查看: 607|回复: 7
定时插座
发表于 2018-4-23 08:06:22 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include "ds1302.h"
#include "main.h"
#include "ir1308.h"
bit readtime_f,key_f = 0,irok;
bit readtemp_f = 0,key_fun_f = 0;
sbit timing_led01 = P3^1; //设置定时1指示灯
sbit timing_led02 = P3^3; //设置定时2指示灯
sbit time_led = P3^0;     //调整时间指示灯
unsigned char key_value,key_select,key_fun = 0,cnt,timing_01=0,timing_02=0;
unsigned int key_count = 0;
SYSTEMTIME timer,timer1,timer2;    //定义两个结构体变量,timer为存当前时间、timer1为存设置定时1时间、timer2为存设置定时2时间
unsigned char ir_mcsj[33];//用于存放33个脉冲的时间长度值
void timer0_init()
    TMOD = 0x21;//定时器0工作方式1,定时器1工作方式2
    TH0 = 0X3C;    //50ms
    TL0 = 0XB0;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
    TH1 = 0X00;
    TL1 = 0X00;
    ET1 = 1;
    TR1 = 1;
    IT0 = 1;
    EX0 = 1;
void timer0_isr() interrupt 1
    static unsigned char counter = 0,counter1 = 0;
    TH0 = 0X3C;       //50ms
    TL0 = 0XB0;
    counter ++;
    key_f = 1;
    if(counter==10)
        counter = 0;
        led = ~led;
        readtime_f = 1;
        counter1 ++;
        if(counter1==2)
            counter1 = 0;
            readtemp_f = 1;
void t1(void) interrupt 3
    cnt++;
void int0 (void) interrupt 0//外部中断0服务函数
    static unsigned char i;
    static bit flag;
    if(flag)
        if(cnt<63&&cnt>=33)
            i=0;
        ir_mcsj = cnt;
        cnt = 0;
        i++;
        if(i==33)
            irok = 1;
            i = 0;
    else
        cnt = 0;
        flag = 1;
void main()
    unsigned char readtemp;
    lcd_initial();
    timer0_init();
    ds1302_init();
    while(1)//主循环
        if(readtemp_f&&!key_fun_f)//读取温度
            readtemp_f = 0;
            readtemp = read_temperature();
            LCD_Write_Char(13,1,readtemp/10+'0');  //显示温度值
            LCD_Write_Char(14,1,readtemp%10+'0');
        if(readtime_f&&!key_fun_f)//读取时间
            readtime_f = 0;
            Ds1302_Read_Time(&timer);
            timer_alarm(&timer,&timer1);
            timer_alarm2(&timer,&timer2);
            LCD_Write_Char(3,1,timer.Hour/10 + '0');  //显示时
            LCD_Write_Char(4,1,timer.Hour%10 + '0');
            LCD_Write_Char(6,1,timer.Minute/10 + '0');//显示秒
            LCD_Write_Char(7,1,timer.Minute%10 + '0');
            LCD_Write_Char(9,1,timer.Second/10 + '0');//显示秒
            LCD_Write_Char(10,1,timer.Second%10 + '0');
            LCD_Write_Char(3,0,timer.Year/10 + '0');  //显示年
            LCD_Write_Char(4,0,timer.Year%10 + '0');
            LCD_Write_Char(6,0,timer.Month/10 + '0'); //显示月
            LCD_Write_Char(7,0,timer.Month%10 + '0');
            LCD_Write_Char(9,0,timer.Day/10+ '0');      //显示日
            LCD_Write_Char(10,0,timer.Day%10 + '0');
            LCD_Write_Char(14,0,timer.Week%10 + '0'); //显示周
        if(irok)//判断是否接收好了红外处理
            IR1308();
        if(key_f)
            key_f = 0;
            key_value = key();
/***********************************选择键************************************/
            if(key_value==0x01)
                    key_select ++;
                    if(key_select>0x07)
                        key_select = 0x00;
                        WRDcomm(0x0c);
                    else
                        WRDcomm(0x0d);
                        switch(key_select)
                            case 0x01CD_Write_Char(3,0,timer.Year/10 + '0');break;
                            case 0x02CD_Write_Char(6,0,timer.Month/10 + '0');break;
                            case 0x03CD_Write_Char(9,0,timer.Day/10 + '0');break;
                            case 0x04CD_Write_Char(13,0,':');break;
                            case 0x05CD_Write_Char(3,1,timer.Hour/10 + '0');break;
