移动电源PCB
Comment | Description | Designator | Footprint | LibRef | Quantity | 150P | 104 | C1 | C0805 | CAP | 1 | 226 | 104 | C2, C4, C5 | C1210 | CAP | 3 | 105 | 104 | C3 | C1210 | CAP | 1 | 224 | 104 | C6 | C0805 | CAP | 1 | | Capacitor (Semiconductor SIM Model) | C7, C8, C9, C10, C11, C12, C14, C15, C18 | C0805 | Cap Semi | 9 | 104 | Capacitor (Semiconductor SIM Model) | C13 | C0805 | Cap Semi | 1 | 106 | 104 | C16, C17 | C1210 | CAP | 2 | SS34 | B34S | D1 | SS34 | DIODE_SCHOTTKY | 1 | BAT54C | Schottky Barrier Double Diode | D2, D3 | SOT23 | BAT54C | 2 | 2.6A/10V | Thermal Fuse | F1 | F1812 | Fuse Thermal | 1 | B+ | Socket | J1 | WIRE | Socket | 1 | B- | Socket | J2 | WIRE | Socket | 1 | 4.7uH | | L1 | L | INDUCTOR | 1 | GREEN_LED | green_Led 3mm | LED1, LED2, LED3, LED4 | LED3 | LED g | 4 | GREEN_LED | green_Led 3mm | LED5 | D0805 | LED g | 1 | 10K | Resistor | NTC1, R2, R4, R6, R14, R15, R17, R23, R31 | R0805 | Res3 | 9 | Header 3 | Header, 3-Pin | P1 | HDR1X3 | Header 3 | 1 | USBOUT | USB 1.1, Right Angle, Thru-Hole, Series A, Reverse Type, Receptacle, 4 Position, Black | P2 | USBHOST | 440314-1 | 1 | MicroUSB | USB 2.0, Right Angle, SMT, A Type, Receptacle, 5 Position, Black | P3 | MICROUSB | 440478-2 | 1 | FDN306P | P-CHANNEL | Q1, Q2 | SOT23 | FDN306P | 2 | 4401 | NPN General Purpose Amplifier | Q3 | SOT23 | 2N3904 | 1 | 8205 | DUAL N-CHANNEL | Q4 | SSOP8 | 8205 | 1 | 1M | Resistor | R1 | R0805 | Res3 | 1 | 30K | Resistor | R3 | R0805 | Res3 | 1 | 0.05R | Resistor | R5, R33 | R2010 | Res3 | 2 | 4.7K | Resistor | R7 | R0805 | Res3 | 1 | 150K | Resistor | R8 | R0805 | Res3 | 1 | 2K | Resistor | R9, R10, R11, R12, R19, R26, R32 | R0805 | Res3 | 7 | 100K | Resistor | R13 | R0805 | Res3 | 1 | 1K | Resistor | R16, R18, R20, R21 | R0805 | Res3 | 4 | 470R | Resistor | R22 | R0805 | Res3 | 1 | 75K | Resistor | R24, R25 | R0805 | Res3 | 2 | 51K | Resistor | R27, R28 | R0805 | Res3 | 2 | 0R | Resistor | R29 | R0805 | Res3 | 1 | 3K | Resistor | R30 | R0805 | Res3 | 1 | PB | Switch | S1 | SPST-2 | SW-PB | 1 | STM8S103F3P6 | | U1 | TSSOP20 | ST 8BIT MCU | 1 | LT1935 | LT1935 1.2MHz Boost DC/DC | U2 | SOT23-5 | LT1935 | 1 | HT33 | | U3 | SOT23 | AS1117 | 1 | MCP6022 | Dual Operational Amplifier | U4 | SSOP8 | LM2904PW | 1 | S-8261 | 单节锂电 | | | | |
评分
参与人数 1 | 威望 -5 |
收起
理由
老吴
| -5 |
http://bbs.ntpcb.com/read.php?tid=125192 |
查看全部评分
