REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
D7 | LED_LED_0603_IC_LED_GREEN | LED_GREEN | LED_0603 |
D17 | DIODE_SCHTKY_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D19 | DIODE_SCHTKY_SMA-FL_IC_SM120A_1 | SM120AF | SMA-FL |
D501 | DIODE_SCHTKY_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D502 | DIODE_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D503 | DIODE_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D506 | DIODE_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D509 | DIODE_1_SMA-FL_IC_NHPAF320-SMA- | NHPAF320-SMA-FL | SMA-FL |
D522 | LED_0_LED_0603_LEDGREEN | LED Green | LED_0603 |
D527 | DIODE_SMA-FL_IC_SM120AF | SM120AF | SMA-FL |
D529 | DIODE_SMA-FL_IC_SM120AF_1 | SM120AF | SMA-FL |
D530 | DIODE_2_SMA-FL_IC_NHPAF320-SMA- | NHPAF320-SMA-FL-NC | SMA-FL |
D534 | BAV99L_SOT23_BAV99L | BAV99L | SOT23 |
FB26 | BEAD_1_SMDFB0603_BLM18HE601SH1 | BLM18HE601SH1 | SMDFB0603 |
FB27 | RES_SMDFB0603_DISCRETE_BLM18HE6 | BLM18HE601SH1 | SMDFB0603 |
FB28 | RES_SMDFB0603_DISCRETE_BLM18HE6 | BLM18HE601SH1 | SMDFB0603 |
FB48 | FB_1_SMDFB0603_BLM18HE601SH1 | BLM18HE601SH1 | SMDFB0603 |
FB49 | FB_1_SMDFB0603_BLM18HE601SH1 | BLM18HE601SH1 | SMDFB0603 |
FB50 | FB_1_SMDFB0603_CBW160808U601T | CBW160808U601T | SMDFB0603 |
FB51 | BEAD_1_SMDFB0603_33UH | 33uH | SMDFB0603 |
FB52 | BEAD_1_SMDFB0603_33UH | 33uH | SMDFB0603 |
FB53 | BEAD_1_SMDFB0603_600@100M | 600@100M | SMDFB0603 |
HOLE2 | TP_VIA_MEM0_PTH4_9X7_5MM_TP_VIA | TP_VIA_MEM0 | PTH4_9X7_5MM |
J10 | MICRO_USB_CONN_0_USB9P_U_M_M5SS | USB AB 5 | USB9P_U_M_M5SSW_2 |
J17 | CONN_HDR_5X2_CON2X5_1P27_SMT_IO | 20021121-00010C4LF | CON2X5_1P27_SMT |
J508 | INTERFACECONNECTOR_2_JPN_CD_13 | CD_1318384 | JPN_CD_1318384 |
J509 | 4HEADER_0_HSIP3-2_54_4 HEADER | 4 HEADER | HSIP3-2_54 |
L3 | INDUCTOR_L_5P7X5P3_2_DISCRETE_L | LVS505020-1R0M-AUHI | L_5P7X5P3_2 |
L4 | INDUCTOR_IND_VLS252010_DISCRETE | LVF252A12-1R0M-AUHI | IND_VLS252010 |
L5 | INDUCTOR_L_5P7X5P3_2_DISCRETE_L | LVS505020-1R0M-AUHI | L_5P7X5P3_2 |
L6 | INDUCTOR_L_5P7X5P3_2_DISCRETE_L | LVS505020-1R0M-AUHI | L_5P7X5P3_2 |
L7 | INDUCTOR_L_5P7X5P3_2_DISCRETE_L | LVS505020-1R0M-AUHI | L_5P7X5P3_2 |
L8 | INDUCTOR_FERRITE_A_IND_LPS4018_ | 2.2uH DNP | IND_LPS4018 |
L510 | INDUCTOR_FERRITE_A_L_7P25X6P72_ | LVS606045L-100 | L_7P25X6P72_4 |
L511 | INDUCTOR_MMD_0_L_10P4X10P3_4_SC | SCDS104R-331 | L_10P4X10P3_4 |
L513 | FIT50-1_ACT45B-510-2P_ACT45B-5 | ACT 45B-510-2P | ACT45B-510-2P |
L517 | INDUCTOR_FERRITE_A_L_7P25X6P72_ | LVS606045L-100 | L_7P25X6P72_4 |
L518 | INDUCTOR_FERRITE_A_L_7P25X6P72_ | LVS606045L-100 | L_7P25X6P72_4 |
L519 | INDUCTOR_FERRITE_A_L_7P25X6P72_ | LVS606045L-100 | L_7P25X6P72_4 |
L520 | FIT50-1_TLDCM-7035_TLDCM7035-2- | TLDCM7035-2-501TF | TLDCM-7035 |
L521 | INDUCTOR_SMDFB0603_DISCRETE_33U | 33uH | SMDFB0603 |
L522 | INDUCTOR_SMDFB0603_DISCRETE_33U | 33uH | SMDFB0603 |