                            case 0x06CD_Write_Char(6,1,timer.Minute/10 + '0');break;
                            case 0x07CD_Write_Char(9,1,timer.Second/10 + '0');break;
                            default:break;
/*********************************加值键***********************************/
            else if(key_value==0x02)
                if(key_select==0x01)//修改年
                    timer.Year ++;
                    if(timer.Year==100)
                    timer.Year = 0;
                else if(key_select==0x02)//修改月
                    timer.Month ++;
                    if(timer.Month==13)
                    timer.Month = 1;
                    LCD_Write_Char(7,0,timer.Month % 10 + '0');
                    LCD_Write_Char(6,0,timer.Month / 10 + '0');
                else if(key_select==0x03)//修改日
                    timer.Day ++;
                    if(timer.Day==32)
                    timer.Day = 1;
                    LCD_Write_Char(10,0,timer.Day % 10 + '0');
                    LCD_Write_Char(9,0,timer.Day / 10 + '0');
                else if(key_select==0x04)//修改星期
                    timer.Week ++;
                    if(timer.Week==8)
                    timer.Week = 1;
                    LCD_Write_Char(14,0,timer.Week % 10 + '0');
                    LCD_Write_Char(13,0,':');
                else if(key_select==0x05)//修改时
                    timer.Hour ++;
                    if(timer.Hour==24)
                    timer.Hour = 0;
                    LCD_Write_Char(4,1,timer.Hour % 10 + '0');
                    LCD_Write_Char(3,1,timer.Hour / 10 + '0');
                else if(key_select==0x06)//修改分
                    timer.Minute ++;
                    if(timer.Minute==60)
                    timer.Minute = 0;
                    LCD_Write_Char(7,1,timer.Minute % 10 + '0');
                    LCD_Write_Char(6,1,timer.Minute / 10 + '0');
                else if(key_select==0x07)//修改秒
                    timer.Second ++;
                    if(timer.Second==60)
                    timer.Second = 0;
                    LCD_Write_Char(10,1,timer.Second % 10 + '0');
                    LCD_Write_Char(9,1,timer.Second / 10 + '0');
/*******************************减值键**********************************/
            else if(key_value==0x04)
                    timer.Year --;
                    if(timer.Year==-1)
                    timer.Year = 99;
                    timer.Month --;
                    if(timer.Month==0)
                    timer.Month = 12;
                    timer.Day --;
                    if(timer.Day==0)
                    timer.Day = 31;
                    timer.Week --;
                    if(timer.Week==0)
                    timer.Week = 7;
                    timer.Hour --;
                    if(timer.Hour==-1)
                    timer.Hour = 23;
                    timer.Minute --;
                    if(timer.Minute==-1)
                    timer.Minute = 59;
                    timer.Second --;
                    if(timer.Second==-1)
                    timer.Second = 59;
    难过
    5 天前
  • 签到天数: 85 天
    终身成就奖社区居民忠实会员社区劳模最爱沙发特殊贡献奖优秀斑竹奖
    发表于 2018-4-23 08:16:50 | 显示全部楼层
    1元学习PADS(3期)
    发表于 2018-4-23 08:33:08 | 显示全部楼层
    PADS-180606高级班
    终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
    发表于 2018-4-23 08:52:51 | 显示全部楼层
    allegro-180504高级班
    发表于 2018-4-23 08:55:10 | 显示全部楼层
    昨天 15:36
  • 签到天数: 117 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-4-23 08:57:06 | 显示全部楼层
    3 天前
    PADS-180305高级班
    发表于 2018-4-23 08:59:07 | 显示全部楼层
    发表于 2018-4-23 09:04:32 | 显示全部楼层
    论坛开启做任务可以
    额外奖励金币快速赚
    积分升级了
