[Allegro16.6以下] 24层开发板EP4S100G5_F1932+EPM2210F324+CY7C1480V25+88E1111+M29EW+VSC8240+S
查看19884 | 回复139 | 2018-9-30 11:05:22 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
s4_gt_100g_devkit_reva.brd
D112CWQ03FN_IR-DPAK_12CWQ03FN12CWQ03FNIR-DPAK
D6ZENERDIODE_SMB403A_03_20VZENER20V ZenerSMB403A_03
D7LED_LUMEX_LED1206_BLUE_LEDBlue_LedLUMEX_LED1206
D8ZC2800E/SOT_SMC_B530C-13B530C-13SMC
D9ZC2800E/SOT_SOD-123_MMSD914MMSD914SOD-123
D10ZENERDIODE_SMB403A_03_20VZENER20V ZenerSMB403A_03
D11ZENERDIODE_SMB403A_03_1SMB5932B1SMB5932BT3GSMB403A_03
D42LED_LUMEX_LED1206_GREEN_LEDGreen_LEDLUMEX_LED1206
J1CONN_JACK_PWR_RAPC712_RAPC712XRAPC712XRAPC712
J22X2_MLX_39_29_1047_RA_4P_39-29-39-29-1047MLX_39_29_1047_RA_4P
J3SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J4SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J510045722_RCPT_0_FCI_10045722_DP10045722FCI_10045722_DP
J28SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J29SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J3010035515_HDR_0_FCI_10035515_DP_10035515FCI_10035515_DP
J31SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGESAMTEC_SFP_MECT20
J32SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGESAMTEC_SFP_MECT20
J33SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J34QSFP_AND_CAGE_0_TYCO_QSFP_38_QSQSFP_AND_CAGETYCO_QSFP_38
J35SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J36SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J37CFP_MOD_5_CFP-148-GUIDERAIL_CFPCFP_MODCFP-148-GUIDERAIL
J38SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J3910045722_RCPT_0_FCI_10045722_DP10045722FCI_10045722_DP
J401X2_HDR2X1_2MM_HDR2X1HDR2x1HDR2X1_2MM
J411X2_HDR2X1_2MM_HDR2X1HDR2x1HDR2X1_2MM
J42CON2_HDR2X1_100MIL_CON2CON2HDR2X1_100MIL
J43SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J48HDR2X10_HDR2X10_100MIL_HDR2X10HDR2X10HDR2X10_100MIL
J49HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02ERJ45
J54SMA_LTI_SASF54GT_0_SMA_LTI-SASFLTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J55CON2_HDR2X1_100MIL_CON2CON2HDR2X1_100MIL
J56CON2_MLX_22_23_2021_MLX_22_23_222_23_2021MLX_22_23_2021_VRT_HDR_2P
J5710035515_HDR_0_FCI_10035515_DP_10035515FCI_10035515_DP
J582X5_HDR2X5_100MIL_SMT_DNIDNIHDR2X5_100MIL_SMT
J59HDR2X7_HDR2X7_100MIL_HDR2X7HDR2X7HDR2X7_100MIL
J60USB_CON_USB2_0-RA_USBCONUSB CONUSB2_0-RA
J6170247-1051_CONN_39_26_7108_702470247-1051CONN_39_26_7108
L1INDUCTOR_COILTRONICS_HCP0703_2.2.2uHCOILTRONICS_HCP0703
L2INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L3INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L4INDUCTOR_IND_WURTH_744028001_1U1uHIND_WURTH_744028001
L5INDUCTOR_IND_WURTH_744028001_1U1uHIND_WURTH_744028001
L6INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L7INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L8INDUCTOR_IND_WURTH_744028001_1U1uHIND_WURTH_744028001
L9INDUCTOR_IND_WURTH_744028001_1U1uHIND_WURTH_744028001
L10INDUCTOR_IND_WURTH_744028001_1U1uHIND_WURTH_744028001
L11BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L12INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L13INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L14INDUCTOR_SMD_1_SM_FERRITE_BEAD_1.0uHSM_FERRITE_BEAD
