[Allegro16.6以下] 8层笔记本电脑主板PCB文件共享 CULV45D-F1  SU2300
查看11548 | 回复63 | 2019-3-3 16:44:17 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
AMIC_CONWTOB_2P_49_2HOLD_RA_LINGYAWTOB_CON_2PAG_WTOB_2P_49_2HOLD_RA_LING
AQ2SOT363_NBUM6K1NSOT363_NB
AT1NB_TPC26T_68TPC26TNB_TPC26T_68
AT2NB_TPC26T_68TPC26TNB_TPC26T_68
AU1NB_QFN_48P_20_276X276_VIAALC269Q-GRNB_QFN_48P_20_276X276_VIA
AU2MB_SOT23_S5_MAXUP7714BMA5-00MB_SOT23_S5_MAX
BAT_CONBATT_7P_79_2HOLD_RA_LF3BATT_CON_7PAG_BATT_7P_79_2HD_RA_LF2
BIOSSOIC_8P_50_212X315MX25L8005M2C_15GSOIC_8P_50_212X315
BIOS_SEL_HEADERHD_1X3P_100_JVE_LF3HEADER_1X3PMB_HD_1X3P_100_LF3
BT_CONWTOB_10P_39_2HOLD_RA_LINGYAWTOB_CON_10PAG_WTOB_10P_39_2HOLD_RA_LIN
CL1R0603_H240OhmR0603_H24
CL2R0603_H240OhmR0603_H24
CLRTCNB_OPEN2_5MIL_PTSGL_JUMPOPEN2_5MIL
CPUFAN_CONWTOB_3P_49_2HOLD_RA_LINGYAWTOB_CON_3PAG_WTOB_3P_49_2HOLD_RA_LING
CR22R04020OhmR0402
CT1NB_TPC26T_68TPC26TNB_TPC26T_68
CT2NB_TPC26T_68TPC26TNB_TPC26T_68
CT3NB_TPC26T_68TPC26TNB_TPC26T_68
CU1SOIC_56P_20_555X319ICS9LPRS427CGLFTSOIC_56P_20_555X319
CX1XTAL_2P_315X17714.318MhzXTAL_2P_315X177
D3C1C0805_H5710UF/6.3VC0805_H57
D3CE1C7343D_H75100UF/2.5VC7343D_H75
D3R1R0402_H160OhmR0402_H16
D3R2R0402_H161KOhmR0402_H16
D3R3R0402_H160OhmR0402_H16
D3R4R0402_H161KOhmR0402_H16
D3R5R0402_H160OhmR0402_H16
DC_JACKDC_PWR_JACK_3P_2H_LF3DC_PWR_JACK_3PAG_DC_PWR_JACK_3P_2H_LF2
DEBUG_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LING
DIMM1DDR3_DIMM_204P_4H_STD_FNNDDR3_DIMM_204PAG_DDR3_DIMM_204P_4H_STD_FN
GD1SOT323BAT54AWSOT323
GD2SOT323BAT54AWSOT323
GD3SOT23_H43BAV99SOT23_H43
GD4SOT23_H43BAV99SOT23_H43
GJP5SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10
GJP6SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10
GJP7SHORTPIN_5X10SHORTPIN_5X10SHORTPIN_5X10
GL1R0603_H240OhmR0603_H24
GL2R0603_H240OhmR0603_H24
GL3R0603_H240OhmR0603_H24
GL4R0603_H240OhmR0603_H24
GL5R0603_H240OhmR0603_H24
GL6R0603_H240OhmR0603_H24
GL7R0603_H240OhmR0603_H24
GL26L0603120Ohm/100MhzL0603
GQ2SOT23_H432N7002ET1GSOT23_H43
GQ3SOT23_H432N7002ET1GSOT23_H43
GR1R04021.27KOhmR0402
GT37NB_TPC26T_68TPC26TNB_TPC26T_68
GU1NB_BGA_631P_31_937X937PARK-XT-S3NB_BGA_631P_31_937X937
GU6SOIC_8P_50_197X236G781-1SOIC_8P_50_197X236
GU11NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295
GU12NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295
GU13NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295
GU14NB_BGA_96P_31_512X295H5TQ1G63BFR-12CNB_BGA_96P_31_512X295
GX1XTAL_2P_315X177_H5927MhzXTAL_2P_315X177_H59
H1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
H14NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
H15HOLE_O63X47DO63X47NO63x47DO63x47NHOLE_O63X47DO63X47N
