SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | | DISCRETE | C1 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 1000pF | | DISCRETE | C2 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C3 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C4 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 4.7uF | | DISCRETE | C5 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C7 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C8 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C10 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | | DISCRETE | C11 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | | DISCRETE | C12 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C13 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C14 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | 10% | DISCRETE | C15 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C16 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7uF | 10% | DISCRETE | C17 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C18 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.016 | 4.7UF | | DISCRETE | C21 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | 10% | DISCRETE | C22 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7uF | 10% | DISCRETE | C23 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | 10% | DISCRETE | C24 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C25 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | 10% | DISCRETE | C26 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0MM | 1.0 UF | | DISCRETE | C28 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 24PF | | DISCRETE | C29 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C32 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_1 | 10UF | | DISCRETE | C34 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 24PF | | DISCRETE | C35 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C37 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 100PF | | DISCRETE | C38 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 0.1UF | | DISCRETE | C39 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | | DISCRETE | C40 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_2 | 10uF | | DISCRETE | C41 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C42 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C43 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | | DISCRETE | C45 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C46 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C47 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.64M | 0.1UF | 10% | DISCRETE | C49 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.0_2 | 10uF | | DISCRETE | C51 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C55 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C56 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C57 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 0.1UF | | DISCRETE | C58 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2uF | | DISCRETE | C59 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 0.1UF | | DISCRETE | C60 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 0.1UF | | DISCRETE | C61 |
LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | | IC | D1 |
LED_0603 | LED_LED_0603_IC_0.67MM_370-7656 | LED GREEN | | IC | D2 |
SOT323_3P | DUALDIODE_CA_SOT23_SOT323_3P_IC | BAT54AWT1G | | IC | D3 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D5 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D6 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D7 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D8 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D9 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D10 |
POWERDI-123_3MMX2MM | DIODE_SCHTKY_POWERDI-123_3MMX2M | DFLS130L-7 | | IC | D11 |
LED4_3P4X3MM_SMT | CLV1A_LED_4P_LED4_3P4X3MM_SMT_I | CLV1A-FKB-CJ1M1F1BB7R4S3 | | IC | D12 |
HDR208_ESQ_SKT | CONN_HDR_8X2_HDR208_ESQ_SKT_IO_ | CON_2X8 | | IO | J1 |
HDR210_ESQ_SKT | CONN_HDR_10X2_HDR210_ESQ_SKT_IO | SKT_2x10 | | IO | J2 |
HDR208_ESQ_SKT | CONN_HDR_8X2_HDR208_ESQ_SKT_IO_ | CON_2X8 | | IO | J3 |
HDR206_ESQ_SKT | CONN_HDR_6X2_HDR206_ESQ_SKT_IO_ | CON_2X6 | | IO | J4 |
HDR_5X2_FTSH_TH_NSP | CONN_HDR_5X2_HDR_5X2_FTSH_TH_NS | HDR 2X5 | | IO | J9 |
HDR_5X2_FTSH_TH_NSP | CONN_HDR_5X2_HDR_5X2_FTSH_TH_NS | HDR 2X5 | | IO | J10 |
CON_RJ45_8P_2P54_TH_RA | RJ45_RB1_125BAG1A_CON_RJ45_8P_2 | RB1-125BAG1A | | IO | J13 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | | IO | J14 |
CON8_SDCARD_PUSH_SM | CON8_SDCARD_SW_CON8_SDCARD_PUSH | CON microSD | | IO | J15 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.58MM_2 | HDR 1X2 | | IO | J21 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | | IO | J22 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38 MM_ | HDR_1X3 | | IO | J25 |
CON5_MICROUSB | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | | IO | J26 |
IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | | DISCRETE | L1 |
IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | | DISCRETE | L2 |
IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | | DISCRETE | L4 |
IND_1608 | BEAD_IND_1608_DISCRETE_0.95MM_1 | 330 OHM | | DISCRETE | L5 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 M_1 | 100 | 1% | DISCRETE | R2 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | R4 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | R5 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R6 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 4.7K | | DISCRETE | R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3108 | 180K | | DISCRETE | R11 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | R12 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R13 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R14 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 4.7K | | DISCRETE | R15 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R16 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-3029 | 220 | | DISCRETE | R17 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R20 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R21 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R22 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | R23 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | 5% | DISCRETE | R24 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R27 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R28 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 1.0K | 1% | DISCRETE | R29 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 15K | 1% | DISCRETE | R30 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R33 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 10.0K | 1% | DISCRETE | R35 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3032 | 100 | | DISCRETE | R36 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55 MM_ | 4.7K | 1% | DISCRETE | R37 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | 5% | DISCRETE | R38 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.55MM_4 | 10.0K | 5% | DISCRETE | R39 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R42 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R43 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R45 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 33 | | DISCRETE | R46 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 33 | | DISCRETE | R49 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R50 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R54 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R57 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7802 | 6.49K | | DISCRETE | R58 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R60 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R62 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R63 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3081 | 576 | | DISCRETE | R68 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3033 | 270 | | DISCRETE | R71 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3033 | 270 | | DISCRETE | R73 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.6MM_47 | 0 | 1% | DISCRETE | R74 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3032 | 100 | | DISCRETE | R76 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R79 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7539 | 0 | | DISCRETE | R80 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3051 | 130 | | DISCRETE | R88 |
RNET_38V_0603 | RESISTOR_ARRAY_RNET_38V_0603_DI | 33 | | DISCRETE | RN1 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_470 | 0 | | DISCRETE | SH1 |
SW2_4X3MM_SM | SW2_STM151XX_SW2_4X3MM_SM_IC_2M | SW2_STM151XX | | IC | SW1 |
SW2_4X3MM_SM | SW2_STM151XX_SW2_4X3MM_SM_IC_2M | SW2_STM151XX | | IC | SW2 |
SW2_4X3MM_SM | SW2_STM151XX_SW2_4X3MM_SM_IC_2M | SW2_STM151XX | | IC | SW3 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP1 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP2 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP3 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP4 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP5 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP6 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP7 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP8 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP9 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP10 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP11 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP12 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP13 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP14 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP15 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | | IO | TP17 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U1 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U2 |
XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | | IC | U3 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U4 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | | IC | U5 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U6 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U7 |
QFN5X3_0P5_3X3 | FXOS8700CQ_QFN_16P_QFN5X3_0P5_3 | FXOS8700CQ | | IC | U8 |
ULLGA6_1P45X1_0P5MM | NLU2GU04_ULLGA6_1P45X1_0P5MM_IC | NLX2G14 | | IC | U9 |
QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | | IC | U10 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | | IC | U11 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | | IC | U12 |
QFN24_4X4MM_SLUG | KSZ8081RNACA_QFN_24P_QFN24_4X4M | KSZ8081RNACA | | IC | U13 |
LQFP100_0P5_14X14 | K64FN1M0VLL12_100P_LQFP100_0P5_ | MK64FN1M0VLL12 | | IC | U14 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U15 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U16 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | | IC | U17 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | | IC | U18 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | | IC | Y1 |
XTAL4_3P4X2P7 | CRYSTAL13_XTAL4_3P4X2P7_IC_0.8M | 25MHZ | | IC | Y2 |
XTAL2-3P2X1P5-SM | XTAL_XTAL2-3P2X1P5-SM_IC_0.9MM_ | 32.768KHZ | | IC | Y3 |
