Name | PCB Decal | Part Type | B1 | RB12/8 | RB12/8 | BAT1 | CR2032_I | CR2032_I | CN1 | CONRA_4P_200 | CONRA_4P_200 | CN2 | POWER_20M | POWER_20M | CN3 | JP2_250_I | JP2_250_I | CN6 | CONRA_4P_200 | CONRA_4P_200 | CN19 | DB15S-F | DB15S-F | CON1 | CN_HDMI_19_050 | CN_HDMI_19_050 | D119 | SOT26 | SOT26 | D128 | DP0080 | DP0080 | D130 | DP0080 | DP0080 | D131 | SOT26 | SOT26 | D132 | SOT26 | SOT26 | D133 | P6KE6.8CA | P6KE6.8CA | D134 | P6KE6.8CA | P6KE6.8CA | F1 | FUSE-DIP2 | FUSE-DIP2 | F2 | FUSE-DIP2 | FUSE-DIP2 | H14 | HOLE_3MM+PAD+VIA | HOLE_3MM+PAD+VIA | J2 | SIP-2P | SIP-2P | J3 | SIP2P-300 | SIP2P-300 | J5 | SIP_4P | SIP_4P | J6 | SIP_4P | SIP_4P | J9 | FPC2X8-1.0 | FPC2X8-1.0 | J10 | MTD_PJ20_3P | MTD_PJ20_3P | J11 | IDE20_2.54 | IDE20_2.54 | J12 | SIP10P_100MIL | SIP10P_100MIL | J13 | IDE60_2.54 | IDE60_2.54 | J23 | RJ45-LED-3 | RJ45-LED-3 | J26 | USB_DOUBLE | USB_DOUBLE | J27 | SIP4P_100MIL | SIP4P_100MIL | J29 | AL_DIP2X8_300MIL | AL_DIP2X8_300MIL | J30 | SIP10P_100MIL | SIP10P_100MIL | J37 | SIP_4P | SIP_4P | J40 | SIP_2P_127 | SIP_2P_127 | K2 | REL_SRS | REL_SRS | L7 | L_GSSR2 | L_GSSR2 | L8 | LCH895 | LCH895 | L9 | LCH895 | LCH895 | L10 | LCH895 | LCH895 | LED1 | LED0603 | LED0603 | MARK3 | MARK1 | MARK1 | MARK4 | MARK1 | MARK1 | T1 | HC5000_24P_P0.99_W19.6 | HC5000_24P_P0.99_W19.6 | U1 | BGA825_065_25X25 | GM8210 | U2 | HEATSINK_38X38 | HEATSINK_38X38 | U3 | SOT23 | SOT23 | U4 | SOIC8_150 | SOIC8_150 | U6 | QFN14_050 | QFN14_050 | U7 | SOT25 | SOT25 | U8 | QFN14_050 | QFN14_050 | U9 | SOT23-6L | SOT23-6L | U10 | SOT23-6L | SOT23-6L | U11 | QFN14_050 | QFN14_050 | U12 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U13 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U14 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U15 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U16 | MSOP8-175-0.65 | PCF8563TS | U17 | SOP16_300 | SOP16_300 | U18 | SOIC8_208 | SOIC8_208 | U19 | SOIC8_150 | SOIC8_150 | U20 | SOIC16_6.2 | SOIC16_6.2 | U21 | QFN14_050 | QFN14_050 | U33 | SOT223 | SOT223 | U35 | GM8312_100 | GM8312_100 | U40 | SOT23-6L | SOT23-6L | U51 | SOIC8_150 | SOIC8_150 | U56 | MSOP10_050_30X49+EPAD | MSOP10_050_30X49+EPAD | U57 | MSOP10_050_30X49+EPAD | MSOP10_050_30X49+EPAD | U64 | QFN64_050_9X9 | QFN64_050_9X9 | U65 | SOT223 | SOT223 | U67 | SOT25 | SOT25 | U72 | SOT89 | SOT89 | U76 | BGA825_065_25X25 | GM8210 | U77 | HEATSINK_38X38 | HEATSINK_38X38 | U78 | SOT25 | SOT25 | U81 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U82 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U83 | MSOP10_050_30X49+EPAD | MSOP10_050_30X49+EPAD | U84 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U85 | DDR3_FBGA_X16_9X15P5 | DDR3_FBGA_X16_9X15P5 | U86 | MSOP10_050_30X49+EPAD | MSOP10_050_30X49+EPAD | U87 | QFN76-BLADE | NVP6114_76QFN | Y1 | XTAL1150X480N | XTAL1150X480N | Y2 | CRY4A | 32.768KHZ/20PPM/CL=12.5PF/MC-146/SMD | Y3 | XTAL4_2 | XTAL4_2 | Y5 | XTAL1150X480N | XTAL1150X480N | Y8 | OSC4_SMD_50X32 | OSC4_SMD_50X32 |
