查看: 9243|回复: 45
[Allegro16.6以下] BQ24616RGE+PCA9539PW+TPS5430DDA+DP83848I+uPD720114+ISO1176DW 做的AM335X 底
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2018-6-15 15:23:18 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    BUZ1DIP_BUZZER-1205_D120-P65-H100BuzzerBZ_1280DX730H
    CON1CON100A2MH_CON_1D27_2X50_SMD_B1.27mm 2x50 SMD BoxCON_1D27_2X50_SMD_BOX_RT
    CON2CON100A2MH_CON_1D27_2X50_SMD_B1.27mm 2x50 SMD BoxCON_1D27_2X50_SMD_BOX_RT
    CON3CON2_CON_3D96_1X2_DIP_DEADER_RT3.96mm 1x2 TH VHCON_3D96_1X2_DIP_DEADER_RT
    CON4CON_BL-8188-4M_1_BL-8188-4M_SMDBL-8188-4MBL-8188-4M_SMD
    CON5MINI USB-ABSMD5_CON_USB_MINI-AMINI USB-AB SMD5CON_USB_MINI-AB_RECEP
    CON6USB FEMALE TYPE ASINGLE_CON_USCON USB FEMALE TYPE ASINGLE SMTCON_USBA_FEMALE_SINGLE_SMD
    CON713F-64GYD2PL2NL_CON_YDS_13F-64G13F-64GYD2PL2NLCON_YDS_13F-64GYD2PLXNL
    CON8L85007-09201C_CON_L850070_092_TTF CARD PUSHCON_L850070_092
    CON9CON24A_CON_2D00_2X12_TH_PHD_VER2.00mm 2x12 TH PHDCON_2D00_2X12_TH_PHD_VERT
    CON10CON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDCON_2D00_2X6_TH_PHD_VERT
    CON11CON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDCON_2D00_2X6_TH_PHD_VERT
    CON12CON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDCON_2D00_2X6_TH_PHD_VERT
    CON13CON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDCON_2D00_2X6_TH_PHD_VERT
    CON14CON16A_CON_2D00_2X8_TH_PHD_VERT2.00mm 2x8 TH PHDCON_2D00_2X8_TH_PHD_VERT
    CON15CON12A_CON_2D00_2X6_TH_PHD_VERT2.00mm 2x6 TH PHDCON_2D00_2X6_TH_PHD_VERT
    CON16MG323_B2B_0D50_50P_RT_SMD_FEMALB2B 0.5MM 50P FEMALEB2B_0D50_50P_RT_SMD_FEMALE
    CON17FFC 0.5MM 50PFLIP_CON_FFC_0D5_FFC 0.5mm 50P FLIPCON_FFC_0D5_50P
    CON18CON2_CON_3D96_1X2_DIP_DEADER_RT3.96mm 1x2 TH VHCON_3D96_1X2_DIP_DEADER_RT
    CON19CON BATTERY CR2032SMD_CON_BATTCON BATTERY CR2032SMDCON_BATTERY_CR2032_SMD
    D1DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D2DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D3DIODE TVSBI-DIR_SMB_P6SMB33AP6SMB33ASMB
    D4DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D5DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D6DIODE TVSBI-DIR_SMB_P6SMB33AP6SMB33ASMB
    D7DIODESCHOTTKY_SMA_SS14SS14SMA
    D8DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D9DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D10DIODESCHOTTKY_SMA_MBRA340T3GMBRA340T3GSMA
    D11DIODE_SOD-523_1N41481N4148SOD-523
    D12DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D13DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D14DIODE TVSUNI-DIR_SMB_P6SMB33AP6SMB33ASMB
    D15DIODE TVSUNI-DIR_SMB_P6SMB33AP6SMB33ASMB
    D16DIODE TVSUNI-DIR_SMB_P6SMB33AP6SMB33ASMB
    D20DIODESCHOTTKY_SMA_SS14SS14SMA
    D21DIODE TVSUNI-DIR_SMB_P6SMB6.8AP6SMB6.8ASMB
    D22DIODE TVSBI-DIR_SMB_P6SMB6.8CAP6SMB6.8CASMB
    D23DIODE TVSUNI-DIR_SMB_P6SMB6.8AP6SMB6.8ASMB
    D24DIODE TVSUNI-DIR_SMB_P6SMB6.8AP6SMB6.8ASMB
    D25DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D26DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D27DIODE_SOD-523_1N41481N4148SOD-523
    D28DIODE_SOD-523_1N41481N4148SOD-523
    D29DIODE_SOD-523_1N41481N4148SOD-523