L523 | INDUCTOR_SMDFB0603_DISCRETE_33U | 33uH | SMDFB0603 |
L524 | INDUCTOR_SMDFB0603_DISCRETE_33U | 33uH | SMDFB0603 |
L525 | INDUCTOR_SMDFB0603_DISCRETE_33U | 33uH | SMDFB0603 |
Q507 | MPF4393_0_SOT23_LP2307LT1G | LP2307LT1G | SOT23 |
Q508 | 2N3445_0_SOT23_LH8050PLTIG | LH8050PLTIG | SOT23 |
Q511 | 2N914_2_SOT23_LH8050PLTIG | LH8050PLTIG | SOT23 |
Q512 | PNP BCE_0_SOT23_L2SA812RLT1G | L2SA812RLT1G | SOT23 |
S3 | SW_DIP4_SW_DIP8_4POS_SM_IC_SWD | SW DIP-4 | SW_DIP8_4POS_SM |
SH2 | RES_SHORT-2_SH0603_DISCRETE_0_ | 0 | SH0603 |
SH4 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
SH5 | RES_SHORT-2_SH0201_CC_DISCRETE_ | 0 | SH0201_CC |
SH6 | RES_SHORT-2_SH0201_CC_DISCRETE_ | 0 | SH0201_CC |
SH7 | RES_SHORT-2_SH0201_CC_DISCRETE_ | 0 | SH0201_CC |
SH8 | RES_SHORT-2_SH0201_CC_DISCRETE_ | 0 | SH0201_CC |
SH9 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
SH91 | RES_SHORT-2_SH0805_40_DISCRET_1 | SOLDER SHORT | SH0805_40 |
SH92 | RES_SHORT-2_SH0805_40_DISCRET_1 | SOLDER SHORT | SH0805_40 |
SH501 | RES_SHORT-2_SH0805_40_DISCRET_1 | SOLDER SHORT | SH0805_40 |
SH502 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
SH503 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
SH504 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
SH506 | RES_SHORT-2_SH0603_DISCRETE_0_ | 0 | SH0603 |
SH508 | RES_SHORT-2_SH0603_DISCRETE_0 | 0 | SH0603 |
SH509 | RES_SHORT-2_SH0603_DISCRETE_0 | 0 | SH0603 |
SH511 | RES_SHORT-2_SH0805_40_DISCRET_1 | SOLDER SHORT | SH0805_40 |
SH513 | RES_SHORT-2_SH0603_DISCRETE_0_ | 0 | SH0603 |
SH514 | RES_SHORT-2_SH0603_DISCRETE_0_ | 0 | SH0603 |
TP527 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
TP537 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
TP_GND1 | TESTLOOP_TPAD_020_IO_TESTLOOP_B | TESTLOOP_BLACK | TPAD_020 |
TVS1 | RES_SMDR0603_DISCRETE_5V_TVS | 5V_TVS | SMDR0603 |
TVS500 | DIODE_TVS_BIDIR_SOD-323_IC_GBLC | GBLC05C | SOD-323 |
TVS501 | DIODE_TVS_BIDIR_SOD323_IC_ESDLI | ESDLIN1524BJ | SOD323 |
TVS504 | DIODE_TVS_BIDIR_SOD-323_IC_ESDG | ESDGBLC03C/NC | SOD-323 |
TVS505 | DIODE_TVS_BIDIR_SOD-323_IC_ESDG | ESDGBLC03C/NC | SOD-323 |
TVS506 | DIODE_TVS_BIDIR_SOD-323_IC_ESDG | ESDGBLC03C/NC | SOD-323 |
TVS507 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS508 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS509 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS510 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS511 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS512 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS513 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS514 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS515 | DIODE_TVS_BIDIR_DO-214AC-SMA_IC | SM6A30CA | DO-214AC-SMA |
TVS516 | DIODE_TVS_BIDIR_DO-214AC-SMA__1 | SM6A30CA-NC | DO-214AC-SMA |
