Loongson 2H(龙芯2H)主板PCB原理图共享(RTL8211E-VB-CG+AU6331)
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBAT_CON1CONN BATTERY2-PIN_0_BATC2-20_HHOLDER BATBATC2-20BIOS1SST25VF016B-50-4C-S2AF_0_DIP8_3SPI SOCKET DIP8_300DIP8_300BIOS2SPIBIOS_SO8_50_208_MX25L8006EPMX25L8006EPI-12GSO8_50_208BZ1BUZZER_BZ2-6R5-1212C_5VDCBUZZE5VDC BuzzerBZ2-6R5-1212CCN1SD/MMC_0_CON1_13_SDCARD SOCKETSD CARD SOCKET 11 pinCON1_13COM1CONNRJ45-8S-S_0_RJ45-8S-S-JACKAJ-068SH-8-F-R4-B4-N4RJ45-8S-S-JACKCON2SOCKET_DDR3_SODIMM_VERT_0_DDR3_DDR3_SO-DIMM_SOCKET_1.5VDDR3_204_STD_5D2CON7CON3_HD_1X3P_100_LF3_DIP1X3-2.5DIP1X3-2.54HD_1X3P_100_LF3CON8D_SUB_18P_4HOLD_DUAL_COM_D_SUB_D_SUB_18P_4HOLDDUAL_COMCON11CON5X2_2_EJTAG_2X7_EJTAGEJTAGEJTAG_2X7CON12BOX_HEAD_2X10P_SUYIN_DIP2X10_2DBOX_HEAD_2X10PDIP2X10_2D54_HD1BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D2DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3D3BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D4DIODE LED_LED0805_LED0805 GREELED 0805 GREENLED0805D5DIODE LED_LED0805_LED0805 GREELED 0805 GREENLED0805D6BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D7BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D8BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D9DIODE_SCHOTTKY_2PIN_SOD323_X_RBx_RB751V-40,NCSOD323D10BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D11BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D12DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3D13BAT54S_1_SOT23-3_BAT54SBAT54SSOT23-3D14BAT54AW_SOT23-3_BAT54AWBAT54AWSOT23-3D15BAT54S_1_SOT23-3_BAT54SBAT54SSOT23-3FB1FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB2MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805FB3MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805FB4MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805FB5MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805FB6FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB7FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB8FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB9FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB10BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805FB11FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB12BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805FB13BEAD_FB0805_X_FB80@100MHZ 3Ax_FB 80@100MHZ 3AFB0805FB14FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB15FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB16FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB17BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805FB18FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB19FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB20BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805FB48FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB49FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB50FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB51FB_FB0603_X_(FB)600OHM/100MHZ-1x_(FB)600OHM/100MHz-1.5AFB0603FB52FERRITEBEAD_2_FB0805_X_FB 80@1x_FB 80@100MHZ 3AFB0805FB53FERRITEBEAD_2_FB0805_X_FB 80@1x_FB 80@100MHZ 3AFB0805FB54FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB55FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB56FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB57FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB58FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB59FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB60FB_FB0603_X_(FB)600OHM/100MHZ-1x_(FB)600OHM/100MHz-1.5AFB0603FB63FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB64FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB65FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB66FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB67FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB68FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB69FB_FB0603_(FB)600OHM/100MHZ-1.5(FB)600OHM/100MHz-1.5AFB0603FB70BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB71BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB72BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB73BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB74BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB75BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB76BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB77BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB78BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB79BEAD_FB0603_(FB)600OHM/100MHZ-1(FB)600OHM/100MHz-1.5AFB0603FB80INDUCTOR_H_FB0805_FB80@100MHZFB 80@100MHZ 3AFB0805FB81FERRITEBEAD_2_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB86FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB87FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB88FERRITEBEAD_1_FB0805_FB 80@100FB 80@100MHZ 3AFB0805FB89MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805FB90MAG FERRITEBEAD_FB0805_FB 80@1FB 80@100MHZ 