L15BEAD_FERRITE_SM_IND_0805_BLM21PBLM21PG331SN1IND_0805
L16INDUCTOR_IND_STEWARD_28F0121-0S10A BEADIND_STEWARD_28F0121-0SR-10
Q1PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q2PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q3PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
RN39RES_PACK_8_RES_PACK_8_5656RES_PACK_8
S12EVQPAC07K_PUSHBUTTON_EVQ_PBSWITPBSwitchPUSHBUTTON_EVQ
SW1SWSLIDE-DPDT_EG2201A_EG2201AEG2201AEG2201A
SW276SB08_DIPSWITCH_SMT_OCTAL_TDA0TDA08H0SB1DIPSWITCH_SMT_OCTAL
SW3SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8DIPSWITCH16
SW4SPST8_DIPSWITCH16_DIP_SW_8DIP_SW_8DIPSWITCH16
TP1T_POINT_R_TP_060SQ040_DNIDNITP_060SQ040
TP2T_POINT_R_TP_060SQ040_DNIDNITP_060SQ040
TP3T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP_060SQ040
TP4T_POINT_R_TP_060SQ040_DNIDNITP_060SQ040
TP20T_POINT_R_TP_060SQ040_54101-G0554101-G05-01LFTP_060SQ040
U1FDMC8878_SO8_FDS8870FDS8870SO8
U2LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U3FDMC8878_SO8_FDS8870FDS8870SO8
U4LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U5LTM46XX_LGA104_LTM4600LTM4600LGA104
U9LTM4601_LGA118_LTM4601LTM4601LGA118
U10LT1374_TSSOP16-EPAD_LT1374LT1374TSSOP16-EPAD
U11LTM4627_3_LGA133_LTM4627LTM4627LGA133
U12LTM4627_3_LGA133_LTM4627LTM4627LGA133
U13NB6L11S_QFN16_NB6L11SMNGNB6L11SMNGQFN16
U14ICS8308I_TSSOP24_ICS8308IICS8308ITSSOP24
U15ICS8543_TSSOP20_ICS8543ICS8543TSSOP20
U16MC100ES6139_TSSOP20_MC100ES6139MC100ES6139TSSOP20
U17ICS8308I_TSSOP24_ICS8308IICS8308ITSSOP24
U18ICS8543_TSSOP20_ICS8543ICS8543TSSOP20
U19ICS8543_TSSOP20_ICS8543ICS8543TSSOP20
U20IDT5T9306_0_VFQFPN-28_EPAD_IDT5IDT5T9306VFQFPN-28_EPAD
U21SI5338A_0_QFN24_SI5338ASi5338AQFN24
U22SI5338A_0_QFN24_SI5338ASi5338AQFN24
U23LT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDODFN8_EPAD
U24LT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDODFN8_EPAD
U25LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U26LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U27LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U28MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U29MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U30MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U31MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U32VSC8240_UBGA81_(S1+S2)_VSC8240VSC8240UBGA81
U33LTM46XX_LGA104_LTM4600LTM4600LGA104
U34AT24C512BN_SO8_AT24C512BNAT24C512BNSO8
U35LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U36MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U37MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U38MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U39MT41J64M16_DDR3_DDR3_96_SPEC_MTMT41J64M16LADDR3_96_SPEC
U40LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U41MIC49500_TAB_S-PAK-7_MIC49500MIC49500S-PAK-7
U42LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U43LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U44EP4S100G5_F1932_F1932_EP4S100G5EP4S100G5_F1932F1932
