【全球首发】三星采用RK3399 方案做的平板电脑PCB文件和原
有关注CES 2017 新闻的朋友应该有听过 国产 CPU 首个被 巨头 三星采用来做 360度翻转的 平板。 当时大幅报道这是 中国芯 标志性的事件。。今天来发一个 三星采用RK3399 方案的CPU 和原理图
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT13705-001225 SM_CON3_W260H260_V3_ALTANT23705-001225 SM_CON3_W260H260_V3_ALTB5003301-001649INSTPARSA1608_IND_BW03_ALTB5023301-001649INSTPARSA1608_IND_BW03_ALTB5033301-001649INSTPARSA1608_IND_BW03_ALTB5043301-001272INSTPARSA2012_IND_P05_ALTB5053301-001272INSTPARSA2012_IND_P05_ALTB5063301-001272INSTPARSA2012_IND_P05_ALTBTC13711-008188 BATT-CONN-9P-2_ALTCD43709-001636 SM_SDCARD8M_W1380H1520_B_V3_ALTCN5033710-004018 CON2M_W420L450_DIP_ALTCN5053722-003839 EARJACK5_W770L1460_V2D150406-001649 SR1006_ESD_V6_ALTD5620404-001669 SM_DFN3M_W200H200_B_V3_ALTD5640404-001088 SOP3M_E210_L06_ALTD5650401-000132 SOP3_E240_L055_ALTD5660401-000132 SOP3_E240_L055_ALTD5670401-000132 SOP3_E240_L055_ALTD5690403-001966 SOP3_E240_L06_1_ALTD5710404-001250 SR1406_DIO_A_ALTD5720404-001250 SR1406_DIO_A_ALTD5730406-001690 SR1006_ESD_V6_ALTD5740406-001690 SR1006_ESD_V6_ALTD5750404-001250 SR1406_DIO_A_ALTD5760406-001690 SR1006_ESD_V6_ALTF14709-002266 FILT6_W160L80_ALTF24709-002266 FILT6_W160L80_ALTF32909-001307 SM_FILT_4_W160H80_C_V2_ALTF42909-001307 SM_FILT_4_W160H80_C_V2_ALTFILT52901-001642 FILT4_W100L125_V2_ALTFILT62901-001642 FILT4_W100L125_V2_ALTFILT112901-001642 FILT4_W100L125_V2_ALTFILT122901-001642 FILT4_W100L125_V2_ALTFILT132901-001599 FILT4_W100L125_V2_ALTIFC63710-004100 CON50M_W1230L410_SOC_ALTJ43711-008201 CON14M_W1340L270_HEA_ALTJ53708-002738 CON6M_W520L320_FPC_S_ALTJ63710-002822 FPC-CONN-40P-4_V2_ALTJ73708-002167 CON50M_W2920L580_FPC_ALTL13301-001649INSTPARSA1608_IND_BW03_ALTL92703-0050213.3uHIND6667_P1750_CYN_ALTL102703-0050412.2uHIND518518_P1300_MAG_ALTL112703-0050412.2uHIND518518_P1300_MAG_ALTL122703-0043974.7uHIND6667_P1750_CYN_ALTL132703-0043974.7uHIND6667_P1750_CYN_ALTL142703-0031822.2UHSR2520_IND_V2_ALTL152703-0049471.0uHSR2017_IND_SEM_ALTL162703-0049471.0uHSR2017_IND_SEM_ALTL172703-0040341.0nHSD0603_IND_V6_ALTL182703-0040341.0nHSD0603_IND_V6_ALTL192703-0040341.0nHSD0603_IND_V6_ALTL202703-0040341.0nHSD0603_IND_V6_ALTL212703-0040341.0nHSD0603_IND_V6_ALTL222703-0042892.2nHSD0603_IND_V6_ALTL232703-0050231.0uHIND6667_P1750_CYN_ALTL242703-0043991.5uHIND101101_P1950_CYN_ALTL252703-0043872.2uHIND655665_P1750_CYN_ALTL262703-0043872.2uHIND655665_P1750_CYN_ALTL272703-0043872.2uHIND655665_P1750_CYN_ALTL282703-0050231.0uHIND6667_P1750_CYN_ALTM1BA61-02876A PEM_LIMA_12_CPM2BA61-02876A PEM_LIMA_12_CPM4BA70-00611A