TA的每日心情 | 开心 2024-7-10 20:37 |
签到天数: 1 天 [LV.1]初来乍到
- 21119
Name | PCB Decal | Part Type | D301 | SMD0603_LED | SMD0603_LED | D302 | EHP-C04/NT01A-P01/TR | EHP-C04/NT01A-P01/TR | H1 | HOLE4.2MM | HOLE4.2MM | H2 | HOLE4.2MM | HOLE4.2MM | H3 | HOLE4.2MM | HOLE4.2MM | H4 | HOLE4.2MM | HOLE4.2MM | J101 | AXK6S00547YG | AXK6S00547YG | J102 | AXK6S00547YG | AXK6S00547YG | J201 | C88P132-01001AH-4PAD | C88P132-01001AH-4PAD | J202 | C88P132-01001AH-4PAD | C88P132-01001AH-4PAD | J203 | C88P132-01001AH-4PAD | C88P132-01001AH-4PAD | J204 | MJ1102-C | MJ1102-C | J205 | MJ1102-C | MJ1102-C | J206 | MJ1102-C | MJ1102-C | J207 | C88P132-01001AH-4PAD | C88P132-01001AH-4PAD | J208 | MJ1102-C | MJ1102-C | J209 | C88P132-01001AH-4PAD | C88P132-01001AH-4PAD | J210 | MJ1102-C | MJ1102-C | J301 | ECF052030X-L | ECF052030X-L | J302 | GS-31LC | GS-31LC | T101 | TVS/SOD-923 | TVS/SOD-923 | T301 | TVS/SOD-923 | TVS/SOD-923 | U101 | SLM757-EVB-238P | SLM757-EVB-238P |
底板
Name | PCB Decal | Value | Part Type | D201 | EMD2 | RB520S-30 | RB520S-30 | D202 | EDZ5.6B/SOD-323 | | EDZ5.6B/SOD-323 | D203 | MH-S3020UBC-T | | MH-S3020UBC-T | D503 | MH-S3020UBC-T | | MH-S3020UBC-T | D801 | PSBD551V-30 | | PSBD551V-30 | GB201 | XH311HG-IV07ESPEC | XH311HG-IV07ESPEC | XH311HG-IV07ESPEC | J101 | AXK5S00047YG | | AXK5S00047YG | J102 | AXK5S00047YG | | AXK5S00047YG | J103 | DIP-CON20 | | DIP-CON20A | J104 | DIP-CON20 | | DIP-CON20A | J105 | DIP-CON20 | | DIP-CON20A | J106 | ISS-12D07 | | ISS-12D07 | J201 | ISS-12D07 | | ISS-12D07 | J202 | DC-02-OD2 | | DC-02-OD2 | J204 | MUP-CM614 | | MUP-CM614 | J205 | C720-2 | | C720-2 | J206 | TESTD_2MM | | TESTD_2MM | J207 | C720-2 | | C720-2 | J208 | TESTD_2MM | | TESTD_2MM | J209 | TESTD_2MM | | TESTD_2MM | J210 | TESTD_2MM | | TESTD_2MM | J211 | XH-NA | | XH-NA | J212 | GS-31LC | | GS-31LC | J302 | 3F32-3/WKUBI005-011P | | 3F32-3/WKUBI005-011P | J303 | RJ11-EVB | | RJ11-EVB | J304 | SPKA | | SPKA | J305 | PAD-MF01 | | PAD-MF01 | J306 | PAD-MF01 | | PAD-MF01 | J307 | PAD-MF01 | | PAD-MF01 | J309 | PAD-MF01 | | PAD-MF01 | J310 | PAD-MF01 | | PAD-MF01 | J311 | PAD-MF01 | | PAD-MF01 | J312 | SPK-A | | SPK-A | J313 | PAD-MF01F | | PAD-MF01 | J314 | PAD-MF01F | | PAD-MF01 | J401 | IUSJ-R0462-S-Y02T | | IUSJ-R0462-S-Y02T | J402 | UAF95-05254-S13802-A | | UAF95-05254-S13802-A | J403 | ISS-12D07 | | ISS-12D07 | J404 | IUSJ-R0462-S-Y02T | | IUSJ-R0462-S-Y02T | J405 | IUSJ-R0462-S-Y02T | | IUSJ-R0462-S-Y02T | J601 | HSF6223-09FEMALE | | HSF6223-09FEMALE | J602 | HSF6223-09FEMALE | | HSF6223-09FEMALE | J801 | ECF052030X-L | | ECF052030X-L | J802 | ECF052030X-L | | ECF052030X-L | J901 | ZIF-25PIN-MIRROR-0.6 | | ZIF-25PIN-MIRROR-0.6 | J902 | ZIF-25PIN-MIRROR-0.6 | | ZIF-25PIN-MIRROR-0.6 | J903 | OK-10F024-04 | | OK-10F024-04 | J904 | AXE130047D | | AXE130047D | K301 | 1102S | | 1102S | K302 | 1102S | | 1102S | K303 | 1102S | | 1102S | K304 | 1102S | | 1102S | K305 | 1102S | | 1102S | L201 | LVS252012 | 2.2uH | LVS252012 | L801 | LVS303010-220M-N | 22uH | LVS303010-220M-N | MIC1 | ROM40T15 | | ROM40T15 | MIC602 | ROM40T15AA | | ROM40T15 | Q401 | EMT3 | | DTC123JETL | T802 | TVS/SOD-923 | | TVS/SOD-923 | U201 | AW3632 | AW3632 | AW3632 | U202 | SPX29302T5-263 | | SPX29302T5-263 | U203 | ETA6003 | | ETA6003 | U301 | AW8733 | | AW8733 | U401 | WAS7220Q | | WAS7222Q | U402 | GL852-LQFP-48 | | GL852-LQFP-48 | U501 | AK09911 | | AK09911 | U502 | KXTJ2-1009&BMA250B | | KXTJ2-1009&BMA250B | U503 | EPL2182-V1.0 | | EPL2182-V1.0 | U504 | AW2013 | NC | AW2013 | U601 | SP3238E-SSOP | | SP3238E-SSOP | U602 | UM3204H | | UM3204H | U603 | UM3204H | | UM3204H | U604 | UM3204H | | UM3204H | U701 | SOT23-5 | | SMG2007 | U702 | SOT23-5 | | SMG2007 | U703 | SOT23-5 | | SMG2007 | U704 | SOT23-5 | | SMG2007 | U801 | ICN6202 | | ICN6202 | U802 | TSOT23-6 | KTD252 | KTD253 | X401 | 7V12000011 | | 7V12000011 | X801 | TCXO/SMD/2.5X2.0/IT2205BE | RAKON/IT2205BE/26MHz | TCXO_RAKON_SMD_4P |
