Comment | Pattern | Qty | Components | 10芯双排插针-2.54 | HEADER_2x5_2_54-6545 | 1 | J3 | ADC_CH7 | TP-1.5r-2.5R | 1 | ADC_CH6 | ADG751BRTZ | SOT-23-6 | 8 | U62.. | AT45DB161D-SU | AT45DB161D-SU | 1 | U2 | AT45DB321D-SU | AT45DB161D-SU | 1 | U13 | AXI | TP-1.5r-2.5R | 1 | P32 | AXO | TP-1.5r-2.5R | 1 | P29 | BLM21B102S | 0805L | 2 | L1, L6 | BXI | TP-1.5r-2.5R | 1 | P34 | BXO | TP-1.5r-2.5R | 1 | P30 | BY_ADC_CH6 | TP-1.5r-2.5R | 1 | BY_ADC_CH6 | BY_ADC_CH7 | TP-1.5r-2.5R | 1 | BY_ADC_CH7 | BZX84C4V7LT1 | SOT23 | 1 | D23 | CCM3310S-N | QFN48-CCM3310-N | 1 | U11 | CJI | TP-1.5r-2.5R | 1 | P43 | CJO | TP-1.5r-2.5R | 1 | P39 | CMP_OUT1 | TP-1.5R-2.5R | 1 | CMP_OUT1 | CMP_OUT2 | TP-1.5R-2.5R | 1 | CMP_OUT2 | CXI | TP-1.5r-2.5R | 1 | P35 | CXO | TP-1.5r-2.5R | 1 | P31 | DA_CMP | TP-1.5R-2.5R | 1 | DA_CMP | DA0_Board | TP-1.5r-2.5R | 2 | DA0_Board, DA1 | DA0 | TP-1.8R-2.2R | 1 | P7 | DA1_Board | TP-1.5r-2.5R | 1 | DA1_Board | DGND | TP-1.5r-2.5R | 2 | P4, P10 | DGND | TP-1.8R-2.2R | 3 | P8, P9, P12 | DJI | TP-1.5r-2.5R | 1 | P44 | DJO | TP-1.5r-2.5R | 1 | P41 | DNP | OSC5*7_4PIN | 1 | G2 | DNP | SFB0603 | 1 | FB15 | DXI | TP-1.5r-2.5R | 1 | P36 | DXO | TP-1.5r-2.5R | 1 | P33 | EFM32GG990 | BGA112-EFM32GG990 | 2 | U5, U114 | FDKZ | HOLE_S65_D45 | 1 | P1 | 0 | TP-1.5r-2.5R | 2 | P15, P16 | Green | 0603LED | 1 | D1 | HEADER-S-2x3-1_27 | HEADER-S-2x3-1_27 | 2 | J2, J5 | JBS | TP-1.5R-2.5R | 1 | JBS1 | JFM25F64SD | CSOP16 | 1 | U12 | JTAG-XILINX-FPGA-14P | HEADER-S-2x7-1_27 | 1 | J1 | K2-1107 | Switch-2 | 3 | SW1, SW2, SW3 | KGKZ | HOLE_S65_D45 | 1 | P2 | KN | TP-1.8R-2.2R | 4 | KN1, KN2, KN3, KN4 | KW | TP-1.8R-2.2R | 4 | KW1, KW2, KW3, KW4 | LED | 0805LED | 1 | D2 | LEUART_JTAG | HEADER_1X5_2_54-6545 | 1 | J4 | LF198AH | TO-99 | 4 | U121, U125, U130, U133 | LT1175IS8 | SOIC-8 | 2 | U31, U32 | LT1764AEQ-ADJ | TO-263-5 | 1 | U7 | LT3015IQ | DD-PAK-5 | 2 | U28, U29 | LT3083IQ | DD-PAK-5 | 2 | U23, U24 | M25P128VME6TG | MLP8 | 1 | U3 | MAX3232ESE+ | SO-16 | 1 | U16 | MAX3491 | SOP14_MAX3491 | 1 | U8 | MAX488ESA/MAX3490 | SO-8 | 1 | U15 | MAX6825TUK-T | SOT23-5 | 1 | U4 | MQ7230PL | MQ7230PL | 2 | U20, U21 | N4_SUM | TP-1.5r-2.5R | 2 | N4_SUM, TP541 | N4 | TP-1.8R-2.2R | 1 | P5 | NFM41P | NFM41P | 3 | Z1, Z2, Z3 | OPA192IDBV | SOT23-5 | 62 | | OPA4192_FL | TSSOP-14 | 18 | | PB1608/110/6A | SFB0603 | 23 | | PB1608-110/6A | SFB0603 | 4 | | PB4532-310/6A | FB1812 | 4 | | RDn | TP-1.5R-2.5R | 1 | RDn | RDp | TP-1.5R-2.5R | 1 | RDp | RED | 0603LED | 2 | D9, D10 | REF5025 | SOIC-8 | 1 | U30 | SD101A | DO-35 | 12 | D6.. | SH_CTRL1 | TP-1.5R-2.5R | 1 | SH_CTRL1 | SH_CTRL2 | TP-1.5R-2.5R | 1 | SH_CTRL2 | SN74LVC4245APW | TSSOP24-PW | 3 | U6, U17, U18 | SWITCH-SMD | SW-SMD | 1 | XS1 | SW-PB | Switch-2 | 2 | S1, S2 | TB | TP-1.5R-2.5R | 1 | TB1 | TDn | TP-1.5R-2.5R | 1 | TDn | TDp | TP-1.5R-2.5R | 1 | TDp | TEMP1 | HOLE_S65_D45 | 2 | T1, T4 | TEMP1 | TEST | 2 | T2, T3 | TL3016 | TSSOP-8 | 9 | U44.. | TPS72618DCQR | SOT223-5-TPS72618 | 1 | U14 | TPS73701DCQ | SOT223-5 | 1 | U19 | TPS73801 | SOT-223-6 | 3 | U22, U25, U26 | TPS74901KTWT | TO-263-7 | 1 | U9 | TPS75633KTT | TO-263-5 | 1 | U10 | TPS77833D | SOIC-8 | 1 | U27 | White | 0603LED | 4 | D3, D5, D8, D11 | XC7A200T-SBG484 | XC7A200T-SBG484 | 1 | U1 |
