重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CN3 | CON6_DIP | PIC_ICD2 | CON6_DIP | D1 | SOD123 | 1N4148 | SOD123 | D3 | DO214AC | SS24 | DO214AC | D4 | DO214AC | SS34 | DO214AC | D5 | DO214AC | SS34 | DO214AC | D6 | DO214AC | SS34 | DO214AC | D8 | SOD123 | 1N5819 | SOD123 | D9 | SOD123 | NC | SOD123 | D11 | DO214AC | SS34 | DO214AC | D12 | DO214AC | SS24 | DO214AC | D14 | SOT23 | BAT54C | SOT23 | D15 | SOT23 | BAT54C | SOT23 | D19 | SOD123 | 1N4148 | SOD123 | D20 | SOT23 | BAT54C | SOT23 | D21 | DO214AC | SS14 | DO214AC | D22 | DO214AC | NC | DO214AC | D23 | SOD123 | NC | SOD123 | D31 | SOT23 | BAT54S | SOT23 | ED25 | E0402N | ESD9B5V | E0402N | ED31 | E0402N | NC/ESD9B5V | E0402N | ED39 | E0402N | NC/ESD9B5V | E0402N | ED41 | E0402N | NC/ESD9B5V | E0402N | F1 | F1808 | R30-250 | F1808 | FB1 | L0603 | BLM18EG601SN1 | L0603 | FB2 | L0603 | BLM18EG601SN1 | L0603 | FB3 | L0603 | BLM18EG601SN1 | L0603 | FB4 | L0603 | BLM18EG601SN1 | L0603 | J2 | CON4_2.0 | CON4_SIP_2.54MM | CON4_2.0 | J5 | USBCON4B | USB-HOSTX1 | USBCON4B | J6 | SD_MMC_UP_BOARD | SD_MMC_UP_BOARD | SD_MMC_UP_BOARD | J7 | USBCON4B | USB-HOSTX1 | USBCON4B | J8 | CON3_2.54 | BAT | CON3_2.54 | J10 | HDMI | HDMI | HDMI | J11 | FPC_CAM_24_05 | CON24_CA | FPC_CAM_24_05 | J15 | CON6_2.0 | CON6 | CON6_2.0 | J17 | FPC_CON6 | CON6 | FPC_CON6 | J18 | CON6_2X2 | CON6_2X2 | CON6_2X2 | J25 | CON4_2.0 | CON4 | CON4_2.0 | J26 | CON2_2.0A | CON2 | CON2_2.0A | J27 | CON4_2.0 | CON4 | CON4_2.0 | J28 | CON4_2.0 | CON4 | CON4_2.0 | J29 | CON4_2.0 | CON4 | CON4_2.0 | J30 | CON4_2.0 | CON4 | CON4_2.0 | J31 | CON6_2.0 | CON6 | CON6_2.0 | J32 | CON4_2.0 | CON4 | CON4_2.0 | J33 | CON3_2.0 | CON3 | CON3_2.0 | J34 | CON3_2.0 | CON3 | CON3_2.0 | J35 | CON4_DIP | CON4 | CON4_DIP | J36 | CON3_1.25DIP | CON3 | CON3_1.25DIP | J37 | CON2_DIP | CON2 | CON2_DIP | L2 | SMD5X5 | 2.2UH/3A | SMD5X5 | L3 | SMD5X5 | 2.2UH/3A | SMD5X5 | L4 | IND-3X3 | 2.2UH/1A | IND-3X3 | L5 | IND-4X4 | 2.2UH/1.5A | IND-4X4 | L7 | L0603 | F.B. | L0603 | L8 | SMD6X6 | 3.3UH/2.8A | SMD6X6 | L10 | L0603 | BLM18PG121SN1 | L0603 | L11 | L0603 | BLM18PG121SN1 | L0603 | L12 | L0402 | NC | L0402 | L13 | L0402 | NC | L0402 | L14 | L0603 | BLM18PG121SN1 | L0603 | L15 | L0603 | BLM18PG121SN1 | L0603 | L16 | L0603 | BLM18PG121SN1 | L0603 | L17 | IND-3X3 | 2.2UH/1A | IND-3X3 | L18 | L0603 | BLM18PG121SN1 | L0603 | L19 | L0603 | F.B. | L0603 | L20 | SMD6X6 | NC | SMD6X6 | L22 | SMD6X6 | 3.3UH/2.8A | SMD6X6 | L23 | IND-4X4 | 3.3UH/1A | IND-4X4 | Q3 | SOT23 | 8050 | SOT23 | Q4 | SOT23 | SS8050LD | SOT23 | Q5 | SOP8 | FDS9435A(SUN2309) | SOP8 | Q7 | SOT23 | SI2305 | SOT23 | Q8 | SOT23 | 8050 | SOT23 | Q9 | SOT23 | SS8050LD | SOT23 | Q10 | SOT23 | SI2305 | SOT23 | Q11 | SOT23 | SI2305 | SOT23 | Q12 | SOT23 | 8050 | SOT23 | Q13 | SOT23 | SS8050LD | SOT23 | Q15 | SOT23 | SI2305 | SOT23 | Q17 | SOT23 | 8050 | SOT23 | Q18 | SOT23 | WNM2021/2SK3018 | SOT23 | Q19 | SOT23 | WNM2021/2SK3018 | SOT23 | Q20 | SOT23 | WNM2021/2SK3018 | SOT23 | Q21 | SOT23 | 8050 | SOT23 | Q22 | SOT23 | WPM2341 | SOT23 | Q24 | SOT23 | WNM2021/2SK3018 | SOT23 | Q25 | SOT23 | WNM2021/2SK3018 | SOT23 | Q26 | SOT23 | WNM2021/2SK3018 | SOT23 | Q29 | SOT23 | WNM2021/2SK3018 | SOT23 | Q30 | SOT23 | WNM2021/2SK3018 | SOT23 | Q31 | SOT23 | WNM2021/2SK3018 | SOT23 | S2 | SK-12D07 | SK-12D07 | SK-12D07 | SW6 | IT_1207SMD | RST | IT_1207SMD | SW7 | IT_1207SMD | RST | IT_1207SMD | TR2 | R0402 | F02_104J4A | R0402 | U1 | BGA453-19X19 | RK3188 | BGA453-19X19 | U2 | BGA78 | DDR3_256M_8BIT | BGA78 | U3 | BGA78 | DDR3_256M_8BIT | BGA78 | U4 | BGA78 | DDR3_256M_8BIT | BGA78 | U5 | BGA78 | DDR3_256M_8BIT | BGA78 | U6 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U7 | TSOP1-48 | NAND_FLASH | TSOP1-48 | U9 | INAND_1 | INAND | INAND_1 | U10 | FE1_IC | FE1.1S | FE1_IC | U11 | LQFP_64 | AX88772A | LQFP_64 | U12 | QFN64_6612 | IT66121FN | QFN64_6612 | U13 | QFN28_8323 | ES8323 | QFN28_8323 | U16 | SOT25 | UP7534GMA5-10/SY6280AAC | SOT25 | U17 | TSSOP8 | AT93C66A | TSSOP8 | U18 | SOT25 | UP7534GMA5-10/SY6280AAC | SOT25 | U19 | SOT25 | UP7534GMA5-10/SY6280AAC | SOT25 | U20 | CRY-D3225 | 12M | CRY-D3225 | U21 | SOT23 | ME083A263X/CE8809C263MA | SOT23 | U22 | CRY-D3225 | 25M | CRY-D3225 | U29 | SLP2510P8 | RCLAMP0524J/ESDA6V8UD | SLP2510P8 | U30 | MSOP8 | HYM8563/TCS9563 | MSOP8 | U31 | MSOP8 | HYM8563/TCS9563 | MSOP8 | U36 | RK903 | RK903/RK901 | RK903 | U38 | SLP2510P8 | RCLAMP0524J/ESDA6V8UD | SLP2510P8 | U51 | SOP8E | LA8533PG | SOP8E | U52 | SOT23 | CE8808N33M | SOT23 | U53 | SOP8E | LA8533PG | SOP8E | U54 | TDFN10-3X3 | TT8514 | TDFN10-3X3 | U55 | SOP14 | PIC16F1824 | SOP14 | U61 | I-PEX | RFANT5220 | I-PEX | U62 | RS232 | TRS3232CDR | RS232 | U63 | RS232 | TRS3232CDR | RS232 | U65 | CON30_2.0A | CON30 | CON30_2.0A | U72 | SOP8 | NC | SOP8 | U74 | H1102 | TRC41604NL | H1102 | U75 | SOT26 | SY8009B | SOT26 | U76 | QFN48-6X6 | ACT8846QM460 | QFN48-6X6 | U81 | SOP20_G8123 | GM8123 | SOP20_G8123 | U82 | SOP8 | SJ8305 | SOP8 | U83 | SOP8 | SJ8305 | SOP8 | U84 | THC63LVD827 | THC63LVD827 | THC63LVD827 | U85 | TO92ECB | IR | TO92ECB | Y1 | CRY-MC146 | 32.768K | CRY-MC146 | Y2 | CRY-D3225 | 24M-20PPM | CRY-D3225 | Y3 | CRY-D3225 | 7V2600001 | CRY-D3225 | Y4 | CRY-D3225 | 12M | CRY-D3225 | Y5 | CRY-D3225 | 12M-20PPM | CRY-D3225 | Y7 | CRY-MC146 | 32.768K | CRY-MC146 |
重要提示:PCB作品文件展下载说明
