[Allegro16.6以下] 8层电脑主板PCB文件共享 SOCKET989 PZ98927
查看14650 | 回复69 | 2019-3-3 17:43:08 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D3104PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70
D3105PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70
D3202DIODE_SOD323_H35_DISCRETE_1SS351SS355SOD323_H35
D4501BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323
D4502BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323
D4503DUAL_DIODE_CONVERT_1ANODE_SOT23BAV99SOT23_H43
D4601DIODE_SOD323_H35_DISCRETE_1SS351SS355SOD323_H35
D6000DIODE_SOD323_H35_DISCRETE_1SS351SS355SOD323_H35
D6002DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323
D6101BAT54C_SOT23_H43_DISCRETE_BAT54BAT54CSOT23_H43
D6801DIODE_SOD323_H35_DISCRETE_1SS351SS355SOD323_H35
D8801DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323
D8802DIODE_SMA_DISCRETE_SX34SX34SMA
D8804DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323
D9205IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457
H5303SCREWHOLE_SMT_NB_SMT_NUT_A40M20A40M20-64ASNB_SMT_NUT_A40M20_H252
H5304SCREWHOLE_SMT_NB_SMT_NUT_A40M20A40M20-64ASNB_SMT_NUT_A40M20_H252
H6530SCREWHOLE_4VIA_NB_H_RT394X315CBRT394X315CB256D91NNB_H_RT394X315CB256D91N_V4
H6531SCREWHOLE_4VIA_NB_H_RT394X315CBRT394X315CB256D91NNB_H_RT394X315CB256D91N_V4
H6533SCREWHOLE_4VIA_NB_H_C256D91N_12C256D91NNB_H_C256D91N_124_P2_V4
H6534SCREWHOLE_4VIA_NB_H_C256D91N_12C256D91NNB_H_C256D91N_124_P2_V4
H6536SCREWHOLE_4VIA_NB_H_RT394X315CBRT394X315CB256D91NNB_H_RT394X315CB256D91N_V4
H6537SCREWHOLE_4VIA_NB_H_RT315X394CBRT315X394CB315D91NNB_H_RT315X394CB315D91N_V4
H6538SCREWHOLE_4VIA_NB_H_RT315X394CBRT315X394CB315D91NNB_H_RT315X394CB315D91N_V4
H6540SCREWHOLE_4VIA_NB_H_S315CB315D9S315CB315D91NNB_H_S315CB315D91N_M2_P2_V4
H6541SCREWHOLE_4VIA_NB_H_C315D91N_12C315D91NNB_H_C315D91N_124_P2_V4
H6542SCREWHOLE_4VIA_NB_H_C315D91N_12C315D91NNB_H_C315D91N_124_P2_V4
H6545HOLE_PTH_NB_H_C236D91_114_P2_C2C236D91NB_H_C236D91_114_P2
H6546HOLE_NPTH_NB_H_O122X102DO122X10O122X102DO122X102NNB_H_O122X102DO122X102N
H6547HOLE_NPTH_NB_H_O122X102DO122X10O122X102DO122X102NNB_H_O122X102DO122X102N
H6548HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
H6549HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
H6550HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
H6551HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
H6552HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
H6553HOLE_PTH_NB_H_CT315CB217D138_P2CT315CB217D138NB_H_CT315CB217D138_P2
J1601DDR3_DIMM_204P_4HOLD_DDR3_DIMM_DDR3_DIMM_204PDDR3_DIMM_204P_24_4H_MO_REV
J1701DDR3_DIMM_204P_4HOLD_DDR3_DIM_1DDR3_DIMM_204PDDR3_DIMM_204P_24_4HOLD_FXC
J3101FPC_CON_24P_2HOLD_RD9_FPC_CON_2FPC_CON_24PFPC_CON_24P_39_2HOLD_ENT
J3102FPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PFPC_12P_20_2HOLD_RA_B
J3704FPC_4P_2HOLD_NB_WTOB_4P_49_2HOLWTOB_CON_4PNB_WTOB_4P_49_2HOLD_EN
J4501BTOB_CON_30P_2HOLD_HRS_WTOB_30PWTOB_CON_30PWTOB_30P_39_2HOLD_IPEX
J5001FPC_4P_2HOLD_WTOB_4P_49_2HOLD_EWTOB_CON_4PWTOB_4P_49_2HOLD_ENTERY
J5101SATA_CON_13P_6HOLD_NB_SATA_13P_SATA_CON_13PNB_SATA_13P_6HOLD_RA_LF2
J5103SATA_CON_22P_4HOLD_TC_NB_SATA_CSATA_CON_22PNB_SATA_CON_22P_4HD_SAN_RA
J5302MINI_PCI_LATCH_52P_4HOLD_MO_MINMINI_CARD_LATCH_52PMINI_PCI_52P_4HOLD_MO_H354
J6101ZIF_CON_6P_2HOLD_WTOB_6P_39_2HOWTOB_CON_6PWTOB_6P_39_2HOLD_RA
J6702FPC_CON_12P_JST_FPC_CON_12P_39_FPC_CON_12PFPC_CON_12P_39
J6801HEADER_2X15P_HD_2X15P_50_SUY_IOHEADER_2X15PHD_2X15P_50_SUY
J6802HEADER_2X20P_NB_HD_2X20P_50_RA_HEADER_2X20PNB_HD_2X20P_50_RA_SUY
J9202BATT_CON_9P_2HD_ALLTOP_NB_BATT_BATT_CON_9PNB_BATT_9P_79_2H_M_LF2
