查看: 17231|回复: 136
[Allegro16.6以下] HI3531D挂4个DDR3+IT6801+SII9022+RTL8211EG 做的一个板子PCB共享
    终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
    发表于 2019-5-8 14:53:01 | 显示全部楼层 |阅读模式
    重要提示:PCB作品文件展下载说明
    CN1HDMI_TYPEA_0_MOLEX_47151_HDMI_AHDMI_A_FEMAL_SMDMOLEX_47151
    CN2HDMI_TYPEA_0_MOLEX_47151_HDMI_AHDMI_A_FEMAL_SMDMOLEX_47151
    D1DZ3_0_SD1710A_DZ3DZ3SD1710A
    D2D2-3_D_0_SOT23_D2-3_DD2-3_DSOT23
    D10RCLAMP3346P_0_BCC7-080-0301L_RCRCLAMP3346PBCC7-080-0301L
    D15LED_0_SD0805-LED_LEDLEDSD0805-LED
    D17LED_0_SD0805-LED_LEDLEDSD0805-LED
    D22DZ3_0_SD1714D_DZ3DZ3SD1714D
    D24D_A_0_HSOD323A_D_AD_AHSOD323A
    D25D_A_0_HSOD323A_D_AD_AHSOD323A
    D44DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D45DZ_L_0_HSOD882_DZ_LDZ_LHSOD882
    D46DIODEPIN_SD1710A_DIODE PINDIODE PINSD1710A
    D47DIODEPIN_SD1710A_DIODE PINDIODE PINSD1710A
    D48DIODEPIN_SD1710A_DIODE PINDIODE PINSD1710A
    D49DIODEPIN_SD1710A_DIODE PINDIODE PINSD1710A
    D54LED_0_SD0805-LED_LEDLEDSD0805-LED
    D55LED_0_SD0805-LED_LEDLEDSD0805-LED
    D56LED_0_SD0805-LED_LEDLEDSD0805-LED
    F1FUSE2_0_SF6127_FUSE2FUSE2SF6127
    FB20BEAD0805_0805-FB_220R/100MHZ220R/100MHz0805-FB
    J6USB-9S2_A_0_USB9-200-1516_USB-9USB-9S2_AUSB9-200-1516
    J10USB-4S4_2_CON90RS2R50-4TM_USB-4USB-4S4CON90RS2R50-4TM
    J11MJ8-SL_1_MJ8-SRLFY_MJ8-SLMJ8-SLMJ8-SRLFY
    J12PWC3_A_2_PWC0103-M-C_PWC3_APWC3_APWC0103-M-C
    J33DB19S4_2_MOLEX_47151_DB19S4DB19S4MOLEX_47151
    J34DB19S4_3_MOLEX_47151_DB19S4DB19S4MOLEX_47151
    J35WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20
    J36WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20
    J37WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20
    J39CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20
    J40CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20
    J41WBC1X4-M2_3_6PIN-20_6PIN-2.06PIN-2.06PIN-20
    J42CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20
    J43CON4X1X254MM_4PIN-20_CON4X1X2MMCON4X1X2MM4PIN-20
    L1L_1_SPL0505H_4.7U4.7USPL0505H
    L2L_1_SPL0505H_4.7U4.7USPL0505H
    L3L_1_SPL0505H_4.7U4.7USPL0505H
    L4L_1_SPL0404B_1UH1UHSPL0404B
    L8L_1_HSL1008_2.2UH2.2UHHSL1008
    L9L_1_SPL0404L_2.2UH2.2UHSPL0404L
    L18L_1_SPL0707G_2.2UH2.2UHSPL0707G
    L19L_252012_2.2UH/1A2.2UH/1A252012
    L20L_252012_2.2UH/1A2.2UH/1A252012
    L21L_1_SPL0505H_4.7U4.7USPL0505H
    LB66LB_0_SL0805_LBLBSL0805
    M1138MIL_STAR_HOLE_TO_M3_ANCM3
    M2138MIL_STAR_HOLE_TO_M3_ANCM3
    M3138MIL_STAR_HOLE_TO_M3_ANCM3
    M4138MIL_STAR_HOLE_TO_M3_ANCM3
    OSC125MHZ_HSX4-0302B_25MHZ25MHZHSX4-0302B
    Q1MOSFETP_SOT23_2N7002P2N7002PSOT23
    Q2MOSFETP_SOT23_2N7002P2N7002PSOT23
    Q3MOSFETP_SOT23_2N7002P2N7002PSOT23
    Q4MOSFETP_SOT23_2N7002P2N7002PSOT23
    S1DSW2_0_DSW4-L_DSW2DSW2DSW4-L
    S2MSW4_2_SSW-PUSH_MSW4MSW4SSW-PUSH
    T1G2401CE_0_STFM24-40-280_G2401CEG2401CESTFM24-40-280
    T2RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045
    T3RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045
    T4RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045
    T5RCLAMP0524P_DFN2510P10E_AZ1045_NC/RCLAMP0524PDFN2510P10E_AZ1045
    TS1TEST_0_GND12_TESTTESTGND12
    U1TPS2551DRVR_0_MLF6-065-0202L_TPTPS2551DRVRMLF6-065-0202L
    U2TPS2551DRVR_0_MLF6-065-0202L_TPTPS2551DRVRMLF6-065-0202L