SHIELD-CLIP-5P-1_ALTM5BA70-00611A SHIELD-CLIP-5P-1_ALTM6BA70-00611A SHIELD-CLIP-5P-1_ALTM7BA70-00611A SHIELD-CLIP-5P-1_ALTM8BA70-00611A SHIELD-CLIP-5P-1_ALTM9BA70-00611A SHIELD-CLIP-5P-1_ALTM10BA70-00611A SHIELD-CLIP-5P-1_ALTMT6MOUNTHOLE-2_2-5_0MM-2P MOUNTHOLE_2_2_5_0_4P_V3_ALTMT7MOUNTHOLE-2_2-5_0MM MOUNTHOLE_2_2_5_0MT9MOUNTHOLE-2_2-5_0MM MOUNTHOLE_2_2_5_0MT10MOUNTHOLE-2_2-5_0MM MOUNTHOLE_2_2_5_0MT12MOUNTHOLE-2_2-5_0MM MOUNTHOLE_2_2_5_0MT14MOUNTHOLE-2_2-5_0MM MOUNTHOLE_2_2_5_0OSC52801-005252 OSC4_W200L160_ALTOSC62801-005019 OSC4M_W320L250_1_ALTQ10505-001064 SOP3_E240_L055_ALTQ50505-003160 SOP3M_E210_L06_ALTQ60505-001089 SOP3M_E280_L075_ALTQ90505-003160 SOP3M_E210_L06_ALTQ110505-003160 SOP3M_E210_L06_ALTQ130505-001064 SOP3_E240_L055_ALTQ140505-001064 SOP3_E240_L055_ALTQ150505-001064 SOP3_E240_L055_ALTQ160505-001064 SOP3_E240_L055_ALTQ220505-002562 DFN8M_W300L300_H055_2_ALTQ230505-002562 DFN8M_W300L300_H055_2_ALTQ240505-002562 DFN8M_W300L300_H055_2_ALTQ250505-002562 DFN8M_W300L300_H055_2_ALTQ260505-002562 DFN8M_W300L300_H055_2_ALTQ270505-002562 DFN8M_W300L300_H055_2_ALTQ280505-002562 DFN8M_W300L300_H055_2_ALTQ290505-002562 DFN8M_W300L300_H055_2_ALTQ300505-002562 DFN8M_W300L300_H055_2_ALTQ330505-002386 SOP3M_E280_L075_ALTQ340505-002386 SOP3M_E280_L075_ALTQ360505-002386 SOP3M_E280_L075_ALTQ370505-002386 SOP3M_E280_L075_ALTQ380505-002386 SOP3M_E280_L075_ALTQ390505-002386 SOP3M_E280_L075_ALTQ400505-002386 SOP3M_E280_L075_ALTQ410505-002386 SOP3M_E280_L075_ALTQ420505-002386 SOP3M_E280_L075_ALTQ430505-002386 SOP3M_E280_L075_ALTQ440505-002386 SOP3M_E280_L075_ALTQ450505-002386 SOP3M_E280_L075_ALTQ460505-002386 SOP3M_E280_L075_ALTQ480505-002386 SOP3M_E280_L075_ALTQ490505-002386 SOP3M_E280_L075_ALTQ500505-002386 SOP3M_E280_L075_ALTQ710505-002386 SOP3M_E280_L075_ALTQ740505-002775 DFN8M_W300L300_H055_2_ALTQ760505-001064 SOP3_E240_L055_ALTQ770505-001064 SOP3_E240_L055_ALTQ790505-002386 SOP3M_E280_L075_ALTQ800505-001064 SOP3_E240_L055_ALTQ820505-002386 SOP3M_E280_L075_ALTQ830505-001883 SOP3M_E210_L06_1_ALTQ840505-001883 SOP3M_E210_L06_1_ALTQ850505-003234 SR1006_ESD_B_V4_ALTQ860505-003234 SR1006_ESD_B_V4_ALTQ870505-001064 