H16HOLE_C79D79NC79D79NHOLE_C79D79N
H21NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
H33NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
HALL_SENNB_SOT23_ANACHIP_H55EC2648-B3-FNB_SOT23_ANACHIP_H55
HD1SOT323BAT54AWSOT323
HDD_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LING
HDMINB_HDMI_19P_4HLD_RA_LF2HDMI_CON_19PNB_HDMI_19P_4HLD_RA_LF2
HJP1NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
HQ1SOT23_H432N7002ET1GSOT23_H43
HRN14R8P0402_H20S56Ohm4R8P0402_H20
HS2NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2
HS3NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2
HS4NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2
HS5NB_NUT_C217BC87D47_LF2HT-G4041M20TFENB_NUT_C217BC87D47_LF2
HU1NB_BGA_956P_19_866X866SU2300NB_BGA_956P_19_866X866
HU2SOIC_8P_26_122X193_H48G781P8FSOIC_8P_26_122X193_H48
IC1C04020.1UF/16VC0402
IC3C04020.1UF/16VC0402
IC4C040210PF/50VC0402
IC41C0402_RD91UF/6.3VC0402
IC42C0402_RD91UF/6.3VC0402
IC43C0805_H5710UF/6.3VC0805_H57
IC58C0402_RD91UF/6.3VC0402
IH1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
IH2NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
IH3HOLE_C87D87NSCREW_HOLEHOLE_C87D87N
IO_CONFPC_30P_20_2HOLD_RA_LINFPC_CON_30PAG_FPC_30P_20_2HOLD_RA_LIN
IR3R040233OhmR0402
IR4R0402499OhmR0402
ITP1HH_EMI_SPRING_150X87SPRING_PADHH_EMI_SPRING_150X87
ITP2HH_EMI_SPRING_150X87SPRING_PADHH_EMI_SPRING_150X87
KB_CONFPC_24P_39_2HOLD_RAFPC_CON_24PFPC_24P_39_2HOLD_RA
LC1C04020.1UF/16VC0402
LC26C040212PF/50VC0402
LCD_CONWTOB_30P_39_2HOLD_RA_ACESWTOB_CON_30PWTOB_30P_39_2HOLD_RA_ACES
LCX3C04020.1UF/16VC0402
LCX4C04020.1UF/16VC0402
LINE_OUTAG_PHONE_JACK_8P_RA_LF2PHONE_JACK_8PAG_PHONE_JACK_8P_RA_LF2
LL3R0603_H240OhmR0603_H24
LT1NB_TPC26T_68TPC26TNB_TPC26T_68
LU1QFP_48P_20_354X354RTL8103EL-GRQFP_48P_20_354X354
LX1NB_XTAL_4P_126X98_HOSON_H2825MhzNB_XTAL_4P_126X98_HOSON_H28
MIC_JACKAG_PHONE_JACK_8P_RA_LF2PHONE_JACK_8PAG_PHONE_JACK_8P_RA_LF2
NCE3C7343D_H75100UF/2.5VC7343D_H75
NCE4C7343D_H75100UF/2.5VC7343D_H75
ND1SOT323BAT54CWSOT323
NJP10NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
NJP12NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
NJP13NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
NJP14NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
NL13L0603120Ohm/100MhzL0603
NQ1SOT23_H432N7002ET1GSOT23_H43
NU1NB_BGA_1362P_1063X984_HDI897605NB_BGA_1362P_1063X984
NU2QFN_48P_20_S276_PAD_MICROTUASM1442TQFN_48P_20_S276_PAD_MICROTU
OL3R0603_H240OhmR0603_H24
OQ3SOT23_H432N7002ET1GSOT23_H43
OQ16SOT23_H432N7002ET1GSOT23_H43
OT54NB_TPC26T_68TPC26TNB_TPC26T_68
OU1QFP_128P_16_630X630IT8500E-LQFP_128P_16_630X630
