重要提示:PCB作品文件展下载说明
下载板块默认-5金币,如果会员有销售附件需要扣销售金币+板块5金币,最少要保证你的积分=100+5+附件销售金额,否则下载不了。
4层PCB设计。
Name | PCB Decal | Value | Part Type | 1D1 | SOT-23 | NC/BAT54C | SOT-23 | 1D7 | LED0603 | LED | LED0603 | 1D8 | LED0603 | LED | LED0603 | 1EC1 | C3216 | NC/47UF_16V | C3216 | 1EC2 | C3216 | NC/100UF_10V | C3216 | 1J1 | DC_006 | DC_006 | DC_006 | 1L1 | L6060 | 1.0UH_5A_DCR<=15MOHM | L6060 | 1L2 | L5050 | NC/2.2UH_2A_DCR<=30MOHM | L5050 | 1L3 | L5050 | 4.7UH_2A_DCR<=70MOHM | L5050 | 1L4 | L5050 | 4.7UH_2A_DCR<=70MOHM | L5050 | 1L5 | L5050 | 2.2UH_2A_DCR<=30MOHM | L5050 | 1L6 | L6060 | NC/1.5UH_5A_DCR_18MOHM | L6060 | 1M1 | MARK | | MARK | 1M2 | MARK | | MARK | 1M3 | MARK | | MARK | 1M4 | MARK | | MARK | 1M5 | MARKA | MARK | MARK | 1M6 | MARK | MARK | MARK | 1M7 | MARKA | MARK | MARK | 1Q1 | SOT-23 | PMBT3904 | SOT-23 | 1Q2 | SOT-23 | PMBT3904 | SOT-23 | 1Q4 | SOT-23 | WPM2015 | SOT-23 | 1U1 | MP8756_QFN12 | MP8756GD | MP8756_QFN12 | 1U2 | SOP8-1P27 | NC/TPS54528/56528DDA | SOP8-1P27 | 1U3 | SOT23-6 | SY8120B1ABC | SOT23-6 | 1U4 | SOT23-6 | SY8120B1ABC | SOT23-6 | 1U5 | SOT23-5A | WL2803E18-5 | SOT23-5 | 1U6 | SOT23-6 | SY8120B1ABC | SOT23-6 | 1U7 | SOT23-5 | WL2803E18-5 | SOT23-5 | 1U10 | SOT23-6 | NC/SY8120B1ABC | SOT23-6 | 2J1 | CN-2P50-4P | A2501WV-4P | CN-2P50-4P | 2SW1 | SW-KFC-A04 | PWR_KEY | SW-KFC-A04 | 2U2 | SOT-23 | MAX809RD/RS809R | SOT-23 | 2U3 | DIP-IR | IRM-3638N3 | DIP-IR | 2Y2 | Y-SMD4P3225 | 24MHZ_CL12PF_20PPM | Y-SMD4P3225 | 3U1 | BGA96-0P8MM | H5TQ4G63AFR-RDC | BGA96-0P8MM | 3U2 | BGA96-0P8MM | H5TQ4G63AFR-RDC | BGA96-0P8MM | 3U3 | BGA96-0P8MM | H5TQ4G63AFR-RDC | BGA96-0P8MM | 3U4 | BGA96-0P8MM | H5TQ4G63AFR-RDC | BGA96-0P8MM | 4U5 | TSOP-48 | NC/29F64G08CBACA | TSOP-48 | 4U7 | BGA169-INAND | EMMC_FLASH | BGA169-INAND | 5D1 | ESD0402 | NC/AZ5725-01F | ESD0402 | 5D2 | ESD0402 | NC/AZ5725-01F | ESD0402 | 5D3 | ESD0402 | NC/AZ5725-01F | ESD0402 | 5D4 | ESD0402 | NC/AZ5725-01F | ESD0402 | 5J1 | RJ45-8P8C | MJ88-B511-RSVS1 | RJ45-8P8C | 5T1 | TS8121C | H1601CG | TS8121C | 5U2 | SOT23-6 | AZC199-04S | SOT23-6 | 6C1 | C0402 | 1UF_6.3V | C0402 | 6C2 | C0402 | NC/10PF_NPO | C0402 | 6C3 | C0402 | 1UF_6.3V | C0402 | 6C4 | C0402 | NC/1NF | C0402 | 6C5 | C0402 | NC/1NF | C0402 | 6C6 | C0805 | 22UF_6.3V | C0805 | 6C7 | C0805 | 22UF_6.3V | C0805 | 6C8 | C0402 | 1UF_6.3V | C0402 | 6D1 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D2 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D3 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D4 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D5 