    U324C02_SOP8-50-150_24C0224C02SOP8-50-150
    U4AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045
    U5SPI_NAND_FLASH_0_WSON8-MX25L128NCWSON8-MX25L12835ZN
    U6SPI_NAND_FLASH_0_WSON8-MX25L128NCWSON8-MX25L12835ZN
    U7ADM706SAR_1_SOP8-50-150_ADM706SADM706SARSOP8-50-150
    U9MX25L25635EMI-12G_0_SOP16-50-30MX25L25635EMI-12GSOP16-50-300A
    U10MP2316_0_QFN14-20-0302-MV_MP231MP2316QFN14-20-0302-MV
    U11PWR1-2_0_SBAT2-13A_PWR1-2PWR1-2SBAT2-13A
    U12HI3531D_M2_3_BGA805-32-3333_HI3HI3531D_M2BGA805-32-3333
    U13MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8
    U14SII9022_0_QFN-72_SII9022SII9022QFN-72
    U15MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609M
    U16MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8
    U17MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8
    U18AZC199-04S_0_SOT23-6L_AZC199-04AZC199-04SSOT23-6L
    U19AZC199-04S_0_SOT23-6L_AZC199-04AZC199-04SSOT23-6L
    U20MX25L25635EMI-12G_0_SOP16-50-30MX25L25635EMI-12GSOP16-50-300A
    U21MAX3485E_0_SOP8-50-150_MAX3485EMAX3485ESOP8-50-150
    U22MT29F2G08ABAEAWP_0_SOP48-20-720MT29F2G08ABAEAWPSOP48-20-720
    U23SN74LVC1G125Q-Q1_1_HSOT-SC70-DCSN74LVC1G125Q-Q1HSOT-SC70-DCK
    U28AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045
    U31RTL8211EG_0_QFN64-050-0909LH_RTRTL8211EG_1QFN64-050-0909LH
    U32AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045
    U33AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045
    U37MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609M
    U38MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609M
    U39MT41J256M16RE-15E-D_0_BGA96-32-MT41J256M16RE-15E-DBGA96-32-1609M
    U40MP2161GJ_0_TSOT23-8_MP2161GJMP2161GJTSOT23-8
    U43MP2326_0_QFN14-20-0302-MV_MP232MP2326QFN14-20-0302-MV
    U44LT8619B_0_IT6801_IT6801IT6801IT6801
    U45PST597NR_3_SOT23-5_TD6817TD6817SOT23-5
    U46AT24C08_AT24C08_SOIC8_AT24C02/NAT24C02/NCAT24C08_SOIC8
    U47PST597NR_3_SOT23-5_TD6817TD6817SOT23-5
    U48PST597NR_0_SOT23-5_TPS2061TPS2061SOT23-5
    U50LT8619B_0_IT6801_IT6801IT6801IT6801
    U53AT24C08_AT24C08_SOIC8_AT24C02/NAT24C02/NCAT24C08_SOIC8
    U54AZ1045-04F_0_DFN2510P10E_AZ1045AZ1045-04FDFN2510P10E_AZ1045
    U55J18_1_MINI_PCIE_CONNECTOR_MINISminisataMINI_PCIE_CONNECTOR
    U56CS5340_TSSOP16_ES7240ES7240TSSOP16
    U57MP1494S_0_TSOT23-8_MP1494SMP1494STSOT23-8
    U58CS4344_0_CS4344_TSSOP10_CS4344CS4344CS4344_TSSOP10
    U59PST597NR_0_SOT23-5_TPS2061TPS2061SOT23-5
    X2X_B_0_HSX4-0302_24MEG24MEGHSX4-0302
    X3X_0_HSX2-0302_32.768KHZ32.768KHZHSX2-0302
    Y1CRYSTAL_4PIN_CRY_3225_27MHZ27MHzCRY_3225
    Y2CRYSTAL_4PIN_CRY_3225_27MHZ27MHzCRY_3225
    重要提示:PCB作品文件展下载说明
     楼主| 发表于 2019-5-8 14:54:01 | 显示全部楼层
    PCB文件共享。不带原理图。回复可见
    游客,如果您要查看本帖隐藏内容请回复
  • 签到天数: 63 天
    PADS-171101高级班
    终身成就奖特殊贡献奖优秀斑竹奖
    发表于 2019-5-8 15:27:42 | 显示全部楼层
  • 签到天数: 4 天
    发表于 2019-5-8 16:14:06 | 显示全部楼层
    6 天前
  • 签到天数: 68 天
    1元学习Allegro(1期)
    终身成就奖特殊贡献奖社区居民忠实会员社区劳模优秀斑竹奖最爱沙发社区明星宣传大使奖
    发表于 2019-5-8 23:00:57 | 显示全部楼层
  • 签到天数: 10 天
    发表于 2019-5-9 06:07:22 | 显示全部楼层
  • 签到天数: 5 天
    PADS20210616高级班
    发表于 2019-5-9 06:23:14 | 显示全部楼层
    如此高密度,定是下了苦功放呀。
    前天 08:14
  • 签到天数: 201 天
    终身成就奖特殊贡献奖社区居民忠实会员
    发表于 2019-5-9 08:20:17 | 显示全部楼层
    发表于 2019-5-9 08:34:10 | 显示全部楼层
    发表于 2019-5-9 08:45:15 | 显示全部楼层
    谢谢分享,可惜没原理图
