查看: 9311|回复: 42
[Allegro16.6以下] 三星S5PC220 POP封装 8层盲埋孔 PCB文件共享
此广告位出租
发表于 2017-12-26 14:20:10 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BT1BATTERY_MS412FE_MS412FE-FL26EMS412FE-FL26EMS412FE
D1DIODETVS_SOD-523_UCLAMP1201HuClamp1201HSOD-523
D2DIODETVS_SOD-523_UCLAMP1201HuClamp1201HSOD-523
D3LED_R0402_LEDLEDR0402
D4LED_R0402_LEDLEDR0402
D5DIODETVS_SOD-523_UCLAMP1201HuClamp1201HSOD-523
D6DIODESCHOTTKY_0_SB07-03C_SB07-SB07-03CSB07-03C
D7ZC2812E/SOT_0_SOT323_DAN217UDAN217USOT323
D8ZC2812E/SOT_1_SOT323_DAN217UDAN217USOT323
D9DIODESCHOTTKY_SOD-323_UDZ5.6BUDZ5.6BSOD-323
D10DIODESCHOTTKY_0_SB07-03C_SB07-SB07-03CSB07-03C
D11ZC2812E/SOT_2_SOT323_DAN217UDAN217USOT323
D12ZC2812E/SOT_3_SOT323_DAN217UDAN217USOT323
D13DIODESCHOTTKY_SOD-323_UDZ5.6BUDZ5.6BSOD-323
D15DIODETVS_RCLAMP2431T_UCLAMP050UCLAMP0501TRCLAMP2431T
D16LED_3_LTPL-C064WD_LTPL-C064WDLTPL-C064WDLTPL-C064WD
D17DIODETVS_RCLAMP2431T_UCLAMP050UCLAMP0501TRCLAMP2431T
D18DIODETVS_RCLAMP2431T_UCLAMP050UCLAMP0501TRCLAMP2431T
D19DIODETVS_RCLAMP2431T_UCLAMP050UCLAMP0501TRCLAMP2431T
D20DIODESCHOTTKY_0_SB07-03C_SB07-SB07-03CSB07-03C
E1ANTENNA_GPS_ANT-GPS_GPS1003GPS1003ANT-GPS
E2ANTENNA_WIFI_ANT-PF_PF1004PF1004ANT-PF
E3ANTENNA_GSM_GSM2804_GSM2804GSM2804GSM2804
FB7TCM1210_TCM1210_TCM1210TCM1210TCM1210
FC1CAP NP_C0402_0R0RC0402
J1CON3_PAD-3_CON3CON3PAD-3
J2DC_0_DCJ-065D_DCJ-065DDCJ-065DDCJ-065D
J5GB5RF40*-1151-7H_FH19SC-40S-05SFP09-04403-XXXFH19SC-40S-05SH
J6CON9_FH19C-09S-05SH_FPC0515-09-FPC0515-09-RL-XXXFH19C-09S-05SH
J7CONN_MHDMI_19P_HDMI-19P_IO_00910091BAAG19QHDMI-19P
J8CONN_TF_TFCARD_TOPP-150108-05GTOPP-150108-05GTFCARD
J9PHONEJACK STEREOSW_J135_J135-1J135-140206-09GJ135
J10CON2_PAD-2_CON2CON2PAD-2
J11CON2_PAD-2_CON2CON2PAD-2
J12CON24_FPC0515-24-RL-XXX_FPC0515FPC0515-24-RL-XXXFPC0515-24-RL-XXX
J13CONN-MICROUSB_USB-MICRO_MR0F-17MR0F-170205-04GUSB-MICRO
J14CON2_PAD-2_CON2CON2PAD-2
J15CONN24_AXK824145_AXK724147Gaxk724147gAXK824145
J16SIM CARD_SIMCARD_SIMCARDSIM CARDSIMCARD
J17CON9_0_FH19C-07S-05SH_FPC0515-0FPC0515-07-RL-XXXFH19C-07S-05SH
L1INDUCTOR_CIG21L_CIG21L4R7MNECIG21L4R7MNECIG21L
L2INDUCTOR_LQM2MPN_LQM2MPN1R0NG0LQM2MPN1R0NG0LQM2MPN
L8INDUCTOR_CIG22L_CIG22H1R0MNECIG22H1R0MNECIG22L
