ARM9 Micro2440核心板原理图和PCB - 副本.zip
(562 KB, 下载次数: 0)
Comment | Designator | Footprint | Quantity | GREEN | 1,2, 3, 4 | LED | 4 | 22p | C1,C2 | 0603A | 2 | 100nF | C3,C7, C14, C15, C16, C17, C18, C19, C20, C21, C22, C23, C24, C25, C26, C27,C28, C29, C30, C31, C32, C33, C39, CA1, CA2, CA3, CA4, CA5, CA6, CA7, CA8,CA9, CA10, CA11, CA12, CA13, CA14, CA15, CA16, CA17, CA18, CA19, CA20, CA21,CA22, CA23 | 0603A | 46 | 10uF/10V | C4,C11 | 3216A | 2 | 15p | C5,C6 | 0603A | 2 | 10uF | C9,C12 | 3216A | 2 | 0.1uF | C10 | 0603A | 1 | 33nF/6.3V | C13 | 0603A | 1 | 104 | C34 | 0603A | 1 | 2n7 | C40 | 0603A | 1 | 680p | C41 | 0603A | 1 | CON2 | J1 | SIP2S | 1 | HEADER 5X2 | JTAG2 | IDC10S | 1 | 10K | NR1,NR2, NR3, NR4, R3, R4, R6, R58, R59, R60, R61 | 0603R | 11 | 1K | NR5,NR8, R40, R41, R42, R43, R57 | 0603R | 7 | RED | Power | LED | 1 | 330 | R1 | 0603R | 1 | 470 | R2 | 0603R | 1 | 15K | R10 | 0603R | 1 | 4.7K | R22,R68 | 0603R | 2 | 0 | R31 | 0603R | 1 | 100K(1%) | R32 | 0603r | 1 | 10(1%) | R33 | 0603r | 1 | 22 | R36,R54, R55, R63, R65, R66 | 0603R | 6 | SW-PB | RST | SW-PB2 | 1 | CON1 | TP1 | TP1 | 1 | S3C2440X | U1 | BGA289 | 1 | K9Fxx08 | U2 | TSOP48 | 1 | MAX8860EUA18 | U3 | MSOP8 | 1 | LM1117-33 | U4 | TO-252 | 1 | HY57V561620FTP-H | U6,U7 | TSOP54 | 2 | MAX811 | U9 | MAX811 | 1 | AM29LV160DB/SST39VF1601 | U10 | TSOP48 | 1 | 32.768kHz | X1 | XTAL-B | 1 | 12M | X2 | OSC2PR-1 | 1 |
