REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
BT1 | BAT_SOCK-2032_0_CR1220_CR1220 | CR1220 | CR1220 |
CN3 | VGAD7M_0_DB15-3RF-A_DB15-3M2 | DB15-3M2 | DB15-3RF-A |
D1 | TSOP4838 | IRM-3638A | SEN3-100C |
D2 | 1SMA13CAT3G | 1SMA13CAT3G | SD1710A |
D8 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D9 | RCLAMP3346PTNT | RCLAMP3346P | BCC7-080-0301L |
D10 | BAT60BE6327 | BAT60BE6327 | HSOD323A |
D11 | BAT60BE6327 | BAT60BE6327 | HSOD323A |
D23 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D24 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D25 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D26 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D37 | ESD8V0R1B_02LRH | ESD8V0R1B_02LRH | HSOD882 |
D38 | ESD8V0R1B_02LRH | ESD8V0R1B_02LRH | HSOD882 |
D39 | ESD8V0R1B_02LRH | ESD8V0R1B_02LRH | HSOD882 |
D42 | ESD8V0R1B_02LRH | ESD8V0R1B_02LRH | HSOD882 |
D43 | ESD8V0R1B_02LRH | ESD8V0R1B_02LRH | HSOD882 |
D51 | RCLAMP0521P_1_SLP1006P2_RCLAMP0 | RCLAMP0531T | SLP1006P2 |
D54 | LED_0_LED0603_LED-G-0603 | Led-G-0603 | LED0603 |
D55 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D56 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D57 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D58 | D2-3_D_SOT23_SM12T1G | SM12T1G | SOT23 |
D59 | LED_0_LED0603_LED-G-0603 | Led-G-0603 | LED0603 |
F1 | 0451005MRL | FUSE2 | SF6127 |
F2 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F3 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F4 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F5 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F6 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F7 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
F8 | FS-A_0_SF1206_SF1206/1A | SF1206/1A | SF1206 |
H10 | HOLE_HOLE5C3MM_HOLE3MM | Hole3mm | HOLE5C3MM |
J1 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J2 | PHONEJACK-O_1_DC552X_DC-5521 | DC-5521 | DC552X |
J3 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J4 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J5 | CON3_PH-3P_PH-3P/NC | ph-3p/NC | PH-3P |
J6 | CON3_PH-3P_PH-3P/NC | ph-3p/NC | PH-3P |
J7 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J8 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J9 | CON3_PH-3P_PH-3P | PH-3P | PH-3P |
J10 | BNCX2_BNC_2_90_SDIX2_75R | SDIX2_75R | BNC_2_90 |
J11 | MJ8-SL_5_TH-CN-254X254P-14N-HR9 | HR911130C | TH-CN-254X254P-14N-HR911130C1 |
J12 | HEADER4_SIP-4P-200_DIP-4P-5.08 | DIP-4P-5.08MM | SIP-4P-200 |
J13 | HEADER4_SIP-4P-200_DIP-4P-5.08 | DIP-4P-5.08MM | SIP-4P-200 |
J14 | MOLEX_484040003 | Molex_484040003 | RUSB9-180-0726A |
J15 | MOLEX_47151 | MOLEX_47151 | MOLEX_47151 |
J16 | BNCX2_BNC_2_90_SDIX2_75R | SDIX2_75R | BNC_2_90 |
J17 | BNCX2_BNC_2_90_SDIX2_75R | SDIX2_75R | BNC_2_90 |
J18 | 17HE_R13150_73HC2 | DB15-3M2 | DB15-3RF-A |
J19 | CON3_CON1X3PD2_CON1X3PD2MM | con1x3pd2mm | CON1X3PD2 |
J46 | CON4_CON1X4PD2_PH-4P | PH-4P | CON1X4PD2 |
J47 | CON4_CON1X4PD2_PH-4P | PH-4P | CON1X4PD2 |
J49 | MOLEX_47151 | MOLEX_47151 | MOLEX_47151 |
L6 | INDUCTOR_SPM6530_2.2UH/3A | 2.2UH/3A | SPM6530 |
L7 | INDUCTOR_SPM6530_2.2UH/3A | 2.2UH/3A | SPM6530 |
L20 | MGCI1608H4N7ST_LF | 4.7NH | SL0603 |
L21 | MGCI1608H4N7ST_LF | 4.7NH | SL0603 |
L22 | MGCI1608H4N7ST_LF | 4.7NH | SL0603 |
L23 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L24 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L25 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L26 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L27 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L29 | L_0_LB0603_5.6NH | 5.6NH | LB0603 |