OX2XTAL_4P_272X5532.768KhzXTAL_4P_272X55
PC1C06030.1UF/25VC0603
PC2C1206_H7510UF/25VC1206_H75
PCE1NB_C7343D_H83220UF/2VNB_C7343D_H83
PCE2C7343D_H87100UF/6.3VC7343D_H87
PCE3C7343D_H87100UF/6.3VC7343D_H87
PCE4NB_C7343D_H83220UF/2VNB_C7343D_H83
PCE5NB_C7343D_H83220UF/2VNB_C7343D_H83
PCE7C352847UF/6.3VC3528
PCE8NB_C7343D_H83220UF/2VNB_C7343D_H83
PCE9NB_C7343D_H83220UF/2VNB_C7343D_H83
PD1SMASS14SMA
PD2VARISTOR_0402V0402MHS03VARISTOR_0402
PD3VARISTOR_0402V0402MHS03VARISTOR_0402
PD4VARISTOR_0402V0402MHS03VARISTOR_0402
PD5SOT323BAT54CWSOT323
PD17SMASS14SMA
PJP23NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
PL1L1812_H67150Ohm/100MhzL1812_H67
PL2L1812_H67150Ohm/100MhzL1812_H67
PL3L0603120Ohm/100MhzL0603
PL4L0603120Ohm/100MhzL0603
PL5L0603120Ohm/100MhzL0603
PL6L0805_H4370Ohm/100MhzL0805_H43
PL7L0805_H4370Ohm/100MhzL0805_H43
PL8INDUCTOR_2P_287X2606.8UHINDUCTOR_2P_287X260
PL9L0805_H4370Ohm/100MhzL0805_H43
PL10L0805_H4370Ohm/100MhzL0805_H43
PL11INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260
PL12L0805_H4370Ohm/100MhzL0805_H43
PL13L0805_H4370Ohm/100MhzL0805_H43
PL14INDUCTOR_2P_287X2604.7UHINDUCTOR_2P_287X260
PL15INDUCTOR_2P_287X2604.7UHINDUCTOR_2P_287X260
PL17L0805_H4370Ohm/100MhzL0805_H43
PL18INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260
PL19L0805_H4370Ohm/100MhzL0805_H43
PL20L0805_H4370Ohm/100MhzL0805_H43
PL21L0805_H4370Ohm/100MhzL0805_H43
PL22INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260
PL23L0805_H4370Ohm/100MhzL0805_H43
PL24L0805_H4370Ohm/100MhzL0805_H43
PL25L0805_H4370Ohm/100MhzL0805_H43
PL26L0805_H4370Ohm/100MhzL0805_H43
PL27INDUCTOR_2P_287X2601UHINDUCTOR_2P_287X260
PL28L0805_H4370Ohm/100MhzL0805_H43
PL29L0805_H4370Ohm/100MhzL0805_H43
PL30L0805_H4370Ohm/100MhzL0805_H43
PL31INDUCTOR_2P_118X118_TK_H7915UHINDUCTOR_2P_118X118_TK_H79
PQ1SOIC_8P_50_201X236EMB24B03GSOIC_8P_50_201X236
PQ2SOIC_8P_50_197X242AP4835GMSOIC_8P_50_197X242
PQ3SOT23_H432N7002ET1GSOT23_H43
PQ4SOT23_H432N7002ET1GSOT23_H43
PQ5SOT23_H43PMBS3906SOT23_H43
PQ6NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ7NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ8SOT363_NBUM6K1NSOT363_NB
PQ9SOT23_H432N7002ET1GSOT23_H43
PQ10SOT23_H432N7002ET1GSOT23_H43
PQ11SOT363_NBUM6K1NSOT363_NB
PQ12SOT363_NBUM6K1NSOT363_NB
PQ13MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ14MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ17SOT363_NBUM6K1NSOT363_NB
PQ18SOT23_H432N7002ET1GSOT23_H43
PQ19NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ20NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ21NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ22MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ27NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ28MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ30SOT363_NBUM6K1NSOT363_NB
