查看: 7353|回复: 39
[Allegro16.6以下] am3359工业通信PCB一份
发表于 2018-5-25 18:11:30 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
工业工薪引擎PCB文件.zip (2.95 MB, 下载次数: 28) am3359工业通信PCB分享一下
****************以下信息由管理员 @老吴       整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
D1LED_TRICOLOR_REDGREENYELLOW_LEDRed_Green_Yellow_LEDLED-SM1210
D2LED_TRICOLOR_REDGREENYELLOW_LEDRed_Green_Yellow_LEDLED-SM1210
D3LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D4LED_YELLOW_LEDLTST-S220_LEDYELLED YellowLEDLTST-S220
D5LED_YELLOW_LEDLTST-S220_LEDYELLED YellowLEDLTST-S220
D6LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D7LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D8LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D9LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D10LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D11DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
D12LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D13DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
D14LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D15LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D16LED_GREEN_SM_LED_0805_GREENLEDGreen LEDSM_LED_0805
D17DIODE_3ARECT_REV40V_DO157LS_116B340A-13-FDO157LS_116X220SMA
D18DIODE_MBRS140T3_MBRS140T_MBRS14MBRS140TMBRS140T
D19DIODE_SMCJ26CA_SMCJ36CA_SMCJ26CSMCJ26CASMCJ36CA
D20DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
F1FUSE_4A_SMDFUSEBLK_FUSE4AFuse 4ASMDFUSEBLK
FB2FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB3FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB9FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB10FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB11FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB12FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB13FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
J12J_CONNECTORRJ45_10_100MBAMDIX_RJ-45 10_100MbCNRJ45-1X1WLED
J22J_CONNECTORRJ45_10_100MBAMDIX_RJ-45 10_100MbCNRJ45-1X1WLED
J3HEADER9X2_0.1IN_FEMALE_HDR2X9VEHeader 9x2 FemaleHDR2X9VER_335M
J4HEADER15X2_0.1IN_FEMALE_HDR2X15Header 15x2 FemaleHDR2X15-344M
J5HEADER_1.27MM_3PIN_SIP3_50LS_TMTMS-103-01SIP3_50LS
J6HEADER_1.27MM_2PIN_SIP2_50LS_TMTMS-102-01SIP2_50LS
J7HEADER_1.27MM_2PIN_SIP2_50LS_TMTMS-102-01SIP2_50LS
J8HEADER_1.27MM_3PIN_SIP3_50LS_TMTMS-103-01SIP3_50LS
J9CONN_DSUB9F_NORCOMP_DB9F_SMD_COConn_DB9FNORCOMP_DB9F_SMD
J10HEADER_1.27MM_2PIN_SIP2_50LS_TMTMS-102-01SIP2_50LS
J11CONN_PWRJACK_RAPC722_CNRAPC722_Power Jack RAPC722XCNRAPC722
J12CONN_LEADSCREWDOWN_2PIN_CONN_OSConnector_ScrewdownCONN_OSTTC02
J13CONN_MICROUSBAB_ZX62-AB-5PA_USBUSB_MicroABZX62-AB-5PA
J14HEADER20X2_0.1IN_FEMALE_HDR2X20Header 20x2 FemaleHDR2X20-335M
J15HEADER10X2_CJTAG_HEADER10X2_CTICTI JTAGHEADER10X2
J16CONN_MICROSD_8_SD-MICRO-SCHA5B0SCHA5B0200SD-MICRO-SCHA5B0300
J17CONN_14PIN_0.5MM_FPC_CON14_P5MM10051922-1410ELFCON14_P5MM_3P75X9P5SMD
J182H_HEADER_3X1_HEADER_3X1_HEADERHEADER 3HEADER_3X1
J192H_HEADER_3X1_HEADER_3X1_HEADERHEADER 3HEADER_3X1
L1DA2304-ALB_DA2304_DA2304-ALDA2304-ALDA2304
L22.2UHINDUCTOR20%1ASMD_IND108SMD2.2uHIND108SMD_110X102
L368UHINDUCTOR20%1.4ASMD_IND_354S68uHIND_354SMD_400SQ
L42.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
L52.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
L6ACM2012_ACM2012H_ACM2012ACM2012ACM2012H
L72.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
MH1MOUNTHOLE_3MM_MH163X138PL_3.5MM3.5MM_MHOLEMH163X138PL
