[Allegro16.6以下] (MTK6763)MT6763VCT_LPDDR4X+MT6356WA  10层手机板PCB和原理
查看18500 | 回复144 | 2019-3-7 20:05:55 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ANT1700IV441000060_ANT1-0103-009_1010610106115524ANT1-0103-009
ANT1701IV441000060_ANT1-0103-009_1010610106115524ANT1-0103-009
ANT2001SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2
ANT2002SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2
ANT2003SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2
ANT2004SMR-TS-2-1-5-1-25DGR2_SMR-TS-2-SMR-TS-2-1-5-1-25DGR2SMR-TS-2-15-125DGR2
ANT220410103114014_ANT1-0203-014_1010310103114014ANT1-0203-014
ANT3006IV441000071_ANT1-0103-018C_3.1.3.1.29.0518ANT1-0103-018C
ANT430310103114014_ANT1-0203-014_1010310103114014ANT1-0203-014
ANT430610103114014_ANT1-0203-014_1010310103114014ANT1-0203-014
ANT4307730300033_CLAMP1-0104-012_L0226L0226-T1SMP-0WV-LCLAMP1-0104-012
ANT43081191740044_CLAMP1-0103-012_11911191740044CLAMP1-0103-012
D801140000023_DF0402-004B_LRB521BS-LRB521BS-30T5GDF0402-004B
D1002140000013_D0603-005_DS160-40THDDS160-40THD02D0603-005
D1701130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D1702130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D1707130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D1708130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003
D1712130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D1720130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D1721130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D1901130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003
D1902130300040_DDF0201-003_NC_ESD545NC_ESD5451Z-2/TRDDF0201-003
D2000130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D2001130100012_VSR0201-003_NC_SDV060NC_SDV0603E5R5C220NPTFVSR0201-003
D2002130100012_VSR0201-003_NC_SDV060NC_SDV0603E5R5C220NPTFVSR0201-003
D2003130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D2004130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D2005130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D2006130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D2007130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D2008140200006_SOD323-2-009_LM3Z5V1PLM3Z5V1PT1GSOD323-2-009
D2009130300036_DDF0402-005_ESD5651N_ESD5651NDDF0402-005
D2010130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D2011130300040_DDF0201-003_ESD5451Z-ESD5451Z-2/TRDDF0201-003
D2012130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D2013130300027_DF0402-004A_LESD8D12TLESD8D12T5GDF0402-004A
D2014130100012_VSR0201-003_SDV0603E5SDV0603E5R5C220NPTFVSR0201-003
D3004130300038_DDF0201-003_ESD5311Z-ESD5311Z-2/TRDDF0201-003
D3005130300038_DDF0201-003_ESD5311Z-ESD5311Z-2/TRDDF0201-003
FB1600130000009_LB0603-008_BLM18PG181BLM18PG181SN1DLB0603-008
FB1601130000009_LB0603-008_BLM18PG181BLM18PG181SN1DLB0603-008
FB1701130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005
FB1702130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005
FB1704130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005
FB1705130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005
FB1707130000044_LB0402-005_BLM15AG102BLM15AG102SN1LB0402-005
FB2201130000046_L0201-003_BLM03AX241SBLM03AX241SN1L0201-003
FL2201310200272_SFLT5-0101-005B_SFHG8SFHG89GA002SFLT5-0101-005B
FL2202310200354_SFLT5-0101-005B_B3924B39242B8840P810SFLT5-0101-005B
