Bill of MaterialReport |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_TOL | COMP_CLASS | REFDES |
SKT_BAT_780X1210 | BATTERY_SKT_3V_SKT_BAT_780X1210 | BK-883 | | IC | BT3 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C3 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-785 | 4.7uF | | IC | C4 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C5 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C6 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C7 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C8 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C9 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C10 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C11 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C12 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C13 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1.25M | 2.2UF | | DISCRETE | C14 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C15 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C16 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.87 | 1000PF | | DISCRETE | C17 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C18 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C19 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C20 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C21 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C22 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C23 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C24 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C25 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C26 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C27 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C28 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C29 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.01UF | | DISCRETE | C30 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C31 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C32 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C33 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C34 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.965 | 0.01UF | | DISCRETE | C35 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C36 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.90M | 18PF | | DISCRETE | C37 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C38 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C39 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C40 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C41 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C42 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 10UF | | DISCRETE | C43 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C44 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C45 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C46 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C47 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C48 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.97 | 0.1UF | | DISCRETE | C49 |
DIODE_3P2X2P2 | LED_DIODE_3P2X2P2_IC_1.1MM_480- | QTLP610CIR | | IC | D3 |
LED_0603_C1 | LED_LED_0603_C1_IC_0.8MM_370-_1 | ORANGE | | IC | D4 |
LED_0603_C1 | LED_LED_0603_C1_IC_0.8MM_370-75 | LED_YELLOW | | IC | D5 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-76 | YEL/GRN | | IC | D6 |
LED_0603_C1 | LED_LED_0603_C1_IC_1.0MM_370-76 | YEL/GRN | | IC | D7 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | | IC | D8 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_3 | LED_OR + ELECTRODE | | IC | D9 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_2 | LED_YEL + ELECTRODE | | IC | D10 |
SOT-23 | BAT721B_SOT-23_IC_1.3MM_480-779 | BAT54C | | IC | D11 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7 | MSS1P3L | | IC | D12 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_1 | LED_GRN + ELECTRODE | | IC | D13 |
LED2_ELECTRODE | LED2_ELECTRODE_LED2_ELECTRODE_4 | LED2_ELECTRODE | | IC | D14 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | HDR 1X2 TH | | IO | J3 |
HDR2X4_TSM_SM | CONN_HDR_4X2_HDR2X4_TSM_SM_IO_9 | HDR_2x4 | | IO | J4 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J5 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | HDR 1X2 TH | | IO | J6 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M__1 | CON_2X10 | | IO | J7 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | | IO | J8 |
CON_TFM_20M_50_SM | CONN_SHRHDR_10X2_CON_TFM_20M_50 | CON_2X10 | | IO | J9 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS TOWERSYSTEM | | IO | J10 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | HDR 1X2 TH | | IO | J11 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.6MM_21 | HDR TH 1X3 | | IO | J12 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | HDR 1X2 TH | | IO | J13 |
CON_FTSH_20M_50_SM | CONN_HDR_10X2_CON_FTSH_20M_50_S | HDR_2X10 | | IO | J14 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.71MM_ | HDR 1X2 TH | | IO | J15 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | | IO | J16 |
HDR203_TSM_SM | CONN_HDR_3X2_HDR203_TSM_SM_IO_9 | HDR_2X3 | | IO | J17 |
CON_SDCARD_13F_SM_RA_511 | CONN_SDCARD_1X13_F_511_CON_SDCA | SD/MMC SKT | | IO | J18 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L3 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05MM_ | 330 OHM | | DISCRETE | L4 |
IND_0805 | BEAD_IND_0805_DISCRETE_1.05MM_ | 330 OHM | | DISCRETE | L5 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L6 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L7 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L8 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | | IC | L9 |
QTLP610 | TRAN_PHOTO_QTLP610_IC_1.1MM_480 | QTLP610CPD | | IC | Q3 |
SOT23 | NPN_SOT23_IC_1.12MM_480-75173_ | MMBT3904LT1G | | IC | Q4 |
SOT-23 | TRAN_NPN_RES_SOT-23_IC_1.3MM_48 | PDTC115T | | IC | Q5 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R3 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R4 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R5 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R6 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R7 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R8 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R9 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R10 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R11 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R12 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R13 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R14 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R15 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R16 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R17 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R18 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R19 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R20 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R21 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R22 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R23 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3085 | 1.54K | | DISCRETE | R24 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7646 | 330 | | DISCRETE | R26 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R27 |
