查看: 16455|回复: 104
[Allegro16.6以下] Atmel ATSAMA5D2-XULT__KitsFiles  pcb和原理图等整套资料SAMA
    17万
    管理员
    原创先锋奖终身成就奖优秀斑竹奖宣传大使奖社区居民社区明星社区劳模最爱沙发新人进步奖忠实会员金点子奖特殊贡献奖
    发表于 2019-4-4 21:10:06 | 显示全部楼层 |阅读模式
    BP1SWITCH2_0_SWS4B60S_TACTSWITCHTact SwitchSWS4B60S
    BP2SWITCH2_0_SWS4B60S_TACTSWITCHTact SwitchSWS4B60S
    BP3SWITCH2_0_SWS4B60S_TACTSWITCHTact SwitchSWS4B60S
    D1LED REDKPG-1608_0_LED0805_REDREDLED0805
    D2RGB_FULLCOLOR_LED_LED4B32X28_RRGB LEDLED4B32X28
    D3LED BLUEKPG-1608_0_LED0805_BLUBLUELED0805
    D4LED REDKPG-1608_0_LED0805_REDREDLED0805
    D5RB160M-60TR_SOD123_RB160M-60TRRB160M-60TRSOD123
    D6SSL-LX15D-RP/SOT23_2_SOT23_123_BAT54CSOT23_123
    D7LL4148_SOD123_1N4148W1N4148WSOD123
    D8LL4148_SOD123_1N4148W1N4148WSOD123
    D9RB160M-60TR_SOD123_(REPLACEDWI(replaced with0R-1206 -see User Guide)SOD123
    J11X6PTS_MALE_STRAIGHT_2.54MM_H6MHeader 1X6H6M
    J2XF2M_OMRON50PTS_0_FPCB50_2P5_5050 Pin FPC ConnectorFPCB50_2P5
    J31X3PIN_CON4B100X60M_1X3PIN1X3PinCON4B100X60M
    J41X2PTS_MALE_STRIGHT_2.00MM_H2P2DNP(Header 1X22.00MM)H2P20
    J51X4PIN_CON4B160X70V_A_1X4PIN1X4PinCON4B160X70V_A
    J6J00-0061PULSE_0_RJ45_13F-64GY_RJ45 ConnectorRJ45_13F-64GY_P12_4
    J71X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8H8M
    J81X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8H8M
    J91X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8H8M
    J102X5PTS_MALE_STRAIGHT_1.27MM_HS2DNP(Header 2X5)HS2X5_2JZ
    J112X5PTS_MALE_STRAIGHT_1.27MM_H_1Header 2X5HS2X5_2JZ
    J122X7PIN_HS2X7_2JZ_DNP(HEADER2X7DNP(Header 2X7)HS2X7_2JZ
    J13SINGLE USB TYPEA_USB4_2AL_SINGSingle USB Type AUSB4_2AL
    J14USB_MICROAB_0_USBMICRO5_6A_MICRMicroUSB AB ConnectorUSBMICRO5_6A
    J151X2PTS_MALE_STRIGHT_2.00MM_H2M_DNP(Header 1X22.54MM)H2M
    J162X3PTS_MALE_STRAIGHT_2.54MM_H2XHeader 2X3H2X3MZ
    J172X18PTS_FEMALE_STRAIGHT_2.54_H_Socket 2X18H_S2X18MZ
    J182X15PTS_MALE_STRAIGHT_2.54_HS2XHeader 2X15HS2X15_2MZ
    J19SD_MMCPLUS_SD13_5B267X180_SDCASD Card ConnectorSD13_5B267X180
    J201X10PTS_FEMALE_STRAIGHT_2.54_H1Socket 1X10H10M
    J211X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8H8M
    J221X8PTS_FEMALE_STRAIGHT_2.54_H8MSocket 1X8H8M
    J23USB_MICROAB_0_USBMICRO5_6A_MICRMicroUSB AB ConnectorUSBMICRO5_6A
    J24HEADER2X2_H2X2LMZ_DNP(HEADER 2DNP(Header 2X2)H2X2LMZ
    J252X10PTS_MALE_ANGLE_2.54MM_H2X10DNP(Header 2X10)H2X10LMZ
    J262X10PTS_MALE_ANGLE_2.54MM_H2X10DNP(Header 2X10)H2X10LMZ
    JP11X2PTS_MALE_STRIGHT_2.00MM_H2_1Header 1X2H2P20
    JP21X2PTS_MALE_STRIGHT_2.00MM_H2_1Header 1X2H2P20
    L1L_10UH-150MA_L1008_2.2UH2.2uHL1008
    L2BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L3BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L4BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L5L_10UH-150MA_L1008_2.2UH2.2uHL1008
    L6L_10UH-150MA_L1008_2.2UH2.2uHL1008
    L7BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L8BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L9BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L10BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L11BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L12L_SMT_L0603_10UH_150MA10uH_150mAL0603
    L13BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L14L_SMT_L0603_10UH_150MA10uH_150mAL0603
