Name | Part Type | PCB Decal | Value | C8 | CAP_NP_2 | C0402 | 0.1u | C9 | CAP_NP_2 | C0402 | 1u | C10 | CAP_NP_2 | C0402 | 0.1u | C11 | CAP_NP_2 | C0402 | 1u | C12 | CAP_NP_2 | C0402 | 0.1u | C13 | CAP_NP_2 | C0402 | 0.1u | C14 | CAP_NP_2 | C0402 | 0.1u | C15 | CAP_NP_2 | C0402 | 0.1u | C16 | CAP_NP_2 | C0402 | 0.1u | C26 | CAP_NP_2 | C0805 | C/226M/805 | C27 | CAP_NP_2 | C0603 | C/106K/603 | C28 | CAP_NP_2 | C0402 | C/104K/402 | C29 | CAP_NP_2 | C0402 | C/102K/402 | C30 | CAP_NP_2 | C0805 | 22uF | C31 | CAP_NP_2 | C0402 | C/103J/402 | C32 | CAP_NP_2 | C0402 | C/103K/402 | C123 | C_402 | C0402 | 22pF/NC | C125 | C_402 | C0402 | 22pF/NC | C126 | C_402 | C0402 | 22pF/NC | C127 | C_402 | C0603 | 1uF | C128 | C_402 | C0603 | 1uF | C129 | C_402 | C0402 | 22pF/NC | C130 | C_402 | C0402 | 22pF/NC | C131 | C_402 | C0603 | 0.1uF | C132 | C_402 | C0603 | 0.1uF | C133 | C_402 | C0402 | 22pF/NC | C134 | C_402 | C0402 | 22pF/NC | C135 | C_402 | C0402 | 22pF/NC | C136 | C_402 | C0402 | 22pF/NC | C137 | C_402 | C0603 | 1uF | C138 | C_402 | C0603 | 1uF | C139 | CAP_NP | C0603 | 1u | C140 | C_402 | C0603 | 1uF | C141 | C_402 | C0603 | 4.7uF | C142 | CAP_NP | C0603 | 1u | C143 | C_402 | C0603 | 4.7uF | C144 | C_402 | C0603 | 4.7uF | C145 | C_402 | C0603 | 4.7uF | C146 | C_402 | C0603 | 4.7uF | C147 | C_402 | C0603 | 4.7uF | C148 | 0_1UF | C0402 | 0.1uF | C149 | 0_1UF | C0402 | 0.1uF | C150 | 0_1UF | C0402 | 0.1uF | C151 | 0_1UF | C0402 | 0.1uF | C152 | C_402 | C0603 | 4.7uF | C153 | C_402 | C0603 | 2.2uF | C154 | C_402 | C0603 | 2.2uF | C155 | C_402 | C0402 | 22pF/NC | C156 | C_402 | C0402 | 22pF/NC | C157 | C_402 | C0603 | 4.7uF | C158 | 0_1UF | C0402 | 0.1uF | C159 | 0_1UF | C0402 | 0.1uF | C160 | C_402 | C0603 | 4.7uF | C161 | 0_1UF | C0402 | 0.1uF | C162 | 0_1UF | C0402 | 0.1uF | C163 | C_402 | C0603 | 2.2uF | D1 | LED_0 | LED-0805 | LED/RED | D2 | LED_0 | LED-0805 | LED/GREEN | D3 | LED_0 | LED-0805 | LED/GREEN | D4 | LED_0 | LED-0805 | LED/GREEN | J1 | BUTTON_(RST) | SW4P | Reset Button | J2 | BUTTON_(RST) | SW4P | Reset Button | J3 | BUTTON_(RST) | SW4P | Reset Button | J4 | CON2 | SIP2-2.54 | CON2 | J5 | CON2 | SIP2-2.54 | CON2 | J6 | CON6_28 | SIP4-2.54 | SIP-1X4 | J15 | CON2 | SIP2-2.54 | CON2 | J16 | CON2 | SIP2-2.54 | CON2 | J19 | CON6_2 | SIP8-2.54 | CON1x8 | J20 | CON6_3 | SIP6-2.54 | CON1x6 | J21 | CON6_1 | SIP10-2.54 | CON1x10 | J22 | CON6_2 | SIP8-2.54 | CON1x8 | J23 | CON2 | SIP2-2.54 | CON2 | J24 | HEADER_3 | SIP3-2.54 | CON2 | J25 | CON6_2_2 | SIP5-2.54 | CON1x6 | J73 | CON6_5 | CON3X2-2.54A | CON3x2 | J74 | JUMPER | SIP2-2.54 | JUMPER | J75 | JUMPER | SIP2-2.54 | JUMPER | J76 | JUMPER | SIP2-2.54 | JUMPER | J109 | CON6_28 | SIP4-2.54 | SIP-1X4 | J110 | CON6_28 | SIP4-2.54 | SIP-1X4 | JP18 | JUMPER | SIP2-2.54 | JUMPER | JP19 | HEADER_3_0 | SIP2-2.54 | GPIO1 | JP20 | HEADER_3_0 | SIP2-2.54 | GPIO1 | JP21 | 5X1PIN_1 | SIP3-2.54 | PIN1X3 | JP22 | 5X1PIN_1 | SIP3-2.54 | PIN1X3 | JP24 | 5X1PIN_4 | SIP4-2.54 | PIN1X4 | L9 | L_2 | L\3X3\NR30 | 4.7uH | L10 | INDUCTOR | L0603 | 0R | L53 | L | L1206 | BEAD(1206) | L54 | L | L1206 | BEAD(1206) | L55 | L | L1206 | BEAD(1206) | L56 | L | L1206 | BEAD(1206) | MIC1 | CON2_0 | SIP2-2.54 | CON2 | MIC2 | CON2_0 | SIP2-2.54 | CON2 | MIC3 | CON2_6 | SIP4-2.54 | CON2 | MIC4 | CON2_0 | SIP2-2.54 | CON2 | MIC5 | CON2_6 | SIP4-2.54 | CON2 | PH1 | PHONEJACK_STEREO_SW_2 | AJ351C-6B | LINE Out | PH2 | PHONEJACK_STEREO_SW_2 | AJ351C-6B | HPOUT | PH3 | PHONEJACK_STEREO_SW_2 | AJ351C-6B | LINE In | R1 | R_2 | R0402 | 0 | R2 | R_2 | R0402 | 0 | R3 | R_2 | R0402 | 0 | R4 | R_2 | R0402 | 0 | R5 | R_2 | R0402 | 0 | R6 | R_2 | R0402 | 0 | R7 | R_2 | R0402 | 0 | R8 | R_2 | R0402 | 0 | R9 | R_2 | R0402 | 0 | R10 | R_2 | R0402 | 0 | R11 | R_2 | R0402 | 0 | R12 | R_2 | R0603 | 0 | R13 | R_2 | R0603 | 0 | R14 | R_2 | R0603 | 0 | R16 | RESISTOR | R0402 | R/330R/402 | R17 | RESISTOR | R0402 | R/330R/402 | R18 | RESISTOR | R0402 | R/330R/402 | R19 | RESISTOR | R0402 | R/330R/402 | R27 | RESISTOR | R0402 | 1M | R30 | RESISTOR | R0402 | R/100K/402 | R32 | RESISTOR | R0402 | R/500K/402 | R34 | R_2 | R0603 | 10K | R35 | R_2 | R0603 | 10K | R36 | R_2 | R0603 | 10K | R223 | R_2 | R0402 | 0 | R225 | R_2 | R0402 | 0 | R226 | R_2 | R0402 | 0 | R227 | R_2 | R0603 | 200K/NC | R228 | R_2 | R0603 | 22 | R229 | R_2 | R0603 | 33 | R230 | R_2 | R0402 | 0 | R231 | R_2 | R0402 | 0 | R232 | R_2 | R0603 | 22 | R233 | R_2 | R0603 | 33 | R234 | R_2 | R0402 | 0 | R235 | R_2 | R0402 | 0 | R236 | R_2 | R0603 | 22 | R237 | R_2 | R0603 | 22 | R238 | R_2 | R0402 | 0 | R239 | R_2 | R0402 | 0 | R240 | R_2 | R0603 | 100K/NC | R241 | R_2 | R0402 | 0 | R242 | R_2 | R0402 | 10K | R243 | R_2 | R0402 | 0 | R244 | R_2 | R0402 | 10K | R245 | R | R0603 | 2.2K | R246 | R | R0603 | 2.2K | R247 | R_2 | R0402 | 0 | R248 | R_2 | R0603 | 10K | R249 | R_2 | R0402 | 0 | R250 | R | R0603 | 2.2K | R251 | R_2 | R0402 | 0 | R252 | R_2 | R0402 | 47 | R253 | R_2 | R0603 | 0 | R254 | R_2 | R0603 | 0 | R255 | R_2 | R0402 | 0 | R299 | R_2 | R0402 | 0 | R327 | R_2 | R0603 | 0 | R328 | R_2 | R0603 | 0 | R329 | R_2 | R0603 | 0 | R330 | R_2 | R0603 | 0 | R331 | R_2 | R0603 | 0 | R333 | R_2 | R0402 | 0/NC | U5 | LT1084-3_0.3 | SOT-23-5P | CAT7103 | U12 | SDRAM_8M_4 | QFN40-0505-.4-H.9-E3.7 | ALC5651 |
