SOIC-8N127P490L390W175HAT24C256U194SST25VF016BSOIC-8N127P530L520W216HSST25VF016BU195MIC2025SOIC-8N0127P0500L0620W0175HMIC2025Y1XTALXTAL-49S_6CHC49S6C-8MHZY2XTAL1XTAL-4N700L150W140HSSP-T7-FY3XTALXTAL-49S_6CHC49S6C-25MHZ
小板
CommentPatternQuantityComponentsI2001L311.0592CRYSTAL1Y12.2NF YCC7.5MM1C3120K 08052042R22, R2420PF±5%8052C20, C214052SO-161U243K2041R34510 08052041R13510R 08052041R9511 08052043R18, R19, R205608051R435K2041R37680K 08052041R3378L05TO92D1U9BEAD8051L4CON3P5.08-31J3CON4P5.08-42J2, J4CON5P5.08-41J1EE19/5AEE16-4X61T1F107D0.151D11HCPL0600SO-82U10, U11LM317TO220HS1Q1LM358SO-81U1LM393ASO-81U4MAX485ESASO-81U6MB6SMB6S1B1MCP3421SOT23-61U3MINI52ZANQFN32L1U5MUR120SMA3D6, D7, D9MZ13-08P7RH60V 7R 25% D=9mm8052L1, L2MZB-10S300-500R/14D391FHPTC1T2NP2041R2NP8051C16NP12062C32, C33P6KE6.8CAD0.1253Z2, Z3, Z6PC357SMD41U7PL521-1SMD42U8, UFTL431AIDBZRSOT231Z4TL432AIDBZRSOT231Z1TRANS1DJKQL21L5VIPER22ADIP81U12XH-2.54-4PIN4PL1JP1Φ3发光二极管(绿色)LED1LED1 PCB 和原理图等整套资料
资料列表
充电桩\\老国标\\电动汽车非车载充电机技术规范.pdf
充电桩\\规格书\\ACPL-M_datasheet.pdf
充电桩\\规格书\\IMP706SESA 规格书.pdf
充电桩\\规格书\\MAX13487EESA规格书.pdf
充电桩\\规格书\\max485.docx
充电桩\\规格书\\MAX485ESA规格书.pdf
充电桩\\规格书\\MC74HC1G08DFT1G规格书.pdf
充电桩\\规格书\\MC74HC595ADR2规格书.pdf
充电桩\\规格书\\MC74VH_datasheet.pdf
充电桩\\规格书\\充电模块
充电桩\\规格书\\光耦参数的理解.pdf
充电桩\\规格书\\发卡软件
充电桩\\规格书\\显示屏
充电桩\\规格书\\电表
充电桩\\规格书\\电阻屏驱动
充电桩\\规格书\\网卡
充电桩\\规格书\\语音模块
充电桩\\规格书\\充电模块\\UR50030-T-V、UR75020-T-V充电模块产品使用说明书1114.pdf
充电桩\\规格书\\发卡软件\\充电桩卡片使用说明.pdf
充电桩\\规格书\\发卡软件\\充电桩发卡软件.exe
充电桩\\规格书\\发卡软件\\充电桩发卡软件使用说明.pdf
充电桩\\规格书\\发卡软件\\充电桩运行库及接口说明.rar
充电桩\\规格书\\显示屏\\显示屏DMT80480T070-15WT.pdf
充电桩\\规格书\\显示屏\\显示屏XG070YI-B3_S数据手册150610.pdf
充电桩\\规格书\\显示屏\\显示屏编写
充电桩\\规格书\\显示屏\\显示屏编写\\DWIN_SET (30K)(1).zip
充电桩\\规格书\\显示屏\\显示屏编写\\DWIN_SET60k.rar
充电桩\\规格书\\显示屏\\显示屏编写\\DWIN_SET直流60K~180K.zip
充电桩\\规格书\\电表\\30KW~60KW(交流计费)DTSD3366D-0-W1三相四线_S1201802_脉冲新接法13.12.pdf
充电桩\\规格书\\电表\\60KW~180KW(直流计费)XH-AUM交流电压表使用说明书V1.0 (1).doc
充电桩\\规格书\\电表\\60KW~180KW(直流计费)DCM3366直流电能表说明书750V.pdf
充电桩\\规格书\\电表\\DCM3366型直流电表DLT645-1997通信协议V1.01.pdf
充电桩\\规格书\\电表\\DCM3366型通讯协议(直流计量 Modbus协议)V1.0.pdf
充电桩\\规格书\\电表\\DTSD3366D-0-W1 modbus通讯 协议V1.4.pdf
充电桩\\规格书\\电表\\DTSD3366D-0-W1型三相智能表DLT645-2007通讯协议V1.0.pdf
充电桩\\规格书\\电表\\XH-AUM交流电压表规格书.pdf
充电桩\\规格书\\电表\\电能表集成读写系统.zip
充电桩\\规格书\\电阻屏驱动\\电阻屏XPT2046用户手册.pdf
充电桩\\规格书\\网卡\\W5500EVB底板原理图.pdf
充电桩\\规格书\\网卡\\W5500数据手册V1.3.pdf
充电桩\\规格书\\网卡\\W5500独立变压器参考电路图.pdf
充电桩\\规格书\\网卡\\W5500相关文档.zip
充电桩\\规格书\\网卡\\W5500集成变压器参考电路图.pdf
充电桩\\规格书\\网卡\\Wiznet_W5500规格书.pdf
充电桩\\规格书\\语音模块\\19种语言合成软件.rar
充电桩\\规格书\\语音模块\\588应用资料.rar
充电桩\\规格书\\语音模块\\MP3转换器.rar
充电桩\\规格书\\语音模块\\WT588D使用资料集.zip
回复可见
**** Hidden Message ***** 好牛叉的板子! 好好学习一下!!! 好好学习一下!!! 学习,学习一下 不错的
