查看: 1838|回复: 1
[Allegro16.6以下] TWR-CM3120-EVM IO-Link主收发器塔式系统模块 6-1047
发表于 2018-11-29 22:22:45 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
TWR-CM3120-EVM.zip (3.94 MB, 下载次数: 6)
Date Thu Nov 29 21:18:04 2018
Bill of MaterialReport
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDES
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC5
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M4700PF DISCRETEC6
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M4700PF DISCRETEC8
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC9
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M2.2UF10%DISCRETEC10
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC11
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC12
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC13
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC14
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC16
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC17
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC18
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC19
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC20
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC21
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UF DISCRETEC22
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.59M18PF DISCRETEC23
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC24
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC25
CASE_D_ALCAP_POL_CASE_D_AL_DISCRETE_8MM_47UF DISCRETEC26
CASE_D_ALCAP_POL_CASE_D_AL_DISCRETE_8MM_47UF DISCRETEC27
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M4700PF DISCRETEC28
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.59M18PF DISCRETEC29
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M4700PF DISCRETEC30
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC50
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC51
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC52
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC53
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC54
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC55
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UF DISCRETEC56
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC57
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63522PF DISCRETEC58
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63522PF DISCRETEC59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UF DISCRETEC60
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.01610uF DISCRETEC61
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC65
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC66
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC67
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uF DISCRETEC68
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC70
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uF DISCRETEC71
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.01610uF DISCRETEC75
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD5
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD6
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD7
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD8
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD9
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD10
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD11
SMC_CASE403DIODE_SCHTKY_SMC_CASE403_IC_2.6B560C-13-F ICD12
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD13
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD14
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD15
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_LED/GRN ICD16
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD17
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD18
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD19
SOD123WDIODE_TVS_SOD123W_IC_1.1MM_480-PTVS33VS1UR ICD20
CASE403A_03ZDIODE_CASE403A_03_IC_2.56MM_41SMB5919BT3G ICD50
FUSE_2X1P4FUSE_FUSE_2X1P4_IC_0.55MM_510-MFU0805FF00500P100 ICF50
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWERSYSTEM IOJ5
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3 IOJ6
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3 IOJ7
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3 IOJ8
CON1X3_3P81_9P2X12P82CONN_HDR_3X1_CON1X3_3P81_9P2X12PLUG_1X3 IOJ10
CON5_TH_1436686CON5_DIN_CON5_TH_1436686_IO_15.1436686 IOJ12
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3 IOJ13
HDR203CONN_HDR_3X2_HDR203_IO_8.5MM_21HDR 2X3 IOJ14
HDR_5X2_FTSH_THCONN_HDR_5X2_HDR_5X2_FTSH_TH_IOHDR 2X5 IOJ15
PJ-102AHDC POWERJACK_PJ-102AH_IO_11MM_CON_1_PWR IOJ17
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ18
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ19
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ20
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ21
CON1X3_3P81_9P2X12P82CONN_HDR_3X1_CON1X3_3P81_9P2X12PLUG_1X3 IOJ24
CON5_TH_1436686CON5_DIN_CON5_TH_1436686_IO_15.1436686 IOJ25
CON5_USB_RA_SMTUSB_MINI_AB_RECEPTACLE_CON5_USBCONN USB MINI-B IOJ52
HDR_5X2_FTSH_THCONN_HDR_5X2_HDR_5X2_FTSH_TH_IOHDR 2X5 IOJ53
HDR106_TH_TSWCONN_HDR_6X1_HDR106_TH_TSW_IO_8HDR 1X6 IOJP6
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL50
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_330 OHM25%DISCRETEL51
SOT1220PMPB85ENEA_SOT1220_8P_SOT1220_IPMPB85ENEAX ICQ5
SOT1220PMPB85ENEA_SOT1220_8P_SOT1220_IPMPB85ENEAX ICQ6
SOT1220PMPB85ENEA_SOT1220_8P_SOT1220_IPMPB85ENEAX ICQ7
SOT1220PMPB85ENEA_SOT1220_8P_SOT1220_IPMPB85ENEAX ICQ8
SOT23-40X40NPN_SOT23-40X40_IC_1.1MM_480-78BC847C ICQ50
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER7
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER8
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER9
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER10
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER11
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER13
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER14
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER17
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER19
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER20
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_3.83K DISCRETER21
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER23
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER25
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410K DISCRETER26
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410K DISCRETER30
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER31
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER32
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER33
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410K DISCRETER34
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER35
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER36
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER37
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER38
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__15605%DISCRETER39
RC1206_OVRES_RC1206_OV_DISCRETE_0.65MM_40.5 DISCRETER40
RC1206_OVRES_RC1206_OV_DISCRETE_0.65MM_40.5 DISCRETER41
RC1206_OVRES_RC1206_OV_DISCRETE_0.65MM_40.5 DISCRETER42
RC1206_OVRES_RC1206_OV_DISCRETE_0.65MM_40.5 DISCRETER43
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER44
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER48
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER51
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410K DISCRETER52
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_0 DISCRETER53
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_12.2K DISCRETER54
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_12.2K DISCRETER57
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_472.2K DISCRETER59
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_472.2K DISCRETER60
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_12.2K DISCRETER61
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__133 DISCRETER63
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__133 DISCRETER64
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__23.3K DISCRETER65
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_333.0K DISCRETER66
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470 DISCRETER68
SW2_SPST_3P5X6P0_5P0SW2P_SW2_SPST_3P5X6P0_5P0_IC_5.EVQ-PE105K ICSW5
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP5
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP6
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP7
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP8
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP9
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP10
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP11
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP12
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_BLACK IOTP13
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP14
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP15
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM__1TESTLOOP_RED IOTP16
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP17
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP18
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP19
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP20
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP21
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP22
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP57
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP58
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP64
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP66
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP67
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP68
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP69
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP70
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP71
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP72
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP73
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP74
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP75
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP76
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP77
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP78
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP79
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP80
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP81
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP82
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP83
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP84
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP85
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP86
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP87
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP88
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP89
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030 IOTP90
QFN32_S142EPKL17Z64VF_QFN_32P_EP_QFN32_S142MKL17Z64VFM4 ICU5
TSSOP8ATMEL_SERIAL_EEPROM_64K-1_TSSOP24FC256 ICU6
SOT23_ADIODE_2LINE_ESD_SOT23_A_IC_1.15GSOT05C-GS08 ICU7
QFN48_0P5_7X7_EP3P9_NSPMC34CM3120_48P_QFN48_0P5_7X7_EPMC34CM3120EP ICU8
QFN48_0P5_7X7_EP3P9_NSPMC34CM3120_48P_QFN48_0P5_7X7_EPMC34CM3120EP ICU9
QFN_48_0P5_7X7MKL25Z128VFT4_49P_QFN_48_0P5_7XMKL25Z128VFT4 ICU50
SOT223LD1117AS18_SOT223_IC_1.8MM_312-NCP1117ST33T3G ICU51
WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P190UK ICU52
WLCSP4_0P4_0P8X0P8_SMDPADP172_CSP_4P_WLCSP4_0P4_0P8X0PNX3P190UK ICU53
XTAL_4_7X5XTAL_13Y_XTAL_4_7X5_IC_1.2MM_2314.7456MHZ ICY5
XTLOSC4_5X3MM_SMCRYSTAL_JXS63_XTLOSC4_5X3MM_SM_8MHZ ICY50
重要提示:PCB作品文件展下载说明
  • 签到天数: 19 天
    发表于 2024-7-10 16:53:08 | 显示全部楼层