FL2204310500026_SFLT6-20-0102-006_DP1DP1608-V1524CAT/LFSFLT6-20-0102-006
FL4101310200360_SFLT5-0101-005B_B3923B39232B8845P810SFLT5-0101-005B
FL4102310200182_SFLT5-0101-005_SAFEA1SAFEA1G90MA0F0AR15SFLT5-0101-005
FL4103310200395_SFLT5-0101-006A_SF14-SF14-2605M5UUA1SFLT5-0101-006A
FL4201310400177_SFLT8-0102-006_SD18-1SD18-1950R8UUQ1SFLT8-0102-006
FL4301310200417_SFLT5-0101-005B_HDFB0HDFB01RSS-B5SFLT5-0101-005B
FL4302310200415_SFLT5-0101-005B_HDFB0HDFB05RSS-B5SFLT5-0101-005B
FL4303310200330_SFLT5-0101-005B_SFHG5SFHG56BA002SFLT5-0101-005B
FL4304310200414_SFLT5-0101-005B_HDFB0HDFB08RSS-B5SFLT5-0101-005B
FL4305310200411_SFLT5-0101-005B_HDFB4HDFB40RSS-B5SFLT5-0101-005B
FL4306310200278_SFLT10-0201-006_SFWG0SFWG00DB002SFLT10-0201-006
FL4307310200399_SFLT5-0101-005B_SAFFBSAFFB2G60AA0F0ASFLT5-0101-005B
FL4308310200268_SFLT5-0101-005B_SAFFBSAFFB1G84AB0F0AR15SFLT5-0101-005B
HOLE3001FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3002FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3003FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3004FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3005FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3006FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3008FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3009FUNCTIONALITY-TEST_NUT_64_102_Pfunctionality-test-pointNUT_64_102_P
HOLE3010HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0
HOLE3011HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0
HOLE3012HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0
HOLE3013HOLE80_0_HOLE80_0_NC_HOLE80_0NC_HOLE80_0HOLE80_0
ID3003ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3004ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3005ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3006ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3007ID_ID_SINGLE_POINTSingle_pointID
ID3008ID_ID_SINGLE_POINTSingle_pointID
ID3009ID_ID_SINGLE_POINTSingle_pointID
ID3010ID_ID_SINGLE_POINTSingle_pointID
ID3011ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3012ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3013ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
ID3014ID-BOARD_ID-BOARD_SET_POINTSET_POINTID-BOARD
J1701440800046_VAF5-0811-039B-BRK_PJPJ-D3167A-ABK7AU05L-RHVAF5-0811-039B-BRK
J1800440000119_SED40-16-S-007_WP7B-SWP7B-S040VA1SED40-16-S-007
J1900440000117_SED30-16-S-007_WP7A-SWP7A-S030VA1SED30-16-S-007
J1901SJ116217_SED24-14-S-006A_SJ1162SJ116217SED24-14-S-006A
J1902SJ116217_SED24-14-S-006A_SJ1162SJ116217SED24-14-S-006A
J2001440000156_SED30-14-S-007_2458524 5857 030 201 829+SED30-14-S-007
J2002440400094_SIM12-1826-015_1.063A1.063A0-013-5R0SIM12-1826-015
J2003440500064_PWC6-0206-007_WP10-S0WP10-S002VA10-R15000PWC6-0206-007
J2101440000092_SED10-16-S-007_WP7A-SWP7A-S010VA1SED10-16-S-007
J2102440000092_SED10-16-S-007_WP7A-SWP7A-S010VA1SED10-16-S-007
J2201440600015_RF2-0202-009A_7.022A07.022A0-000-1R0RF2-0202-009A
J4201440600015_RF2-0202-009A_7.022_17.022A0-000-1R0RF2-0202-009A
J4202440600015_RF2-0202-009A_7.022_17.022A0-000-1R0RF2-0202-009A
J4204440600020_RF4-0202-012_1002005910020059RF4-0202-012
L801120000236_L0201-003_22NH_IV12022 nHL0201-003
L802120000236_L0201-003_22NH_IV12022 nHL0201-003
L803130000044_LB0402-005_BLM15AG1_1BLM15AG102SN1LB0402-005