JP2301SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP2302SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP2303SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP26013MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JP26023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP26033MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LF
JP27023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP27033MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP27043MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP27053MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP27063MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP30013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP6803SL_0603_SHORTPIN_R0603_SHORTLASHORT LANDSHORTPIN_R0603
JP7201SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP7202SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP7203SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORT
JP80013MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JP81033MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP81043MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP81053MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP81063MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP81073MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP81093MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP81103MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JP81113MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JP81123MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JP81133MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JP81143MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JP82013MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JP82023MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JP82033MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP82043MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LF
JP83013MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP83023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP83033MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP83043MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP84013MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP84023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP85043MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP85053MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP85063MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP86013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP86023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SP
JP86033MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHING
JP87013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP87023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LF
JP92023MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JP92033MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LF
JRST20013MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
JRST20023MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PT
L4501BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43
L4502BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L4503BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L4504BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43
L5303COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUI
L7201BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L7202BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L7203BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L7205BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L7206R_R0603_H24_DISCRETE_0OHM0OhmR0603_H24
L7207R_R0603_H24_DISCRETE_0OHM0OhmR0603_H24
L7208R_R0603_H24_DISCRETE_0OHM0OhmR0603_H24
L7209R_R0402_DISCRETE_0OHM0OhmR0402
L7210R_R0402_DISCRETE_0OHM0OhmR0402
L7713BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603
L8001INDUCTOR_NB_INDUCTOR_2P_441X3940.36UHNB_INDUCTOR_2P_441X394
L8002INDUCTOR_NB_INDUCTOR_2P_441X3940.36UHNB_INDUCTOR_2P_441X394
L8101INDUCTOR_INDUCTOR_2P_291X264_TO4.7UHINDUCTOR_2P_291X264_TOKO
L8102INDUCTOR_INDUCTOR_2P_291X264_TO4.7UHINDUCTOR_2P_291X264_TOKO
L8201INDUCTOR_NB_INDUCTOR_2P_441X3940.36UHNB_INDUCTOR_2P_441X394
L8301INDUCTOR_INDUCTOR_2P_291X264__11.0UHINDUCTOR_2P_291X264_TOKO
L8401INDUCTOR_NB_INDUCTOR_2P_205X1852.2UHNB_INDUCTOR_2P_205X185
L8501INDUCTOR_INDUCTOR_2P_287X260_DI0.47UHINDUCTOR_2P_287X260
L8601INDUCTOR_INDUCTOR_2P_287X260_DI0.47UHINDUCTOR_2P_287X260
L8801INDUCTOR_INDUCTOR_2P_287X260__16.8UHINDUCTOR_2P_287X260
L9203BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43
L9204BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43
LED5601LED_3P_3NC_LED_3P_126X59_DISCREBLUELED_3P_126X59
LED5602LED_3P_3NC_LED_3P_126X59_DISCREBLUELED_3P_126X59
LED5603LED_3P_3NC_LED_3P_126X59_DISCREBLUELED_3P_126X59
LED5604LED_3P_HARVA_LED_3P_126X59_HARVAMBER/GREENLED_3P_126X59_HARV
LED5605LED_3P_3NC_LED_3P_126X59_DISCREBLUELED_3P_126X59
LED5606LED_3P_3NC_LED_3P_126X59_DISCREBLUELED_3P_126X59
LX4501COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUI
Q0301N_MOS_SOT23_SOT23_H61_DISCRETE_H2N7002SOT23_H61
Q2001N_MOS_SOT23_SOT23_H61_DISCRETE_H2N7002SOT23_H61
Q2102N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q2404N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43
Q2405N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43
Q2406N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43
Q2501UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q2801UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q2802UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q2901N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q3201NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904SOT23_H43
Q3202UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q4501UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q4502N_MOS_SO6_SO6_H43_DISCRETE_SI34SI3456BDVSO6_H43
Q4503N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q5001NB_NPN_SOT23_NB_BJT_SOT23_H43_DPMBS3904NB_BJT_SOT23_H43
Q5002N_MOS_SOT23_SOT23_H61_DISCRETE_H2N7002SOT23_H61
Q5601UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q5602N_MOS_SOT23_SOT23_H61_DISCRETE_H2N7002SOT23_H61
Q6802UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q7601N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q7602P_MOS_SOT23_SOT23_H43_DISCRETE_SI2301BDS_T1_E3SOT23_H43
Q8001RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0WPAK_7P_50_201X240
Q8002RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8003RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8004RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0WPAK_7P_50_201X240
Q8005RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8006RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8101SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8102SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8103SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8104SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8201RJK0353DPA_WPAK_7P_50_201X240_2RJK0355DPA-01WPAK_7P_50_201X240
Q8202RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8203UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q8204NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904SOT23_H43