U45LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U46SI552_2_XTAL_SI570_SI552_570SI552_570XTAL_SI570
U47CY7C2563KV18_BB165A_CY7C1512KV1CY7C1512KV18BB165A
U48CY7C2563KV18_BB165A_CY7C1512KV1CY7C1512KV18BB165A
U49CY7C2563KV18_BB165A_CY7C1512KV1CY7C1512KV18BB165A
U50CY7C2563KV18_BB165A_CY7C1512KV1CY7C1512KV18BB165A
U51LTC2418_SSOP28_NAR_LTC2418LTC2418SSOP28_NAR
U52LTC2418_SSOP28_NAR_LTC2418LTC2418SSOP28_NAR
U53LT1761_SOT23-5_LT1761LT1761SOT23-5
U54LT1761_SOT23-5_LT1761LT1761SOT23-5
U55MIC69502_S-PAK-7_MIC69502MIC69502S-PAK-7
U56SI5338A_0_QFN24_SI5338ASi5338AQFN24
U57CY7C1480V25_165BGA_F165_CY7C148CY7C1480V25_F165F165
U58MIC69502_S-PAK-7_MIC69502MIC69502S-PAK-7
U59LT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDODFN8_EPAD
U60LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U61MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U62MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U63MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U64LT1761_SOT23-5_LT1761LT1761SOT23-5
U65M29EW_F64_M29EWM29EWF64
U6688E1111_BCC96_88E111188E1111BCC96
U67ICS83054I-01_0_TSSOP16_ICS83054ICS83054I-01TSSOP16
U68LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U69LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U70LM95235_MSOP8_LM95235LM95235MSOP8
U71LT3010_1_MSOP8-EPAD_LT3010LT3010MSOP8-EPAD
U72EPM2210F324_F324_EPM2210F324EPM2210F324F324
U73LT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDODFN8_EPAD
U74LT3080-1_DFN8_EPAD_LT3080-1/1.1LT3080-1/1.1A LDODFN8_EPAD
U75AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BSO8
U76ISL54050_UTQFN10_ISL54050ISL54050UTQFN10
U77LTM8023EV_0_LGA50_LTM8023EVLTM8023EVLGA50
U78SN65220DBV_SOT23-DBV_SN65220DBVSN65220DBVSOT23-DBV
U79FT245BL_LQFP-32_FT245BLFT245BLLQFP-32
U80EPM240M100_M100_EPM240M100EPM240M100M100
U81TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQPSOP-DGQ10
U82MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U83MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U84MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U85MAX3372EEKA_0_SOT23-8_MAX3373MAX3373SOT23-8
U86LTC3026_DFM10-EPAD_LTC3026LTC3026DFM10-EPAD
U87TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQPSOP-DGQ10
U88TPS51100_PSOP-DGQ10_TPS51100DGQTPS51100DGQPSOP-DGQ10
X1635L3C3_XTAL_EG2100_644.53125MH644.53125MHzXTAL_EG2100
X2XTAL_XTAL_PACK_D_25MHZ25MHzXTAL_PACK_D
X3OSC_ALT_ECS3525_ECS-3525-500-BECS-3525-500-BECS3525
X4OSC_ALT_XTAL_SG310_24MHZ24MHzXTAL_SG310
Y1CRYSTAL_XTAL_ABM3_25.000MHZ25.000MHzXTAL_ABM3
Y2CRYSTAL_XTAL_ABM3_25.000MHZ25.000MHzXTAL_ABM3
Y3CRYSTAL_XTAL_ABM3_25.000MHZ25.000MHzXTAL_ABM3
Y4CRYSTAL_XTAL_HC49_6.000MHZ6.000MHzXTAL_HC49
重要提示:PCB作品文件展下载说明
老吴 | 2018-9-30 11:09:26 | 显示全部楼层
PCB文件来了。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
bingo426 | 2018-9-30 11:44:14 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
b838899 | 2018-9-30 13:26:26 | 显示全部楼层
yong24hao | 2018-9-30 13:48:41 | 显示全部楼层
牛了,Altear的FPGA加速卡。
dukejue | 2018-9-30 14:07:32 | 显示全部楼层
hl646398140 | 2018-9-30 14:11:14 | 显示全部楼层
miaomiao | 2018-9-30 16:09:44 | 显示全部楼层
单枪舞九州 | 2018-9-30 18:53:02 | 显示全部楼层
yangxf0120 | 2018-9-30 19:37:09 | 显示全部楼层
