Name | PCB Decal | Value | Part Type | D1 | SOD_323 | SCS751V-40 | DIODE | D3 | DIO-13X25 | RB400VA-50TR/40V | DIODE_SCHOTTKY | D15 | SOD-123-T | XBS104S14 | DIODE_SCHTKY | D501 | SOD-123 | RB160M-30TR | SOD-123 | D502 | SOD-123 | RB160M-30TR | SOD-123 | D508 | SOD-523 | RB521S-40 | SOD-523 | D509 | SOD-523 | RB521S-40 | SOD-523 | D510 | SOD-523 | RB521S-40 | SOD-523 | D511 | SOD-523 | RB521S-40 | SOD-523 | D512 | DIO-13X25 | RB400VA-50TR/40V | DIO-13X25 | D2300 | SOD_323 | SCS751V-40 | DIODE | ED2000 | ESD0402 | ESD5451N | DIODE_BI_DIR_TRIG | FB407 | R0402 | BLM15HD102SN1 | FERRITE_1 | H001 | PAD1.8 | TP_0.7 | TP | H003 | PAD1.8 | TP_0.7 | TP | H004 | PAD1.8 | TP_0.7 | TP | H005 | PAD1.8 | TP_0.7 | TP | J1 | BAT-4PIN | C1200RS00420P920 | 4PIN_1.2MM_JACK | J3 | TF_M618C | TFWF1-S11-1X0X | TF-M618C | J5 | CON_FPC-0.5-6P | FPC-0.5-6P_·-??_1.2H | CON_FPC-0.5-6P | J401 | HMT-JACK05-42DXC10-DIP01 | EAR_JACK_3 | EAR_JACK_4 | J803 | FH34SC-8-0D5SH | FPC_CONN_8PIN | FPC_CONN_3 | J1301 | FPC_CONN_40P_XF2M | EJ080NA-04B | AUO--LCD_4 | J2000 | MICROUSB_5PIN_D26 | USB | MINI_USB_1 | J6000 | DSANT | ECT818000071 | JP3_0 | K1 | KEY-TC-043 | Power_KEY | SW4P_0 | K304 | KEY-TC-043 | Power_KEY | SW4P_0 | L1 | PL252012 | 10uH/0.7A/252012 | IND_PL252012 | L2 | PL252012 | 10uH/0.7A/252012 | IND_PL252012 | L19 | CD43 | 2.2uH-DCR<0.1R-2A | INDUCTOR_0_2 | L41 | CKS4B14X20W | 90OHM£¨DLW21HN900SQ2L£? | CHOKE_COM | L501 | IND-LQH44P | 2.2uH | INDUCTOR_2 | L502 | IND-LQH44P | 4.7uH | INDUCTOR_2 | L1100 | L0603 | 180R-100M | INDUCTOR | L1300 | L0603 | 180R-100M | INDUCTOR | L2300 | IND4X4 | 1.0uH | INDUCTORS_OF_FERRITE_2 | L2301 | IND3X3 | 1.0uH | INDUCTORS_OF_FERRITE_2 | L2302 | IND3X3 | 1.0uH | INDUCTORS_OF_FERRITE_2 | L2303 | IND3X3 | 1.0uH | INDUCTORS_OF_FERRITE_2 | L2304 | IND4X4 | 1.0uH | INDUCTORS_OF_FERRITE_2 | L2305 | IND3X3 | 1uH | INDUCTORS_OF_FERRITE_2 | L2306 | IND_252012 | 0.24uH | INDUCTORS_OF_FERRITE_2 | L6000 | IND3X3 | SWPA3012S4R7MT/1A | INDUCTORS_OF_FERRITE | M1 | MARK | MARK | MARK | M2 | MARK | MARK | MARK | M3 | MARK | MARK | MARK | M4 | MARK | MARK | MARK | M100 | MARK | MARK | MARK | M101 | MARK | MARK | MARK | M102 | MARK | MARK | MARK | M103 | MARK | MARK | MARK | P1402 | PAD140X70 | TP_0.7 | TP | P1403 | PAD140X70 | TP_0.7 | TP | P1404 | PAD140X70 | TP_0.7 | TP | Q1 | SOT23 | SI2312 | ACE2305 | Q2 | SOT23 | SI2312 | ACE2305 | Q103 | SOT_23 | Hall_IC | HALL_IC | Q801 | SOT-363 | UMX1N | NPNX2-UMX1N | Q2300 | SOT_23 | S8050 | NPN | Q2301 | SOT_23 | WPM2015-3/TR | MOSFET_P | Q2302 | SOT_23 | S8050 | NPN | Q3500 | SOT_23 | WNM2016-3/TR | MOSFET_N_2 | Q3501 | SOT_323 | WNM2021-3/TR | MOSFET_N_2 | Q4602 | SOT_23 | WPM2015-3/TR | MOSFET_P | Q4603 | SOT_23 | S8050 | NPN | U1 | TDFN-6L | AW9961 | G5121_0 | U2 | SOT_23_5 | NC/IA6004-15S25-F | IA6004-15S25-F | U6 | CW2015CSAD | cw2015csad | CW2015CSAD | U17 | SOT23-6 | SY7152 | RT9266PE_3 | U401 | QFN-32-4X4 | WM8904 | WM8904_1 | U501 | WSON-8 | AT88SC0104CA | SST25VF080_0 | U505 | TDFN-6L | AW9961 | G5121_0 | U506 | QFN_6X6_48_0D4 | TPS65185 | TPS65185_1 | U1000 | BGA453_19R00X19R00X1R40 | RK3368 | BGA453_19R00X19R00X1R40 | U2000 | SOT_23 | ESD5302F | ESD_ESDA6V8UL | U2300 | QFN68_7R00X7R00X0R80_T | RK818-1 | PMIC_RK818 | U2301 | WLCSP-20 | XZ3216 | WLCSP-20 | U3500 | FBGA178_13R00X11R50X1R20 | 256x32bit | FBGA178_13R00X11R50X1R20 | U3900 | SOT_23_5 | PT5108E23E-18 | LDO_PT5108 | U4000 | BGA169_18R00X14R00X1R20 | eMMC | BGA169_18R00X14R00X1R20 | U6000 | AP6XXX | AP6330 | AP6493_0 | Y1100 | CRY4_3R20X2R50X0R80 | 24MHz | CRYSTAL_4P | Y2300 | CRY2_6R90X1R40X1R30 | 32.768KHz | CRYSTAL_2P_1G | Y6001 | CRY-D3225 | 26MHz-10ppm | CRYSTAL-4_0 |