L33 | INDUCTOR_SPM6530_2.2UH/2A | 2.2UH/2A | SPM6530 |
L34 | INDUCTOR_SPM6530_2.2UH/2A | 2.2UH/2A | SPM6530 |
L35 | L_SPM6530_2.2UH/8A | 2.2UH/8A | SPM6530 |
L36 | L_0_LB0603_6.2NH | 6.2NH | LB0603 |
L37 | L_0_LB0603_6.2NH | 6.2NH | LB0603 |
LB34 | LB_LB0603_LB0603/1A/120R | LB0603/1A/120R | LB0603 |
OSC1 | OSC4P_XT3225YY_12.288MHZ | 12.288MHZ | XT3225YY |
RC1 | C-0603_SR1206_0R/1206 | 0R/1206 | SR1206 |
RN13 | RESAR_IS_4/SM_RPAK8-10X25-28V_4 | 4K7_x4 | RPAK8-10X25-28V |
RN14 | RESAR_IS_4/SM_RPAK8-10X25-28V_4 | 4K7_x4 | RPAK8-10X25-28V |
RN15 | RESAR_IS_4/SM_RPAK8-10X25-28V_4 | 4K7_x4 | RPAK8-10X25-28V |
RN16 | RESAR_IS_4/SM_RPAK8-10X25-28V_4 | 4K7_x4 | RPAK8-10X25-28V |
RN17 | RESAR_IS_4/SM_RPAK8-10X25-28V_7 | 75Rx4 | RPAK8-10X25-28V |
RN18 | RESAR_IS_4/SM_RPAK8-10X25-28V_7 | 75Rx4 | RPAK8-10X25-28V |
RN19 | RESAR_IS_4/SM_RPAK8-10X25-28V_7 | 75Rx4 | RPAK8-10X25-28V |
RN20 | RESAR_IS_4/SM_RPAK8-10X25-28V_7 | 75Rx4 | RPAK8-10X25-28V |
RP24 | 4RPP_1_SRN8-0804_4X33R | 4x33R | SRN8-0804 |
S1 | DTS_61N_K | MSW4-6X6MM | SW_90 |
U1 | HI3531A_8_HT3531A_MOLEX-55091-1 | MOLEX-55091-1674 | HT3531A |
U8 | MP1484_0_SOT23-6B_TPS562200DDCT | TPS562200DDCT | SOT23-6B |
U9 | MP1484_0_SOT23-6B_TPS562200DDCT | TPS562200DDCT | SOT23-6B |
U10 | GL850_SOP28_GL850 | GL850 | SOP28 |
U11 | PL2303_SOP28_PL2303/NC | PL2303/NC | SOP28 |
U12 | PL2303_SOP28_PL2303/NC | PL2303/NC | SOP28 |
U13 | MAX3232E_SOP16_SP3232EEN | SP3232EEN | SOP16 |
U14 | MAX3232E_SOP16_SP3232EEN | SP3232EEN | SOP16 |
U15 | MAX3232E_SOP16_SP3232EEN/NC | SP3232EEN/NC | SOP16 |
U16 | S-1206B18-M3T1G_SOT89-3_S-1206B | S-1206B18-U3T1G | SOT89-3 |
U17 | TLV320AIC31_MLF32-050-0505LE_TL | TLV320AIC31 | MLF32-050-0505LE |
U19 | AZC199-04S | AZC199-04S | SOT23-6L |
U20 | AZ1045-04F | AZ1045-04F | DFN2510P10E_AZ1045 |
U21 | AZ1045-04F | AZ1045-04F | DFN2510P10E_AZ1045 |
U27 | 24C08/NC_SOP8_AT24C04 | AT24C04 | SOP8 |
U37 | GV7704_0_BGA169-11X11X0P56MM-0P | GV7704 | BGA169-11X11X0P56MM-0P8MM |
U38 | GV7704_0_BGA169-11X11X0P56MM-0P | GV7704 | BGA169-11X11X0P56MM-0P8MM |
U39 | SN74AVC20T245DGG_0_TSSOP56-0R50 | SN74AVC20T245DGG | TSSOP56-0R50-6R00 |
U40 | SN74AVC20T245DGG_0_TSSOP56-0R50 | SN74AVC20T245DGG | TSSOP56-0R50-6R00 |
U41 | SN74AVC20T245DGG_0_TSSOP56-0R50 | SN74AVC20T245DGG | TSSOP56-0R50-6R00 |
U42 | TXB0106_TSSOP16_TXB0106PWR | TXB0106PWR | TSSOP16 |
U43 | MP1484_0_SOT23-6B_TPS562200DDCT | TPS562200DDCT | SOT23-6B |
U44 | MP1484_0_SOT23-6B_TPS562200DDCT | TPS562200DDCT | SOT23-6B |
U45 | 1117_0_SOT-223_TLV1117-1.8V | TLV1117-1.8V | SOT-223 |
U46 | 1117_0_SOT-223_TLV1117-1.8V | TLV1117-1.8V | SOT-223 |
U47 | ADV7842_0_BGA256_ADV7842KBCZ-5 | ADV7842KBCZ-5 | BGA256 |
U48 | 24LC040A_0_SOP8_IC_25LC040A/NC | 25LC040A/NC | SOP8 |
U49 | RCLAMP0524_SLP2510P8-10P_IC_RCL | RCLAMP0524 | SLP2510P8-10P |
U50 | RCLAMP0524_SLP2510P8-10P_IC_RCL | RCLAMP0524 | SLP2510P8-10P |
U51 | RCLAMP0504_0_SLP1616P6-6L_IC_RC | RCLAMP0504 | SLP1616P6-6L |
U52 | 24C08/NC_SOP8_AT24C04 | AT24C04 | SOP8 |
U93 | MP8765_0_QFN16-8765_MP8765GQ | MP8765GQ | QFN16-8765 |
U94 | GS2994_QFN16_GS2994_GS2994 | GS2994 | QFN16_GS2994 |
U95 | GS2994_QFN16_GS2994_GS2994 | GS2994 | QFN16_GS2994 |
X1 | CRYSTAL4_1_5032_12M | 12M | 5032 |
X2 | CRYSTAL4_1_5032_12M/NC | 12M/NC | 5032 |
X3 | CRYSTAL4_1_5032_12M/NC | 12M/NC | 5032 |
X7 | CRYSTAL_0_XT3225_28.63636MHZ | 28.63636MHz | XT3225 |