SOP3_E240_L055_ALTSHORT5RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSHORT500RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT501RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT575RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT578RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT579RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT580RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT581RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT582RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTSHORT583RES-Z1608-SHORT-P0ohmZ1608_RES_SHORT_PADSHORT584RES-Z1608-SHORT-P0ohmZ1608_RES_SHORT_PADSHORT585RES-Z1608-SHORT-P0ohmZ1608_RES_SHORT_PADSHORT586RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSHORT587RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSHORT588RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSHORT589RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSHORT590RES-Z0603-SHORT-P0ohmZ0603_RES_SHORT_PAD_ALTSLC5013708-002933 CON30M_W3420L580_V3_ALTSLC5183708-002738 CON6M_W520L320_FPC_S_ALTTR10505-001064 SOP3_E240_L055_ALTTR30505-001064 SOP3_E240_L055_ALTTR120505-003234 SR1006_ESD_B_V4_ALTTR130505-003234 SR1006_ESD_B_V4_ALTTR5090501-000465 SOP3_E240_L055_ALTTR5100501-000465 SOP3_E240_L055_ALTTR5440505-003293 SOP3_E210_L06_ALTTR5560505-001064 SOP3_E240_L055_ALTTR5600505-002777 DFN8M_W300L300_H055_2_ALTTR5610505-002777 DFN8M_W300L300_H055_2_ALTTR5620505-002777 DFN8M_W300L300_H055_2_ALTTR5630505-002777 DFN8M_W300L300_H055_2_ALTU41202-001128 SM_DFN6M_W145H100_B_ALTU93101009-001053 SOP3_E280_L075_ALTU93121205-005419 BGA6M_W150L100_E025_L_ALTU11076RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTU11077RES-Z1005-SHORT-P0ohmZ1005_RES_SHORT_PAD_V2_ALTU11078RF-ALC5514-CGT QFN32M_W400L400_C055_ALTU110811203-006960 QFN24M_W400L400_E055_4_ALTU110821209-002332 MOD14M_W300L250_ALTU110841203-008365 DFN8M_W200L220_E045_ALTU11085RF-FUSB302B QFN14M_W250L250_E045_1_ALTU11086RF-FUSB302B QFN14M_W250L250_E045_1_ALTU11088RF-AP2552 DFN6M_W200L200_H045_4_ALTU11089RF-BD99955 QFN40M_W500L500_C055_ALTU11090RF-TPS51285 QFN20M_W300L300_C055_ALTU110911203-008352 QFN16M_W300L300_E055_3_ALTU110921203-008352 QFN16M_W300L300_E055_3_ALTU110931203-007372 DFN4MP_W100L100_3_V2_ALTU110941203-008653 QFN20M_W300L300_D055_ALTU110951203-008653 QFN20M_W300L300_D055_ALTU110961203-008653 QFN20M_W300L300_D055_ALTU110971201-003927 BGA9M_W143L134_C024_L_V2_ALTU11099RF-DA7219 BGA32M_W450L164_ST022_L_ALTU111001205-004761 DFN14M_W200L300_C05_ALTU111011205-004761 DFN14M_W200L300_C05_ALTU111021205-004761 DFN14M_W200L300_C05_ALTU11103RF-TPS65261-1RHB QFN32M_W500L500_E055_6_ALTU111041105-002731 BGA178M_W1100L1150_K028_L_V2_ALTU111051107-002418 SOP8M_E600_L1310_ALTU11108RF-RK3399-3 BGA828M_W2100L2100_H03_L_ALTU11109RF-NPCX586GA0BX BGA128M_W700L700_E0275_L_1_V3_ALTU111110801-003437 