L1003120300106_PL0203-012D_10UH_IV110 uHPL0203-012D
L1006130000042_L0402-005_BLM15HD102SBLM15HD102SN1DL0402-005
L1701100000001_R0402-004_0R_100000000RR0402-004
L1702100000001_R0402-004_0R_100000000RR0402-004
L1703100000001_R0402-004_0R_100000000RR0402-004
L1704100000001_R0402-004_0R_100000000RR0402-004
L1707120000132_L0402-007_68NH_IV12068 nHL0402-007
L1708130000036_LB0603-008_PZ1608D102PZ1608D102-R80TFLB0603-008
L1801130000054_LB0201-003_BLM03HD102BLM03HD102SN1LB0201-003
L1802100000004_R0201-003_0R_100000000RR0201-003
L1804100000001_R0402-004_0R_100000000RR0402-004
L2000100000001_R0402-004_0R_IV1000000RR0402-004
L2001100000001_R0402-004_0R_IV1000000RR0402-004
L2003100000000_R0603-005_0R_IV1000000RR0603-005
L2105100000089_R0201-003_24R_100000024RR0201-003
L2106100000089_R0201-003_24R_100000024RR0201-003
L2201120000296_L0201-003_82NH_1200082 nHL0201-003
L2202120000296_L0201-003_82NH_1200082 nHL0201-003
L2204120000277_L0201-003_9.1NH_12009.1 nHL0201-003
L2205120000287_L0201-003_27NH_1200027 nHL0201-003
L2207120000269_L0201-003_12NH_1200012 nHL0201-003
L2208120000242_L0201-003_NC_8.2NH_1NC_8.2 nHL0201-003
L2211120000049_L0201-003_NC_2.2NH_IVNC_2.2nHL0201-003
L2213120000186_L0201-003_10NH_1200010 nHL0201-003
L2216100000004_R0201-003_0R_100000000RR0201-003
L4101110000064_C0201-003_33PF/50V_I33pF/50 VC0201-003
L4102120000248_L0201-003_NC_1.8NH_INC_1.8 nHL0201-003
L4103120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003
L4104120000241_L0201-003_3.9NH_IV123.9 nHL0201-003
L4105120000187_L0201-003_5.1NH_IV125.1 nHL0201-003
L4106120000277_L0201-003_9.1NH_IV129.1 nHL0201-003
L4107120000184_L0201-003_4.7NH_IV124.7 nHL0201-003
L4108120000058_L0201-003_3.3NH_IV1203.3nHL0201-003
L4109110000094_C0201-003_NC_2.2PF/25NC_2.2pF/25 VC0201-003
L4110120000248_L0201-003_NC_1.8NH_INC_1.8 nHL0201-003
L4112120000245_L0201-003_1.2NH_IV121.2 nHL0201-003
L4113120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003
L4114120000241_L0201-003_NC_3.9NH_INC_3.9 nHL0201-003
L4115120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4116120000245_L0201-003_1.2NH_IV121.2 nHL0201-003
L4117120000248_L0201-003_NC_1.8NH_1NC_1.8 nHL0201-003
L4118120000238_L0201-003_2NH_IV12002 nHL0201-003
L4119120000238_L0201-003_2NH_IV12002 nHL0201-003
L4120110000064_C0201-003_33PF/50V_1133pF/50VC0201-003
L4205120000188_L0201-003_NC_3.3NH_1NC_3.3 nHL0201-003
L4206120000250_L0201-003_1.5NH_IV121.5 nHL0201-003
L4207120000233_L0201-003_15NH_IV12015 nHL0201-003
L4208120000188_L0201-003_NC_3.3NH_1NC_3.3 nHL0201-003
L4211120000223_L0201-003_1.3NH_IV121.3 nHL0201-003
L4212120000249_L0201-003_7.5NH_IV127.5 nHL0201-003
L4216120000241_L0201-003_3.9NH_IV123.9 nHL0201-003
L4218120000240_L0201-003_6.8NH_IV126.8 nHL0201-003
L4219120000250_L0201-003_1.5NH_IV121.5 nHL0201-003
L4220120000242_L0201-003_8.2NH_IV128.2 nHL0201-003
L4221120000176_L0201-003_2.4NH_IV122.4 nHL0201-003
L4229120000058_L0201-003_3.3NH_120003.3nHL0201-003
L4230120000293_L0201-003_2.4000NH_I2.4000 nHL0201-003
L4231120000304_L0201-003_NC_10NH_IVNC_10 nHL0201-003
L4232120000304_L0201-003_NC_10NH_IVNC_10 nHL0201-003
L4233120000265_L0201-003_5.6NH_IV125.6 nHL0201-003
L4234120000237_L0201-003_1NH_IV12001 nHL0201-003
L4239120000243_L0201-003_NC_18NH_12NC_18 nHL0201-003
L4240120000117_L0201-003_NC_18NH_120NC_18nHL0201-003
