重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CN1 | CON12P1.0MMA | 12P(C12-1.0K-02S) | CON12P | CN2 | CON50P/SMD-0.5MM | AT070TN92/94 | FPC50 | CN3 | CON12P1.0MMA | 12P(C12-1.0K-02S) | CON12P | CN4 | CON10PA20TA | | CN10 | CN5 | FMANT | | PIN2 | CN6 | CON2PA20TA | 2P2.54mm | CON2P | CN8 | CON20P(JYJ/AMP)AAA | | CON22P | CN9 | CON5PA20TA | 5P2.0mm | CON5P | CN10 | CON10P1.0MMA | 10P1.0 | CN10M | CN11 | CON10P1.0MMA | 10P1.0 | CN10M | CN12 | PFC1.0MM/4P | PFC1.0MM/4P | CON4_1 | CN13 | CON10PA20TA | | CN10 | CN14 | COM4P2.0MM-VA | PAD-SIP10P | CON4P | CN16 | CON9PA20TA | 9P2.0mm | CN9 | CN17 | CON10PA20TA | 10P2.0mm | CN10 | CN606 | CON5PA20TA | 5P2.0mm | CON5P | CN607 | CON2PA20TA | 2P2.54mm | CON2P | CON3 | SMTXH-V-6 | ARCJTAG/2MM/NC | SMTXH-V-6 | D2 | SOD123 | IN5819 | D_2 | D3 | IN5819 | IN5822 | IN5819 | D10 | D0805 | 1N4148 | DIODE | D11 | IN5819 | IN5819 | IN5819 | D15 | ZD0805 | 9.1V | ZENER | D102 | SS34A | IN5408 | SS34A | D103 | ZD0805 | 7.5V | ZENER | D104 | IN5819 | IN5822 | IN5819 | D105 | ZD0805 | 7.5V | ZENER | DM2 | P1 | TP | T_POINT_R | DP2 | P1 | TP | T_POINT_R | F3 | FA2 | 1A | FUSE1 | GPS1 | GPSCON2A | 30P1.0MM | CON32 | IR | P1 | TP | T_POINT_R | L1 | L-0805 | 2.7uH | 100UH | L2 | SMTL-3D7X3D7 | 10uH | INDUCTOR | L3 | 150UH | 47UH/5A | EI-20 | L4 | SMTL-3D7X3D7 | 10uH | INDUCTOR | L11 | SMTL-3D7X3D7 | 10uH | INDUCTOR | L13 | L-0805 | 2.7uH | 100UH | L18 | SMTL-3D7X3D7 | 22uH | INDUCTOR | L105 | L10PCB | 220UH/15A | EI-15 | L106 | 150UH | 47UH/5A | EI-20 | Q1 | BAT54S | BAT54S | BAT54S | Q2 | SOT-23B | 2SD1803 | TRX | Q4 | SOT-23B | 2S8550 | PNPTR | Q5 | SOT-23B | 2S8550 | PNPTR | Q11 | BAT54S | BAT54S | BAT54S | Q16 | SOT23 | MI3407 | AP809 | Q106 | SOT-23B | 2N3906 | PNPTR | Q107 | SOT23 | MI3407 | AP809 | Q114 | SOT89 | A1001 | A1001 | U1 | TSOP-66 | HY5DU561622T-5 | TSOP-66 | U2 | TSOP-48 | HY27UT084G2A | TSOP-48 | U3 | SOT89 | LM1117-3.3V | A1001 | U4 | TO-252B | LM7809 | 78LXX | U5 | LQFP-216 | AML6236V | LQFP-216 | U6 | IC-PQ1CZ21H2Z | AP1507 | TD1507 | U7 | SOT23-5 | MP2105 | TPS73601_2 | U8 | SOT89 | LM1117-1.8V | A1001 | U9 | SO8A | 256KBYTE_SPI_NOR | SO8A | U10 | SOT23 | AS809S | AP809 | U11 | TO-252B | LM7809 | 78LXX | U12 | DIP8-SOP | | 4558M | U13 | SOT23 | KIA7032 | AP809 | U14 | TSSOP-10 | ZT2083/NC | ZT2003S_0 | U15 | QFP64-10_10 | ESN2817 | ESN2817 | U16 | SOT26-6P | G5126 | MP3202 | U17 | TO-252B | LM7809 | 78L05 | U18 | SOT23-5 | MP2105 | TPS73601_2 | U19 | TVP5150 | TVP5150 | TVP5150 | U20 | SOP-32 | PT2312 | PT2312 | U21 | SO16 | 74HC4053 | 74HC4052 | U23 | TPS61041 | TPS61040 | TPS61041 | U28 | TSSOP-10 | CS4344 | CS4344B | U104 | FLEXIWATT25 | TDA7388 | TDA7381A | U106 | SOT89 | 78L09 | A1001 | U107 | IC-PQ1CZ21H2Z | AP1507 | TD1507 | U301 | EAC-ST7540AFIAA | ST7540AF3 | TUNER-ST7540 | U401 | SOP-16 | BU1924F | BU1924 | U602 | SIP10A | BA6247 | BA6247 | U901 | SSOP24 | FMS6502 | FMS6502 | X1 | XTAL_HC49SMT | 24M | CRY4.5M | X2 | XTAL_HC49SMT | 14.318M | CRY4.5M | X3 | XTAL_HC49SMT | 4.332M | CRY4.5M | X101 | 32.768K | 32.768k | CRY4.5M |
重要提示:PCB作品文件展下载说明