    D30DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D31DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D32DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D33DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D34DIODE_SOD-523_1N41481N4148SOD-523
    D35DIODE_SOD-523_1N41481N4148SOD-523
    D36DIODE_SOD-523_1N41481N4148SOD-523
    D37DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    D38DIODE TVSBI-DIR_D0402_RCLAMP05RCLAMP0521PD0402
    F1FUSE_F1206_2A2AF1206
    F2FUSE_F1206_2A2AF1206
    F3FUSE_F1206_200MA200mAF1206
    F4FUSE_F1206_200MA200mAF1206
    FB1FERRITEBEAD_L0603_220R/100MHZ220R/100MHzL0603
    FB2FERRITEBEAD_L0603_220R/100MHZ220R/100MHzL0603
    H13HOLE_MHOLE_C150D90_C150D90C150D90MHOLE_C150D90
    J21.25MM 8P SMDDF14B_CON_1D25_8P1.25mm 8P SMD DF14BCON_1D25_8P_SMD_DF14B
    J42.54MM 1X4 THTJC3_CON_2D54_1X42.54mm 1x4 TH TJC3CON_2D54_1X4_TH_TJC3
    J52.54MM 1X6 THTJC3_CON_2D54_1X62.54mm 1x6 TH TJC3CON_2D54_1X6_TH_TJC3
    J62.54MM 1X6 THTJC3_CON_2D54_1X62.54mm 1x6 TH TJC3CON_2D54_1X6_TH_TJC3
    J7CON10A_0_CON_2D54_2X5_DIP_PIN_V2.54MM 2X5 DIP PINCON_2D54_2X5_DIP_PIN_VERT
    J82.54MM 1X6 THTJC3_CON_2D54_1X62.54mm 1x6 TH TJC3CON_2D54_1X6_TH_TJC3
    J92.54MM 1X4 THTJC3_CON_2D54_1X42.54mm 1x4 TH TJC3CON_2D54_1X4_TH_TJC3
    J102.54MM 1X3 THPIN_CON_2D54_1X3_2.54mm 1x3 TH PINCON_2D54_1X3_TH
    L1COMMON MODECHOKE_L10D0X8D0X5D05uHL10D0X8D0X5D0MM
    L2INDUCTOR_L12D5X12D5X8D0MM_22UH22uHL12D5X12D5X8D0MM
    L3INDUCTOR_L12D5X12D5X8D0MM_22UH22uHL12D5X12D5X8D0MM
    L4INDUCTOR_L12D5X12D5X8D0MM_22UH22uHL12D5X12D5X8D0MM
    L5INDUCTOR_L12D5X12D5X8D0MM_22UH22uHL12D5X12D5X8D0MM
    LED1LED_D0603_LED REDLED REDD0603
    MOD1BLK-MD-BC04-L_BLK-MD-BC04-L_BLKBLK-MD-BC04-LBLK-MD-BC04-L
    MOD2REX3S_REX3S_ZIGBEE_REX3SZIGBEE_REX3SREX3S
    OSC1OSCILLATOR SMD4PIN_SMD_3225_5050MHzSMD_3225
    P1SIM8PP_GW-SIM8PP_GW-SIM8PP-0LY8GW-SIM8PP-0LY8GW-SIM8PP
    Q1FDS4935A_SOIC8_D8_FDS4935AFDS4935ASOIC8_D8
    Q2FDS4935A_SOIC8_D8_FDS4935AFDS4935ASOIC8_D8
    Q3FDS4935A_SOIC8_D8_FDS4935AFDS4935ASOIC8_D8
    Q4FDS6982_SOIC8_D8_FDS6982FDS6982SOIC8_D8
    Q5MMBT3904/SOT_1_SOT23-3_DBZ3_MMBMMBT3904SOT23-3_DBZ3
    Q10MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q11MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q12MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q15MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q16MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q18MMBT3904/SOT_1_SOT23-3_DBZ3_MMBMMBT3904SOT23-3_DBZ3
    Q19MMBT3904/SOT_1_SOT23-3_DBZ3_MMBMMBT3904SOT23-3_DBZ3
    Q20MOSFET PSOT_SOT346_AO3415AO3415SOT346
    Q21MOSFET PSOT_SOT346_AO3415AO3415SOT346
    Q22MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q23MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    Q24MOSFET NSOT_SOT23_2N7002K2N7002KSOT23
    SW1SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    SW2SWPUSHBUTTON-SPST_BUTTON_SPST_SW_PUSHBUTTON_SPSTBUTTON_SPST_SMT
    SW3SWPUSHBUTTON-SPST_BUTTON_SPST_SW_PUSHBUTTON_SPSTBUTTON_SPST_SMT
    SW4SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    SW5SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    SW6SWPUSHBUTTON-SPST_BUTTON_SPST_SW_PUSHBUTTON_SPSTBUTTON_SPST_SMT