PQ33NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ34MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ35SOT23_H432N7002ET1GSOT23_H43
PQ36SOT363_NBUM6K1NSOT363_NB
PQ620SOT89STF826SOT89
PQ621SOT23_H432N7002ET1GSOT23_H43
PQ622SOT363_NBUM6K1NSOT363_NB
PQ624MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ625NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ626NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ627NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ629MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ630MB_SOT669_COLAYRJK0355DPA-00-J0MB_SOT669_COLAY
PQ631SOT363_NBUM6K1NSOT363_NB
PQ632SOT363_NBUM6K1NSOT363_NB
PQ633NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ634NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ635NB_SI7900EDN_H44SI7326DN_T1_E3NB_SI7900EDN_H44
PQ636SOT363_NBUM6K1NSOT363_NB
PQ637SOT363_NBUM6K1NSOT363_NB
PQ638SOT23_H432N7002ET1GSOT23_H43
PQ639SOT23_H432N7002ET1GSOT23_H43
PQ641SOT363_NBUM6K1NSOT363_NB
PQ642SOT363_NBUM6K1NSOT363_NB
PQ643SOT363_NBUM6K1NSOT363_NB
PQ644SOT363_NBUM6K1NSOT363_NB
PQ645SOT363_NBUM6K1NSOT363_NB
PQ646SOT363_NBUM6K1NSOT363_NB
PQ647SOT363_NBUM6K1NSOT363_NB
PQ648SOT23_H432N7002ET1GSOT23_H43
PQ649SOT363_NBUM6K1NSOT363_NB
PT_TOP26NB_TPC26T_68TPC26TNB_TPC26T_68
PU1QFN_32P_20_197X197_PAD_AMIMB39A132MB_QFN_32P_20_S197_PAD_A_4V
PU2MB_QFN_32P_20_S197_RIC_4VIART8152DGQWMB_QFN_32P_20_S197_RIC_4VIA
PU3QFN_24P_20_S157_PAD_RC_4VIART8205CGQWQFN_24P_20_S157_PAD_RC_4VIA
PU4QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4V
PU5SOIC_8P_50_197X236_PAD_GMUP7711U8MB_SOIC_8P_50_197X236_PD_4V
PU6QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4V
PU7SOIC_8P_50_197X236_PAD_ANPEAPL5912KACTRLSOIC_8P_50_197X236_PAD_ANPE
PU13SOIC_8P_50_197X236AS358MTR-E1SOIC_8P_50_197X236
PU14SOT23_S5_RD1LMV321IDBVRNB_SOT23_S5_T
PU16QFN_16P_20_118X118_PAD_H31RT8202APQWMB_QFN_16P_20_S118_PAD_4V
PU17SOT23_S6_FITI_H39MP3202DJSOT23_S6_FITI_H39
PWRBTN_CONFPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LIN
PWRBTN_CON1FPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LIN
PWR_BTNTP_SW_4P_2HOLD_LYTACT_SWITCH_4PTP_SW_4P_2HOLD_LY
PWR_BTN1TP_SW_4P_2HOLD_LYTACT_SWITCH_4PTP_SW_4P_2HOLD_LY
PWR_LEDLED_2P_63X31_H30Y&GLED_2P_63X31_H30
PWR_LED1HH_LED_2P_63X31WHITEHH_LED_2P_63X31
Q65NBS_SOT23_H432N7002NBS_SOT23_H43
R19R0402_H16330OhmR0402_H16
RD1SOT323BAT54CWSOT323
RTC_CONWTOB_2P_49_2HOLD_RA_LINGYAWTOB_CON_2PAG_WTOB_2P_49_2HOLD_RA_LING