RC0402_25 | RES_RC0402_25_DISCRETE__470-760 | 1.0K | | DISCRETE | R28 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R29 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R30 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3078 | 270 | | DISCRETE | R31 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R33 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R34 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R35 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R36 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R37 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R38 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | | DISCRETE | R39 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R40 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R41 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R42 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R43 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R44 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R45 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R46 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | | DISCRETE | R47 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-3091 | 4.99K | | DISCRETE | R48 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R49 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R50 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R51 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R52 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R53 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R54 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R55 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R56 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R57 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R58 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R59 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R60 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R61 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R62 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R63 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R64 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R65 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R66 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R67 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R68 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R69 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R70 |
POT3_3352T | POT_POT3_3352T_DISCRETE_470-801 | 5K | | DISCRETE | R71 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R72 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R73 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R74 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 4.70K | | DISCRETE | R75 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R76 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R77 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7543 | 4.70K | | DISCRETE | R78 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R79 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R80 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R81 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R82 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R83 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R84 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 1.0M | | DISCRETE | R85 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R86 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R87 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R88 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R89 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R90 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R91 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7603 | 1.0K | | DISCRETE | R92 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R93 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7584 | 1.0M | | DISCRETE | R94 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R95 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R96 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R97 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R98 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R99 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7579 | 33 | | DISCRETE | R100 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R101 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R102 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R103 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | | DISCRETE | R104 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R105 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R106 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R107 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7648 | 10M | | DISCRETE | R108 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R109 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | | DISCRETE | R110 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R111 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R112 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R113 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R114 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7541 | 10.0K | | DISCRETE | R115 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7835 | 2.2K | | DISCRETE | R116 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R117 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R118 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R119 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R120 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R121 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R122 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R123 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R124 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R125 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R126 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R127 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R128 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7540 | 0 | | DISCRETE | R129 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | | IC | SW3 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | | IC | SW4 |
SW4_4MM | SW_TACT-SPST-2_SM_SW4_4MM_IC_4. | PB switch | | IC | SW5 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP3 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP4 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP5 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP6 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP7 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP8 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | | IO | TP9 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP10 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP11 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP12 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_210 | TEST POINT BLACK | | IO | TP13 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8MM_21 | TEST POINT WHITE | | IO | TP14 |
TSSOP20 | 74LVC573A_TSSOP20_IC_1.2MM_312- | 74LVC573A | | IC | U3 |
SKT_BGA144_1_18X18_CUSTOM | MARCONI_SKT_BGA144_1_18X18_CUST | MK40X256VMD100+SKT12X12 144BGA | | IC | U4 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | | IC | U5 |
SOT223 | LT1129CST-3.3_SOT223_IC_1.8MM_3 | MIC2920A-3.3WS | | IC | U6 |
TSSOP-14 | 74_04_TSSOP-14_IC_1.2MM_312-753 | SN74LVC04APWE4 | | IC | U7 |
DFN_10_0P5_3X3A | MMA7660FC_DFN_10_0P5_3X3A_IC_1M | MMA7660FC | | IC | U8 |
SOIC14 | 74-125_14P_SOIC14_IC_1.75MM_312 | 74HCT125 | | IC | U9 |
SOT_143 | SPB0503_SOT_143_IC_1.22MM_480-7 | SP0503B | | IC | U10 |
TQFP44 | MC9S08JM60CFGE_TQFP44_IC_1.60M | MC9S08JM60CLD | | IC | U11 |
TSSOP14 | 74LVC125_TSSOP14_IC_1.2MM_312-7 | 74LVC125 | | IC | U12 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC__ | 8.00MHZ | | IC | X3 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_IC_2.25MM_230- | 32.768KHz | | IC | Y3 |
XTL2_ECS_CSM7_SM | XTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_ | 4MHz | | IC | Y4 |
