这是一个生成obong pad的skill,在15.7中可以正常使用,但在16.01 中会报错!
直接关闭程序!!
请大侠帮忙看下!
代码如下:
axlCmdRegister( "test_mt" 'test_mt)
defun( test_mt ()
"T123X100R080X060"
"TR108X87_16X13"
pad_X=123
pad_Y=100
drill_ref_X=108
drill_ref_Y=87
pad_pow_x=drill_ref_X
pad_pow_y=drill_ref_Y
drill_X=80
drill_Y=60
pad_name="T123X100R080X060"
flash_name="TR128X107_108X087_016_013"
drill_data = make_axlPadStackDrill(?holeType "OVAL_SLOT" ?slotSize drill_X:drill_Y?drillChar "" ?plating &quotLATED")
println("pad1")
pad_list = cons(make_axlPadStackPad(?layer "TOP" ?type "REGULAR" ?figure "OBLONG" ?figureSize pad_X:pad_Y) nil)
; pad_list = cons(make_axlPadStackPad(?layer "TOP" ?type "THERMAL" ?figure "FLASH" ?figureSize pad_pow_x:pad_pow_y ?flash flash_name) pad_list)
; pad_list = cons(make_axlPadStackPad(?layer "TOP" ?type "ANTIPAD" ?figure "OBLONG" ?figureSize pad_pow_x:pad_pow_y) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "DEFAULT INTERNAL" ?type "REGULAR" ?figure "OBLONG" ?figureSize drill_ref_X:drill_ref_Y) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "DEFAULT INTERNAL" ?type "THERMAL" ?figure "FLASH" ?flash flash_name) pad_list)
; pad_list = cons(make_axlPadStackPad(?layer "DEFAULT INTERNAL" ?type "THERMAL" ?figure "FLASH" ?figureSize pad_pow_x:pad_pow_y ?flash flash_name) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "DEFAULT INTERNAL" ?type "ANTIPAD" ?figure "OBLONG" ?figureSize (pad_pow_x+2)pad_pow_y+2)) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "BOTTOM" ?type "REGULAR" ?figure "OBLONG" ?figureSize pad_X:pad_Y) pad_list)
; pad_list = cons(make_axlPadStackPad(?layer "BOTTOM" ?type "THERMAL" ?figure "FLASH" ?figureSize pad_pow_x:pad_pow_y ?flash flash_name) pad_list)
; pad_list = cons(make_axlPadStackPad(?layer "BOTTOM" ?type "ANTIPAD" ?figure "OBLONG" ?figureSize pad_pow_x:pad_pow_y) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "SOLDERMASK_TOP" ?type "REGULAR" ?figure "OBLONG" ?figureSize (pad_X+4)pad_Y+4)) pad_list)
pad_list = cons(make_axlPadStackPad(?layer "SOLDERMASK_BOTTOM" ?type "REGULAR" ?figure "OBLONG" ?figureSize (pad_X+4)pad_Y+4)) pad_list)
println(pad_name)
println(drill_data)
println(pad_list)
ps_id = axlDBCreatePadStack(pad_name drill_data pad_list t)
晕死!!
我想打“:( ”却变成 而 “ :) ” 却是 。
郁闷!!
[ 本帖最后由 年薪十块 于 2008-12-2 17:02 编辑 ] |