MH2MOUNTHOLE_3MM_MH163X138PL_3.5MM3.5MM_MHOLEMH163X138PL
MH3MOUNTHOLE_3MM_MH163X138PL_3.5MM3.5MM_MHOLEMH163X138PL
MH4MOUNTHOLE_3MM_MH163X138PL_3MM_M3MM_MHOLEMH163X138PL
Q1NPN_DMC564040R_SMINI6-F3-B_DMC5DMC564040RSMINI6-F3-B
Q2NPN_DMC564040R_SMINI6-F3-B_DMC5DMC564040RSMINI6-F3-B
Q3NPN_DMC564040R_SMINI6-F3-B_DMC5DMC564040RSMINI6-F3-B
Q4NPN_DMC564040R_SMINI6-F3-B_DMC5DMC564040RSMINI6-F3-B
RP133OHMX8_1/16W5%SMD_EXB-2HV330JV33x8EXB-2HV330JV
RP233OHMX8_1/16W5%SMD_EXB-2HV330JV33x8EXB-2HV330JV
RP333OHMX8_1/16W5%SMD_EXB-2HV330JV33x8EXB-2HV330JV
S1SWITCHTACTILE3POS_SMD_SW3_4X2P5SwitchTactile3PosSW3_4X2P5
SW1SWITCHDIPROTARIES_SMD_SW-ND3FR1Rotary SwitchSW-ND3FR10
U1M29W160G_TFBGA48_M29W160EBM29W160EBTFBGA48
U2TLK110_HTQFP_48PIN_TLK110TLK110HTQFP_48PIN
U3TLK110_HTQFP_48PIN_TLK110TLK110HTQFP_48PIN
U4SN74CB3Q3306APW_PW8_SN74CB3Q330SN74CB3Q3306APWRPW8
U5SN74LVC1G08DCKT_SC70_SM-SO-SC70SN74LVC1G08SM-SO-SC70-5
U6CAT24C256W_SOIC8_208_CAT24C256WCAT24C256WSOIC8_208
U7SN74LVC1G32DCK_SC70-5-43M_SN74LSN74LVC1G32DCKSC70-5-43M
U8SN74LVC1G32DCK_SC70-5-43M_SN74LSN74LVC1G32DCKSC70-5-43M
U9SN74CBTLV3257RGY_QFN4X3P5-16-39SN74CBTLV3257RGYQFN4X3P5-16-39M
U10SN74LVC1G06DCK_DCK5_SN74LVC1G06SN74LVC1G06DCKDCK5
U11SN74CBTLV3257RGY_QFN4X3P5-16-39SN74CBTLV3257RGYQFN4X3P5-16-39M
U121A_CDCE913_TSSOP5X4-14-47M_CDCECDCE913TSSOP5X4-14-47M
U13SN74AUP2G08_U_8_DCU_SN74AUP2G08SN74AUP2G08U_8_DCU
U14AM335X_15MMX15MM_AM33XX_15X15_AAM335X_15x15AM33XX_15X15
U15MT41J128M16JT-125_BGA14X10-96_MMT41J128M16JT-125BGA14X10-96
U16ISO1050_SO8_W_DUB_ISO1050ISO1050SO8_W_DUB
U17W25Q64_SOIC8_265_W25Q64W25Q64SOIC8_265
U18FT2232_0_LQFP64_10X10_FT2232HLFT2232HLLQFP64_10X10
U19LM94022_SC70-5_LM94022LM94022SC70-5
U20SN74LVC1G07_DCK5_SN74LVC1G07SN74LVC1G07DCK5
U21TPS5420D_SOIC-8_TPS5420DTPS5420DSOIC-8
U22TPS65910A3_U_48_RSL_TPS65910A3TPS65910A3U_48_RSL
U23TPD4S012_U_6_DRY_TPD4S012TPD4S012U_6_DRY
U24TPD6E001RSE_U_10_RSE_TPD6E001TPD6E001U_10_RSE
U25PCA9536_MSOP3X3-8-43M_PCA9536DGPCA9536DGKMSOP3X3-8-43M
U26SN74ALVCH16374DGVR_TVSOP-48_SN7SN74ALVCH16374DGVTVSOP-48
U27TPS76650_SOIC_8_TPS76650TPS76650SOIC_8
U28ISO1176T_U_16_DW_ISO1176TISO1176TU_16_DW
U29TPS51200_DRCPSO_10PIN_TPS51200TPS51200DRCPSO_10PIN
U30TPS71718_SMDSC70-5_TPS71718TPS71718SMDSC70-5
U31TPIC2810_U_16_D_TPIC2810TPIC2810U_16_D
U32TPS78633DCQ_SOT223_6PIN_TPS7863TPS78633SOT223_6PIN
U3393C46B_SSOT23-6_SOT23-6_93LC56B93LC56BSOT23-6
U34TPS61041DBV_DBV5_TPS61041TPS61041DBV5
U35SN65HVS882_U_28_PWP_SN65HVS882SN65HVS882U_28_PWP
U371A_SN74LV244APWRG3_TSSOP4X6-20_SN74LV244ATSSOP4X6-20
U381A_SN74LV244APWRG3_TSSOP4X6-20_SN74LV244ATSSOP4X6-20
Y1CRYSTAL25MHZABM3_SM_OSC_ABM3_2525MHzSM_OSC_ABM3
Y2CRYSTAL12MHZ_ECS-120-20-30B_XTA12MHz,+/-50ppmXTAL4_3P2X5SMD
Y3CRYSTAL24MHZ18PFSMD_XTAL4_3P2X224MHzXTAL4_3P2X2P5_SMD
Y4CRYSTAL_SMD32_768KHZ_MC-306_32.32.768KHz MC-306MC-306
重要提示:PCB作品文件展下载说明
发表于 2018-5-25 20:16:32 | 显示全部楼层
发表于 2018-5-25 20:25:59 | 显示全部楼层
    昨天 15:34
  • 签到天数: 272 天
    社区居民社区劳模原创先锋奖终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2018-5-25 22:37:19 | 显示全部楼层
    发表于 2018-5-26 06:23:59 | 显示全部楼层
    下来,学习,收藏,谢谢。
    5 小时前
  • 签到天数: 160 天
    7万
    发表于 2018-5-26 08:21:09 | 显示全部楼层
    PADS20200316初级班
    发表于 2018-5-26 08:46:03 | 显示全部楼层
    6 天前
  • 签到天数: 68 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2018-5-26 08:55:47 | 显示全部楼层
    TI的板子,工业级的多
  • 签到天数: 4 天
    发表于 2018-5-26 08:58:46 | 显示全部楼层
    发表于 2018-5-26 09:18:56 | 显示全部楼层