TVS517 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS518 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS519 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
TVS520 | DIODE_TVS_BIDIR_SOD-323_IC_ES_1 | ESDGBLC03C | SOD-323 |
U1 | PCIMX6Q6VV1A_4_BGA624_0P8_21X21 | MCIMX6S6AVM10AD | BGA624_0P8_21X21 |
U2 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16TW-107AUT | BGA96_0P8_9P15X14P15 |
U3 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16TW-107AUT | BGA96_0P8_9P15X14P15 |
U4 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16TW-107AUT | BGA96_0P8_9P15X14P15 |
U5 | 4G_DDR3_SDRAM_256MX16_96P_BGA96 | MT41K256M16TW-107AUT | BGA96_0P8_9P15X14P15 |
U11 | MMPF0100NPZES_56P_QFN56_0P5_8X8 | MMPF0100F0AZES | QFN56_0P5_8X8_EP4P1X4P4 |
U20 | 1G125_SC70-5_A_IC_NC7SP125P5X | NC7SP125P5X | SC70-5_A |
U22 | 1G125_SC70-5_A_IC_NC7SP125P5X | NC7SP125P5X | SC70-5_A |
U506 | MIC2015-0_1.5YM6_SOT23-6_IC_MIC | MIC2005-0.5YM6 | SOT23-6 |
U507 | SRV05-4_SOT23-6_IC_SRV05-4 | SRV05-4 | SOT23-6 |
U525 | SN74LVC1T45DBV_0_SOT23-6_SN74LV | SN74LVC1T45DBV | SOT23-6 |
U530 | SPC5604B_3_LQFP64-1212-_5_SPC56 | SPC5604B | LQFP64-1212-_5 |
U531 | JTAG14_CON7X2-2_54A_JTAG14 | JTAG14 | CON7X2-2_54A |
U534 | PESD1CAN_SOT23_NUP2105L | NUP2105L | SOT23 |
U535 | ISL79987_QFN48-0707-_5-PAD_ISL7 | ISL79987 | QFN48-0707-_5-PAD |
U545 | MPQ4423_QFN8-0303-_65_MPQ4423 | MPQ4423 | QFN8-0303-_65 |
U546 | MPQ4423_QFN8-0303-_65_MPQ4423 | MPQ4423 | QFN8-0303-_65 |
U547 | MPQ4423_QFN8-0303-_65_MPQ4423 | MPQ4423 | QFN8-0303-_65 |
U550 | MPQ4423_QFN8-0303-_65_MPQ4423 | MPQ4423 | QFN8-0303-_65 |
U551 | NJU71091_0_DFN8-2X2-_5_NJU71091 | NJU71091-T1 | DFN8-2X2-_5 |
U552 | PESD1CAN_SOT23_SZNUP2105L | SZNUP2105L | SOT23 |
U560 | ADV7393_CP-40-1_ADV7393WBCPZ | ADV7393WBCPZ | CP-40-1 |
U562 | TJA1043_0_SO14-6-1_27_TJA1043 | TJA1043 | SO14-6-1_27 |
U563 | MICROSD-PJS008-200_0_SD13P_15X1 | MicroSD-PJS008-200 | SD13P_15X15 |
U570 | PESD1CAN_SOT23_SZNUP2105L | SZNUP2105L | SOT23 |
U572 | WIFIMODE-I84-52PIN_52PIN_1_0MM_ | WIFIMOED-I84-52PIN/NC | 52PIN_1_0MM_DK |
U574 | SN74LVC1T45DBV_0_SOT23-6_SN74LV | SN74LVC1T45DBV | SOT23-6 |
U582 | XTAL1108_TDFN-2X2-8L_SSDCI1108A | SSDCI1108AF | TDFN-2X2-8L |
U583 | SDINBDG4-8G-XA_2_BGA153-PINA-A_ | SDINBDG4-8G-XA | BGA153-PINA-A |
U584 | LC464_0_UDFN4PIN_LC464E | LC464E | UDFN4PIN |
U585 | LC464_0_UDFN4PIN_LC464E | LC464E | UDFN4PIN |
U588 | DS28E11_TSOC6_DS28E11 | DS28E11 | TSOC6 |
U589 | WSIC_SOT23-6_JMIC-SOT-23-6L | JMIC-SOT-23-6L | SOT23-6 |
U590 | MPQ8904_1_QFN8-0302-_5_MPQ8904- | MPQ8904-AEC1 | QFN8-0302-_5 |
U591 | MPQ8904_1_QFN8-0302-_5_MPQ890_1 | MPQ8904-AEC1/NC | QFN8-0302-_5 |
Y2 | XTAL_NX3215SA_IC_32.768KHZ | 32.768kHz | NX3215SA |
Y3 | XTAL_13Y_CRY-3_2-2_5-4P_IC_24MH | 24MHZ | CRY-3_2-2_5-4P |
Y7 | XTAL_13Y_CRY-3_2-2_5-4P_IC_27MH | 27MHZ | CRY-3_2-2_5-4P |
Y8 | XTAL_13Y_CRY-3_2-2_5-4P_IC_16MH | 16MHZ | CRY-3_2-2_5-4P |