SATA_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LING
SATA_SLOTAG_SATA_22P_50_2H_LF2SATA_CON_22PAG_SATA_22P_50_2H_LF2
SD3SOT323BAT54CWSOT323
SJP2NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
SJP31MM_OPEN_5MIL_FLASHING1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
SJP13NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
SL3L0603120Ohm/100MhzL0603
SL4L0603120Ohm/100MhzL0603
SL5L0805_H4370Ohm/100MhzL0805_H43
SL6L0603120Ohm/100MhzL0603
SL7L0805_H4370Ohm/100MhzL0805_H43
SPI2HD_2X4P_100_K8_PRX_LF3HEADER_2X4P_K8HD_2X4P_100_K8_PRX_LF3
SPI_CONFPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LIN
SPI_CON2AG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LING
SPI_CON3FPC_CON_6P_20_2HOLD_RA_LINFPC_CON_6PAG_FPC_CON_6P_20_2HD_RA_LIN
SPI_PWRLED_2P_63X31_H16ORANGELED_2P_63X31_H16
SPI_SLOTMB_IC_SOCKET_D_8P_100_LF3IC_SCK_8PMB_IC_SOCKET_D_8P_100_LF3
SPKR_CONWTOB_4P_39_2HOLD_RA_LINWtoB_CON_4PAG_WTOB_4P_39_2HOLD_RA_LIN
SQ5SOT363_NBUM6K1NSOT363_NB
ST23NB_TPC26T_68TPC26TNB_TPC26T_68
SU1NB_BGA_569P_630X630ICH9M_SFFNB_BGA_569P_630X630_NONHDI
SX1XTAL_4P_272X5532.768KhzXTAL_4P_272X55
TC1C1206_H7547UF/6.3VC1206_H75
TC2C04020.1UF/16VC0402
TC3C06031UF/16VC0603
TH1NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
TH2HOLE_C47D47N_PLACEC47D47NHOLE_C47D47N_PLACE
TH3NB_H_C276D87N_M2_P2_V4C276D87NNB_H_C276D87N_M2_P2_V4
TH4HOLE_O59X47DO59X47NO59X47DO59X47NHOLE_O59X47DO59X47N
TP_CONAG_FPC_12P_20_2HOLD_RA_LINGFPC_CON_12PAG_FPC_12P_20_2HOLD_RA_LING
U4974LVC125APW_TSSOP1474LVC125APWSOIC_14P_26_201X252
U3CE1C7343D_H87100UF/6.3VC7343D_H87
U3D1SOIC_8P_26_122X193AZ1065-06QSOIC_8P_26_122X193
U3F1POLYSWITCH_2P_1206_H391.5A/6VPOLYSWITCH_2P_1206_H39
U3L1R0603_H240OhmR0603_H24
U3L2R0603_H240OhmR0603_H24
U3L3R0603_H240OhmR0603_H24
U3L4R0603_H240OhmR0603_H24
U3L5R0603_H240OhmR0603_H24
U3L6R0603_H240OhmR0603_H24
U3L7R0603_H240OhmR0603_H24
U3L8R0805_H240OhmR0805_H24
U3L10CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
U3L11CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
U3L12L0805_H4370Ohm/100MhzL0805_H43
U3Q1SOT23_H432N7002ET1GSOT23_H43
U3R1R0402_H160OhmR0402_H16
U3R2R040212KOhmR0402
U3R3R0402_H164.7KOhmR0402_H16
U3R4R040210MOhmR0402
U3R6R040212KOhmR0402
U3R8R0402_H160OhmR0402_H16
U3R9R0402_H160OhmR0402_H16
U3R10R0402_H160OhmR0402_H16
U3R11R0402_H160OhmR0402_H16
U3R12R0402_H1610KOhmR0402_H16
U3R13R0402_H164.7KOhmR0402_H16
U3R14R0402_H1610KOhmR0402_H16
U3R15R0402_H160OhmR0402_H16
U3R16R0402_H145.1KOhmR0402_H14
U3R17R0402_H1610KOhmR0402_H16
U3RN14R8PS0Ohm4R8P
U3T1TPC26B_S4_68TPC26bMB_TPC26B_S4_68
U3T2TPC26B_S4_68TPC26bMB_TPC26B_S4_68
U3T3TPC26B_S4_68TPC26bMB_TPC26B_S4_68