Q8205N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q8206RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8301RJK0353DPA_WPAK_7P_50_201X240_2RJK0355DPA-01WPAK_7P_50_201X240
Q8302RJK0353DPA_WPAK_7P_50_201X240_2RJK0355DPA-01WPAK_7P_50_201X240
Q8401N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q8501RJK0353DPA_WPAK_7P_50_201X240_2RJK0355DPA-01WPAK_7P_50_201X240
Q8502RJK0353DPA_WPAK_7P_50_201X240_3RJK0349DPA-00-J0WPAK_7P_50_201X240
Q8503UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q8601RJK0353DPA_WPAK_7P_50_201X240_DRJK0355DPA-00-J0WPAK_7P_50_201X240
Q8602RJK0353DPA_WPAK_7P_50_201X240_1RJK0353DPA-00-J0WPAK_7P_50_201X240
Q8604NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904SOT23_H43
Q8605N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43
Q8801FDS4435BZ_SO8_DISCRETE_FDS4435BFDS4435BZSO8
Q8802SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8803SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q8804FDS4435BZ_SO8_DISCRETE_FDS4435BFDS4435BZSO8
Q8808UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q8810NB_2N7002K_NB_MOS_SOT23_H44_DIS2N7002K_T1_E3NB_MOS_SOT23_H44
Q8812UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q9101SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9102SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9103PUMD12_SOT363_PHILIPS_DISCRETE_PUMD12SOT363_PHILIPS
Q9104SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9105SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9106PUMD12_SOT363_PHILIPS_DISCRETE_PUMD12SOT363_PHILIPS
Q9107PUMD12_SOT363_PHILIPS_DISCRETE_PUMD12SOT363_PHILIPS
Q9108SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9109SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9111SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9112SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PAD
Q9203UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q9205UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
Q9206UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NB
RR_R0402_H16_DISCRETE_1KOHM1KOhmR0402_H16
R8009R_R0805_H24_DISCRETE_2.2OHM2.2OhmR0805_H24
R8010R_R0603_H24_DISCRETE_2.2OHM2.2OhmR0603_H24
R8011R_R0402_DISCRETE_0OHM0OhmR0402
R8012R_R0603_H24_DISCRETE_2.2OHM2.2OhmR0603_H24
R8013R_R0402_DISCRETE_0OHM0OhmR0402
R8014R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8015R_R0402_DISCRETE_100OHM100OhmR0402
R8016R_R0402_DISCRETE_0OHM0OhmR0402
R8017R_R0402_DISCRETE_100OHM100OhmR0402
R8019R_R0805_H24_DISCRETE_2.2OHM2.2OhmR0805_H24
R8020THERMISTOR_R0603_DISCRETE_100KO100KOHMR0603
R8021R_R0402_H16_DISCRETE_1KOHM1KOhmR0402_H16
R8022R_R0402_DISCRETE_47KOHM47KOHMR0402
R8023R_R0402_H16_DISCRETE_1KOHM1KOhmR0402_H16
R8024R_R0402_DISCRETE_47KOHM47KOHMR0402
R8025R_R0402_DISCRETE_47KOHM47KOHMR0402
R8026R_R0402_DISCRETE_0OHM0OhmR0402
R8027THERMISTOR_R0603_DISCRETE_100KO100KOHMR0603
R8028R_R0402_DISCRETE_0OHM0OhmR0402
R8029R_R0402_H16_DISCRETE_5.36KOHM5.36KOhmR0402_H16
R8030R_R0402_H16_DISCRETE_39.2KOHM39.2KOhmR0402_H16
R8031R_R0402_DISCRETE_1.65KOHM1.65KOhmR0402
R8032R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8033R_R0402_DISCRETE_80.6KOHM80.6KOhmR0402
R8034R_R0402_DISCRETE_47.5KOHM47.5KOhmR0402
R8035R_R0402_H16_DISCRETE_162KOHM162KOhmR0402_H16
R8036R_R0402_DISCRETE_0OHM0OhmR0402
R8607R_R0402_H16_DISCRETE_60.4KOHM60.4KOhmR0402_H16
R8608R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8609THERMISTOR_R0603_DISCRETE_10KOH10KOHMR0603
R8610R_R0402_DISCRETE_150KOHM150KOHMR0402
R8611R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8612R_R0402_H16_DISCRETE_4.99KOHM4.99KOhmR0402_H16
R8613R_R0402_DISCRETE_1.33KOHM1.33KOhmR0402
R8614R_R0603_H24_DISCRETE_0OHM0OhmR0603_H24
R8615R_R0603_H24_DISCRETE_0OHM0OhmR0603_H24
