查看: 7158|回复: 26
[资料贡献] MT8516芯片技术资料分享
发表于 2018-9-5 10:04:49 | 显示全部楼层 |阅读模式
MT8516芯片技术资料分享,下边有网盘下载链接
1 System Overview
MT8516 is a highly integrated connected audio platform incorporating application processing and connectivity subsystems to enable connected audio applications. The chip integrates a Quad-core ARM® Cortex-A35 MPCoreTM operating up to 1.3 GHz. The MT8516 interfaces to NAND flash memory, LPDDR2, LPDDR3, DDR3, DDR3L and DDR4 for optimal performance and also supports booting from eMMC to minimize the overall BOM cost. In addition, an extensive set of interfaces such as TDM/PDM inputs are included for microphone voice input control / search applications on connected audio products.
The application processor, a Quad-core ARM® Cortex-A35 MPCoreTM which includes a NEON multimedia processing engine.
MT8516 includes two wireless connectivity functions, WLAN and Bluetooth. The RF parts of those two blocks are also built-in MT8516 chip which can support 802.11 bgn. With two advanced radio technologies integrated into one single chip, MT8516 provides the best and most convenient connectivity solution among the industry. MT8516 implements advanced and sophisticated Radio Coexistence algorithms and hardware mechanisms.  It also supports single antenna sharing among 2.4 GHz antenna for Bluetooth, WLAN. The enhanced overall quality is achieved for simultaneous voice, data, and audio transmission. The small footprint with low-power consumption greatly reduces the PCB layout resource.
1.1 Platform Features
· AP MCU subsystem
- Quad-core ARM® Cortex-A35 MPCoreTM operating at 1.3 GHz
- NEON multimedia processing engine with SIMDv2 / VFPv4 ISA support
- 32KB L1 I-cache and 32KB L1 D-cache
- 512KB unified L2 cache
- DVFS technology with adaptive operating voltage from 1.05V to 1.31V
· Wireless Connectivity MCU subsystem
- Andes N9 processor with 48KB I-cache, 40KB D-cache
· External memory interface
- Supports LPDDR2, LPDDR3, DDR3/L, DDR4 up to 2GB
- 32-bit data bus width
- Memory clock up to 800 MHz
- Supports self-refresh/partial self-refresh mode
- Low-power operation
- Programmable slew rate for memory controller’s IO pads
- Supports dual rank memory device
- Advanced bandwidth arbitration control
· Security
- ARM® TrustZone® Security
· Storage
- NAND flash controller supporting NAND bootable, iNAND2® and MoviNAND®
- 3 sets of memory card controller supporting SD/SDHC/MMC and SDIO2.0/3.0 protocols
· Connectivity
- Two USB ports, port0 support USB 2.0 OTG mode but port1 only support USB 2.0 host mode. The two USB20 ports support connection Hub to transfer data communications with HS/FS/LS Device. USB2.0 high-speed dual mode supporting 8 Tx and 8 Rx endpoints.
- 3 UARTs for external devices and debugging interfaces
- SPI master for external devices
- 3 I2C to control peripheral devices, e.g. CMOS image sensor, or LCM module
- I2S master output and master/slave input for connection with optional external hi-end audio codec
- GPIOs
- 10M/100M Ethernet MAC with MII and RMII interface
- IR receiver
· Operating conditions
- Core voltage: 1.15V
- Processor DVFS+SRAM voltage : 1.15V~1.31V (Typ. 1.15V ; sleep mode 0.85V)
- I/O voltage: 1.8V/2.8V/3.3V
- Memory: 1.2V/1.35V/1.5V
- NAND: 1.8V/3.3V
- LCM interface: 1.8V/3.3V
- Clock source: 26-MHz, 32.768-kHz
· Package
- Type: WB TFBGA
- 12.6mm x 13.1mm
- Height: 1.2 mm maximum
- Ball count: 406 balls
- Ball pitch: 0.5mm
1.2 Multimedia Features
· Display
- Supports landscape or portrait panel resolution up to FWXGA (1366x768)
- MIPI DSI interface (4 data lanes)
- Single link LVDS interface
- Supports RGB interface panel
· Audio
- I2S Master mode sampling rates supported: 8kHz to 192kHz
- I2S In Slave mode sampling rates supported: 8kHz to 48kHz
- Sample formats supported: 16-bit/24-bit, Mono/Stereo
- Interfaces supported: DAI, I2S, TDM, SPDIF
- Flexible and powerful audio post-processing technologies
- Supports DIR(SPDIF-input) decode: supports 32, 44.1, 48, 88.2, 96kHz sample rate.
- Supports SPDIF-output encode: supports 32, 44.1, 48, 88.2, 96kHz sample rate.
- Supports Time Division Multiplexer I2S output (master mode only): supports 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 192kHz sample rate and
channel number up to 2/4/8 in configuration by 1/2/4 data pins (corresponding to 2/4/8 channels),
- Dedicated pin for TDM TX (not share clock pins with TDM RX).
