SCH:
PCB:
PCB 3D:
实物图:
变压器绕组:
AD设计资料:
其它资料:
NO. | Number | Package | Device Name | Description | Quantity | Unit | Designator | 1 | 1 | 1206 | SMD Resistor | 1206-750.00K-5%-0.250W | 3 | Pcs | R23,R24,R25 | 1 | 2 | 1206 | SMD Resistor | 1206-330.00K-5%-0.250W | 3 | Pcs | R27,R32,R42 | 1 | 3 | 1206 | SMD Resistor | 1206-510.00K-1%-0.250W | 3 | Pcs | R12,R18,R26 | 1 | 4 | 1206 | SMD Resistor | 1206-130.00K-5%-0.250W | 3 | Pcs | R22,R30,R37 | 1 | 5 | 1206 | SMD Resistor | 1206-430.00K-5%-0.250W | 4 | Pcs | R38,R39,R40,R41 | 1 | 6 | 1206 | SMD Resistor | 1206-001.60R-1%-0.250W | 5 | Pcs | R3,R4,R5,R6,R7 | 1 | 7 | 1206 | SMD Resistor | 1206-001.80R-1%-0.250W | 1 | Pcs | R8 | 1 | 8 | 1206 | SMD Resistor | 1206-091.00K-1%-0.250W | 2 | Pcs | R19,R20 | 1 | 9 | 1206 | SMD Resistor | 1206-004.70K-5%-0.250W | 1 | Pcs | R36 | 1 | 10 | 1206 | SMD Resistor | 1206-030.00K-5%-0.250W | 1 | Pcs | R34 | 1 | 11 | 1206 | SMD Resistor | 1206-047.00K-5%-0.250W | 1 | Pcs | R15 | 2 | 12 | 0805 | SMD Resistor | 0805-015.00K-1%-0.125W | 1 | Pcs | R2 | 2 | 13 | 0805 | SMD Resistor | 0805-016.00K-1%-0.125W | 1 | Pcs | R9 | 2 | 14 | 0805 | SMD Resistor | 0805-001.20K-5%-0.125W | 1 | Pcs | R21 | 2 | 15 | 0805 | SMD Resistor | 0805-270.00R-5%-0.125W | 1 | Pcs | R1 | 2 | 16 | 0805 | SMD Resistor | 0805-091.00R-5%-0.125W | 1 | Pcs | R14 | 2 | 17 | 0805 | SMD Resistor | 0805-082.00R-5%-0.125W | 1 | Pcs | R16 | 2 | 18 | 0805 | SMD Resistor | 0805-047.00K-5%-0.125W | 1 | Pcs | R13 | 2 | 19 | 0805 | SMD Resistor | 0805-004.70R-5%-0.125W | 1 | Pcs | R17 | 2 | 19 | 0805 | SMD Resistor | 0805-020.00R-5%-0.125W | 1 | Pcs | R43 | | 20 | Φ4.5mm*11mm | Carbon Film Resister | 4.7K-5%-1W-Φ4.5mm*11mm | 2 | Pcs | R10,R11 | | 21 | Φ4.5mm*11mm | Carbon Film Resister | 100K-5%-1W-Φ4.5mm*11mm | 1 | Pcs | R35 | | 22 | Φ3.2mm*11mm | Carbon Film Resister | 10R-5%-0.5W-Φ3.2mm*11mm | 1 | Pcs | R29 | 5 | 23 | 0805 | SMD Capacitor | 0805-X7R-68nF-10%-025V | 2 | Pcs | C1,C3 | 5 | 24 | 0805 | SMD Capacitor | 0805-X7R-2.2uF-10%-025V | 1 | Pcs | C2 | 5 | 25 | 1206 | SMD Capacitor | 1206-X7R-4.7nF-10%-630V | 1 | Pcs | C5 | 3 | 26 | 13*8*16 | X Capactor | 220nF-310Vac-Pin10-13*8*16 | 1 | Pcs | CX1 | 3 | 27 | 6mm*13mm | Y Capactor | 2.2nF-400Vac-Pin10-6*13 | 2 | Pcs | CY1,CY2 | 3 | 28 | 11*5*11 | CBB Capactor | 100nF-630V-Pin10-11*5*11 | 1 | Pcs | CBB1 | 3 | 29 | 11*6.5*11 | CBB Capactor | 220nF-630V-Pin10-11*6.5*11 | 1 | Pcs | CBB2 | 3 | 30 | Φ10mm*20mm | Elec capacitors | 330uF-50V-Pin5-Φ10*16 | 3 | Pcs | CE4,CE5,CE6 | 3 | 31 | Φ10mm*12mm | Elec capacitors | 6.8uF-450V-Pin5-Φ10*12 | 1 | Pcs | CE3 | 3 | 33 | Φ5mm*11mm | Elec capacitors | 22uF-50V-Pin2-Φ5*11 | 2 | Pcs | CE1,CE2 | | 34 | Φ10mm*16mm | DM Inductor | 2.0mH-10%-Pin6-Φ10*16 | 2 | PCS | L1,L2 | | 34 | Φ10mm*12mm | DM Inductor | 2.0mH-10%-Pin6-Φ10*12 | 1 | PCS | L3 | | 35 | Φ9*Φ5*5mm | CM Incuctor | 600uH-20%-Φ9*Φ5*5mm | 1 | PCS | LF1 | | 36 | Φ9*Φ5*3mm | CM Incuctor | 300uH-20%-Φ9*Φ5*3mm | 1 | PCS | LF2 | 6 | 37 | DO-201AD | Diode | SF56-5A-400V-Ultrafast | 2 | Pcs | D6,D7 | 6 | 38 | SMA | Diode | RS1M-1A-1000V-fast | | 2 | Pcs | D4,D5 | 6 | 39 | SOD-123L | Diode | 1N4148-0.2A-75V | | 2 | Pcs | D2,D3 | 6 | 40 | SOD-123L | Diode | F1M-0.5A-1000V-Fast | 1 | Pcs | D1 | | 41 | TO-220F | MOS-FET | SMF8N80-1.4Ω/800V | | 1 | PCS | Q2 | | 42 | SOT23-3 | Transistor | MMBT3904-40V-0.2A-NPN | 1 | PCS | Q1 | 6 | 43 | GBU-4L | Bridge | GBU410-4A-1000V | | 1 | Pcs | BD1 | | 44 | 16mm*5mm | MOV | 14D561-560V-6.5KA | | 2 | PCS | VDR1,VDR2 | | 45 | 8mm*4mm | Fuse | 3.15A-300V-TimeLag | 1 | PCS | F2 | | 46 | 8mm*4mm | Fuse | 10A-300V-Time Lag | | 1 | PCS | F1 | | 47 | TO-92 | IC | TL431 | | | 1 | PCS | U1 | 8 | 48 | SOP-8 | IC | BP3319MB-SOP8 | | 1 | PCS | U2 | 9 | 49 | PQ2620 | Transformer | 42TS : 15TS : 6TS | | 1 | PCS | T1 | | 50 | | Heat Sink | 23mm×16mm×15mm | 1 | PCS | | 10 | 51 | | PCB | FR-4/1.6mm-124mm*45mm | 1 | PCS | |