    L15BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L16BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L17BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L18BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L19BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L20L_SMT_L0603_10UH_150MA10uH_150mAL0603
    L21BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L22L_SMT_L0603_10UH_150MA10uH_150mAL0603
    L23BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L24BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L25BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L26BEAD_FERRITE_R0603_180OHM AT 1180ohm at 100MHzR0603
    L27L_10UH-150MA_L1008_0.47UH0.47uHL1008
    MH1PTH_2_MHC50D30_PTHPTHMHC50D30
    MH2PTH_2_MHC50D30_PTHPTHMHC50D30
    MH3PTH_3_MHC50D30_PTHPTHMHC50D30
    MH4PTH_2_MHC50D30_PTHPTHMHC50D30
    Q1IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q2IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q3IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q4IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q5IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q6IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q7PMOS_0_SOT23_123_DNP(IRLML6402)DNP(IRLML6402)SOT23_123
    Q8IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    Q9IRLML2402_0_SOT23_123_BSS138BSS138SOT23_123
    U1AT32UC3A_BGA100F_AT32UC3A4256HHAT32UC3A4256HHB-C1UR
    ( AT32UC3A4256J-C1UR
    BGA100F
    U2ACT8945A_QFN40_1P4H_ACT8945AQJ4ACT8945AQJ405-TQFN40_1P4H
    U3KSZ8081RNB_0_QFN32_1P5H_KSZ8081KSZ8081RNBQFN32_1P5H
    U4MT41K128M16JT-125_BGADDR96P8B90MT41K128M16JT-125:KBGADDR96P8B90X140
    U5PRTR5V0U2X_SOT143B_PRTR5V0U2XPRTR5V0U2XSOT143B
    U6SAMA5D2X_BGA289_0_BGA289P8__SAMSAMA5D27-CNBGA289P8
    U7TLV431A_SOT23_123_TLV431ATLV431ASOT23_123
    U8MT41K128M16JT-125_BGADDR96P8B90MT41K128M16JT-125:KBGADDR96P8B90X140
    U9AT25DF321_SU_0_SOIC8JG_AT25DF32AT25DF321ASOIC8JG
    U10QSPI_N25Q_8PIN_SOIC8JG_DNP(N25QDNP(N25Q128A13ESE40F)SOIC8JG
    U11EMMC_BGA153P5_MTFC4GLDEA-0MWTMTFC4GLDEA-0M WTBGA153P5
    U12TPS2113_TSSOP8FA_TPS2113TPS2113TSSOP8FA
    U13ADG849_DCK6FN_ADG849ADG849DCK6FN
    U141G126_0_SOT353_5__NL17SZ126DFT2NL17SZ126DFT2GSOT353_5
    U151G126_0_SOT353_5__NL17SZ126DFT2NL17SZ126DFT2GSOT353_5
    U16SP2525A-SO8_SOIC8JA_SP2525A-1ENSP2525A-1EN-LSOIC8JA
    U17DMC2400UV_SOT563_6_DMC2400UVDMC2400UVSOT563_6
    U18AT24C08B-PU_DFN8_1P5R_AT24MAC40AT24MAC402-MAHM-TDFN8_1P5R
    U19DMC2400UV_SOT563_6_DMC2400UVDMC2400UVSOT563_6
    U201G126_0_SOT353_5__NL17SZ126DFT2NL17SZ126DFT2GSOT353_5
    U211G126_0_SOT353_5__NL17SZ126DFT2NL17SZ126DFT2GSOT353_5
    U22FAN48610_BGA9P4_FAN48610FAN48610BGA9P4
    Y1XTAL_13Y_A_X4S32X25__12MHZCL=112MHz CL=15pFX4S32X25
    Y212MHZ_X4S32X25_25MHZCL=20PF25MHz CL=20pFX4S32X25
    Y332_0.768K_X4S70X15_32.768KHZCL32.768KHz CL=12.5pFX4S70X15
    Y4XTAL_13Y_A_X4S32X25__12MHZCL=112MHz CL=15pFX4S32X25
    17万
    管理员
     楼主| 发表于 2019-4-4 21:13:32 | 显示全部楼层
    PCB ,原理图,生产资料等全部一起打包。回复可见
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2019-4-4 21:18:48 | 显示全部楼层
    发表于 2019-4-4 22:12:04 | 显示全部楼层
    游客
    发表于 2019-4-4 22:30:50 | 显示全部楼层
    前天 12:43
  • 签到天数: 67 天
    发表于 2019-4-4 22:39:17 | 显示全部楼层
    发表于 2019-4-4 22:58:37 | 显示全部楼层
    什么看不到布线的样子
    发表于 2019-4-4 22:58:47 | 显示全部楼层
  • 签到天数: 103 天
    7万
    发表于 2019-4-5 07:42:51 | 显示全部楼层
    社区居民忠实会员社区劳模原创达人最爱沙发终身成就奖特殊贡献奖原创先锋奖优秀斑竹奖
    发表于 2019-4-5 08:50:25 | 显示全部楼层
