REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | BC103 | FB0805 | 120ohm/100mhz/0805/3a | FB0805 | CN101 | CON-2 | short | CON-2 | CN102 | CON-2 | short | CON-2 | CN103 | CON-8 | pin 1x8 | CON-8 | CN104 | DB9 | cn104 | DB9 | CN107 | CON-8 | pin 1x8 | CON-8 | D101 | SOT523-AAC | dan222 | SOT523-AAC | D103 | SMC-AC | ss36 | SMC-AC | D104 | SMC-AC | ss36 | SMC-AC | D105 | BR_SMD1_MBS | b4s/30a/400v | BR_SMD1_MBS | D106 | DO-214AC | p4smaj58a | DO-214AC | D107 | BR_SMD1_MBS | b4s/30a/400v | BR_SMD1_MBS | D108 | DO-214AA | murs120t3/1a/200v | DO-214AA | D109 | SOT23ACN | bas16 | SOT23ACN | D110 | SOT23ACN | mmbz5248b sot23 | SOT23ACN | D111 | SOT23ACN | mmbz5248b sot23 | SOT23ACN | D112 | SOT23ACN | bas16 | SOT23ACN | J101 | CN_2_19S_F | .25in f smt | CN_2_19S_F | JK102 | DC_JACK | tp_0 | DC_JACK | JK103 | RJ45_8PX2 | rj45x2 | RJ45_8PX2 | JK104 | USB_A_4P | usb_connector | USB_A_4P | JK105 | CON16 | jk100 | CON16 | L1 | CHOKE_STIB4_3_5A | common choke /n | CHOKE_STIB4_3_5A | L101 | COIL256X620 | 5uh/5a | COIL256X620 | L102 | COIL256X620 | 5uh/5a | COIL256X620 | L103 | COIL256X620 | 5uh/5a | COIL256X620 | L108 | GS1608DF | 10uh/1.1a 6.6*4.5mm | GS1608DF | L109 | GS3316DF | 1uh/9a 13*9.4mm | GS3316DF | L611 | CHOKEX2-2012 | common choke100mhz/90r | CHOKEX2-2012 | LED101 | LED-2 | led_green | LED-2 | MH1 | MT9-134MIL | 157 drill / 360pad | MT9-134MIL | MH2 | MT9-C315D182NP | 157 drill / 360pad | MT9-C315D182NP | MH3 | MT9-134MIL | 157 drill / 360pad | MT9-134MIL | MH4 | MT9-C315D182NP | 157 drill / 360pad | MT9-C315D182NP | Q103 | TO252GDS | ap09n20h | TO252GDS | Q104 | TO252GDS | nc/ap09n20h | TO252GDS | Q803 | MMBT2222S | mmbt2222 | MMBT2222S | Q804 | MMBT2222S | mmbt2222 | MMBT2222S | Q805 | MMBT2222S | mmbt2222 | MMBT2222S | SW1 | SW-TACT-743HA | reset_default | SW-TACT-743HA | SW102 | SW-4 | reset_buttom | SW-4 | SW103 | SLIDE218_04LPST | dip switch 4 | SLIDE218_04LPST | T102 | SXFMR_H5007 | epg4011 | SXFMR_H5007 | T103 | SXFMR_H5007 | epg4011 | SXFMR_H5007 | T104 | AFD1501 | afd1501 | AFD1501 | U16 | SO8 | lp3965es-adj | SO8 | U101 | EPBGA388 | ppc405ex epbga-388 | EPBGA388 | U102 | SO8 | ics18101 | SO8 | U103 | TSSOP8 | x1205 tssop8 | TSSOP8 | U104 | SOT235P | ds1775r1/tr sot23-5 | SOT235P | U105 | SO8 | at24c04 soic8 | SO8 | U106 | SO8 | at24c04 soic8 | SO8 | U107 | SOT143-4P | g692l293 sot143 | SOT143-4P | U109 | SO8 | aoz1014 sop8 | SO8 | U111 | SO8 | lp3965es-adj | SO8 | U112 | TO263-5P | lp3965es-adj to263-5 | TO263-5P | U113 | SO9 | g2996p1u sop8 | SO9 | U114 | TSOP056 | s29gl512ntf010 tsop56 | TSOP056 | U115 | TQFP100 | lc4064v-75 tqfp100 | TQFP100 | U116 | TSSOP14 | 74lvc00d tssop14 | TSSOP14 | U117 | FBGA84 | 512mbx16 ddr2 | FBGA84 | U118 | FBGA84 | 512mbx16 ddr2 | FBGA84 | U119 | FBGA84 | 512mbx16 ddr2 | FBGA84 | U120 | FBGA84 | 512mbx16 ddr2 | FBGA84 | U121 | VFQFP40P_GP | cspu877a vfqfpn-40 | VFQFP40P_GP | U122 | SSOP20 | sp3223 sspo20 | SSOP20 | U123 | MINIPCI_EXPRESS | minipci_e slot | MINIPCI_EXPRESS | U124 | MINIPCI_EXPRESS | minipci_e slot | MINIPCI_EXPRESS | U125 | QFN32 | lp3965es-adj | QFN32 | U126 | TSSOP20 | ics557-05 | TSSOP20 | U130 | RFP128P | m88e1000s_pqfp128 | RFP128P | U131 | RFP128P | m88e1000s_pqfp128 | RFP128P | U133 | QFN32 | qfn32 | QFN32 | U134 | SOT235P | rt9702a | SOT235P | U135 | IP4059 | ip4059cx5/lf | IP4059 | U136 | SO8 | fds2582 sop8 | SO8 | U137 | SSOP8 | tps2375pw | SSOP8 | U138 | SO8 | fds2582 sop8 | SO8 | U139 | MSOP8-0_65MM | ucc3809p-2 msop8 | MSOP8-0_65MM | U140 | LTV_817S | ltv-817sc-ta1 | LTV_817S | U141 | SOT235P | tlv431acdbvr sot23-5 | SOT235P | U146 | SO8 | apm9424 | SO8 | X103 | XS2_MS2V_TS | 32.768khz | XS2_MS2V_TS | X104 | OSCSMD7X5 | 32.768khz | OSCSMD7X5 | X105 | OSCSMD7X5 | 125mhz | OSCSMD7X5 | X106 | SBX49SM | 24mhz | SBX49SM | X110 | XTAL1 | 33.33mhz | XTAL1 | X111 | XTAL1 | 25mhz | XTAL1 | X112 | XTAL1 | 25mhz | XTAL1 | X301 | XTAL1 | 25mhz | XTAL1 |
