查看: 3346|回复: 14
[Allegro16.6以下] 几个MTK6572底板PCB和原理图
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2017-12-16 17:25:45 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    CN1BATT_CONN_3PIN_1_VT-SWITCH_SKHHSKHHLUA010VT-SWITCH
    CN2CON_USB_7P_SOCKET2_0_HY07-AB070HY07-AB0700HY07-AB0700-A1
    CN5BATT_CONN_3PIN_1_VT-SWITCH_SKHHSKHHLUA010VT-SWITCH
    CN6BATT_CONN_3PIN_1_VT-SWITCH_SKHHSKHHLUA010VT-SWITCH
    CN7USB-B_USB-B_USB-Busb-bUSB-B
    CN8USB-B_USB-B_USB-Busb-bUSB-B
    CN9USB-B_USB-B_USB-Busb-bUSB-B
    D1LEDA_4PIN_LED0605_BL-HJEGKBE36TBL-HJEGKBE36T-TRBLED0605
    D1101WSB5819W-2TR_WSB5819_WSB5819WSB5819WSB5819
    D1102WSB5819W-2TR_WSB5819_SS34SS34WSB5819
    ESD1DIODE TVSBI-DIR_SLP1006P2_PESDPESD5V0S1BLDSLP1006P2
    J2HYX-TF008011019_0_SD_473521001_473521001SD_473521001
    J75_2.0QHD_LCM_FH26-25S-0_3SHW_5.5.0QHD_LCMFH26-25S-0_3SHW
    J85_0.0QGD_TP_CONN_ZIF_6P_05MM_DO5.0QGD_TPCONN_ZIF_6P_05MM_DOWN
    J1202PJ-393_PJ-393_PJ-393PJ-393PJ-393
    J1203BT032Q-034BP_FH26-45S-0_3SHW_BTBT032Q-034BP(NC)FH26-45S-0_3SHW
    J1204XRM144A2315_XRM144A2315_XRM144AXRM144A2315(NC)XRM144A2315
    J1205RGB/MCU_2MM_25X2_RGB/MCUPINRGB/MCU PIN2MM_25X2
    JF001CON,RF,C89P109-1000X-H_5_RF_CABC89P109-1000X-HRF_CABLE_CON_2M0X1M7_C89P109
    L1BEAD_L0402_120R(NC)120R(NC)L0402
    L2BEAD_L0402_120R(NC)120R(NC)L0402
    L5BEAD_R0402_120R120RR0402
    L6BEAD_R0402_120R120RR0402
    L8BEAD_R0402_120R120RR0402
    L10IND_P_L0402_NC(OR1NH)NC(or1nH)L0402
    L11IND_L0402_6.8NH6.8nHL0402
    L12IND_L0402_100NH100nHL0402
    L13IND_L0402_82NH82nHL0402
    L14IND_NC_L0402NC_NCNCL0402NC
    L15IND_L0402_10NH/LQG15HN10NJ0210nH/LQG15HN10NJ02L0402
    L16IND_L0402_27NH/LQG15HN10NJ0227nH/LQG15HN10NJ02L0402
    L1102INDUCTOR_POWER_LPS3015_3.3UH/6A3.3uH/6ALPS3015
    LP1101INDUCTOR_POWER_LPS3015_22UH22uHLPS3015
    MIC1MICROPHONE_2_MICROPHONE_BOM6015BOM6015EP1.8-G423-RC-R6818MICROPHONE
    P2ENS000046760_GPSWIFI_ANT_ENS000ENS000046760GPSWIFI_ANT
    P5CAM_CM9080_LED_AXE624124_CAM_CMCAM_CM9080AXE624124
    P7POWER_DC-005-5_5X2_POWERpowerDC-005-5_5X2
    P8P3_DIP-3_P3P3DIP-3
    P9MIPI_2MM_15X2_MIPIPINMIPI PIN2MM_15X2
    P10P4_DIP-4_I2CI2CDIP-4
    P11P4_DIP-4_IOIODIP-4
    P12P6_DIP-6_SPISPIDIP-6
    REC502REC / 2403 260 00031_CON2_3M5XRECEIVERCON2_3M5X7M5_3M94
    RF1GPS_ANT_U_FL-R-SMT-1_GPS_ANTGPS_ANTU_FL-R-SMT-1