R8616R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8618R_R0402_DISCRETE_100KOHM100KOhmR0402
R8619R_R0402_DISCRETE_100KOHM100KOhmR0402
R8621R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8622R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8623R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8624R_R0402_H16_DISCRETE_10OHM10OhmR0402_H16
R8701R_R0402_H14_DISCRETE_7.5KOHM7.5KOhmR0402_H14
R8702R_R0402_H16_DISCRETE_0OHM0OhmR0402_H16
R8703R_R0402_H16_DISCRETE_20KOHM20KOhmR0402_H16
R8704R_R0402_DISCRETE_10OHM10OhmR0402
R8801R_R1508_DISCRETE_20MOHM20mOHMR1508
R8802R_R1508_DISCRETE_20MOHM20mOHMR1508
R8803R_R0402_DISCRETE_200KOHM200KOhmR0402
R8804R_R0805_H24_DISCRETE_2.2OHM2.2OhmR0805_H24
R8805R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8806R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8808R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8809R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8810R_R0402_H16_DISCRETE_0OHM0OhmR0402_H16
R8811R_R0402_DISCRETE_33KOHM33KOhmR0402
R8812R_R0603_DISCRETE_10KOHM10KOhmR0603
R8813R_R0603_DISCRETE_20KOHM20KOhmR0603
R8814R_NB_R0603_H22_DISCRETE_13.7KOH13.7KOhmNB_R0603_H22
R8815R_R0402_H16_DISCRETE_20KOHM20KOhmR0402_H16
R8816R_R0402_H16_DISCRETE_1KOHM1KOhmR0402_H16
R8818R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8819R_R0402_H16_DISCRETE_16.9KOHM16.9KOhmR0402_H16
R8820R_R0402_H16_DISCRETE_1KOHM1KOhmR0402_H16
R8822R_R0402_DISCRETE_23.2KOHM23.2KOhmR0402
R8823R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8824R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8825R_R0402_DISCRETE_130KOHM130KOhmR0402
R8826R_R0402_H16_DISCRETE_20KOHM20KOhmR0402_H16
R8827R_R0402_DISCRETE_130KOHM130KOhmR0402
R8828R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8829R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R8830R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R8837R_R0402_H16_DISCRETE_100KOHM100KOhmR0402_H16
R9101R_R0402_DISCRETE_33.2KOHM33.2KOhmR0402
R9102R_R0402_H16_DISCRETE_20KOHM20KOhmR0402_H16
R9104R_R0402_H16_DISCRETE_20KOHM20KOhmR0402_H16
R9105R_R0402_H16_DISCRETE_10KOHM10KOhmR0402_H16
R9106R_R0402_DISCRETE_100KOHM100KOhmR0402
R9107R_R0402_DISCRETE_100KOHM100KOhmR0402
R9108R_R0402_DISCRETE_100KOHM100KOhmR0402
R9110R_R0402_DISCRETE_200KOHM200KOhmR0402
R9111R_R0402_DISCRETE_200KOHM200KOhmR0402
R9112R_R0402_DISCRETE_200KOHM200KOhmR0402
R9113R_R0402_DISCRETE_200KOHM200KOhmR0402
R9201R_R0402_DISCRETE_330OHM330OhmR0402
R9202R_R0402_DISCRETE_330OHM330OhmR0402
R9203R_R0402_DISCRETE_330OHM330OhmR0402
RN03012R4PS_2R4P0402_H18_DISCRETE_10K10KOHM2R4P0402_H18
RN06014R8PS_4R8P_DISCRETE_0OHM0Ohm4R8P
RN06024R8PS_4R8P_DISCRETE_0OHM0Ohm4R8P
RN24074R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20
RN24084R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20
RN29012R4PS_2R4P0402_H18_DISCRETE_10K10KOHM2R4P0402_H18
RN29022R4PS_2R4P0402_H18_DISCRETE_22O22OHM2R4P0402_H18
RN30014R8PS_4R8P_DISCRETE_4.7KOHM4.7KOHM4R8P
RN30024R8PS_4R8P_DISCRETE_4.7KOHM4.7KOHM4R8P
RN30034R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20
RN30044R8PS_4R8P_DISCRETE_4.7KOHM4.7KOHM4R8P
RN30054R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20
RN30064R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20
RN30074R8PS_4R8P0402_H20_DISCRETE_100100KOhm4R8P0402_H20
RN30084R8PS_4R8P0402_H20_DISCRETE_47O47OHM4R8P0402_H20
RN53012R4PS_2R4P0603_DISCRETE_0OHM0Ohm2R4P0603
RN60014R8PS_4R8P0402_H20_DISCRETE_100100KOhm4R8P0402_H20
RN68012R4PS_2R4P0402_DISCRETE_4.7KOHM4.7KOHM2R4P0402
RN68022R4PS_2R4P0402_DISCRETE_2.2KOHM2.2KOHM2R4P0402
RN74018R16PS_NB_8R16P_DISCRETE_56OHM56Ohm8R16P