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D6 | ESD0402 | NC/AZ5725-01F | ESD0402 | 6D7 | ESD0402-P | AZ5413 | ESD0402-P | 6D8 | ESD0402-P | AZ5413 | ESD0402-P | 6D9 | ESD0402-P | AZ5413 | ESD0402-P | 6D10 | ESD0402-P | AZ5413 | ESD0402-P | 6F1 | FUSE-0805 | FUSE-500MA | FUSE-0805 | 6F2 | FUSE-0805 | FUSE-500MA | FUSE-0805 | 6J1 | TF-CARD-PUSH | TFWF1-EBF1-1X0X | TF-CARD-PUSH | 6J2 | CON4-USB-AF_2P45 | CON4-USB-AF_2P45 | CON4-USB-AF_2P45 | 6J3 | CON4-USB-AF_2P45 | CON4-USB-AF_2P45 | CON4-USB-AF_2P45 | 6SW1 | KFC-334-4.3 | UPDATE | KFC-334-4.3 | 7C1 | C0402 | NC | C0402 | 7C2 | C0603 | 4.7UF_6.3V | C0603 | 7C3 | C0402 | 1UF_6.3V | C0402 | 7C4 | C0402 | 0R | C0402 | 7C5 | C0603 | NC/10UF_6.3V | C0603 | 7C6 | C0402 | NC/0.1UF | C0402 | 7C7 | C0402 | NC | C0402 | 7C8 | C0402 | NC/0.1UF | C0402 | 7C10 | C0402 | 22PF_5%_NPO | C0402 | 7C11 | C0402 | 22PF_5%_NPO | C0402 | 7C12 | C0402 | 0.1UF | C0402 | 7C13 | C0603 | 10UF_6.3V | C0603 | 7C14 | C0402 | NC/6.8PF_NPO | C0402 | 7C15 | C0402 | 0R | C0402 | 7C16 | C0402 | NC | C0402 | 7C17 | C0402 | NC | C0402 | 7C18 | C0402 | 0.1UF | C0402 | 7J1 | J-MS-156 | ACA-5036-A3-CC-S | J-MS-156 | 7J2 | J-MS-156 | NC/ACA-5036-A3-CC-S | J-MS-156 | 7L2 | L3030 | 4.7UH_1A_DCR<=80MOHM | L3030 | 7Q1 | SOT-23 | NC/WPM2015 | SOT-23 | 7Q2 | SOT-23 | NC/PMBT3904 | SOT-23 | 7U1 | QFN44-PT09MM | AP6255 | QFN44-PT09MM | 7U2 | WF-UM02BS | NC/RTL8188-EUS | WF-UM02BS | 7Y2 | Y-SMD4P3225 | 37.4MHZ_16PF_10PPM | Y-SMD4P3225 | 9C1 | C0402 | 1UF_6.3V | C0402 | 9C2 | C0402 | 0.1UF | C0402 | 9C3 | C0402 | 1UF_6.3V | C0402 | 9C5 | C0402 | 1UF_6.3V | C0402 | 9C6 | C0402 | 0.1UF | C0402 | 9C7 | C0402 | 1UF_6.3V | C0402 | 9C8 | C0402 | 1NF | C0402 | 9C9 | C0402 | 1UF_6.3V | C0402 | 9C10 | C0402 | 1UF_6.3V | C0402 | 9C11 | C0603 | 10UF_6.3V | C0603 | 9C17 | C0402 | 1UF_6.3V | C0402 | 9D1 | DFN2510P10E | NC/AZ1345-04F | DFN2510P10E | 9D2 | DFN2510P10E | NC/AZ1345-04F | DFN2510P10E | 9D3 | ESD0402 | NC/AZ5725-01F | ESD0402 | 9D4 | ESD0402 | NC/AZ5725-01F | ESD0402 | 9D5 | ESD0402 | NC/AZ5725-01F | ESD0402 | 9J1 | HDMI_A | HDMI-DIP-TYPE-A-19P | HDMI_A | 9Q1 | SOT-23 | NC/WPM2015 | SOT-23 | 9Q2 | SOT-23 | WNM2020 | SOT-23 | AJ1 | PJ-320A-5.0 | SW-T1.5 | PJ-320A-5.0 | AJ3 | DQ_015AA | DQ_015 | DQ_015 | AU2 | TSSOP-14-PT065 | DIO2133CT14 | TSSOP-14-PT065 | U1 | BGA483_0P65 | GXL_S905D | BGA483_0P65 | VC1 | C0402 | 100PF_5%_NPO | C0402 | VC2 | C0402 | 27PF_5%_NPO | C0402 | VC3 | C0402 | 100PF_5%_NPO | C0402 | VD1 | ESD0402 | AZ5725-01F | ESD0402 | VL1 | L0603 | 1.8UH | L0603 |