L4242120000246_L0201-003_NC_3.6NH_INC_3.6 nHL0201-003
L4243120000240_L0201-003_NC_6.8NH_INC_6.8 nHL0201-003
L4244120000117_L0201-003_NC_18NH_120NC_18nHL0201-003
L4245120000242_L0201-003_NC_8.2NH_INC_8.2 nHL0201-003
L4249120000241_L0201-003_NC_3.9NH_1NC_3.9 nHL0201-003
L4253120000250_L0201-003_NC_1.5NH_INC_1.5 nHL0201-003
L4254120000246_L0201-003_NC_3.6NH_INC_3.6 nHL0201-003
L4255110000064_C0201-003_33PF/50V_I33pF/50 VC0201-003
L4256120000265_L0201-003_NC_5.6NH_INC_5.6 nHL0201-003
L4257120000239_L0201-003_NC_12NH_IVNC_12 nHL0201-003
L4301120000288_L0201-003_27NH_IV12027 nHL0201-003
L4302120000244_L0201-003_9.1NH_IV129.1 nHL0201-003
L4303120000219_L0201-003_6.2NH_IV126.2 nHL0201-003
L4304120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4305120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4306120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4307120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4308110000094_C0201-003_2.2PF/25V_2.2pF/25 VC0201-003
L4309120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003
L4310120000293_L0201-003_2.4000NH_I2.4000 nHL0201-003
L4311120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003
L4312120000232_L0201-003_2.7NH_IV122.7 nHL0201-003
L4313120000249_L0201-003_NC_7.5NH_INC_7.5 nHL0201-003
L4314120000243_L0201-003_18NH_1200018 nHL0201-003
L4315120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4316120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4321120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4322120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4323120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4324120000232_L0201-003_NC_2.7NH_INC_2.7 nHL0201-003
L4325120000265_L0201-003_5.6NH_IV125.6 nHL0201-003
L4326120000240_L0201-003_6.8NH_IV126.8 nHL0201-003
L4327120000240_L0201-003_6.8NH_IV126.8 nHL0201-003
L4329120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4330120000058_L0201-003_NC_3.3NH_IVNC_3.3nHL0201-003
L4331120000058_L0201-003_NC_3.3NH_12NC_3.3nHL0201-003
L4333100000004_R0201-003_NC_0R_10000NC_0RR0201-003
L4334100000004_R0201-003_0R_100000000RR0201-003
L4335100000004_R0201-003_0R_100000000RR0201-003
L4337110000211_C0201-003_0.5PF/50V_10.5pF/50VC0201-003
L4338110000211_C0201-003_0.5PF/50V_10.5pF/50VC0201-003
L4339100000004_R0201-003_0R_100000000RR0201-003
L4340120000246_L0201-003_3.6NH_IV123.6 nHL0201-003
LB1901130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1902130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1903130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1904130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1905130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1906130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1907130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1909130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1915130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1916130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LB1917130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
LED1912IV470100003_LED2-0203-026-BOA_IIV470100003LED2-0203-026-BOA
LED1913IV470100002_LED2-0203-019-BOA_IIV470100002LED2-0203-019-BOA
MIC1701IV460000097_MIC5-0304-010A_S18OS18OB381-015MIC5-0304-010A
MR2101100300005_TSR0402-005_100K_1003100KTSR0402-005