RN74028R16PS_NB_8R16P_DISCRETE_56OHM56Ohm8R16P
RN74038R16PS_NB_8R16P_DISCRETE_56OHM56Ohm8R16P
RN74048R16PS_NB_8R16P_DISCRETE_56OHM56Ohm8R16P
RNX45012R4PS_2R4P0603_DISCRETE_0OHM0Ohm2R4P0603
RP24018R10PS_8R10P_DISCRETE_10KOHM10KOhm8R10P
RP24028R10PS_8R10P_DISCRETE_10KOHM10KOhm8R10P
RP24038R10PS_8R10P_DISCRETE_10KOHM10KOhm8R10P
RX1704R_R0402_DISCRETE_0OHM0OhmR0402
RX2115R_R0402_DISCRETE_0OHM0OhmR0402
RX2116R_R0402_DISCRETE_0OHM0OhmR0402
SL0301SL_0402_SHORTPIN_R0402_SHORTLASHORT LANDSHORTPIN_R0402
SL0302SL_0402_SHORTPIN_R0402_SHORTLASHORT LANDSHORTPIN_R0402
SW4102TP_SWITCH_5P_HCH_SW_5P_354X244_TACT_SWITCH_5PSW_5P_354X244_DTNS
SW4103TP_SWITCH_5P_HCH_SW_5P_354X244_TACT_SWITCH_5PSW_5P_354X244_DTNS
U0301PZ98927_NB_SOCKET989_IO_SOCKET9SOCKET989NB_SOCKET989
U2001IBEXPEAK_M_NB_BGA_1071P_20_1063IBEXPEAK-MNB_BGA_1071P_20_1063X984
U2401NC7SZ08M5_SC70_S5_IC_NC7SZ08P5XNC7SZ08P5X_NLSC70_S5
U2407PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236
U2502NC7SZ08M5_SC70_S5_IC_NC7SZ08P5XNC7SZ08P5X_NLSC70_S5
U2802SST25LF040A_SOIC_8P_50_213X311_SST25VF032BSOIC_8P_50_213X311
U2901ICS9LRS3197AKLFT_VIA_NB_QFN_32PICS9LRS3197AKLFTNB_QFN_32P_S197_PAD_ICS_V
U3001IT8502E_L_QFP_128P_16_630X630_IIT8502E-LQFP_128P_16_630X630
U3003SST25LF040A_SOIC_8P_50_212X315_SST25VF080BSOIC_8P_50_212X315
U3501PI5V330_SOIC_16P_25_197X236_IC_TS5V330CDBQRSOIC_16P_25_197X236
U3502PI5V330_SOIC_16P_25_197X236_IC_TS5V330CDBQRSOIC_16P_25_197X236
U3503PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236
U3504PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236
U3505PI5V330_SOIC_16P_25_197X236_IC_TS5V330CDBQRSOIC_16P_25_197X236
U3601CX20672_VIA_NB_QFN_40P_20_S236_CX20672-11ZNB_QFN_40P_20_S236_PAD_VIA
U5001G781_1_SOIC_8P_26_122X193_H48_IG781-1P8FSOIC_8P_26_122X193_H48
U5002G781_1_SO8_H69_IC_G781G781SO8_H69
U6000NC7SZ08M5_SOT23_S5_SC70_RD4_H43NC7SZ08P5XSOT23_S5_SC70_RD4_H43
U6001NC7SZ08M5_SOT23_S5_SC70_RD4_H43NC7SZ08P5XSOT23_S5_SC70_RD4_H43
U6002NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILD
U7201M96_NB_BGA_962P_1142X1142_IC_M9M92(A12)NB_BGA_962P_1142X1142
U7301H5TQ1G63BFR_12C_NB_BGA_96P_31_5H5TQ1G63BFR-12CNB_BGA_96P_31_512X295
U8001NCP3218MNR2G_8VIA_QFN_48P_16_S2NCP3218MNR2GQFN_48P_16_S236_PAD_INT_8V
U8101RT8206AGQW_4VIA_NB_QFN_32P_S197RT8206AGQWNB_QFN_32P_S197_PA_S_H31_4V
U8102UP7714HMA5_MB_SOT23_S5_MAX_IC_UUP7714BMA5-00MB_SOT23_S5_MAX
U8201RT8202APQW_2VIA_MX_QFN_16P_20_SRT8202APQWMX_QFN_16P_20_S118_PAD_2V
U8301RT8202APQW_2VIA_MX_QFN_16P_20_SRT8202APQWMX_QFN_16P_20_S118_PAD_2V
U8302UP7711U8_4VIA_MB_SOIC_8P_50_197UP7711U8MB_SOIC_8P_50_197X236_PD_4V
U8401RT8015BGQW_MB_DFN_10P_20_S118_PRT8015BGQWMB_DFN_10P_20_S118_PAD_RI
U8501RT8202APQW_2VIA_MX_QFN_16P_20_SRT8202APQWMX_QFN_16P_20_S118_PAD_2V
U8601RT8152DGQW_QFN_32P_20_S197_PAD_RT8152DGQWQFN_32P_20_S197_PAD_SIR_H31
U8701UP7706U8_4VIA_MB_SOIC_8P_197X23UP7706U8MB_SOIC_8P_197X236_4VIA
U8801MB39A132_QFN_32P_20_197X197_PADMB39A132QFN_32P_20_197X197_PAD_AMI
U8802LMV321M5X_NB_SOT23_S5_T_IC_LMV3LMV321IDBVRNB_SOT23_S5_T
X2001CRYSTAL_3P_XTAL_3P_362X112_DISC32.768KHZXTAL_3P_362X112
X2101CRYSTAL_XTAL_2P_236X138_DISCRET25MhzXTAL_2P_236X138
X2901CRYSTAL_XTAL_2P_528X191_H126_DI14.318MhzXTAL_2P_528X191_H126
X3001CRYSTAL_3P_XTAL_3P_362X112_DISC32.768KHZXTAL_3P_362X112
重要提示:PCB作品文件展下载说明
老吴 | 2019-3-3 17:45:18 | 显示全部楼层
PCB文件共享。回复可见下载
游客,如果您要查看本帖隐藏内容请回复
hsin | 2019-3-3 17:53:54 | 显示全部楼层
miaomiao | 2019-3-3 18:30:35 | 显示全部楼层
asdf140 | 2019-3-3 19:35:58 | 显示全部楼层
老吴周天还这么上进,
junkyoung | 2019-3-3 20:09:43 | 显示全部楼层
丁响820425 | 2019-3-3 20:09:53 | 显示全部楼层
lbmone | 2019-3-3 21:53:14 | 显示全部楼层
好资料很多,谢谢分享
boatxin | 2019-3-4 06:52:01 | 显示全部楼层
单枪舞九州 | 2019-3-4 07:06:58 | 显示全部楼层