    SW7SWPUSHBUTTON-SPST_BUTTON_SPST_SW_PUSHBUTTON_SPSTBUTTON_SPST_SMT
    SW8SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    SW9SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    SW10SWDIP-6_CON_DIP_6P_1D27_SOP_1.1.27mm 6BIT SMD SOPSwitchCON_DIP_6P_1D27_SOP
    TP1TEST POINT_TP30_TP30TP30TP30
    TP6TEST POINT_TP30_TP30TP30TP30
    TP7TEST POINT_TP30_TP30TP30TP30
    U1BQ24616RGE_QFN24_BQ24616RGEBQ24616RGEQFN24
    U2FDS8433A_SOIC8_D8_FDS8433AFDS8433ASOIC8_D8
    U3TPS5430DDA_SON8_DDA8_TPS5430DDATPS5430DDASON8_DDA8
    U4TPS5430DDA_SON8_DDA8_TPS5430DDATPS5430DDASON8_DDA8
    U5TPS5430DDA_SON8_DDA8_TPS5430DDATPS5430DDASON8_DDA8
    U6FDS8433A_SOIC8_D8_FDS8433AFDS8433ASOIC8_D8
    U7SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U8SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U9SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U10UPD720114_TQFP48_PFB48_UPD72011uPD720114TQFP48_PFB48
    U11PRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2XSOT143B
    U12DP83848I_LQFP48_G48_DP83848IDP83848ILQFP48_G48
    U13SLVU2.8-4_SO8_SLVU2.8-4SLVU2.8-4SO8
    U14TMP100_SOT23-6_DBV6_TMP100TMP100SOT23-6_DBV6
    U15PESD5V0L4UG_SOT353_PESD5V0L4UGPESD5V0L4UGSOT353
    U16PESD5V0L4UG_SOT353_PESD5V0L4UGPESD5V0L4UGSOT353
    U17ISO1176DW_SOIC16_DW16_ISO1176DWISO1176DWSOIC16_DW16
    U18PESD2CAN_SOT23-3_DBZ3_PESD2CANPESD2CANSOT23-3_DBZ3
    U19PESD2CAN_SOT23-3_DBZ3_PESD2CANPESD2CANSOT23-3_DBZ3
    U20MAX3232EIPW_TSSOP16_PW16_MAX323MAX3232EIPWTSSOP16_PW16
    U21PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U22SN74LV4051APW_TSSOP16_PW16_SN74SN74LV4051APWTSSOP16_PW16
    U23PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U24MAX3232EIPW_TSSOP16_PW16_MAX323MAX3232EIPWTSSOP16_PW16
    U25PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U26PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U27SN74LV4051APW_TSSOP16_PW16_SN74SN74LV4051APWTSSOP16_PW16
    U28MAX3232EIPW_TSSOP16_PW16_MAX323MAX3232EIPWTSSOP16_PW16
    U29PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U30PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U31SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U32MAX3232EIPW_TSSOP16_PW16_MAX323MAX3232EIPWTSSOP16_PW16
    U33PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U34PESD15VL2BT_SOT23-3_DBZ3_PESD15PESD15VL2BTSOT23-3_DBZ3
    U35PCA9539PW_TSSOP24_PCA9539PWPCA9539PWTSSOP24
    U36TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U37TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U38PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U39PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U40PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U41PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U42PCA9539PW_TSSOP24_PCA9539PWPCA9539PWTSSOP24