    SCREW5SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SCREW6SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SCREW7SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SCREW8SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SCREW9SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SCREW10SCEW_HOLE_HOLE_C158D110_C4MM_H2C4mm_H2.8mmHOLE_C158D110
    SH1SHUNT_R0402_SHUNT_L4-SIG_PWR_P4SHUNT_L4-SIG_PWR_P4XP6R0402
    SPK501MIC_1_DF13C-2P-1P25V_DF13C-2P-1DF13C-2P-1.25VDF13C-2P-1P25V
    U1112CP2123ST-A1_SOT-23-6_CP2123ST-ACP2123ST-A1SOT-23-6
    U1508G9091-330T11U_SOT-23-5_G9091-33G9091-330T11USOT-23-5
    U2107MT6572-DOU-DEV_MT72_MODULE_SMT_MT6572-DOU-DEVMT72_MODULE_SMT_DOU
    U2108AW8110CSR_BGA9_1M5X1M5_P05M_AW8AW8110CSR(NC)BGA9_1M5X1M5_P05M
    U2109SIM_2_TSP-6P-18T_TSP-6P-18TTSP-6P-18TTSP-6P-18T
    U2111MAX2659_UDFN6_1M5X1_P05M_MAX265MAX2659ELT+UDFN6_1M5X1_P05M
    U2113KXTE9-1050_LGA10_3X3M_P065M_KXTKXTE9-1050LGA10_3X3M_P065M
    U2114SIM_2_TSP-6P-18T_TSP-6P-18TTSP-6P-18TTSP-6P-18T
    U2115RCLAMP0504FA_RCLAMP0504FA_RCLAMrclamp0504faRCLAMP0504FA
    U2117MIC29302BU_TO-220_MIC29302BUMIC29302BUTO-220
    U2118SMF05C_SMF05C_SMF05CSMF05CSMF05C
    U2119SMF05C_SMF05C_SMF05CSMF05CSMF05C
    U2120LT0308H111_LT0308H111_LT0308H11LT0308H111LT0308H111
    U2121NL27WZ07_07_TSOP-6_NL27WZ07_07NL27WZ07_07TSOP-6
    U2122NL27WZ07_07_TSOP-6_NL27WZ07_07NL27WZ07_07TSOP-6
    U2123CH1002_SOT23-6_CH1002CH1002SOT23-6
    UE001IC-ECOMPASS-AK8963C_BGA14_1M6X1AK8963CBGA14_1M6X1M6_P04M
    UE002IC-PRO LIGHTSENSOR-STK3171-018STK3171-018DFN8_3M94X2M36_P097M
    V9003VDR 0402 14V 10PF+/-30%_3_R040SDV1005H140C100NPTFR0402
    Z1MOTO_3P_CE_RENESAS_VIB_ALT_GS-3GS-3200CE_RENESAS_VIB_ALT
    Z2SAWA_5PIN_1A4B235G_RFSAW_5P_1M4SAFEB1G57KE0F00RFSAW_5P_1M4X1M1_P05M
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2017-12-16 17:26:11 | 显示全部楼层
    都一起打包.7z (3.03 MB, 下载次数: 15)
    发表于 2017-12-16 19:16:02 | 显示全部楼层
    发表于 2017-12-16 21:11:04 | 显示全部楼层
    终身成就奖社区居民优秀斑竹奖
    发表于 2017-12-16 21:23:14 | 显示全部楼层
    谢谢分享MTK6572底板PCB和原理图
    发表于 2017-12-17 11:03:12 | 显示全部楼层
    还是核心板技术含量高一些
    发表于 2017-12-17 11:08:26 | 显示全部楼层
    前天 18:40
  • 签到天数: 91 天
    终身成就奖社区居民
    发表于 2017-12-18 08:03:24 | 显示全部楼层
    又是个开发板的图里面抠的吧
    社区居民终身成就奖优秀斑竹奖社区明星宣传大使奖特殊贡献奖原创先锋奖
    发表于 2017-12-18 08:39:22 | 显示全部楼层
    发表于 2017-12-18 08:43:37 | 显示全部楼层
