#include "stm32f10x.h"
#include "pwm.h"
#include "delay.h"
#include "oled.h"
#include "encode.h"
#include "usart.h"
#include "string.h"
#include "sys.h"
#define PWMPeriod 719
u16 sum=0,n=1;
float num0=0,num1=0,num4=0,num3=0;
float a[3],w[3],angle[3],T;
char str[6],str1[3],str2[5],str3[12];
float x,xv;
u16 V,num;
extern unsigned char Re_buf[11],temp_buf[11],counter;
extern unsigned char sign;
/*绝对式PID算法,接口参数结构类型*/
typedef struct
/*PID算法接口变量,用于给用户获取或修改PID算法的特性*/
float kp; //比例系数
float ki; //积分系数
float kd; //微分系数
float errILim;//误差积分上限
float errNow;//当前的误差
float ctrOut;//控制量输出
/*PID算法内部变量,其值不能修改*/
float errOld;
float errP;
float errI;
float errD;
}PID_AbsoluteType;
/*增量式PID算法,接口参数结构类型*/
typedef struct
float kp; //比例系数
float ki; //积分系数
float kd; //微分系数
float errNow; //当前的误差
float dCtrOut;//控制增量输出
float ctrOut;//控制输出
float errOld1;
float errOld2;
}PID_IncrementType;
void drc(int a) //3表示电机制动,1表示电机正转,2表示电机反转,PA12接IN1,PA11接IN2
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_1;
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_ResetBits(GPIOB,GPIO_Pin_8|GPIO_Pin_1);
switch(a)
case 1: GPIO_ResetBits(GPIOB,GPIO_Pin_8); GPIO_SetBits(GPIOB,GPIO_Pin_1);break;//正转(逆时针)
case 2: GPIO_ResetBits(GPIOB,GPIO_Pin_1); GPIO_SetBits(GPIOB,GPIO_Pin_8);break;//反转(顺时针)
case 3: GPIO_ResetBits(GPIOB,GPIO_Pin_8); GPIO_ResetBits(GPIOB,GPIO_Pin_1); break;//电机立即制动
s32 MotorSpeed,PwmOne_Set,PwmOne_Mode;
void UserMotorSpeedSetOne(s32 control)//电机1转速/转向设置(TIM1)
MotorSpeed = control;//读取PID的输入值
if(MotorSpeed > PWMPeriod) MotorSpeed = PWMPeriod-1 ;//上限 CCR的值必须小于或等于ARR的值
if(MotorSpeed <-PWMPeriod) MotorSpeed = -(PWMPeriod-1);//下限
if(MotorSpeed<0) { PwmOne_Set = -MotorSpeed; PwmOne_Mode =0;}//反
else { PwmOne_Set = MotorSpeed; PwmOne_Mode =1;}//正
if(PwmOne_Mode) { TIM4->CCR4 = PwmOne_Set;drc(1);} //MotorOneForward正转
else { TIM4->CCR4 = PwmOne_Set;drc(2); } //MotorOneBack 反转
//绝对式PID算法
void PID_AbsoluteMode(PID_AbsoluteType* PID)
if(PID->kp < 0) PID->kp = -PID->kp;
if(PID->ki < 0) PID->ki = -PID->ki;
if(PID->kd < 0) PID->kd = -PID->kd;
if(PID->errILim < 0) PID->errILim = -PID->errILim;
PID->errP = PID->errNow; //读取现在的误差,用于kp控制
PID->errI += PID->errNow; //误差积分,用于ki控制
if(PID->errILim != 0) //微分上限和下限
if( PID->errI > PID->errILim) PID->errI = PID->errILim;
else if(PID->errI < -PID->errILim) PID->errI = -PID->errILim;
PID->errD = PID->errNow - PID->errOld;//误差微分,用于kd控制
PID->errOld = PID->errNow; //保存现在的误差
PID->ctrOut = PID->kp * PID->errP + PID->ki * PID->errI + PID->kd * PID->errD;//计算绝对式PID输出
/************闭环增量*****************************/
void PID_IncrementMode(PID_IncrementType* PID)
float dErrP, dErrI, dErrD;
dErrP = PID->errNow - PID->errOld1;
dErrI = PID->errNow;
dErrD = PID->errNow - 2 * PID->errOld1 + PID->errOld2;
PID->errOld2 = PID->errOld1; //二阶误差微分
PID->errOld1 = PID->errNow; //一阶误差微分
/*增量式PID计算*/
PID->dCtrOut = PID->kp * dErrP + PID->ki * dErrI + PID->kd * dErrD;
if(PID->kp == 0 && PID->ki == 0 && PID->kd == 0) PID->ctrOut = 0;
else PID->ctrOut += PID->dCtrOut;
/*****************************************电机速度环伺服***********************************************/
s32 spdTag, spdNow, control;//定义一个目标速度,采样速度,控制量
//PID_AbsoluteType PID_Control;//定义PID算法的结构体(位置)
PID_IncrementType PID_Control;//定义PID算法的结构体(增量)
void User_PidSpeedControl(s32 SpeedTag)
spdNow = V; spdTag = SpeedTag;
PID_Control.errNow = spdTag - spdNow; //计算并写入速度误差
PID_Control.kp = 0.045; //写入比例系数为15
PID_Control.ki = 0.015; //写入积分系数为5
PID_Control.kd = 0.015; //写入微分系数为5
// PID_Control.errILim = 10000000; //写入误差积分上限为1000 下限为-1000
// PID_AbsoluteMode(& ID_Control); //执行位置式PID算法
PID_IncrementMode(& ID_Control); //执行增量式PID算法
control = PID_Control.ctrOut; //读取控制值
//if( PID_Control.errNow>10|| PID_Control.errNow<-10)
UserMotorSpeedSetOne(control); //放入PWM,用于收敛速度的控制中
void TIM3_IRQHandler()//读取脉冲计时器
sum++;
TIM3->CNT=0;
TIM_ClearITPendingBit(TIM3,TIM_IT_Update);
void TIM2_IRQHandler()//0.01s固定时间获取TIM3的计数,num4输出0.1s的脉冲
num0=num1;//0.01s前的脉冲个数
num1=(float)TIM3->CNT;//0.01s后的脉冲个数
num3=(num1-num0)+num3;//num3累积计算每一次中断的脉冲,10次后输出
if(n%10==0)
num4=num3;
num3=0;
if(n==100000)
n=0;
n++;
TIM_ClearITPendingBit(TIM2,TIM_IT_Update);//清除中断
int main()
int i=0;
USART1_Config();
delay_init(72); //延时函数初始化
pwm_PB9_init(719,0); //D13控制电机
TIM4->CCR4=500;
while(1)
// i++;
// TIM4->CCR4=i;
// if(i==718)
// i=0;
// delay_ms(100);