L15INDUCTOR_LQH44PN_LQH44PN100MP0LQH44PN100MP0LQH44PN
L16INDUCTOR_R0402_BLM15AG221SN1DBLM15AG221SN1DR0402
L17INDUCTOR_R0402_100UH100UHR0402
L18INDUCTOR_R0402_100UH100UHR0402
L19INDUCTOR_R0402_100UH100UHR0402
L20INDUCTOR_BEAD0402_BLM15AG221SN1BLM15AG221SN1DBEAD0402
L21INDUCTOR_R0402_5.6NH5.6NHR0402
L22INDUCTOR_BEAD0402_BLM15AG221SN1BLM15AG221SN1DBEAD0402
L23INDUCTOR_R0402_3.3NH3.3NHR0402
L24INDUCTOR_R0402_100NH100NHR0402
L25INDUCTOR_BEAD0402_BLM15AG221SN1BLM15AG221SN1DBEAD0402
Q1PDTC114YE_SOT416_PDTC114YEPDTC114YESOT416
Q2PNP_SC-75_IC_2PA17742PA1774SC-75
Q3DTC114EET1_SC-75_DTC114EET1GDTC114EET1GSC-75
Q4DUALMOSFET_SOT-363_NTJD4105CT1NTJD4105CT1GSOT-363
Q7NPN_SC-59_IC_MMST3906MMST3906SC-59
Q8MOSFETN_0_SOT23_MOSFET NMOSFET NSOT23
Q9NPN_SC-59_IC_MMST3906MMST3906SC-59
Q10PDTC114YE_SOT416_PDTC114YEPDTC114YESOT416
Q11PDTC114YE_SOT416_PDTC114YEPDTC114YESOT416
Q12NPN_0_SC-75_IC_PBSS2515EPBSS2515ESC-75
Q13PDTC114YE_SOT416_PDTC114YEPDTC114YESOT416
Q14MOSFETP_0_SC-75_NTA4151PNTA4151PSC-75
Q15PDTC114YE_SOT416_PDTC114YEPDTC114YESOT416
Q16MOSFETP_1_SC-75_NTA4151PNTA4151PSC-75
Q24NPNEBC_SC-59_MMST3904MMST3904SC-59
Q25NPNEBC_SC-59_MMST3904MMST3904SC-59
U1S5PC220_S5PC220_S5PC220S5PC220S5PC220
U2ST2329AQTR_QFN10_1_8X1_4_ST2329ST2329AQTRQFN10_1_8X1_4
U3SGM6600_SOT23-6_0_95MM_SGM6603-SGM6603-5.0YN6G/TRSOT23-6_0_95MM
U4S5M8767A_S5M8767_S5M8767S5M8767S5M8767
U5MAX8903AETI_QFN28_4X4_MAX8903AEMAX8903AETIQFN28_4X4
U6MAX17040_MAX17040_MAX17040MAX17040MAX17040
U7FXLA102_FXMA2102_FXLA102FXLA102FXMA2102
U8UNA MODULE-OPENFRAME_LGA104_30UNA Module-open frameLGA104_30_39X17_56MM
U9FXLA102_FXMA2102_FXLA102FXLA102FXMA2102
U10FXLA102_FXMA2102_FXLA102FXLA102FXMA2102
U11FXLA102_FXMA2102_FXLA102FXLA102FXMA2102
U13RCLAMP3304P_RCLAMP3304P_RCLAMP3rclamp3304pRCLAMP3304P
U14SN75LVDS83BZQLR_SN75LVDS83BZQLRSN75LVDS83BZQLRSN75LVDS83BZQLR
U15RCLAMP0544T_SLP2010P8T_RCLAMP05RCLAMP0544TSLP2010P8T
U16FP6745_SOT23-6_0_95MM_FP6745S8GFP6745S8GSOT23-6_0_95MM
U17RCLAMP0544T_SLP2010P8T_RCLAMP05RCLAMP0544TSLP2010P8T
U18RCLAMP0522T_SLP2010P4T_RCLAMP05RCLAMP0522TSLP2010P4T
U19ST2129QTR_QFN10_1_8X1_4_ST2129QST2129QTRQFN10_1_8X1_4
U20FP6791_TSSOP-8_FP6791FP6791TSSOP-8