3AFB0805H1HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STARH2HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STARH3HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STARH4HOLE_1_HOLE138-339-8STAR_HOLEHOLEHOLE138-339-8STARID1MARKOPTICS-1_0_MARKC_MARKMARKMARKCID2MARKOPTICS-1_0_MARKC_MARKMARKMARKCID3MARKOPTICS-1_0_MARKC_MARKMARKMARKCID4MARKOPTICS-1_0_MARKC_MARKMARKMARKCID5MARKOPTICS-1_0_MARKC_MARKMARKMARKCID6MARKOPTICS-1_0_MARKC_MARKMARKMARKCJ1MINIPCIE_0_MPCI52-F_MINIPCIE 5MINI PCIE 52PINHIGH7.0MMMPCI52-FJK1CON_AUDIO-PHONO-X2_0_AUDIO_2_STSTACKED_AUDIO_JACKAUDIO_2JP1HEADER20X2_1_DIP2X20_2D_H_HEADHEADER 20X2DIP2X20_2D_HL7L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603L8L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603L9L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603L10L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603L11L_IND_MS0603_(PL)MS0603-6R8MB(PL)MS0603-6R8MBIND_MS0603LED1LED_0_LED0805_LED0805 GREENLED 0805 GREENLED0805LED2LED_0_LED0805_LED0805 GREENLED 0805 GREENLED0805LED3LED_DUAL_BICOLOR_3_LED-4P_21PCT21PCT120TG4-140LED-4PLED4LED_DUAL_BICOLOR_3_LED-4P_21PCT21PCT120TG4-140LED-4PLED5LED_LED0805_LED 0805GREENLED 0805 GREENLED0805MINIPCIE1CONN PCIE MINICARD_0_MPCI52-F_MINI PCIE 52PINHIGH7.0MMMPCI52-FMINIPCIE2CONN PCIE MINICARD_0_MPCI52-F_MINI PCIE 52PINHIGH7.0MMMPCI52-FPCIEX1PCIEX16_1_PCIESLOT_164_PCIE164PCIE164PCIESLOT_164PD1DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3PD2DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3PD3DUAL_DIODE_3CATHODE_SOT23-3_BATBAT54CWSOT23-3PL1BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL2BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL3BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL4INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603PL5BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805PL6BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805PL7BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL8BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL9BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL10BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805PL11BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805PL12INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603PL13BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL14BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL15BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL16BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL17BEAD_FB0805_DISCRETE_FB80@100MFB 80@100MHZ 3AFB0805PL18INDUCTOR_IND_MS0603_MS0603-1R0MMS0603-1R0MB/11AIND_MS0603PL19BEAD_FB0805_FB80@100MHZ 3AFB 80@100MHZ 3AFB0805POC1C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603POC2C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603POC3C_C0603_DISCRETE_4700PF/50V4700PF/50VC0603POR1R_R0805_DISCRETE_1,5%1,5%R0805POR2R_R0805_DISCRETE_1,5%1,5%R0805POR3R_R0805_DISCRETE_1,5%1,5%R0805POR4R_R0805_DISCRETE_1,5%1,5%R0805PQ1NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3PQ2NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3PQ3PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669PQ4PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ5PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669PQ6PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ7NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3PQ8NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3PQ9PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ10PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ11PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ12NPN_SOT23_SOT23-3_DISCRETE_PMBTPMBT3904SOT23-3PQ13PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ14PH8230E_MB_SOT669_DISCRETE_AO_1AON6414ALMB_SOT669PQ15PH8230E_MB_SOT669_DISCRETE_AON6AON6788MB_SOT669PQ16NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3PQ17NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3PU2SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PADPU3RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150PU4RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150PU5SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PADPU6SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PADPU7SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PADPU8SOIC_8P_50_197X237_PAD(IC)MP2307DN_LF_ZSOIC_8P_50_197X237_PADPU9RT9214A_SOP8-50-150_IC_RT8105GSRT8105GSSOP8-50-150PWR1CONNDC-JACK_1_CONN_PWR_MSTDC00CONN DC-JACKCONN_PWR_MSTDC00520PWR_HDD1HDD POWER CONNECTOR1X4_PWC4-204P 