PL601120300197_PL0203-012D_0.47000U0.47000 uHPL0203-012D
PL602120300197_PL0203-012D_0.47000U0.47000 uHPL0203-012D
PL603120300236_PL0202-010D_1UH_IV121 uHPL0202-010D
PL604120300236_PL0202-010D_1UH_IV121 uHPL0202-010D
PL605120300261_PL0203-010F_1UH_IV121 uHPL0203-010F
PL606120300261_PL0203-010F_1UH_IV121 uHPL0203-010F
PL1001120300261_PL0203-010F_1UH_IV121 uHPL0203-010F
PL1002120300239_PL0202-010D_2.2000UH2.2000 uHPL0202-010D
PL1600120300261_PL0203-010F_1UH_IV121 uHPL0203-010F
TP3028MANUFACTURAL-TEST_32_TP32_MANUFmanufactural-test-pointTP32
TP3029MANUFACTURAL-TEST_32_TP32_MANUFmanufactural-test-pointTP32
TP3030FUNCTIONALITY-TEST_TP24_FUNCTIOfunctionality-test-pointTP24
U101MT6763VCT_LPDDR4X_BGA566-16-111MT6763VCT_LPDDR4XBGA566-16-1112-009
U601MT6356WA_BGA181-16-0606-006_MT6MT6356WABGA181-16-0606-006
U1001MT6370P_BGA93-16-0404-006_MT637MT6370PBGA93-16-0404-006
U1500220300233_BGA221-20-1213-010_KMKMRX1000BM-B614BGA221-20-1213-010
U1602AW87319CSR_BGA19-20-0203-006_AWAW87319CSRBGA19-20-0203-006
U1801130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
U1803130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
U1804130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
U1810130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
U1811130500013_LB0403-005B_EXC14CT90EXC14CT900ULB0403-005B
U1902230000103_DFN4-26-0101-006_NCP1NCP114AMX120TCGDFN4-26-0101-006
U1907IV270100036_BGA36-16-0202-006_FFSA644BUCXBGA36-16-0202-006
U1911230000096_DFN4-26-0101-006_NCP1NCP114AMX105TCGDFN4-26-0101-006
U1912230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004
U1913230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004
U1914230000113_DFN4-26-0101-004_WL28WL2820D28-4/TRDFN4-26-0101-004
U2002230600010_BGA12-16-0102-006C_NCNC_KTS1681BGA12-16-0102-006C
U2101ICM-20608D_BCC16-20-0303-008_ICICM-20608DBCC16-20-0303-008
U2201240700008_QFN40-16-0505-009A_MTMT6625LQFN40-16-0505-009A
U2202320300021_BCC6-16-0101-005_AW50AW5015DNRBCC6-16-0101-005
U4001MT6177_RF_BGA144-16-0505-007_MTMT6177_RFBGA144-16-0505-007
U4101320100104_BCC42-17-0407-007_320320100104BCC42-17-0407-007
U4202310400181_SFLT8-0102-006_SD18-1SD18-1880R8UUA1SFLT8-0102-006
U4204310400163_SFLT8-0102-006_SD18-0SD18-0836R8UUQ1SFLT8-0102-006
U4205320100064_BCC38-19-0506-008A_RFRF5216BCC38-19-0506-008A
U4206310400170_SFLT8-0102-005A_B3927B39272B8674P810SFLT8-0102-005A
U4207310400215_SFLT8-0102-006_SAYEY8SAYEY897MBG0F0AR05SFLT8-0102-006
U4208310200278_SFLT10-0201-006_SFWG0SFWG00DB002SFLT10-0201-006
U4209320500050_QFN12-20-0202-006A_SKSKY13396-397LFQFN12-20-0202-006A
U4211310400220_SFLT8-0102-005A_B3918B39182B8680P810SFLT8-0102-005A
U4301MXD8680_BCC14-16-0202-006_MXD86MXD8680BCC14-16-0202-006
U4308320500109_BGA8-16-0101-005C_NC_NC_SKY19223-001BGA8-16-0101-005C
U4309320500114_BGA11-16-0202-004B_CXCXA4429GCBGA11-16-0202-004B
X801190000099_X4-0203-010_26/MHZ_IV26/MHzX4-0203-010
X2201190100048_X4-0203-009_26/MHZ_IV26/MHzX4-0203-009
重要提示:PCB作品文件展下载说明
老吴 | 2019-3-7 20:10:08 | 显示全部楼层
PCB和原理图一起打包。还没有完全画完的。仅做参考。
游客,如果您要查看本帖隐藏内容请回复
南亭好远 | 2019-3-7 23:22:09 | 显示全部楼层
yfchen1003 | 2019-3-8 08:14:53 | 显示全部楼层
ntpcbyanli4111 | 2019-3-8 08:37:26 | 显示全部楼层
love欣 | 2019-3-8 08:57:20 | 显示全部楼层
linyuanfei | 2019-3-8 09:10:32 | 显示全部楼层
boatxin | 2019-3-8 09:19:55 | 显示全部楼层
liyongyi3 | 2019-3-8 09:22:42 | 显示全部楼层
miaomiao | 2019-3-8 09:49:30 | 显示全部楼层