U22FXLA102_FXMA2102_FXLA102FXLA102FXMA2102
U23RCLAMP0544T_RCLAMP0544T_RCLAMP0RCLAMP0544TRCLAMP0544T
U24RCLAMP0544T_RCLAMP0544T_RCLAMP0RCLAMP0544TRCLAMP0544T
U25ST2329AQTR_QFN10_1_8X1_4_ST2329ST2329AQTRQFN10_1_8X1_4
U26KMCMG000M-B9980_0_KMCMG000M-B99KMCMG000M-B9980KMCMG000M-B9980
U27RCLAMP0506T_RCLAMP0506T_RCLAMP0RCLAMP0506TRCLAMP0506T
U29RCLAMP3304P_RCLAMP3304P_RCLAMP3rclamp3304pRCLAMP3304P
U31RCLAMP3624T_RCLAMP3624T_RCLAMP3RCLAMP3624TRCLAMP3624T
U32WM8994_WM8994_WM8994WM8994WM8994
U33SM0401L-MF422-M02_MIC-BGA4_SM04SM0401L-MF422-M02MIC-BGA4
U34SAFEB1G57KB0F00_SAFEB1G57K0F00_SAFEB1G57KB0F00SAFEB1G57K0F00
U35BGU7005_MAX2659_BGU7005BGU7005MAX2659
U36GNS7560_GNS7560_GNS7560GNS7560GNS7560
U37RP100N121D_SOT23_5_RP100N121DRP100N121DSOT23_5
U38SWB-A31_SWB-A31_SWB-A31SWB-A31SWB-A31
U39HMC5883L_HMC5883L_HMC5883LHMC5883LHMC5883L
U40FXMA2102_FXMA2102_FXMA2102FXMA2102FXMA2102
U41ALPU-MR_SOT23-6_0_95MM_ALPU-MRALPU-MRSOT23-6_0_95MM
U43BMA250_BMA250_BMA250BMA250BMA250
U44MPU_3050_MPU30X0_MPU_3050MPU_3050MPU30X0
U46SP6685_DFN-10_SP6686ER-LSP6686ER-LDFN-10
U47USB3503A_USB3503A_USB3503AUSB3503AUSB3503A
U49BAV99W_SOT323_BAV99WBAV99WSOT323
U50MAX6412_SOT23_5_MAX6412MAX6412SOT23_5
U51LTR-558ALS-01_LTR-558ALS-01_LTRLTR-558ALS-01LTR-558ALS-01
X1NZ2520SD12MHZ_XTAL_2520_NZ2520SNZ2520SD12MHZXTAL_2520
X2XTAL_XTAL_3225_7V260000127V26000012XTAL_3225
X3XTAL_XTAL_3225_DSX321G26MHZDSX321G26MHZXTAL_3225
X_FC1CAP NP_C0402_33NH33nHC0402
X_FC2CAP NP_C0402_33NH33nHC0402
Y1CRYSTAL4/SM_0_XTAL_3225_XTAL_24XTAL_24MXTAL_3225
Y2XM/SM_XTAL_2012_XTAL_32K736_201XTAL_32K736_2012XTAL_2012
Y3TCXO_TCXO_16M368_2520_NT2520SA1NT2520SA16.368MHZTCXO_16M368_2520
重要提示:PCB作品文件展下载说明
此广告位出租
此广告位出租
 楼主| 发表于 2017-12-26 14:21:06 | 显示全部楼层
PCB文件共享。回复可见
游客,如果您要查看本帖隐藏内容请回复
此广告位出租
发表于 2017-12-26 14:57:42 | 显示全部楼层
终身成就奖原创先锋奖优秀斑竹奖
发表于 2017-12-26 16:09:55 | 显示全部楼层
终身成就奖社区居民忠实会员宣传大使奖贴图大师奖优秀斑竹奖
发表于 2017-12-26 16:29:39 | 显示全部楼层
社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
发表于 2017-12-26 18:25:45 | 显示全部楼层
  • 签到天数: 37 天
    发表于 2017-12-27 00:07:11 | 显示全部楼层
    发表于 2017-12-27 08:06:51 | 显示全部楼层
    allegro-171023高级班
    发表于 2017-12-27 08:31:07 | 显示全部楼层
    发表于 2017-12-27 09:03:53 | 显示全部楼层