    U43TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U44TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U45PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U46PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U47PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U48PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U49TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U50TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U51PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U52PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U54PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U55TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U56TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U57PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U58PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U59PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U60TLP281-4_SO16_OPTOCOUPLER_TLP29TLP291-4(GB)SO16_OPTOCOUPLER
    U61PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U62PESDXVL2BT_SOT23-3_DBZ3_PESD24VPESD24VL2BTSOT23-3_DBZ3
    U64ADR02AR_SOIC8_D8_ADR02ARADR02ARSOIC8_D8
    U65SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U66SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U67SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U68AD7888BR_SOIC16_D16_AD7888BRAD7888BRSOIC16_D16
    U69AD5025BRUZ_TSSOP14_AD5025BRUZAD5025BRUZTSSOP14
    U70AD8531AR_SOIC8_D8_OP07DRZOP07DRZSOIC8_D8
    U71AD8531AR_SOIC8_D8_OP07DRZOP07DRZSOIC8_D8
    U72SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U73PESD5V0L4UG_SOT353_PESD5V0L4UGPESD5V0L4UGSOT353
    U74SN74LVC2G07DCK_SC70-6_DCK6_SN74SN74LVC2G07DCKSC70-6_DCK6
    U75RCLAMP0524P.TCT_SLP2510P8_RCLAMRCLAMP0524P.TCTSLP2510P8
    U76PRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2XSOT143B
    U77PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U78PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U79PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U80PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U81PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U82PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U83PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U84PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U85PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U86PESD5V0U2BT_SOT23-3_DBZ3_PESD5VPESD5V0U2BTSOT23-3_DBZ3
    U87TLP155E_SO5_OPTOCOUPLER_TLP155ETLP155ESO5_OPTOCOUPLER
    U88TLP155E_SO5_OPTOCOUPLER_TLP155ETLP155ESO5_OPTOCOUPLER
    U89TLP155E_SO5_OPTOCOUPLER_TLP155ETLP155ESO5_OPTOCOUPLER
    U90PESD24VL2BT_SOT23-3_DBZ3_PESD24PESD24VL2BTSOT23-3_DBZ3
    U91PESD24VL2BT_SOT23-3_DBZ3_PESD24PESD24VL2BTSOT23-3_DBZ3
    Y1CRYSTAL SMD4PIN_SMD_3225_30MHZ30MHzSMD_3225
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2018-6-15 15:25:09 | 显示全部楼层
    JZ335X.7z (1.99 MB, 下载次数: 80)
    昨天 08:47
  • 签到天数: 89 天
    发表于 2018-6-15 20:00:38 | 显示全部楼层
    发表于 2018-6-15 20:17:30 | 显示全部楼层
    发表于 2018-6-15 20:24:39 | 显示全部楼层
  • 签到天数: 19 天
    终身成就奖优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2018-6-16 00:35:15 | 显示全部楼层
  • 签到天数: 181 天
    终身成就奖社区居民特殊贡献奖优秀斑竹奖
    发表于 2018-6-16 00:49:33 | 显示全部楼层
    4 小时前
  • 签到天数: 105 天
    发表于 2018-6-16 06:42:26 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2018-6-16 08:12:04 | 显示全部楼层
  • 签到天数: 48 天
    PADS-180606高级班
    终身成就奖社区居民忠实会员社区劳模最爱沙发优秀斑竹奖特殊贡献奖原创先锋奖
    发表于 2018-6-16 08:53:07 | 显示全部楼层