SOT-953_ALTU111120801-002628 SOP5M_E210_L066_ALTU111131203-005403 SM_DFN6M_W200H200_J_V2_ALTU111153722-004013 USB22_W916L1151_V5_ALTU111163301-001649INSTPARSA1608_IND_BW03_ALTU111262203-00727010000nFSA1608_CAP_V3_ALTU111352801-005345 OSC4_W200L160_ALTU111362203-0067070.0047nFSD0603_CAP_V6_ALTU111452203-006048100nFSB1005_CAP_V3_ALTU111462203-006048100nFSB1005_CAP_V3_ALTU111532203-00038615pFSB1005_CAP_V3_ALTU111542203-00038615pFSB1005_CAP_V3_ALTU111610406-001690 SR1006_ESD_V6_ALTU111682007-0079421MSB1005_RES_V3_ALTU111710406-001649 SR1006_ESD_V6_ALTU111720406-001633 SR2020_DIO_V2_ALTU11179RF-TMP512AIRSAR QFN16M_W400L400_H055_V2_ALTU111841003-002636 QFN12M_W170L200_C065_ALTU111851003-002636 QFN12M_W170L200_C065_ALTU11186RF-660-00196-01 BGA78M_W500L500_E0275_L_ALTU112312203-006839100NFSD0603_CAP_V6_ALTU112322203-006839100NFSD0603_CAP_V6_ALTU112332203-006839100NFSD0603_CAP_V6_ALTU112342203-006839100NFSD0603_CAP_V6_ALTU112352203-006839100NFSD0603_CAP_V6_ALTU112362203-006839100NFSD0603_CAP_V6_ALTU112402203-00727010000nFSA1608_CAP_V3_ALTU112412203-00727010000nFSA1608_CAP_V3_ALTU112422703-0052426.8uHCOIL500525_P08_CYN_ALTU112502007-008055100KSD0603_RES_V6_ALTU112511107-002373 BGA153M_W1150L1300_E03_L_1_V4_ALTU11252RF-SLG3NB3469-1 QFN16M_W200L300_C045_ALTU112532203-006839100NFSD0603_CAP_V6_ALTU11254RF-88W8997PA0-NXW2E005-P162 QFN98M_W900L900_MARVELL_ALTU11255RF-88PG823-A0-NPD2C000-P162 QFN24M_W400L400_E055_ALTU112570801-002998 SOP5M_E210_L066_ALTU11259RF-AP2552 DFN6M_W200L200_H045_4_ALTU112762007-0001710SB1005_RES_V3_ALTU112770505-003293 SOP3_E210_L06_ALTU112780505-003293 SOP3_E210_L06_ALTU112792007-0071364.7K,1%SB1005_RES_V3_ALTU112802007-0071364.7K,1%SB1005_RES_V3_ALTU112812203-006839100NFSD0603_CAP_V6_ALTU112822203-0065621000nFSB1005_CAP_V3_ALTU112831001-001975 MOD6M_W70L110_ALTU112842007-0001710SB1005_RES_V3_ALTU112850406-001690 SR1006_ESD_V6_ALTUEP5001107-002406 SOP8MP_E790_L1270_V2_ALTUME5061105-002731 BGA178M_W1100L1150_K028_L_V2_ALTZD5110406-001649 SR1006_ESD_V6_ALTZD5120406-001649 SR1006_ESD_V6_ALTZD11180406-001649 SR1006_ESD_V6_ALTZD11190406-001649 SR1006_ESD_V6_ALTZD11200406-001649 SR1006_ESD_V6_ALTZD11210406-001649 SR1006_ESD_V6_ALTZD11220406-001649 SR1006_ESD_V6_ALTZD11240403-000579 SOP3_E230_L06_ALT 刚才前面一个帖子有说了,手上的资料太多了http://bbs.ntpcb.com/read.php?tid-96008.html没时间整理来发论坛上。。
时间不够,这是没办法了。只能慢慢整理。 不过有时候有一些资料太新了,也不敢发。大家懂的。
资料来了,原理图是PDF格式。 PCB 是ALLEGRO16.6格式。不过资料太新了。RMB上,没需要的看看截图就好。
资料从朋友那里弄来的,如有侵权,请联系我,第一时间删除。
仅限用来学术交流,拿去生产的后果自负。不保证资料完整性和正确性。 Good 真实全球首发 三星也会使用rk芯片 高大上啊 可以哦
