重要提示:PCB作品文件展下载说明
论坛上类似这个的有几个,不过没有重复一样的。
Name | PCB Decal | Value | Part Type | 8D7 | ESD0402 | | ESD0402 | ANT1 | ANT_JACK | ANT | ANT_JACK | CM2 | MTM-C | NC/100UF/16V | MTM-C | CM4 | C0805 | | C0805 | CM5 | MTM-C | | MTM-C | CM6 | C0805 | | C0805 | CP1 | C0402 | | C0402 | D2 | SOD123 | 1N5819 | SOD123 | D4 | SOD123 | NC/1N5819 | SOD123 | D19 | SOD123 | | SOD123 | D2201 | SOD323 | BZT52C5V6 | SOD323 | D2202 | SOT23 | | SOT23 | D5000 | DO-214AC(SMA) | | DO-214AC(SMA) | D5001 | SOD123 | | SOD123 | DJ1 | DQT-003 | DQT-003 | DQT-003 | DP1 | SOD-123 | | SOD-123 | EC7000 | C0805 | | C0805 | EC7001 | C0805 | | C0805 | ED3 | E0402N | NC/ESD9B5V | E0402N | ED24 | SOT23 | NC/ESDA6V8UL/AZC199-02S | SOT23 | H2 | H3.8MM | H3.8MM | H3.8MM | H3 | H3.8MM | H3.8MM | H3.8MM | H4 | H3.8MM | H3.8MM | H3.8MM | J1 | JACK\DC | | JACK\DC | J2 | SD_F03 | TF_SD_SOCKET | SD_F03 | J3 | HDMI_A | HDMI_A | HDMI_A | J4 | DC-7.4X5.9-5PN | PHONEJACK | DC-7.4X5.9-5PIN | J5 | BATTERY2PIN | | BATTERY2PIN | J16 | UART-DEBUG | NC/UART-DEBUG | UART-DEBUG | J5000 | FPC50-A | | FPC50-A | J7001 | SPKPAD | | SPKPAD | J7505 | 30PIN2_0_1 | | 30PIN2_0_1 | J7507 | BL6PIN2_0 | | BL6PIN2_0 | J7508 | 10PIN | GLIDE PAD CNN | 10PIN | J7509 | 10PIN | GLIDE PAD CNN | 10PIN | J7510 | PJ-327F | | PJ-327F | JP1 | RJ45-8P8C-MJ88 | RJ45S | RJ45-8P8C-MJ88 | L2 | PL0303-CD54 | | PL0303-CD54 | L6 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L7 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L9 | IND-3X3 | 2.2UH/1A | IND_3X3 | L10 | IND-3X3 | SWPA3015S3R3NT/1A | IND_3X3 | L11 | L0603 | BLM18PG181SN1 | L0603 | L12 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L15 | IND-3X3 | 2.2UH/1.5A | IND-3X3 | L26 | IND-4X4 | SWPA5020SR24NT/5A | IND-4X4 | L27 | IND-4X4 | SWPA5020SR24NT/5A | IND-4X4 | L5000 | IND-4X4 | | IND-4X4 | MIC7000 | MIC_D4_2X2_5 | | MIC_D4_2X2_5 | Q1 | SOT23 | WNM2021/2SK3018 | SOT23 | Q2 | SOT23 | WNM2021/2SK3018 | SOT23 | Q7 | SOT23 | NC/8050 | SOT23 | Q8 | SOT23 | NC/WNM2021/2SK3018 | SOT23 | Q22 | SOT23 | WPM2015 | SOT23 | Q2206 | SOT23 | NC/WPM2015 | SOT23 | Q2208 | SOT23 | NC/8050 | SOT23 | Q2210 | SOT23 | | SOT23 | Q7000 | SOT23 | | SOT23 | Q7001 | SOT23 | | SOT23 | Q7002 | SOT23 | | SOT23 | Q7004 | SOP8-BL | | SOP8-BL | Q7007 | SOT23 | | SOT23 | SW1 | TK-TS-03PV | | TK-TS-03PV | SW2200 | TC-0514 | | TC-0514 | T1 | MARK | MARK | MARK | T2 | MARK | MARK | MARK | T4 | MARK | MARK | MARK | T6 | MARK | MARK | MARK | U1 | BGA636_1 | MCU_RK3288 | BGA636_1 | U2 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U3 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U4 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U5 | FBGA96-10X14 | DDR3_128MX16BIT | FBGA96-10X14 | U6 | TSOP1-48A | NAND_FLASH | TSOP1-48 | U7 | INAND_169_A | EMMC | INAND_169_A | U8 | TSOP1-48 | TSD_FLASH | TSOP1-48 | U14 | SOT25 | SY6280AAC/WS4601 | SOT25 | U15 | SOT25 | PT5108E23E-18 | SOT25 | U16 | SLP2510P8 | NC/RCLAMP0524PA/ESD5304 | SLP2510P8 | U17 | SLP2510P8 | NC/RCLAMP0524PA/ESD5304 | SLP2510P8 | U19 | SOIC24 | H5007(PULSE) | SOIC24 | U20 | QFN48-6X6 | RTL8211E-VB-CG | QFN48-6X6 | U21 | SOT23 | NC/CE8809C263MA | SOT23 | U22 | TSOP-6 | NC/NL27WZU04 | TSOP-6 | U23 | AP6XXX | AP6335 | AP6XXX | U24 | SOT25 | NC/PT5108E23E-15 | SOT25 | U27 | SOT25 | NC/SY6280AAC/WS4601 | SOT25 | U30 | MSOP8 | HYM8563 | MSOP8 | U35 | WLCSP-20 | SYR827 | WLCSP-20 | U36 | WLCSP-20 | SYR828 | WLCSP-20 | U76 | QFN48-6X6 | ACT8846QM490-T | QFN48-6X6 | U78 | SOT25 | | SOT25 | U2208 | SOT23 | NC/ZEN056 | SOT23 | U5000 | BL10PIN2 | | BL10PIN2 | U7000 | ES8323D | | ES8323D | U7001 | MSOP8 | | MSOP8 | U7002 | MSOP8 | | MSOP8 | U7003 | SOP8H-50-155 | | SOP8H-50-155 | USB1 | USB-2 | | USB-2 | USB2 | USB8PIN | | USB8PIN | Y2 | CRY-D3225 | 24M-20PPM | CRY-D3225 | Y3 | CRY-D3225 | 25MHZ-30PPM | CRY-D3225 | Y4 | CRY-D3225 | 37.4MHZ-10PPM | CRY-D3225 | Y5 | CRY_MC146 | 32.768KHZ | CRY_MC146 |
重要提示:PCB作品文件展下载说明