- Supports Time Division Multiplexer input: supports 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48, 88.2, 96, 192kHz sample rate and channel number up to 2/4/8 in 1 serial data pin,
- Dedicated pin for TDM RX (not share clock pins with TDM TX).
· Speech
- Noise reduction
- Noise suppression
- Dual-MIC noise cancellation
- Echo cancellation
- Echo suppression
- Dual-MIC input
- Digital MIC input
· HDMI transmitter
- Built-in HDMI TX 1.4 supports Full HD 1080p video output
- Audio return channel
1.3 Wi-Fi/Bluetooth Features
· Supports integrated Wi-Fi/Bluetooth
- Supports single antenna for Bluetooth and WLAN
- Self calibration
- Best-in-class current consumption performance
- Intelligent BT/WLAN coexistence scheme that goes beyond PTA signaling (for example, transmit window and duration that take into account protocol exchange sequence, frequency, etc.)
· Wi-Fi
- Single-band (2.4GHz) single stream 802.11 b/g/n MAC/BB/RF
- 802.11 d/h/k compliant
- Security: WFA WPA/WPA2 personal, WPS2.0, WAPI (Hardware)
- QoS: WFA WMM, WMM PS
- Supports 802.11n optional features: STBC, A-MPDU, Blk-Ack, RIFS, MCS feedback, 20/40MHz coexistence (PCO), unscheduled PSMP
- Supports 802.11w protected managed frames
- Supports Wi-Fi Direct (WFA P-2-P standard)
- Supports HotSpot 2.0 Passpoint
- Per packet TX power control
· Bluetooth
- Bluetooth specification v2.1+EDR
- Bluetooth v4.0 Low Energy (LE)
- Rx sensitivity: GFSK -95dBm, DQPSK -94dBm, 8-DPSK -88dBm
- Best-in-class BT/Wi-Fi coexistence performance
- Up to 4 piconets simultaneously with background inquiry/page scan
- Supports Scatternet
- Packet Loss Concealment (PLC) function for better voice quality
- Low-power scan function to reduce power consumption in scan modes
1.4 General Description
MediaTek MT8516 has integrated 802.11 b/g/n and Bluetooth 4.0 + HS radios and passive devices (IPD) to provide a connected audio solution. The application processor incorporates a high efficient 64-bit Quad Cortex-A35 processor operating at 1.3 GHz. Rich memory interfaces (PCDDR3, DDR4, LPDDR3, eMMC, Raw NAND) provide high flexibility to support variant memory configurations. The elaborate MMD (MediaTek Module Design) provides verified schematics and PCB layout for memory and power source to reduce development time. Combo chip MT6630, 802.11ac/BT also gives the alternative to fullfill high end WiFi/BT requirement. MT8516 processor delivers high-performance computing, low-power consumption, and good multimedia experience.
World-leading technology
Based on MediaTek’s world-leading SoC architecture with advanced 28nm RF process, the MT8516 integrates digital and RF into one chip that is suitable for compact PCB design. The PMIC, MT6392, is designed to supply all the power to MT8516 itself. The two-chip solution brings lower rBOM and design effort to cost-effectively develop applications with fast time to market.
Flash I/FUSBSDIOI2CGPIOCoresightPowerManagementRTC I/FAudioCODECCortexA35CortexA35CortexA35CortexA35512KB L2INTCTimerDMABoot ROMDualDisplay Wi-Fi802.11b/g/nBluetooth4.0 + HSConnectivityRFEMIPC / USB DevicesI2C DevicesDDR3 32bit1600MbpsNANDDebugFacilityMT6392DC/DCLDOGaugeLCMTVMT8516WiFi/BTAntennaHDMIMIPI / LVDSAudio codecSpeaker AMP6630(option)(wifi/BT/GPS)eMMC /SD / SDIOeMMC,SD Card(option)
Figure 1-1: Block Diagram of MT8516
网盘下载链接:链接: https://pan.baidu.com/s/1OrCu2YxC56iv4m4MP8hK7w 密码: f5ud
PADS-181015高级班
社区居民忠实会员社区劳模终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖金点子奖
发表于 2018-9-5 10:36:17 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
发表于 2018-9-5 13:49:31 | 显示全部楼层
终身成就奖原创先锋奖
发表于 2018-9-5 15:40:18 | 显示全部楼层
  • 签到天数: 17 天
    发表于 2018-9-5 17:00:30 | 显示全部楼层
    前天 09:12
  • 签到天数: 213 天
    社区居民终身成就奖特殊贡献奖原创先锋奖
    发表于 2018-9-5 17:35:16 | 显示全部楼层
    发表于 2018-9-5 18:40:39 | 显示全部楼层
    发表于 2018-9-5 20:03:44 | 显示全部楼层
    发表于 2018-9-5 21:42:44 | 显示全部楼层
    终身成就奖原创先锋奖优秀斑竹奖
    发表于 2018-9-6 06:45:14 | 显示全部楼层