U3U1BGA_100P_30_315X315FL1000GBGA_100P_30_315X315
U3U2MB_SOT23_S5_MAXUP7714BMA5-00MB_SOT23_S5_MAX
U3USB1NB_USB_9P_4HD_FOX_LF2USB_CON_9PNB_USB_9P_4HD_FOX_LF2
U3X1XTAL_4P_197X12610MhzXTAL_4P_197X126
VD25SOT323BAV99W_LSOT323
VF1POLYSWITCH_2P_1206_H391.5A/6VPOLYSWITCH_2P_1206_H39
VGAAG_D_SUB_15P_2H_F_LY_LF2D_SUB_15PAG_D_SUB_15P_2H_F_LY_LF2
VL1R0603_H240OhmR0603_H24
VL2R0603_H240OhmR0603_H24
VL3R0603_H240OhmR0603_H24
VL4CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
VL5CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
VL6CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
VL7CHOKE_4P_79X47_H5190Ohm/100MHzCHOKE_4P_79X47_H51
VPC1R0402_H160OhmR0402_H16
VPC2C06030.1UF/25VC0603
VPC3C0805_H5710UF/6.3VC0805_H57
VPC4C0805_H5710UF/6.3VC0805_H57
VPC5C1206_H7510UF/25VC1206_H75
VPC6C1206_H7510UF/25VC1206_H75
VPC7C04020.1UF/16VC0402
VPD1SMASS14SMA
VPJP1NB_PWR_FB_SHORT_PTSHORT_PINNB_PWR_FB_SHORT_PT
VPL1L0805_H4370Ohm/100MhzL0805_H43
VPL2INDUCTOR_2P_118X118_TK_H7915UHINDUCTOR_2P_118X118_TK_H79
VPR1R0402845KOhmR0402
VPR2R04027.32KOhmR0402
VPR3R0402_H16100KOhmR0402_H16
VPU1SOT23_S6_FITI_H39MP3202DJSOT23_S6_FITI_H39
VQ3SOT23_H49AP2301GNMB_SOT23
VQ5SOT23_H432N7002ET1GSOT23_H43
VQ6SOT23_H49AP2301GNMB_SOT23
VQ7SOT23_H49AP2301GNMB_SOT23
VQ8SOT23_H432N7002ET1GSOT23_H43
VQ9SOT23_H43MMBT3904SOT23_H43
VQ10SOT23_H432N7002ET1GSOT23_H43
VQ11SOT363_NBUM6K1NSOT363_NB
VR1R0402_H1610KOhmR0402_H16
V_12V_OUTWTOB_4P_31_2HOLD_RAWTOB_CON_4PWTOB_4P_31_2HOLD_RA
V_5V_INWTOB_4P_31_2HOLD_RAWTOB_CON_4PWTOB_4P_31_2HOLD_RA
WC2C0402_RD91UF/6.3VC0402
WC5C06034.7uF/6.3VC0603
WC6C0402_RD91UF/6.3VC0402
WC7C04020.1UF/16VC0402
WC8C0805_H5710UF/6.3VC0805_H57
WC9C04020.1UF/16VC0402
WC10C0402_RD91UF/6.3VC0402
WH1NB_SMT_NUT_C236B189D150_LF2U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2
WLAN_SLOTAG_MINI_PCI_52P_4HOD_F_0MINI_PCI_LATCH_52PAG_MINI_PCI_52P_4HOD_HALF
WQ1SOT23_H432N7002ET1GSOT23_H43
WQ4SOT23_H432N7002ET1GSOT23_H43
WQ5SOT23_H432N7002ET1GSOT23_H43
WR1R0805_H240OhmR0805_H24
WR2R0402_H1610KOhmR0402_H16
WT1NB_TPC26T_68TPC26TNB_TPC26T_68
WT2NB_TPC26T_68TPC26TNB_TPC26T_68
WT3NB_TPC26T_68TPC26TNB_TPC26T_68
WT4NB_TPC26T_68TPC26TNB_TPC26T_68
WT5NB_TPC26T_68TPC26TNB_TPC26T_68
重要提示:PCB作品文件展下载说明
老吴 | 2019-3-3 16:47:21 | 显示全部楼层
PCB文件共享,没有原理图。 回复可见下载。
游客,如果您要查看本帖隐藏内容请回复
PS:老吴花钱弄来的文件给大家共享的,请大家下载学习就好。不要发网上。
hsin | 2019-3-3 17:53:06 | 显示全部楼层
miaomiao | 2019-3-3 18:43:25 | 显示全部楼层
牛X,谢谢分享牛X,谢谢分享
lbmone | 2019-3-3 21:55:14 | 显示全部楼层
boatxin | 2019-3-4 06:51:47 | 显示全部楼层
lijunming1983cn | 2019-3-4 08:58:29 | 显示全部楼层
baihushan | 2019-3-4 10:10:13 | 显示全部楼层
veis | 2019-3-4 15:57:07 | 显示全部楼层
高端,感谢老吴分享[s:151]
yfhaotian168 | 2019-3-5 09:00:04 | 显示全部楼层