5.08mmPWC4-200TM-HDDQ1N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q2N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q3N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q4N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q5N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q6N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q7N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q8N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q9N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q10N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q11SMD_NDS7002A_SOT23-GDSAP2306GNSOT23-3Q12SMD_NDS7002A_SOT23-GDSAP2306GNSOT23-3Q13N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q14MOSFET_P-CH_GENERIC_S08_SOIC_8PME4435SOIC_8P_50_197X236Q15N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q16N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q17N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q18N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q19NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q20N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q21N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q22N_MOS_SOT23_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q232020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q24NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q25RT9173_8P_SOP8-50-150_RT9173GSRT9173GSSOP8-50-150Q262020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q27NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q282020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q29NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q302020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q31NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q322020010700_0_SOT23-3_NDS2N7002ANDS2N7002ASOT23-3Q33NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3Q34NPN_SOT23_SOT23-3_PMBT3904PMBT3904SOT23-3SATA1CONNSATA_0_SATA7-TF_SATA 1X7SATA 1X7SATA7-TFSIM_CON19346_0_SIM_6P_100_2HOLD_HAMBURGSIM_SLOTSIM_6P_100_2HOLD_HAMBURGSP2SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP3SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP4SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP5SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP6SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP7SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP8SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP9SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP10SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP11SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP12SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP13SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP14SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSP15SHORTPAD_0_SHORT_PAD_X_SHORT Px_SHORT PADSHORT_PADSW1SW4PIN_SW_P2P_RESET_BUTTONRESET_BUTTONSW_P2PSW2SW4PIN_SW_P2P_RESET_BUTTONRESET_BUTTONSW_P2PSYS_FANCPU_FAN_1_H1X3_FAN_FAN1X3/WHITEFAN1x3/WhiteH1X3_FANU1LOONGSON2H_LS2H_BGA_(S1+S2+S3+Loongson 2HLS2H_BGAU21GBITNAND_0_TSOP48-750-20_K9F1K9F1G08U0C-PCB0TSOP48-750-20U3NC7SZ08_SOT23_5_NC7SZ08NC7SZ08SOT23_5U4NC7SZ08_SOT23_5_NC7SZ08NC7SZ08SOT23_5U5PWRTPS2052BD_SOP8-50-150_TPS20TPS2052BDSOP8-50-150U6CM1293A_SOT23-6_(KW)CM1293A-04S(KW)CM1293A-04SOSOT23-6U7ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4U8PWRTPS2052BD_SOP8-50-150_TPS20TPS2052BDSOP8-50-150U9CM1293A_SOT23-6_(KW)CM1293A-04S(KW)CM1293A-04SOSOT23-6U10RTL8211D/E_QFN48_0D4_1G_RTL8211RTL8211E-VB-CGQFN48_0D4_1GU11RTL8211D/E_QFN48_0D4_1G_RTL8211RTL8211E-VB-CGQFN48_0D4_1GU12ZT2083_MSOP-10L_X_ZT2083x_ZT2083MSOP-10LU13RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8EU14RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8EU15ALC888S_GR_4_QFP_48P_20_354X354ALC888S_GRQFP_48P_20_354X354_H63U16LM78_SOP8-50-150_IC_L78L05ACD13L78L05ACD13TRSOP8-50-150U17RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8EU18MAX811_SOT143_IMP811TEUS-TIMP811TEUS-TSOT143U19MAX811_SOT143_IMP811TEUS-TIMP811TEUS-TSOT143U23TMP_0_QFPS48_0D5_1D6_AU6331AU6331QFPS48_0D5_1D6U24ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4U25ADM3202_MAX3232/SO_TSSOP16_0D65(IC)SP3232ECYTSSOP16_0D65_4D4U26D_SUB_VGA_COM_4HOLD_VGA_COM_D_SD_SUB_VGA_COM_4HOLDVGA_COMU27RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8EU28RT9018A_1_SOP8E_RT9018A-25GSPRT9018A-25GSPSOP8EUSB_RJ45_1USB_RJ45_LED_8_USB_RJ45LED_T_USUSB_RJ45_LED_8USB_RJ45LED_TUSB_RJ45_2USB_RJ45_LED_8_USB_RJ45LED_T_USUSB_RJ45_LED_8USB_RJ45LED_TV1BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V2BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V3BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V4BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V5BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V6BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3V7BAT54S_0_SOT23-3_BAT54SBAT54SSOT23-3Y1MX_CRYSTAL_1_XN8038_XNMCHCNDED-XNMCHCNDED-32.768KHzXN8038Y2CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8Y3CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8Y4CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8Y5CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8Y6CY_CRYSTAL_4_XS4_5032_0D8_XVH_1XVHEECNANF-25.0000XS4_5032_0D8Y7OSC_SMD7050_OCETGIJANF(100MHZ-SOCETGIJANF(100MHz-SMD7050)SMD7050Y9CY_CRYSTAL_4_XS4_5032_0D8_XVHEEXVHEECNANF-12.0000XS4_5032_0D8 PCB文件和原理图 ,回复可见下载。
**** Hidden Message ***** 牛X,谢谢 这跟卫星云图似的 厉害了 学习下 厉害了 学习下 厉害了学习下 老吴所出,必是精品!
